NI-HSDIO 2.0 Driver Win32/62 Eng/Jpn NI高速数字输入输出仪器驱动程序2.0
NI-HSDIO
NI-HSDIO为使用NI PXI数字波形仪器或数字波形设备的客户提供支持。
NI-HSDIO是与数字波形硬件进行通信的NI仪器驱动程序,用于执行高速DIO (HSDIO)任务。该驱动程序软件包含基于IVI准则的灵活API、完整的硬件支持文档,以及配置和测试实用程序。
Win32/64Eng/Jpn
2.0
文件大小: 1990860267 字节 (1.85 GB)
修改日期: 2014-11-06 06:43
MD5: ea7c9461d0cb45080290fb16f0e00489(官方正确)
SHA1: 318e8ee31383ed548f58415b78d2897b5ead1601
SHA256: d34b80571e2b73ced5775f8a67373bb3490832e682e3396808401f5103b1cd57
CRC32: 9f6565c5
HSDIO2.0.txt
(573 Bytes, 下载次数: 0, 售价: 10 圆)
NI-HSDIO ReadmeVersion 2.0 Thank you for using NI-HSDIO. This file contains important information about NI-HSDIO and is organized into the following sections: - New Features
- Supported Hardware
- System Requirements
- Installed File Names and Locations
- Updates and Notifications
- Documentation
- Uninstalling/Modifying NI-HSDIO
- Known Issues
- Bug Fixes
NI-HSDIO 2.0 includes the following new features: - Support for external calibration of NI PXIe-6555 and NI PXIe-6556.
- New attributes (only available for the NI PXIe-6555 and NI PXIe-6556):
- Attribute Committal Strategy (NIHSDIO_ATTR_ATTRIBUTE_COMMITTAL_STRATEGY)
- Cumulative Error Bits (NIHSDIO_ATTR_HWC_CUMULATIVE_ERROR_BITS)
- Support for NI-HSDIO run-time custom installers built using NI application development environments (ADEs). This installer contains instrument driver run-time components required to deploy applications using NI digital waveform generator/analyzers.
Notes:
The run-time installer does not contain support for interactively configuring or testing hardware using Measurement & Automation Explorer (MAX).
The run-time installer does not support upgrading from NI-HSDIO 1.9.x or earlier or NI-DAQmx 8.9.x or earlier. You must uninstall these products prior to installing the NI-HSDIO Run-Time installer.
NI-HSDIO 1.9 includes the following new features: - Support for NI PXIe-6555 devices.
NI-HSDIO 1.8.3 includes the following new features: - Support for LabVIEW 2012 (32-bit) and LabVIEW 2012 (64-bit).
NI-HSDIO 1.8.1 includes the following new features: - Support for NI PXIe-6556 devices.
- Support for PPMU force and sense functionality.
NI-HSDIO 1.7.5 includes the following new features: - Support for LabVIEW 2011 (32-bit) and LabVIEW 2011 (64-bit).
NI-HSDIO 1.7.3 includes the following new features: - Support for LabVIEW 2010 (32-bit) and LabVIEW 2010 (64-bit).
NI-HSDIO 1.7.1 includes the following new features: - Fixed fatal issue when upgrading NI-HSDIO on Windows 7 (64-bit) and Windows Server 2008 R2.
NI-HSDIO 1.7 includes the following new features: - Support for LabVIEW 2009 (64-bit).
- Support for 64-bit user mode.
- Support for multibank data delay on NI 6547/6548 devices only.
- Additional support for hardware comparison on NI 6547/6548 devices.
- Additional support for per pin, per cycle tristate on NI 6547/6548 devices.
