NI-HSDIO 16.0 Driver Win32/62 Eng/Jpn NI高速数字输入输出仪器驱动程序16.0
NI-HSDIO
NI-HSDIO为使用NI PXI数字波形仪器或数字波形设备的客户提供支持。
NI-HSDIO是与数字波形硬件进行通信的NI仪器驱动程序,用于执行高速DIO (HSDIO)任务。该驱动程序软件包含基于IVI准则的灵活API、完整的硬件支持文档,以及配置和测试实用程序。
Win32/64Eng/Jpn
16.0
文件大小: 2140023686 字节 (1.99 GB)
修改日期: 2016-07-19 23:46
MD5: c17b4e634fa24625f0a225cbcf644b58(官方正确)
SHA1: 92c7e3743e2d33200f39de5ebc7110b9dc163ce0
SHA256: 143fc453e094da8df449b61b0bcb2c2ef808fd8f3a8f3507a3c8b199f739483a
CRC32: d3f0c9b6
HSDIO16.0.txt
(577 Bytes, 下载次数: 0, 售价: 10 圆)
NI-HSDIO 16.0 ReadmeAugust 2016 Thank you for using NI-HSDIO. This file contains important information about NI-HSDIO and is organized into the following sections: New Features Supported Hardware System Requirements Installed Software, Documentation, and Examples Documentation NI Software Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003 Product Security and Critical Updates Driver Version Naming Changes Uninstalling/Modifying NI-HSDIO Obsolete Properties and Attributes Known Issues Bug Fixes Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 Legal Information New FeaturesNI-HSDIO 16.0 adds support for LabVIEW 2016 (32- and 64-bit) NI-HSDIO 15.0 adds support for LabVIEW 2015 (32- and 64-bit) NI-HSDIO 14.0 adds support for LabVIEW 2014 (32- and 64-bit) NI-HSDIO 2.0 includes the following new features: - Support for external calibration of NI PXIe-6555 and NI PXIe-6556.
- New attributes (only available for the NI PXIe-6555 and NI PXIe-6556):
- Attribute Committal Strategy (NIHSDIO_ATTR_ATTRIBUTE_COMMITTAL_STRATEGY)
- Cumulative Error Bits (NIHSDIO_ATTR_HWC_CUMULATIVE_ERROR_BITS)
- Support for NI-HSDIO Runtime custom installers built using NI application development environments (ADEs). This installer contains instrument driver runtime components required to deploy applications using NI digital waveform generator/analyzers.
Notes:
The runtime installer does not contain support for interactively configuring or testing hardware using Measurement & Automation Explorer (MAX).
The runtime installer does not support upgrading from NI-HSDIO 1.9.x or earlier or NI-DAQmx 8.9.x or earlier. You must uninstall these products prior to installing the NI-HSDIO Runtime installer.
NI-HSDIO 1.9 includes the following new features: - Support for NI PXIe-6555 devices.
- Support for multi-sample pattern matching and active load functionality (PXIe-6556 only).
- Updated self-calibration function that fixes an issue affecting the NI PXIe-6556 input skew specifications. For more information, visit ni.com/info and enter the Info Code 6556SKEW.
- Faster PMU and digital pattern functionality.
NI-HSDIO 1.8.3 adds support for LabVIEW 2012 (32- and 64-bit) NI-HSDIO 1.8.1 includes the following new features: - Support for NI PXIe-6556 devices.
- Support for PPMU force and sense functionality.
Supported HardwareThe following table shows which hardware products are supported under particular operating systems. | Hardware Product | 32-bit1 | 64-bit | | NI PXI/PCI-6541 | √ | √ | | NI PXI/PCI-6542 | √ | √ | | NI PXIe-6544 | √ | √ | | NI PXIe-6545 | √ | √ | | NI PXIe-6547 | √ | √ | | NI PXIe-6548 | √ | √ | | NI PXI/PCI-6551 | √ | √ | | NI PXI/PCI-6552 | √ | √ | | NI PXIe-6555 | √ | √ | | NI PXIe-6556 | √ | √ | | NI PXI/PCI-6561 | √ | √ | | NI PXI/PCI-6562 | √ | √ | | 1 MXI Express and MXI-4 are supported on Windows 10/8.1/7. |
Note: Device-specific information about these modules is included in the NI Digital Waveform Generator/Analyzer Help. System RequirementsSupported Operating SystemsNI-HSDIO 16.0 and later supports the following operating systems: - Windows 10/8.11/7 SP12 (32-bit and 64-bit)
- Windows Server 2012 R21 (64-bit)
- Windows Server 2008 R2 SP12 (64-bit)
1 NI software installs VC2015 Runtime and .NET 4.6.1. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update. Note NI-HSDIO 16.0 and later does not support Windows Server non-R2 editions. NI recommends that you have the most recent service pack for your operating system installed. Supported Real-Time Operating EnvironmentsNI-HSDIO 16.0 and later supports the following real-time operating environments: - LabVIEW Real-Time Module
- LabWindows™/CVI™ Real-Time Module
Note NI-HSDIO 16.0 and later does not support self-calibration of the NI PXIe-6556 with LabVIEW Real-Time Module. Use NI-HSDIO 15.0 and LabVIEW 2012 to perform self-calibration of the PXIe-6556 with LabVIEW Real-Time Module. Minimum Requirements- Processor—1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
- RAM—1 GB RAM (32-bit) or 2 GB RAM (64-bit)
- Windows 10/8.1/7, with all available critical updates and service packs
Application Development Environments (ADEs)Note You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-HSDIO. To add support for ADEs installed after installing NI-HSDIO, modify your NI-HSDIO installation or launch the NI-HSDIO installer again. - NI LabVIEW 2013 SP1, 2014 SP1, 2015 SP1, or 2016
- LabVIEW Real-Time Module 2013 SP1, 2014 SP1, 2015 SP1, or 2016
- LabWindows/CVI 2013 or later
- LabWindows/CVI Real-Time Module 2013 or later
- Microsoft Visual C++ (MSVC) 6.0 or later
Installed Software, Documentation, and ExamplesInstalled Software- is an alias for the following National Instruments file folder location: Users\Public\Public Documents\National Instruments
- (32-bit) Program Files\IVI Foundation\IVI\
- (64-bit) Program Files (x86)\IVI Foundation\IVI\
| Note | $(IVIROOTDIR32) is configured as an environment variable on the target system. | | If you upgraded an installation of IVI, your files may be located in the following location:
