查看: 3179|回复: 0
[NI驱动程序] NI-HSDIO 15.0 Driver Win32/62 Eng/Jpn NI高速数字输入输出仪器驱动程序15.0
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-19 00:20:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-HSDIO
    NI-HSDIO为使用NI PXI数字波形仪器或数字波形设备的客户提供支持。
    NI-HSDIO是与数字波形硬件进行通信的NI仪器驱动程序,用于执行高速DIO  (HSDIO)任务。该驱动程序软件包含基于IVI准则的灵活API、完整的硬件支持文档,以及配置和测试实用程序。
    Win32/64Eng/Jpn
    15.0
    文件大小: 2006849355 字节 (1.87 GB)
    修改日期: 2015-08-03 22:06
    MD5: 61a9212ae4be622a0548bf3bfb80ccdf(官方正确)
    SHA1: 7ce394d415fef184c09ae4f9c616ef77e3e440c1
    SHA256: db759b6cf8b0962e97ab39a70f23932be0ff725c5910edae4e299037624c9919
    CRC32: eef7d0af
    HSDIO15.0.txt (577 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-HSDIO Readme
    Version 15.0
    Thank you for using NI-HSDIO. This file contains important information about NI-HSDIO and is organized into the following sections:
    Driver Version Naming Changes
    Uninstalling/Modifying NI-HSDIO
    NI-HSDIO 15.0 adds support for LabVIEW 2015 (32- and 64-bit)
    NI-HSDIO 14.0 adds support for LabVIEW 2014 (32- and 64-bit)
    NI-HSDIO 2.0 includes the following new features:
    • Support for external calibration of NI PXIe-6555 and NI PXIe-6556.
    • New attributes (only available for the NI PXIe-6555 and NI PXIe-6556):
      • Attribute Committal Strategy (NIHSDIO_ATTR_ATTRIBUTE_COMMITTAL_STRATEGY)
      • Cumulative Error Bits (NIHSDIO_ATTR_HWC_CUMULATIVE_ERROR_BITS)
    • Support for NI-HSDIO Runtime custom installers built using NI application development environments (ADEs). This installer contains instrument driver runtime components required to deploy applications using NI digital waveform generator/analyzers.
      Notes:
      The runtime installer does not contain support for interactively configuring or testing hardware using Measurement & Automation Explorer (MAX).
      The runtime installer does not support upgrading from NI-HSDIO 1.9.x or earlier or NI-DAQmx 8.9.x or earlier. You must uninstall these products prior to installing the NI-HSDIO Runtime installer.
    NI-HSDIO 1.9 includes the following new features:
    • Support for NI PXIe-6555 devices.
    • Support for multi-sample pattern matching and active load functionality (PXIe-6556 only).
    • Updated self-calibration function that fixes an issue affecting the NI PXIe-6556 input skew specifications. For more information, visit ni.com/info and enter the Info Code 6556SKEW.
    • Faster PMU and digital pattern functionality.
    NI-HSDIO 1.8.3 adds support for LabVIEW 2012 (32- and 64-bit)
    NI-HSDIO 1.8.1 includes the following new features:
    • Support for NI PXIe-6556 devices.
    • Support for PPMU force and sense functionality.
    The following table shows which hardware products are supported under particular operating systems.
    Hardware ProductSupported Under Supported Under Windows 8.1 (32-bit)/Windows 8.0 (32-bit)/7 (32-bit)/Vista (32-bit)/XP1Supported Under Windows 8.1 (64-bit)/Windows 8.0 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI PXI/PCI-6541
    NI PXI/PCI-6542
    NI PXIe-6544
    NI PXIe-6545
    NI PXIe-6547
    NI PXIe-6548
    NI PXI/PCI-6551
    NI PXI/PCI-6552
    NI PXIe-6555
    NI PXIe-6556
    NI PXI/PCI-6561
    NI PXI/PCI-6562
    1 MXI Express and MXI-4 are supported on Windows 8.1/8/7/Vista/XP, but MXI-3 is supported on only Windows XP.
    Note:  Device-specific information about these modules is included in the NI Digital Waveform Generator/Analyzer Help.
    System RequirementsSupported Operating System
    NI-HSDIO 15.0 and later supports the following operating systems:
    • Windows 8.1 (32-bit and 64-bit)
    • Windows 8.0 (32-bit and 64-bit)
    Note:  NI-HSDIO 15.0 and later do not support Windows Server non-R2 editions.
