查看: 2950|回复: 0
[NI驱动程序] NI-Industrial Communications for CANopen 1.0.3 Driver Win32/64Eng NI-CANopen仪器通信驱动程序1.0.3
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-20 00:09:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for CANopen可帮助您创建符合CiA DS-301标准的CANopen主应用程序。
    NI-Industrial Communications for CANopen是一款驱动程序软件,为您使用CANopen接口设备、C系列CANopen接口模块和PXI CANopen接口模块提供所需的支持。它包含丰富的LabVIEW VI和属性库,因此您可以为兼容的硬件设备开发自定义的CANopen应用程序。
    Win32/64Eng
    1.0.3
    文件大小: 540923680 字节 (515.87 MB)
    修改日期: 2013-10-12 01:30
    MD5: caeccfd2ecbcf0ec8c717a062be30d09(官方正确)
    SHA1: a5da6fd824c05a4b165f2ea5bbf7a982a907b6ef
    SHA256: eb837e470ed9b1d1f47667ea5cfab82ec2fb411dd8ad1dc22c011bc5fe213957
    CRC32: 7f8b6072
    CANopen1.0.3.txt (646 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for CANopen 1.0.3 Readme
    September 2013
    This file contains information about the NI-Industrial Communications for CANopen software, including system requirements, installation instructions, new features and changes, a partial list of bugs fixed, and how to access the help and examples.
    New Features and Changes
    CANopen 1.0.3
    CANopen 1.0.2
    CANopen 1.0.1
    CANopen 1.0
    Known Issue
    NI Software Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    The NI-IndCom for CANopen software contains an extensive library of VIs and properties in LabVIEW. Use these VIs and properties to program CANopen master applications that comply with the CiA DS-301 standard. This software also provides built-in functionality for device configuration and online test panel in LabVIEW.
    New Features and ChangesCANopen 1.0.3
    • Added support for LabVIEW 2013
    • Added support for NI cRIO-9068
    CANopen 1.0.2
    • Added support for LabVIEW 2012
    CANopen 1.0.1
    • Added support for LabVIEW 2011
    • Added support for NI cRIO-9081 and NI cRIO-9082
    • The CANopen VIs palette includes the following changed polymorphic VI instance:
      • CANopen Interface Create—Includes an optional termination? input that enables or disables the onboard termination. The termination is a 120 Ω resistor.
    CANopen 1.0
    • First release to support NI CANopen hardware that includes PCI-8531, PXI-8531, and NI 9881
    • Released a common high-level API across PCI, PXI, and CompactRIO targets running either a Windows or LabVIEW Real-Time OS
    You can install and run this version of the NI-IndCom for CANopen software on the following operating systems:
    • Windows XP SP3 (32-bit)
    The NI-IndCom for CANopen installer does not support Windows NT/Me/2000/98/95, the Windows Server non-R2 editions, or Windows XP x64.
    Caution  If you upgrade your system from a previous version of Microsoft Windows to Microsoft Windows Vista, you must uninstall all National Instruments software prior to performing the upgrade. After the upgrade is complete, you can reinstall your National Instruments software.
    Refer to Supported Hardware and Software for NI-Industrial Communications for CANopen, for a complete list of NI hardware and software supported by each NI CANopen interface.
    Before installing the NI-IndCom for CANopen software, log on as Administrator or as a user with Administrator privileges. The NI-IndCom for CANopen software setup program must have Administrator privileges, because the program modifies the configuration registry of your system. Complete the following steps to install the NI-IndCom for CANopen software:
    • Insert the NI-IndCom for CANopen software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-IndCom for CANopen software CD.
    • The installation wizard guides you through the necessary steps to install the NI-IndCom for CANopen software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking the Cancel button.
    • When the installation is complete, click the Finish button.
    Installing the Software on a Real-Time Target
    Complete the following steps to install the NI-IndCom for CANopen software on a real-time target in Measurement & Automation Explorer:
    • Expand Remote Systems in the configuration tree and expand your real-time target.
    • Select the Software category. Click the Add/Remove Software icon on the toolbar to launch the LabVIEW Real-Time Software Wizard.
    • If the real-time target is a CompactRIO controller, select Custom software installation.
    • Select NI-Industrial Communications for CANopen x from the feature list and click the Next button.
    • Follow the remaining installation instructions until installation is complete.
    NI-Industrial Communications for CANopen Updates and Notifications
    Refer to the NI-Industrial Communications for CANopen Help, accessible by selecting Help»NI-Industrial Communications for CANopen from the pull-down menu in LabVIEW, for information about using the NI-IndCom for CANopen software.
    LabVIEW examples for the NI-IndCom for CANopen software are in the labview\examples\NI-Industrial Communications for CANopen folder. You can modify an example VI to fit an application or copy an example and paste the example to a VI you create.
    Known Issue
    NI-IndCom for CANopen 1.0.3 has the following known issue:
    The CANopen TPDO RTR Request Send VI is not optimized for real-time performance. Do not use this VI in the Timed Loop. If you add this VI to the Timed Loop, this VI induces jitter and the program is not deterministic. National Instruments does not recommend you to use this VI in the time-critical applications.
    The following table contains the ID and title of the issue fixed in the NI-IndCom for CANopen 1.0.2. This table is not an exhaustive list of issues fixed in the current version of NI-IndCom for CANopen.
    335637LabVIEW crashes when some EDS files are being parsed
    351959The SDO confirmation frame should be ignored if its index/subindex is wrong
    The following table contains the ID and title of the issue fixed in the NI-IndCom for CANopen 1.0.1. This table is not an exhaustive list of issues fixed in this version of NI-IndCom for CANopen.
    310647Allow users to choose whether to enable onboard termination
    Finding All Programs
    NI-Industrial Communications for CANopen Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-Industrial Communications for CANopen will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-Industrial Communications for CANopen that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2011–2013 National Instruments. All rights reserved.
    GMT+8, 2025-11-19 09:03