Supported HardwareThe following table shows which hardware products are supported under particular operating systems. | Hardware Product | Supported Under Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP1 | Supported Under Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit) | | NI PXI/PCI-6541 | √ | √ | | NI PXI/PCI-6542 | √ | √ | | NI PXIe-6544 | √ | √ | | NI PXIe-6545 | √ | √ | | NI PXIe-6547 | √ | √ | | NI PXIe-6548 | √ | √ | | NI PXI/PCI-6551 | √ | √ | | NI PXI/PCI-6552 | √ | √ | | NI PXIe-6555 | √ | √ | | NI PXIe-6556 | √ | √ | | NI PXI/PCI-6561 | √ | √ | | NI PXI/PCI-6562 | √ | √ | | 1 MXI Express and MXI-4 are supported on Windows 7/Vista/XP, but MXI-3 is supported on only Windows XP. |
Note: Device-specific information about these modules is included in the NI Digital Waveform Generator/Analyzer Help. System RequirementsSupported Operating SystemsNI-HSDIO 2.0 and later supports the following operating systems: - Windows 8 (32-bit and 64-bit)
- Windows 7 (32-bit and 64-bit)
- Windows Vista (32-bit and 64-bit)
- Windows XP Service Pack 2 (32-bit)
- Windows Server 2003 R2 (32-bit)
- Windows Server 2008 R2 (64-bit)
Note: NI-HSDIO 2.0 and later do not support Windows Server non-R2 editions. It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-HSDIO 1.7.2 or earlier. Supported Real-Time Operating EnvironmentsNI-HSDIO 2.0 and later supports the following real-time operating environments: - LabVIEW Real-Time Module
- LabWindows/CVI Real-Time Module
Minimum System Requirements- Processor—Pentium III/Celeron 600 MHz or equivalent
- RAM—
- Windows XP: 128 MB
- Windows 8/7/Vista: 512 MB
- Microsoft Internet Explorer 5.5 or later
- A screen resolution of 800 x 600 with 256 colors
- Windows 8/7/Vista/XP, with all available critical updates and service packs
Recommended System- Processor—Pentium 4 or equivalent
- RAM—
- Windows XP: 256 MB
- Windows 8/7/Vista: 1 GB
- A screen resolution of 1024 x 768
Application Development Environments (ADEs)Note: You should install ADEs, such as NI LabVIEW, NI LabWindows™/CVI™ or Microsoft Visual Studio®, before installing NI-HSDIO. To add support for ADEs installed after installing NI-HSDIO, modify your NI-HSDIO installation or launch the NI-HSDIO installer again. - NI LabVIEW 2009 SP1 (32-bit), 2009 SP1 (64-bit), 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 SP1 (32-bit), 2011 SP1 (64-bit), 2012 SP1 (32-bit), or 2012 SP1 (64-bit)
- LabVIEW Real-Time Module 2009 SP1 (32-bit), 2009 SP1 (64-bit), 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 SP1 (32-bit), 2011 SP1 (64-bit), 2012 SP1 (32-bit), or 2012 SP1 (64-bit)
- LabWindows/CVI 9.0.1 or later
- LabWindows/CVI Real-Time Module 2009 or later
- Microsoft Visual C++ (MSVC) 6.0 or later
- If you are running your application on an RT target, 128 MB of memory or more is required.
Installed File Names and Locations- is an alias for the following National Instruments file folder location:
- Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
- Windows 7/Vista: Users\Public\Documents\National Instruments
- Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
- Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
| Note | $(IVIROOTDIR32) is configured as an environment variable on the target system. | | If you upgraded an installation of IVI, your files may be located in the following location:
- Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
- Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
File Locations| Item | Installed Location on Windows 8 (32-bit)/Windows 7 (32-bit)/Vista (32-bit)/XP | | NI-HSDIO | \Drivers\niHSDIO | | NI-HSDIO Function Panel | \Drivers\niHSDIO\niHSDIO.fp | | NI-HSDIO Examples | \niHSDIO\Examples | | NI-HSDIO Header files | \Include | | NI-HSDIO Import Library files (32-bit) | \Lib | | NI-HSDIO Import Library files (64-bit) | \Lib_x64 | | NI-HSDIO DLL (32-bit) | \Bin |
Additional File Locations for Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)| Item | Installed Location on Windows 8 (64-bit)/Windows 7 (64-bit)/Vista (64-bit) | | NI-HSDIO Function Panel | \Drivers\niHSDIO\niHSDIO.fp | | NI-HSDIO Header files | \Include | | NI-HSDIO Import Library files (64-bit) | \Lib_x64 | | NI-HSDIO DLL (64-bit) | \Bin |
Updates and NotificationsNational Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates. National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications. DocumentationThe product documentation is available at Start» Programs»National Instruments»NI-HSDIO»Documentation. Visit ni.com/manuals for the latest versions of product documentation. The documentation for NI-HSDIO and NI Digital Waveform Generator/Analyzer modules includes the following items: - NI Digital Waveform Generator/Analyzer Getting Started Guide—Explains how to install, configure, and test a National Instruments digital waveform generator/analyzer.
