查看: 3389|回复: 0
[NI驱动程序] NI-Industrial Communications for CANopen 19.0 Win32Eng NI-CANopen仪器通信驱动程序19.0
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-20 00:18:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for CANopen可帮助您创建符合CiA DS-301标准的CANopen主应用程序。
    NI-Industrial Communications for CANopen是一款驱动程序软件,为您使用CANopen接口设备、C系列CANopen接口模块和PXI CANopen接口模块提供所需的支持。它包含丰富的LabVIEW VI和属性库,因此您可以为兼容的硬件设备开发自定义的CANopen应用程序。
    Win32Eng
    19.0
    文件大小: 644642816 字节 (614.78 MB)
    修改日期: 2019-06-14 06:47
    MD5: 18f5caa97485139b02cd45ec658a9b11(官方正确)
    SHA1: 48b7425748b4916167ff17e58192e3e246f562dc
    SHA256: 336479b3e56c68f80bd99b4e1058cbaccd5736f6be4977b7ac72062b096a8343
    CRC32: 69fe9d51
    CANopen19.0.txt (641 Bytes, 下载次数: 1, 售价: 10 圆)
    NI-Industrial Communications for CANopen 19.0 Readme
    May 2019
    This file contains important information about the NI-Industrial Communications for CANopen, including system requirements, installation instructions, new features and changes, a partial list of bugs fixed, and how to access the help and examples.
    Caution  The NI-Industrial Communications for CANopen 19.0 software or later requires the NI 9881 module with the updated firmware. When you upgrade the software to the 19.0 version or later, check the software version of the media that shipped with the NI 9881 module. If the version is not 19.0 or later, or you are not sure of the version number, NI recommends that you update the firmware. Otherwise, when you use NI-Industrial Communications for CANopen 19.0 or later, firmware images corrupt or get mismatched. Ensure that you have appropriate hardware and software installed and complete the following task to upgrade the firmware.
    • Double-click Firmware_Update_Instructions.html in the \NI-IndCom for CANopen directory and follow the instructions to use a LabVIEW example project to update the firmware.
    NI-Industrial Communications for CANopen Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    The NI-Industrial Communications for CANopen software contains an extensive library of VIs and properties in LabVIEW. Use these VIs and properties to program CANopen master applications that comply with the CiA DS-301 standard. You can deploy the applications to RT targets. This software also provides built-in functionality for device configuration and online test panel in LabVIEW.
    Refer to Supported Hardware and Software for NI-Industrial Communications for CANopen, for a complete list of NI hardware and software supported by each NI CANopen interface.
    NI-Industrial Communications for CANopen supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R2 (64-bit)1
    • Windows Server 2008 R2 SP1 (64-bit)2
    Note  Refer to NI-Industrial Communications for CANopen Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  In 2016 NI-Industrial Communications for CANopen dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-Industrial Communications for CANopen 19.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Industrial Communications for CANopen 19.0 to an unsupported OS. Additionally, after installing NI-Industrial Communications for CANopen 19.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note  Upgrading Windows 8.0 to Windows 8.1 with the NI-Industrial Communications for CANopen software installed might result in device configuration information damage and ostensible disconnection between devices. NI recommends that you reinstall the NI-Industrial Communications for CANopen software after upgrading the operating system.
    Installing the Software on an RT Target
    Complete the following steps to install the NI-Industrial Communications for CANopen software on an RT target in NI Measurement & Automation Explorer (MAX):
    • Expand Remote Systems in the configuration tree and expand your RT target.
    • Select the Software category. Click the Add/Remove Software icon on the toolbar to launch the LabVIEW Real-Time Software Wizard.
    • If the RT target is a CompactRIO controller, select Custom software installation.
    • Select NI-Industrial Communications for CANopen x from the feature list and click the Next button.
    • Follow the remaining installation instructions until installation is complete.
    New FeaturesCANopen 19.0
    • Added support for LabVIEW 2019 (32-bit).
    CANopen 18.0
    • Added support for LabVIEW 2018 (32-bit).
    • Added support for cRIO-904x/905x.
    • Updated the firmware upgrade tool for NI 9881.
    CANopen 17.0
    • Added support for LabVIEW 2017 (32-bit).
    CANopen 16.0
    • Added support for LabVIEW 2016 (32-bit).
    • Added support for cRIO-9032/9035 (Sync)/9037/9039 (Sync).
    CANopen 15.0
    • Added support for LabVIEW 2015 (32-bit).
    • Added support for sbRIO-9607/9627 and RMC-9697.
    CANopen 14.5
    • Added support for LabVIEW 2014 SP1 (32-bit).
    • Added support for cRIO-9030/9031/9033/9035/9036/9038/9039/9063/9064/9065/9066/9067.
    CANopen 1.0.3
    • Added support for LabVIEW 2013 (32-bit).
    • Added support for cRIO-9068.
    CANopen 1.0.2
    • Added support for LabVIEW 2012 (32-bit).
    CANopen 1.0.1
    • Added support for LabVIEW 2011 (32-bit).
    • Added support for cRIO-9081/9082.
    • The CANopen VIs palette includes the following changed polymorphic VI instance:
      • CANopen Interface Create—Includes an optional termination? input that enables or disables the onboard termination. The termination is a 120 Ω resistor.
    CANopen 1.0
    • First release to support NI CANopen hardware that includes PCI-8531, PXI-8531, and NI 9881.
    • Released a common high-level API across PCI, PXI, and CompactRIO targets running either Windows or NI Linux Real-Time.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the NI-Industrial Communications for CANopen.
    The following items are the IDs and titles of a subset of issues fixed in NI-Industrial Communications for CANopen 15.0. This is not an exhaustive list of issues fixed in the current version of NI-Industrial Communications for CANopen. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    533911NI-Industrial Communications for CANopen 14.5 reads TPDO incorrectly
    The following items are the IDs and titles of a subset of issues fixed in NI-Industrial Communications for CANopen 14.5. This is not an exhaustive list of issues fixed in the current version of NI-Industrial Communications for CANopen. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    511845Add error codes to report issues when using CANopen 14.5 on the NI 9881 module with outdated files
    The following items are the IDs and titles of a subset of issues fixed in NI-Industrial Communications for CANopen 1.0.2. This is not an exhaustive list of issues fixed in the current version of NI-Industrial Communications for CANopen. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    335637LabVIEW crashes when some EDS files are being parsed
    351959The SDO confirmation frame should be ignored if its index/subindex is wrong
    The following items are the IDs and titles of a subset of issues fixed in NI-Industrial Communications for CANopen 1.0.1. This is not an exhaustive list of issues fixed in the current version of NI-Industrial Communications for CANopen. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    310647Allow users to choose whether to enable onboard termination
    Refer to the NI-Industrial Communications for CANopen Help, accessible by selecting Help»NI-Industrial Communications for CANopen in LabVIEW, for information about using the NI-Industrial Communications for CANopen software.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the NI-Industrial Communications for CANopen software are in the labview\examples\NI-Industrial Communications for CANopen folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, NI Measurement & Automation Explorer (MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    NI-Industrial Communications for CANopen will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2011–2019 National Instruments. All rights reserved.
    375165G-01
    GMT+8, 2025-11-19 09:04
