查看: 3165|回复: 0
[NI驱动程序] NI-Industrial Communications for CANopen 1.0 Driver Win32/64Eng NI-CANopen仪器通信驱动程序1.0
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-20 00:01:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for CANopen可帮助您创建符合CiA DS-301标准的CANopen主应用程序。
    NI-Industrial Communications for CANopen是一款驱动程序软件,为您使用CANopen接口设备、C系列CANopen接口模块和PXI CANopen接口模块提供所需的支持。它包含丰富的LabVIEW VI和属性库,因此您可以为兼容的硬件设备开发自定义的CANopen应用程序。
    Win32/64Eng
    1.0
    文件大小: 267274848 字节 (254.89 MB)
    修改日期: 2011-06-18 04:05
    MD5: 9c40b347c1e98950519ff85164698c6e(官方正确)
    SHA1: af513b5fc6cf2a560d801426009933b3d02442e6
    SHA256: c49bbe69df0a6dc91d8d0e1de02df10c33686d07e9754c7cfc51cc8e6b311747
    CRC32: 264aaaa2
    CANopen1.0.0.txt (651 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for CANopen Readme
    Version 1.0
    May 2011
    This file contains information to introduce you to the NI-IndCom for CANopen software and provides you with help resources you can use. This file contains the following information that you need to understand:
    The NI-IndCom for CANopen software contains an extensive library of VIs and properties in LabVIEW. Use these VIs and properties to program CANopen master applications that comply with the CiA DS-301 standard. This software also provides built-in functionality for device configuration and online test panel in LabVIEW.
    You can install and run this version of the NI-IndCom for CANopen software on the following operating systems:
    • Windows XP (32-bit)
    The NI-IndCom for CANopen installer does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
    Caution  If you upgrade your system from a prior version of Microsoft Windows to Microsoft Windows Vista, you must uninstall all National Instruments software prior to performing the upgrade. After the upgrade is complete, you can reinstall your National Instruments software.
    This version of the NI CANopen software supports the following National Instruments hardware products on Windows and LabVIEW RT:
    • NI PCI-8531 (1-Port CANopen Interface for PCI)
    • NI PXI-8531 (1-Port CANopen Interface for PXI)
    • NI 9881 (1-Port C Series CANopen module for CompactRIO)
      • CompactRIO - NI-RIO 3.6.1 and LabVIEW 2010 SP1 (32-bit) required.
        • Real-Time Controller: NI cRIO-9012, NI cRIO-9014, NI cRIO-9022, NI cRIO-9023, NI cRIO-9024 and NI cRIO-9025
        • CompactRIO Reconfigurable Chassis: NI cRIO-9111, NI cRIO-9112, NI cRIO-9113, NI cRIO-9114, cRIO-9116, and cRIO-9118
        • The LabVIEW 2010 SP1 FPGA Module is required to build a bitstream with an NI 9881 module in the project
    Caution  If you use the cRIO-9012 controller together with a cRIO 9116 or 9118 backplane, NI recommends you remove software components from the cRIO-9012 that are not required in order to maximize the amount of available free memory. Please refer to KB 5LG4DIJL for more information.
    Supported Development Environment
    NI-IndCom for CANopen software requires LabVIEW 2010 SP1 (32-bit). If you want to run CANopen software on NI real-time hardware platforms, you must install the LabVIEW 2010 SP1 Real-Time module.
    Before installing the NI-IndCom for CANopen software, log on as Administrator or as a user with Administrator privileges. The NI-IndCom for CANopen software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-IndCom for CANopen software:
    • Insert the NI-IndCom for CANopen software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-IndCom for CANopen software CD.
    • The installation wizard guides you through the necessary steps to install the NI-IndCom for CANopen software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
    Installing the Software on a Real-Time Target
    Complete the following steps to install the NI-IndCom for CANopen software on a real-time target in Measurement & Automation Explorer (MAX):
    • Expand Remote Systems in the configuration tree and expand your real-time target.
    • Select the Software category. Click the Add/Remove Software icon on the toolbar to launch the LabVIEW Real-Time Software Wizard.
    • If the real-time target is a CompactRIO controller, select Custom software installation.
    • Select NI-IndCom for CANopen in the feature list and click Next.
    • Follow the remaining installation instructions until installation is complete.
    Refer to the NI-Industrial Communications for CANopen Help, accessible by selecting Help»NI-Industrial Communications for CANopen from the pull-down menu in LabVIEW, for information about using the NI-Industrial Communications for CANopen software.
    LabVIEW examples for the NI-Industrial Communications for CANopen software are in the labview\examples\NI-Industrial Communications for CANopen folder. You can modify an example VI to fit an application or copy and paste from one or more examples into a VI you create.
    Installing Microsoft Silverlight
    Using Microsoft Silverlight
    Important Information
    © 2011 National Instruments Corporation. All rights reserved.
    Copyright (c) 1998, 1999, 2000 Thai Open Source Software Center Ltd and Clark Cooper Copyright (c) 2001, 2002, 2003, 2004, 2005, 2006 Expat maintainers.
    Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
    The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    GMT+8, 2025-11-19 09:04
