NI-HSDIO 1.9 Driver Win32/62 Eng/Jpn NI高速数字输入输出仪器驱动程序1.9
NI-HSDIO
NI-HSDIO为使用NI PXI数字波形仪器或数字波形设备的客户提供支持。
NI-HSDIO是与数字波形硬件进行通信的NI仪器驱动程序,用于执行高速DIO (HSDIO)任务。该驱动程序软件包含基于IVI准则的灵活API、完整的硬件支持文档,以及配置和测试实用程序。
Win32/64Eng/Jpn
1.9
文件大小: 1860299400 字节 (1.73 GB)
修改日期: 2012-10-06 00:50
MD5: 1b1490b9a6ed7011382e6d1975ab5080(官方正确)
SHA1: 60d503be2b1921c8b98c578f6e10fec17c0c9dc9
SHA256: f439a203310828e60e73f3f6465b44c6ea3af8d5aaccf709b0e76ed0efa1220b
CRC32: bdd65e49
HSDIO1.9.txt
(573 Bytes, 下载次数: 0, 售价: 10 圆)
NI-HSDIO Instrument Driver ReadmeVersion 1.9 Thank you for using NI-HSDIO. This file contains important information about NI-HSDIO and is organized into the following sections: - New Features
- Supported Hardware
- System Requirements
- Installed File Names and Locations
- Updates and Notifications
- Documentation
- Uninstalling/Modifying NI-HSDIO
- Known Issues
- Bug Fixes
- Notice Regarding Microsoft Silverlight Installation and Redistribution
New FeaturesNI-HSDIO 1.9 includes the following new features: - Support for NI PXIe-6555 devices.
- Support for multi-sample pattern matching and active load functionality.
NI-HSDIO 1.8 includes the following new features: - Support for NI PXIe-6556 devices.
- Support for PPMU force and sense functionality.
NI-HSDIO 1.7.3 includes the following new features: - Support for LabVIEW 2010 (32-bit) and LabVIEW 2010 (64-bit).
NI-HSDIO 1.7.1 includes the following new features: - Fixed fatal issue when upgrading NI-HSDIO on Windows 7 (64-bit) and Windows Server 2008 R2.
NI-HSDIO 1.7 includes the following new features: - Support for LabVIEW 2009 (64-bit)
- Support for 64-bit user mode
- Support for multibank data delay on NI 6547/6548 devices only
- Additional support for hardware comparison on NI 6547/6548 devices
- Additional support for per pin, per cycle tristate on NI 6547/6548 devices
Supported HardwareThe following table shows which hardware products are supported under particular operating systems. | Hardware Product | Supported Under Windows 7 (32-bit)/Vista (32-bit)/XP1 | Supported Under Windows 7 (64-bit)/Vista (64-bit) | | NI PXI/PCI-6541 | √ | √ | | NI PXI/PCI-6542 | √ | √ | | NI PXIe-6544 | √ | √ | | NI PXIe-6545 | √ | √ | | NI PXIe-6547 | √ | √ | | NI PXIe-6548 | √ | √ | | NI PXI/PCI-6551 | √ | √ | | NI PXI/PCI-6552 | √ | √ | | NI PXIe-6555 | √ | √ | | NI PXIe-6556 | √ | √ | | NI PXI/PCI-6561 | √ | √ | | NI PXI/PCI-6562 | √ | √ | | 1 MXI Express and MXI-4 are supported on Windows 7/Vista/XP, but MXI-3 is supported on only Windows XP. |
Note: Device-specific information about these modules is included in the NI Digital Waveform Generator/Analyzer Help. System RequirementsSupported Operating SystemsNI-HSDIO 1.9 and later supports the following operating systems: - Windows 7 (32-bit and 64-bit)
- Windows Vista (32-bit and 64-bit)
- Windows XP Service Pack 3 (32-bit)
- Windows Server 2003 R2 (32-bit)
- Windows Server 2008 R2 (64-bit)
Note: NI-HSDIO 1.8 and later does not support Windows Server non-R2 editions. It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-HSDIO 1.7.2 or earlier. Supported Real-Time Operating EnvironmentsNI-HSDIO 1.9 and later supports the following real-time operating environments: - LabVIEW Real-Time Module
- LabWindows/CVI Real-Time Module
Minimum System Requirements- Processor—Pentium III/Celeron 600 MHz or equivalent
- RAM—
- Windows XP: 128 MB
- Windows 7/Vista: 512 MB
- Microsoft Internet Explorer 5.5 or later
- A screen resolution of 800 x 600 with 256 colors
- Windows 7/Vista/XP, with all available critical updates and service packs
Recommended System- Processor—Pentium 4 or equivalent
- RAM—
- Windows XP: 256 MB
- Windows 7/Vista: 1 GB
- A screen resolution of 1024 x 768
- LabVIEW 8.6.1, 2009 SP1 (32-bit), 2009 SP1 (64-bit), 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 SP1 (32-bit), or 2011 SP1 (64-bit)
- LabVIEW Real-Time Module 8.6.1, 2009 SP1, 2010 SP1, or 2011 SP1
- Note: Calibration of NI 6555/6556 devices is supported only on LabVIEW Real-Time Module 2010 SP1 and 2011 SP1.
