查看: 2989|回复: 0
[NI驱动程序] NI-HSDIO 14.0 Driver Patch Win32/62 Eng/Jpn NI高速数字输入输出仪器驱动程序14.0补丁
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-19 00:18:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-HSDIO
    NI-HSDIO为使用NI PXI数字波形仪器或数字波形设备的客户提供支持。
    NI-HSDIO是与数字波形硬件进行通信的NI仪器驱动程序,用于执行高速DIO  (HSDIO)任务。该驱动程序软件包含基于IVI准则的灵活API、完整的硬件支持文档,以及配置和测试实用程序。
    Win32/64Eng/Jpn
    14.0Patch
    文件大小: 39387136 字节 (37.56 MB)
    修改日期: 2014-08-08 04:12
    MD5: 3f2dd9de45b99e0bebee90a0974a0e56(官方正确)
    SHA1: 4b27cc642a385a9b69a80b778173f4305fa18791
    SHA256: c1a40b9f294690c16ea9ad7f382e24dff7f580e258f4a9ec5c9ba55c5f978233
    CRC32: a15e3579
    HSDIO14.0Patch.txt (604 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-HSDIO Readme
    Version 14.0
    Thank you for using NI-HSDIO. This file contains important information about NI-HSDIO and is organized into the following sections:
    Installed File Names and Locations
    Uninstalling/Modifying NI-HSDIO
    NI-HSDIO 14.0 includes the following new features:
    • Support for LabVIEW 2014 (32-bit and 64-bit).
    NI-HSDIO 2.0 includes the following new features:
    • Support for external calibration of NI PXIe-6555 and NI PXIe-6556.
    • New attributes (only available for the NI PXIe-6555 and NI PXIe-6556):
      • Attribute Committal Strategy (NIHSDIO_ATTR_ATTRIBUTE_COMMITTAL_STRATEGY)
      • Cumulative Error Bits (NIHSDIO_ATTR_HWC_CUMULATIVE_ERROR_BITS)
    • Support for NI-HSDIO Runtime custom installers built using NI application development environments (ADEs). This installer contains instrument driver runtime components required to deploy applications using NI digital waveform generator/analyzers.
      Notes:
      The runtime installer does not contain support for interactively configuring or testing hardware using Measurement & Automation Explorer (MAX).
      The runtime installer does not support upgrading from NI-HSDIO 1.9.x or earlier or NI-DAQmx 8.9.x or earlier. You must uninstall these products prior to installing the NI-HSDIO Runtime installer.
    NI-HSDIO 1.9 includes the following new features:
    • Support for NI PXIe-6555 devices.
    NI-HSDIO 1.8.3 includes the following new features:
    • Support for LabVIEW 2012 (32- and 64-bit)
    NI-HSDIO 1.8.1 includes the following new features:
    • Support for NI PXIe-6556 devices.
    • Support for PPMU force and sense functionality.
    NI-HSDIO 1.7.5 includes the following new features:
    • Support for LabVIEW 2011 (32- and 64-bit).
    NI-HSDIO 1.7.3 includes the following new features:
    • Support for LabVIEW 2010 (32- and 64-bit).
    NI-HSDIO 1.7.1 includes the following new features:
    • Fixed fatal issue when upgrading NI-HSDIO on Windows 7 (64-bit) and Windows Server 2008 R2.
    NI-HSDIO 1.7 includes the following new features:
    • Support for LabVIEW 2009 (64-bit).
    • Support for 64-bit user mode.
    • Support for multibank data delay on NI 6547/6548 devices only.
    • Additional support for hardware comparison on NI 6547/6548 devices.
    • Additional support for per pin, per cycle tristate on NI 6547/6548 devices.
    The following table shows which hardware products are supported under particular operating systems.
    Hardware ProductSupported Under Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP1Supported Under Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI PXI/PCI-6541
    NI PXI/PCI-6542
    NI PXIe-6544
    NI PXIe-6545
    NI PXIe-6547
    NI PXIe-6548
    NI PXI/PCI-6551
    NI PXI/PCI-6552
    NI PXIe-6555
    NI PXIe-6556
    NI PXI/PCI-6561
    NI PXI/PCI-6562
    1 MXI Express and MXI-4 are supported on Windows 7/Vista/XP, but MXI-3 is supported on only Windows XP.
    Note:  Device-specific information about these modules is included in the NI Digital Waveform Generator/Analyzer Help.
    System RequirementsSupported Operating System
    NI-HSDIO 14.0 and later supports the following operating systems:
    Note:  NI-HSDIO 14.0 and later do not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-HSDIO 1.7.2 or earlier.
