查看: 2993|回复: 0
[NI驱动程序] NI-HSDIO 17.0 Driver Win32/62 Eng/Jpn NI高速数字输入输出仪器驱动程序17.0
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-19 00:23:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-HSDIO
    NI-HSDIO为使用NI PXI数字波形仪器或数字波形设备的客户提供支持。
    NI-HSDIO是与数字波形硬件进行通信的NI仪器驱动程序,用于执行高速DIO  (HSDIO)任务。该驱动程序软件包含基于IVI准则的灵活API、完整的硬件支持文档,以及配置和测试实用程序。
    Win32/64Eng/Jpn
    17.0
    文件大小: 1828776148 字节 (1.70 GB)
    修改日期: 2017-05-23 00:05
    MD5: 1d8c739df38237b8390999f921e1c1ae(官方正确)
    SHA1: 26a77be9b8d23252ea10495a358f914aa670cb00
    SHA256: 2fe2ee1e76cac3c53978fc7f3d72376e468f9c1325fa03cc60076723484b1124
    CRC32: dafcc4a0
    HSDIO17.0.txt (577 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-HSDIO 17.0 Readme
    May 2017
    Thank you for using NI-HSDIO. This file contains important information about NI-HSDIO and is organized into the following sections:
    Driver Version Naming Changes
    Uninstalling/Modifying NI-HSDIO
    Obsolete Properties and Attributes
    NI-HSDIO 17.0 adds support for LabVIEW 2017 (32- and 64-bit)
    NI-HSDIO 16.0 adds support for LabVIEW 2016 (32- and 64-bit)
    NI-HSDIO 15.0 adds support for LabVIEW 2015 (32- and 64-bit)
    NI-HSDIO 14.0 adds support for LabVIEW 2014 (32- and 64-bit)
    NI-HSDIO 2.0 includes the following new features:
    • Support for external calibration of NI PXIe-6555 and NI PXIe-6556.
    • New attributes (only available for the NI PXIe-6555 and NI PXIe-6556):
      • Attribute Committal Strategy (NIHSDIO_ATTR_ATTRIBUTE_COMMITTAL_STRATEGY)
      • Cumulative Error Bits (NIHSDIO_ATTR_HWC_CUMULATIVE_ERROR_BITS)
    • Support for NI-HSDIO Runtime custom installers built using NI application development environments (ADEs). This installer contains instrument driver runtime components required to deploy applications using NI digital waveform generator/analyzers.
      Notes:
      The runtime installer does not contain support for interactively configuring or testing hardware using Measurement & Automation Explorer (MAX).
      The runtime installer does not support upgrading from NI-HSDIO 1.9.x or earlier or NI-DAQmx 8.9.x or earlier. You must uninstall these products prior to installing the NI-HSDIO Runtime installer.
    NI-HSDIO 1.9 includes the following new features:
    • Support for NI PXIe-6555 devices.
    • Support for multi-sample pattern matching and active load functionality (PXIe-6556 only).
    • Updated self-calibration function that fixes an issue affecting the NI PXIe-6556 input skew specifications. For more information, visit ni.com/info and enter the Info Code 6556SKEW.
    • Faster PMU and digital pattern functionality.
    NI-HSDIO 1.8.3 adds support for LabVIEW 2012 (32- and 64-bit)
    NI-HSDIO 1.8.1 includes the following new features:
    • Support for NI PXIe-6556 devices.
    • Support for PPMU force and sense functionality.
    The following table shows which hardware products are supported under particular operating systems.
    Hardware Product32-bit164-bit
    NI PXI/PCI-6541
    NI PXI/PCI-6542
    NI PXIe-6544
    NI PXIe-6545
    NI PXIe-6547
    NI PXIe-6548
    NI PXI/PCI-6551
    NI PXI/PCI-6552
    NI PXIe-6555
    NI PXIe-6556
    NI PXI/PCI-6561
    NI PXI/PCI-6562
    1 MXI Express and MXI-4 are supported on Windows 10/8.1/7.
    Note:  Device-specific information about these modules is included in the NI Digital Waveform Generator/Analyzer Help.
    NI-HSDIO 17.0 and later supports the following operating systems:
    1NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    2NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Note  NI-HSDIO 17.0 and later does not support Windows Server non-R2 editions.