    NI-HSDIO 15.0 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows XP: 128 MB
      • Windows 8.1/8.0/7/Vista:512 MB
    • Windows 8.1/8.0/7/Vista/XP SP3, with all available critical updates and service packs
    Recommended System
    • RAM—;
      • Windows XP: 256 MB
      • Windows 8.1/8.0/7/Vista:1 GB
    • A screen resolution of 1024 x 768
    • Windows 8.1/8.0/7/Vista/XP, with all available critical updates and service packs
    Note:  You should install ADEs, such as NI LabVIEW, NI LabWindows®/CVI® or Microsoft Visual Studio®, before installing NI-HSDIO. To add support for ADEs installed after installing NI-HSDIO, modify your NI-HSDIO installation or launch the NI-HSDIO installer again.
    • NI LabVIEW 2012 SP1 (32-bit), 2012 SP1 (64-bit), 2013 SP1 (32-bit), 2013 SP1 (64-bit), 2014 SP1 (32-bit), 2014 SP1 (64-bit), 2015 (32-bit), or 2015 (64-bit)
    • LabVIEW Real-Time Module 2012 SP1, 2013 SP1, 2014 SP1, or 2015
    • LabWindows/CVI 9.0.1 or later
    • LabWindows/CVI Real-Time Module 2009 or later
    • If you are running your application on an RT target, 128 MB of memory or more is required.
      • Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows 8.1/8.0/7/Vista: Users\Public\Public Documents\National Instruments
      • Windows 8.1 (32-bit)/8.0 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        • Windows 8.1 (32-bit)/8.0 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        Note  $(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 8.1/8.0/7/Vista/XP
    NI-HSDIO\Drivers\niHSDIO
    NI-HSDIO Function Panel\Drivers\niHSDIO\niHSDIO.fp
    NI-HSDIO Examples\niHSDIO\Examples
    NI-HSDIO Header files\Include
    NI-HSDIO Import Library files (32-bit)\Lib
    NI-HSDIO Import Library files (64-bit)\Lib_x64
    NI-HSDIO DLL (32-bit)\Bin
    Additional File Locations for Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI-HSDIO DLL (64-bit)\Bin
    The product documentation is available at Start» Programs»National Instruments»NI-HSDIO»Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI Digital Waveform Generator/Analyzer HelpHTML/Windows HelpContains instructions for opening, configuring, initiating signal generation, and closing the session. Also, contains information about programming and fundamentals.
    NI Digital Waveform Generator/Analyzer Getting Started Guide for your devicePrinted and PDFContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
    Specifications for your devicePrinted and PDFContains specifications for the capabilities and valid operating conditions of your NI device
    NI-HSDIO ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    To use the .NET API, you must install the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information on versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    Note  To view the specifications, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    NI-HSDIO versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-HSDIO 14.0.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-HSDIO 2.0. The first version released under the new numbering scheme is NI-HSDIO 14.0.0.
    Perform the following procedure to uninstall NI-HSDIO 15.0:
    • Click Change/Remove.
    • Select NI-HSDIO 15.0 from the dialog box that appears.
    For Windows 8.x, complete the following steps:
    • Click the Uninstall button.
    As part of the NI-HSDIO installation, the following software is installed. To completely remove the NI-HSDIO installation from your system, you must also remove all of the following products:
    • NI-HSDIO Runtime 15.0
    • NI LabVIEW SignalExpress 2012 (optional)
    • NI IVI Compliance Package 15.0
    • NI Measurement & Automation Explorer 15.0
    • NI-DAQmx 15.0
    • Traditional NI-DAQ 7.4.4 (optional)
    • NI-VISA 15.0
    • NI I/O Trace 15.0
    • NI Spy 2.7.2
    Obsolete Properties and Attributes
    The Hardware Compare Mode property and the NIHSDIO_ATTR_HWC_HARDWARE_COMPARE_MODE attribute are obsolete. They are replaced by the Supported Data States property and the NIHSDIO_ATTR_SUPPORTED_DATA_STATES attribute.
    You can access the software and documentation known issues list online. Refer to the NI-HSDIO 15.0 Known Issues at ni.com using the info code exhcjt for an up-to-date list of known issues in NI-HSDIO 15.0.
    The following items are changes in NI-HSDIO 15.0 from NI-HSDIO 2.0. This table is not an exhaustive list of issues fixed in the current version of NI-HSDIO.
    333216Fixed an issue in which intermittent failures were occurring when using Hardware Compare on the NI 6551 or NI 6552 at frequencies between 48 Hz and 65 Hz.
    373229Fixed an issue in which calling self-calibration on an NI PXIe-6555 or NI PXIe-6556 when using LabVIEW Real Time caused Property Node errors.
    394554Fixed an issue in which PFI lines 24 through 31 were not defined in nihsdio.h.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.0) or click the down arrow on the bottom left of the screen (Windows 8.1).
    NI-DMM Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments NI-DMM will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-DMM that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes.
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Legal information
    © 2003–2015 National Instruments Corporation. All rights reserved.
    375376A-01
    GMT+8, 2025-11-19 09:04