    NI-HSDIO 14.0 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows XP: 128 MB
      • Windows 8/7/Vista: 512 MB
    • Windows 8/7/Vista/XP, with all available critical updates and service packs
    Recommended System
    • RAM—
      • Windows XP: 256 MB
      • Windows 8/7/Vista: 1 GB
    • A screen resolution of 1024 x 768
    Note:  You should install ADEs, such as NI LabVIEW, NI LabWindows™/CVI™ or Microsoft Visual Studio®, before installing NI-HSDIO. To add support for ADEs installed after installing NI-HSDIO, modify your NI-HSDIO installation or launch the NI-HSDIO installer again.
    • NI LabVIEW 2011 SP1 (32- and 64-bit), 2012 SP1 (32- and 64-bit), 2013 SP1 (32- and 64-bit), 2014 SP1 (32- and 64-bit)
    • LabVIEW Real-Time Module 2011 SP1 (32- and 64-bit), 2012 SP1 (32- and 64-bit), 2013 SP1 (32- and 64-bit), 2014 S1 (32- and 64-bit)
    • LabWindows/CVI 9.0.1 or later
    • LabWindows/CVI Real-Time Module 2009 or later
    • If you are running your application on an RT target, 128 MB of memory or more is required.
      • Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows 7/Vista: Users\Public\Documents\National Instruments
      • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        Note  $(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 8 (32-bit)/Windows 7 (32-bit)/Vista (32-bit)/XP
    NI-HSDIO\Drivers\niHSDIO
    NI-HSDIO Function Panel\Drivers\niHSDIO\niHSDIO.fp
    NI-HSDIO Examples\niHSDIO\Examples
    NI-HSDIO Header files\Include
    NI-HSDIO Import Library files (32-bit)\Lib
    NI-HSDIO Import Library files (64-bit)\Lib_x64
    NI-HSDIO DLL (32-bit)\Bin
    Additional File Locations for Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8 (64-bit)/Windows 7 (64-bit)/Vista (64-bit)
    NI-HSDIO DLL (64-bit)\Bin
    The product documentation is available at Start» Programs»National Instruments»NI-HSDIO»Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI Digital Waveform Generator/Analyzer HelpHTML/Windows HelpContains instructions for opening, configuring, initiating signal generation, and closing the session. Also, contains information about programming and fundamentals.
    NI Digital Waveform Generator/Analyzer Getting Started Guide for your devicePrinted and PDFContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
    Specifications for your devicePrinted and PDFContains specifications for the capabilities and valid operating conditions of your NI device
    NI-HSDIO ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Note  To view the specifications, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    Driver Version Naming Changes
    NI-HSDIO versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-HSDIO 14.0.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-HSDIO 2.0. The first version released under the new numbering scheme is NI-HSDIO 14.0.0.
    Uninstalling/Modifying the Instrument Driver
    Perform the following procedure to uninstall NI-HSDIO 14.0:
    • Click Change/Remove.
    • Select NI-HSDIO 14.0 from the dialog box that appears.
    For Windows 8/7/Vista, complete the following steps:
    As part of the NI-HSDIO installation, the following software is installed. To completely remove the NI-HSDIO installation from your system, you must also remove all of the following packages:
    • NI-HSDIO Runtime 14.0
    • NI LabVIEW SignalExpress 2012 (optional)
    • NI IVI Compliance Package 4.4
    • NI Measurement & Automation Explorer 14.0
    • NI-DAQmx 9.1.7
    • Traditional NI-DAQ 7.4.4 (optional)
    • NI-VISA 5.1.2
    • NI Spy 2.7.2
    Obsolete Properties and Attributes
    The Hardware Compare Mode property and the NIHSDIO_ATTR_HWC_HARDWARE_COMPARE_MODE attribute are obsolete. They are replaced by the Supported Data States property and the NIHSDIO_ATTR_SUPPORTED_DATA_STATES attribute.
    You can access the software and documentation known issues list online. Refer to the NI-HSDIO 14.0 Known Issues List at ni.com for an up-to-date list of known issues in NI-HSDIO 14.0
    The following items are changes in NI–HSDIO 14.0 from NI–HSDIO 2.0. This table is not an exhaustive list of issues fixed in the current version of NI–HSDIO.
    333216Fixed an issue in which intermittent failures were occurring when using Hardware Compare on the NI 6551 or NI 6552 at frequencies between 48 Hz and 65 Hz.
    373229Fixed an issue in which calling self-calibration on an NI PXIe-6555 or NI PXIe-6556 when using LabVIEW Real Time caused Property Node errors.
    394554Fixed an issue in which PFI lines 24 through 31 were not defined in nihsdio.h.
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    Legal information
    © 2003–2014 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-11-19 09:00