- LabWindows™/CVI™ 9.0.1 or later
- LabWindows/CVI Real-Time Module 2009 or later
- Microsoft Visual C++ (MSVC) 6.0 or later
- If you are running your application on an RT target, 128 MB of memory or more is required.
Installed File Names and Locations- is an alias for the following National Instruments file folder location:
- Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
- Windows 7/Vista: Users\Public\Documents\National Instruments
- Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
- Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
| NOTES: | $(IVIROOTDIR32) is configured as an environment variable on the target system. | | If you upgraded an installation of IVI, your files may be located in the following location:
- Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
- Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
- Windows 7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
| NOTE: | $(IVIROOTDIR64) is configured as an environment variable on the target system. |
File Locations| Item | Installed Location on Windows 7 (32-bit)/Vista (32-bit)/XP | | NI-HSDIO | \Drivers\niHSDIO | | NI-HSDIO Function Panel | \Drivers\niHSDIO\niHSDIO.fp | | NI-HSDIO Examples | \niHSDIO\Examples | | NI-HSDIO Header files | \Include | | NI-HSDIO Import Library files (32-bit) | \Lib | | NI-HSDIO DLL (32-bit) | \Bin |
Additional File Locations for Windows 7 (64-bit)/Vista (64-bit)| Item | Installed Location on Windows 7 (64-bit)/Vista (64-bit) | | NI-HSDIO | \Drivers\niHSDIO | | NI-HSDIO Function Panel | \Drivers\niHSDIO\niHSDIO.fp | | NI-HSDIO Header files | \Include | | NI-HSDIO Import Library files (32-bit) | \Lib | | NI-HSDIO Import Library files (64-bit) | \Lib_x64 | | NI-HSDIO DLL (64-bit) | \Bin |
Updates and NotificationsNational Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates. National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications. DocumentationThe product documentation is available at Start»All Programs»National Instruments»NI-HSDIO»Documentation. Visit ni.com/manuals for the latest versions of product documentation. The documentation for NI-HSDIO and NI Digital Waveform Generator/Analyzer modules includes the following items: - NI Digital Waveform Generator/Analyzer Getting Started Guide—Explains how to install, configure, and test a National Instruments digital waveform generator/analyzer.
- NI Digital Waveform Generator/Analyzer Help—Contains instructions for opening, configuring, initiating signal generation, and closing the session. Also, contains information about programming and fundamentals.
- Specifications document for your device—Contains specifications for the capabilities and valid operating conditions of your NI device.
- User Guides for NI-HSDIO hardware accessories—Contains operating instructions for your NI accessory.
Note To view the specifications, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat. Uninstalling/Modifying the Instrument DriverPerform the following procedure to uninstall NI-HSDIO 1.9: For Windows XP, complete the following steps: - Launch the Control Panel by selecting Start»Control Panel.
- Double-click Add or Remove Programs.
- Select National Instruments Software.
- Click Change/Remove.
- Select NI-HSDIO 1.9 from the dialog box that appears.
- Click Remove to uninstall the product; click Modify to change the components that are installed.
For Windows 7/Vista, complete the following steps: - Launch the Control Panel by selecting Start»Control Panel.
- Double-click Programs and Features.
- Click the Uninstall/Change button.