- (32-bit) Program Files\IVI\
- (64-bit) Program Files (x86)\IVI\
- (64-bit) Program Files\IVI Foundation\IVI\
| Note | $(IVIROOTDIR64) is configured as an environment variable on the target system. |
File Locations| Item | Installed Location | | NI-HSDIO | \Drivers\niHSDIO | | NI-HSDIO Function Panel | \Drivers\niHSDIO\niHSDIO.fp | | NI-HSDIO Examples | \NI-HSDIO\Examples | | NI-HSDIO Header files | \Include | | NI-HSDIO Import Library files (32-bit) | \Lib | | NI-HSDIO Import Library files (64-bit) | \Lib_x64 | | NI-HSDIO DLL (32-bit) | \Bin | Additional File Locations for 64-bit operating systems| Item | Installed Location | | NI-HSDIO Function Panel | \Drivers\niHSDIO\niHSDIO.fp | | NI-HSDIO Header files | \Include | | NI-HSDIO Import Library files (64-bit) | \Lib_x64 | | NI-HSDIO DLL (64-bit) | \Bin | DocumentationDocumentation for NI-HSDIO is located at Start»All Programs»National Instruments»NI-HSDIO»Documentation. The documentation set is composed of the following documents. | Document | Format | Description | | NI Digital Waveform Generator/Analyzer Help | HTML/Windows Help | Contains instructions for opening, configuring, initiating signal generation, and closing the session. Also, contains information about programming and fundamentals. | | NI Digital Waveform Generator/Analyzer Getting Started Guide for your device | Printed and PDF | Contains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device. | | Specifications for your device | PDF | Contains specifications for the capabilities and valid operating conditions of your NI device. | | NI-HSDIO Readme | HTML (this document) | Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices. |
For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. To use the .NET API, you must install the the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport. Note To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/reader. NI-HSDIO 16.0 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003With this release, NI-HSDIO drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-HSDIO 16.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-HSDIO 16.0 to an unsupported OS. Additionally, after installing NI-HSDIO 16.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments. Driver Version Naming ChangesNI-HSDIO versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-HSDIO 14.0.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-HSDIO 2.0. The first version released under the new numbering scheme is NI-HSDIO 14.0.0. Uninstalling/Modifying NI-HSDIOFor Windows 7, complete the following steps: - Launch the Control Panel by selecting Start»Control Panel.
- Double-click Programs and Features.
- Select National Instruments Software.
- Click the Uninstall/Change button.
- Select NI-HSDIO 16.0 from the dialog box that appears.
- Click Remove to uninstall the product; click Modify to change the components that are installed.
For Windows 10/8.1, complete the following steps: - Right-click on the Start button.
- Select Control Panel.
- Select Programs» Programs and Features.
- Click the Uninstall button.
As part of the NI-HSDIO 16.0 installation, the following software is installed. To completely remove the NI-HSDIO 16.0 installation from your system, you must also remove all of the following packages: - NI-HSDIO Runtime 16.0
- NI Hierarchical Waveform Storage 16.0
- NI SignalExpress 20121
- NI IVI Compliance Package 16.0
- NI Measurement & Automation Explorer 16.0
- NI-DAQmx 15.0
- Traditional NI-DAQ 7.4.41
- NI-DAQmx MAX Configuration Support 15.0
- NI-VISA 16.0
- NI IO Trace 15.0
1The installation of these packages is not required to install or uninstall NI-HSDIO. Caution Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly. Note Do not attempt to uninstall by manually deleting files. Obsolete Properties and AttributesThe Hardware Compare Mode property and the NIHSDIO_ATTR_HWC_HARDWARE_COMPARE_MODE attribute are obsolete. They are replaced by the Supported Data States property and the NIHSDIO_ATTR_SUPPORTED_DATA_STATES attribute. Known IssuesYou can access the software and documentation known issues list online. Refer to the NI-HSDIO 16.0 Known Issues at ni.com/info and enter the Info Code exk5ui for an up-to-date list of known issues in NI-HSDIO 16.0. Bug FixesThe following items are the IDs and titles of a subset of issues fixed in NI-HSDIO. This is not an exhaustive list of issues fixed in the current version of NI-HSDIO. If you have a CAR ID, you can search this list to validate that the issue has been fixed. The following items were fixed in NI-HSDIO 2.0. | ID | Fixed Issue | | 333216 | Fixed an issue in which intermittent failures were occurring when using Hardware Compare on the NI 6551 or NI 6552 at frequencies between 48 Hz and 65 Hz. | | 373229 | Fixed an issue in which calling self-calibration on an NI PXIe-6555 or NI PXIe-6556 when using LabVIEW Real Time caused Property Node errors. | | 394554 | Fixed an issue in which PFI lines 24 through 31 were not defined in nihsdio.h. |
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, Automating the Installation of a Suited Installer.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install National Instruments software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. Legal InformationCopyright © 2003–2016 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents. 375376B-01 |