- NI Digital Waveform Generator/Analyzer Help—Contains instructions for opening, configuring, initiating signal generation, and closing the session. Also, contains information about programming and fundamentals.
- Specifications document for your device—Contains specifications for the capabilities and valid operating conditions of your NI device.
Note To view the specifications, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat. NI-HSDIO Updates and NotificationsNational Instruments posts information about critical updates and security notifications on ni.com. Visit ni.com/info, and enter the info code updates to access this information. Uninstalling/Modifying the Instrument DriverPerform the following procedure to uninstall NI-HSDIO 2.0: For Windows XP, complete the following steps: - Launch the Control Panel by selecting Start»Control Panel.
- Double-click Add or Remove Programs.
- Select National Instruments Software.
- Click Change/Remove.
- Select NI-HSDIO 2.0 from the dialog box that appears.
- Click Remove to uninstall the product; click Modify to change the components that are installed.
For Windows 8/7/Vista, complete the following steps: - Launch the Control Panel by selecting Start»Control Panel.
- Double-click Programs and Features.
- Click the Uninstall/Change button.
As part of the NI-HSDIO installation, the following software is installed. To completely remove the NI-HSDIO installation from your system, you must also remove all of the following packages: - NI-HSDIO Runtime 2.0
- NI LabVIEW SignalExpress 2012 (optional)
- NI IVI Compliance Package 4.4
- NI Measurement & Automation Explorer 5.4
- NI-DAQmx 9.1.7
- Traditional NI-DAQ 7.4.4 (optional)
- NI-VISA 5.0
- NI Spy 2.7.2
Caution Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly. Note Do not attempt to uninstall by manually deleting files. Obsolete Properties and AttributesThe Hardware Compare Mode property and the NIHSDIO_ATTR_HWC_HARDWARE_COMPARE_MODE attribute are obsolete. They are replaced by the Supported Data States property and the NIHSDIO_ATTR_SUPPORTED_DATA_STATES attribute. Known IssuesYou can access the software and documentation known issues list online. Refer to the NI-HSDIO 2.0 Known Issues List at ni.com for an up-to-date list of known issues in NI-HSDIO 2.0 Bug FixesThe following items are changes in NI–HSDIO 2.0 from NI–HSDIO 1.9. This table is not an exhaustive list of issues fixed in the current version of NI–HSDIO.
| ID | Fixed Issue | | 333216 | Fixed an issue where intermittent failures were occurring when using Hardware Compare on the NI 6551 or NI 6552 at frequencies between 48 Hz and 65 Hz. | | 373229 | Fixed an issue where calling self-calibration on an NI PXIe-6555 or NI PXIe-6556 when using LabVIEW Real Time caused Property Node errors. | | 394554 | Fixed an issue where PFI lines 24 through 31 were not defined in nihsdio.h. |
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information, refer to the following KnowledgeBase articles: - For more information on silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information on silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, Automating the Installation of a Suited Installer.
How to Use NI Software with Microsoft Windows 8When you install National Instruments software on Microsoft Windows 8, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (MAX), and the new NI Launcher. Using NI LauncherNI Launcher helps you find and launch installed NI products. It provides you with a method of finding NI products similar to the Start menu in previous versions of Microsoft Windows. To use NI Launcher, click the NI Launcher tile on the Start screen. NI Launcher launches the desktop and opens a menu containing a list of NI products. Click any NI product to launch it. | Note MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher. | Pinning Frequently Used ApplicationsFor convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary: | Current Application | Icon Location | Pin to Action | | Windows 8 Desktop | Desktop Taskbar | Right-click application and select Pin to Taskbar | | Windows 8 Desktop | Start screen | Right-click application and select Pin to Start | | Windows 8 Start screen | Desktop Taskbar | Right-click application and select Pin to taskbar from the menu bar on the bottom of the screen | Finding All ProgramsIf you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files by right-clicking anywhere on the Start screen and selecting All apps. A list of all installed software and related files appears, in alphabetical order by creator or type. For more information about NI support for Windows 8, visit ni.com/windows8. Important InformationCopyright © 2003–2013 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. Trademarks CVI, National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. The mark LabWindows is used under a license from Microsoft Corporation. Windows is a registered trademark of Microsoft Corporation in the United States and other countries. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents. |