As part of the NI-HSDIO installation, the following software is installed. To completely remove the NI-HSDIO installation from your system, you must also remove all of the following packages: - NI LabVIEW SignalExpress 2010
- NI IVI Compliance Package 4.2
- NI Measurement & Automation Explorer 4.7.2
- NI-DAQmx 9.1.7
- NI-VISA 5.0
- NI-SPY 2.7.2
Caution: Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly. Note: Do not attempt to uninstall by manually deleting files. Obsolete Properties and AttributesThe Hardware Compare Mode property and the NIHSDIO_ATTR_HWC_HARDWARE_COMPARE_MODE attribute are obsolete. They are replaced by the Supported Data States property and the NIHSDIO_ATTR_SUPPORTED_DATA_STATES attribute. Known IssuesYou can access the software and documentation known issues list online. Refer to the NI-HSDIO 1.9 Known Issues List at ni.com for an up-to-date list of known issues in NI-HSDIO 1.9. Bug FixesThe following items are changes in NI–HSDIO 1.7 and later, including NI–HSDIO 1.9. This table is not an exhaustive list of issues fixed in the current version of NI–HSDIO.
| ID | Fixed Issue | | 334636 | Fixed an issue in which when writing data within a certain voltage range on NI 6555/6556 devices, then sourcing a PMU voltage, then changing the voltage range and committing again, the sourced PMU voltage is incorrectly altered by 1 volt. | | 328561 | Fixed an issue in which, on NI 6555/6556 devices, when transitioning from Force Voltage to Force Current and back to Force Voltage on the same channel without disabling between transitions, the second voltage forced is different than the desired voltage. Similarly, when transitioning from Force Current to Force Voltage and back to Force Current on the same channel without disabling between transitions, the second current forced is different than the desired current. | | 327476 | Fixed an issue in which, in certain cases, the clock frequency or requested source may not be the same clock used when acquiring or generating data on NI 6545/6548 devices. | | 246065 | Fixed an issue in which an NI-HSDIO kernel crash occurred when waking up from sleep mode. | | 208009 | Fixed an issue in which a crash occurs when upgrading NI-HSDIO on Windows 7/Vista (64-bit). | | 293330 | Fixed an issue in which the niHSDIO HWC Fetch Sample Errors (U32) VI was broken on LabVIEW (64-bit). | | 245495 | Fixed an issue in which NI PXI High-Speed Digital I/O devices may fail to initialize when using an NI PXIe-8133 controller. This may manifest itself as an error when initializing a new device session or by not being properly identified in Measurement and Automation Explorer. | | 209053 | Fixed an issue in which the installer needs to stop service nidevldu before upgrading binaries. | | 195356 | Fixed an issue in which the Test Panel in Measurement & Automation Explorer (MAX) reported an unsupported device error when using the NI PXI-6561 hardware. | | 193283 | Fixed an issue in which NI 6545/6548 devices may experience the internal underflow error -200316 when running scripted generation above 100 MHz with the following statements: repeat until, if else, and break. For more information, search ni.com/kb using the code 52RESNHB. | | 181331 | Fixed an issue in which setting the data position of higher channels to Delay from Sample Clock Rising Edge caused lower channels to change from falling edge to rising edge. | | 183454 | Removed support for round trip delay values from 22 to 24 because they are not properly supported in hardware. | | 176994 | NI-HSDIO can now be deployed to Industrial Controller Real Time (NI 31xxRT) targets. | | 37746 | Added shipping examples that demonstrate setting up a triggered acquisition and generation session on the same device using NI-TClk. |
Notice Regarding Microsoft Silverlight Installation and RedistributionInstalling Microsoft SilverlightSome NI components require Microsoft Silverlight. If you do not have Silverlight installed on your computer, but you do have Internet access, you can download the installer from Microsoft at http://www.microsoft.com/silverlight/. If you do not have Internet access, you can install Silverlight from this NI distribution media. Using Microsoft SilverlightYou may not use any H.264/MPEG-4 AVC and/or VC-1 technology or codecs included in or with Microsoft Silverlight software which may be provided by NI as Third Party Software, including for the purpose of encoding or decoding video in compliance with, or making use of, the H.264/AVC visual standard or the VC-1 video standard. Redistribution of Microsoft SilverlightIf you create and distribute software applications that contain NI components that also use Microsoft Silverlight, you may be authorized to include Silverlight in installers or on physical media as long as you comply with certain requirements. Refer to the notice.txt file in the \_Legal Information\Microsoft Silverlight 4.0 directory or the NI standard End User License Agreement (EULA) located in the \Common\MDF\EULADepot\NIReleased directory for more information. Important InformationCopyright © 2003–2012 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations: - Notices are located in the \_Legal Information and directories.
- EULAs are located in the \Shared\MDF\EULAs directory.
Trademarks CVI, National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. The mark LabWindows is used under a license from Microsoft Corporation. Windows is a registered trademark of Microsoft Corporation in the United States and other countries. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents. |