    Note  In 2016 NI-HSDIO dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-HSDIO 17.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-HSDIO 17.0 to an unsupported OS. Additionally, after installing NI-HSDIO 17.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-HSDIO 17.0 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    • LabWindows™/CVI™ Real-Time Module
    Note  NI-HSDIO 16.0 and later does not support self-calibration of the NI PXIe-6556 with LabVIEW Real-Time Module. Use NI-HSDIO 15.0 and LabVIEW 2012 to perform self-calibration of the PXIe-6556 with LabVIEW Real-Time Module.
    Minimum Requirements
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-HSDIO. To add support for ADEs installed after installing NI-HSDIO, modify your NI-HSDIO installation or launch the NI-HSDIO installer again.
    • NI LabVIEW 2014 SP1, 2015 SP1, 2016, or 2017
    • LabVIEW Real-Time Module 2014 SP1, 2015 SP1, 2016, or 2017
    • LabWindows/CVI 2013 or later
    • LabWindows/CVI Real-Time Module 2013 or later
        • (32-bit) Program Files\IVI\
    ItemInstalled Location
    NI-HSDIO\Drivers\niHSDIO
    NI-HSDIO Function Panel\Drivers\niHSDIO\niHSDIO.fp
    NI-HSDIO Examples\NI-HSDIO\Examples
    NI-HSDIO Header files\Include
    NI-HSDIO Import Library files (32-bit)\Lib
    NI-HSDIO Import Library files (64-bit)\Lib_x64
    NI-HSDIO DLL (32-bit)\Bin
    Additional File Locations for 64-bit operating systems
    NI-HSDIO DLL (64-bit)\Bin
    Documentation for NI-HSDIO is located at Start»All Programs»National Instruments»NI-HSDIO»Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI Digital Waveform Generator/Analyzer HelpHTML/Windows HelpContains instructions for opening, configuring, initiating signal generation, and closing the session. Also, contains information about programming and fundamentals.
    NI Digital Waveform Generator/Analyzer Getting Started Guide for your devicePrinted and PDFContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
    Specifications for your devicePDFContains specifications for the capabilities and valid operating conditions of your NI device.
    NI-HSDIO ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    To use the .NET API, you must install the the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    NI-HSDIO no longer installs IVI Compliance Package. NI-HSDIO supports IVI configuration and runtime, but no longer supports the following features:
    · LabVIEW and CVI IVI class driver APIs for developing IVI interchangeable applications
    · IVI Class Simulation drivers
    · IVI-COM Adapters
    If you want to use the above features, you must install IVI Compliance Package separately, either from ni.com/downloads or from the NI Device Drivers 2017 DVD.
    NI-HSDIO versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-HSDIO 14.0.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-HSDIO 2.0. The first version released under the new numbering scheme is NI-HSDIO 14.0.0.
    • Select NI-HSDIO 17.0 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI-HSDIO 17.0 installation, the following software is installed. To completely remove the NI-HSDIO 17.0 installation from your system, you must also remove all of the following packages:
    • NI-HSDIO Runtime 17.0
    • NI Hierarchical Waveform Storage 17.0
    • NI SignalExpress 20121
    • NI Measurement & Automation Explorer 17.0
    • NI-DAQmx 17.0
    • Traditional NI-DAQ 7.4.41
    • NI-DAQmx MAX Configuration Support 17.0
    • NI-VISA 17.0
    • NI IO Trace 17.0
    1The installation of these packages is not required to install or uninstall NI-HSDIO.
    The Hardware Compare Mode property and the NIHSDIO_ATTR_HWC_HARDWARE_COMPARE_MODE attribute are obsolete. They are replaced by the Supported Data States property and the NIHSDIO_ATTR_SUPPORTED_DATA_STATES attribute.
    You can access the software and documentation known issues list online. Refer to the NI-HSDIO Known Issues at ni.com/info and enter the Info Code exk5ui for an up-to-date list of known issues in NI-HSDIO.
    The following items are the IDs and titles of a subset of issues fixed in NI-HSDIO. This is not an exhaustive list of issues fixed in the current version of NI-HSDIO. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items were fixed in NI-HSDIO 2.0.
    333216Fixed an issue in which intermittent failures were occurring when using Hardware Compare on the NI 6551 or NI 6552 at frequencies between 48 Hz and 65 Hz.
    373229Fixed an issue in which calling self-calibration on an NI PXIe-6555 or NI PXIe-6556 when using LabVIEW Real Time caused Property Node errors.
    394554Fixed an issue in which PFI lines 24 through 31 were not defined in nihsdio.h.
    © 2003–2017 National Instruments. All rights reserved.
    375376C-01
    GMT+8, 2025-11-19 09:01
