查看: 3286|回复: 0
[NI驱动程序] NI-HSDIO 1.8.1 Driver Win32/62 Eng/Jpn NI高速数字输入输出仪器驱动程序1.8.1
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-19 00:10:57 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-HSDIO
    NI-HSDIO为使用NI PXI数字波形仪器或数字波形设备的客户提供支持。
    NI-HSDIO是与数字波形硬件进行通信的NI仪器驱动程序,用于执行高速DIO  (HSDIO)任务。该驱动程序软件包含基于IVI准则的灵活API、完整的硬件支持文档,以及配置和测试实用程序。
    Win32/64Eng/Jpn
    1.8.1
    文件大小: 1798775776 字节 (1.68 GB)
    修改日期: 2012-04-06 00:21
    MD5: 91ddf90b58a87aa35a0ebe03a85efa0d(官方正确)
    SHA1: 607ecda38e1aaeb640610558dd7e854b8fc81e00
    SHA256: aed4e89c8ea47b42e77bf93d97265d5d6170d06e982c9b9f053c0ab2256b94a1
    CRC32: dabb8748
    HSDIO1.8.1.txt (578 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-HSDIO Instrument Driver Readme
    Version 1.8.1
    Thank you for using NI-HSDIO. This file contains important information about NI-HSDIO and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Updates and Notifications
    • Documentation
    • Uninstalling/Modifying NI-HSDIO
    • Known Issues
    • Bug Fixes
    • Notice Regarding Microsoft Silverlight Installation and Redistribution
    NI-HSDIO 1.8 includes the following new features:
    • Support for NI PXIe-6556 devices.
    • Support for PPMU force and sense functionality.
    NI-HSDIO 1.7.3 includes the following new features:
    • Support for LabVIEW 2010 (32-bit) and LabVIEW 2010 (64-bit).
    NI-HSDIO 1.7.1 includes the following new features:
    • Fixed fatal issue when upgrading NI-HSDIO on Windows 7 (64-bit) and Windows Server 2008 R2.
    NI-HSDIO 1.7 includes the following new features:
    • Support for LabVIEW 2009 (64-bit)
    • Support for 64-bit user mode
    • Support for multibank data delay on NI 6547/6548 devices only
    • Additional support for hardware comparison on NI 6547/6548 devices
    • Additional support for per pin, per cycle tristate on NI 6547/6548 devices
    NI-HSDIO 1.6.1 includes the following new features:
    • Support for LabVIEW 2009 (32-bit)
    NI-HSDIO 1.6 includes the following new features:
    • Support for the NI 6544/6545/6547/6548 devices
    • Added localized Japanese software and documentation
    • Desktop PC support for the LabVIEW Real-Time Module
    • Support for detecting NI Modular Instrument devices in LabWindowsTM/CVITM
    • Support to continuously stream data while using the Pause trigger
    • New source synchronous acquisition and generation examples for LabVIEW and LabWindows/CVI
    • Added fetch optimizations for NI-HSDIO dynamic acquisitions
    • Support for generation Stop trigger
    The following table shows which hardware products are supported under particular operating systems.
    Hardware ProductSupported Under Windows 7 (32-bit)/Vista (32-bit)/XP1Supported Under Windows 7 (64-bit)/Vista (64-bit)
    NI PXI/PCI-6541
    NI PXI/PCI-6542
    NI PXIe-6544
    NI PXIe-6545
    NI PXIe-6547
    NI PXIe-6548
    NI PXI/PCI-6551
    NI PXI/PCI-6552
    NI PXIe-6556
    NI PXI/PCI-6561
    NI PXI/PCI-6562
    1 MXI Express and MXI-4 are supported on Windows 7/Vista/XP, but MXI-3 is supported on only Windows XP.
    Note:  Device-specific information about these modules is included in the NI Digital Waveform Generator/Analyzer Help.
    NI-HSDIO 1.8.1 and later supports the following operating systems:
    • Windows XP Service Pack 2 (32-bit)
    Note:  NI-HSDIO 1.8 and later does not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-HSDIO 1.7.2 or earlier.
    NI-HSDIO 1.8.1 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows XP: 128 MB
      • Windows 7/Vista: 512 MB
    • Windows 7/Vista/XP, with all available critical updates and service packs
    Recommended System
    • RAM—
      • Windows XP: 256 MB
      • Windows 7/Vista: 1 GB
    • A screen resolution of 1024 x 768
      • LabVIEW  8.5.1, 8.6.1, 2009 SP1 (32-bit), 2009 SP1 (64-bit), 2010 SP1 (32-bit), or 2010 SP1 (64-bit)
      • LabVIEW Real-Time Module 8.5.1, 8.6.1, 2009 SP1, or 2010 SP1
        • Note: Calibration of NI 6555/6556 devices is not supported on LabVIEW Real-Time Module.
      • LabWindows™/CVI™ 8.5.1 or later
      • LabWindows/CVI Real-Time Module 9.0 or later
    • If you are running your application on an RT target, 128 MB of memory or more is required.
      • Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows 7/Vista: Users\Public\Documents\National Instruments
      • Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        NOTES:$(IVIROOTDIR32) is configured as an environment variable on the target system.
        • Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        NOTE:$(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 7 (32-bit)/Vista (32-bit)/XP
    NI-HSDIO\Drivers\niHSDIO
    NI-HSDIO Function Panel\Drivers\niHSDIO\niHSDIO.fp
    NI-HSDIO Examples\niHSDIO\Examples
    NI-HSDIO Header files\Include
    NI-HSDIO Import Library files (32-bit)\Lib
    NI-HSDIO Import Library files (64-bit)\Lib_x64
    NI-HSDIO DLL (32-bit)\Bin
    Additional File Locations for Windows 7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 7 (64-bit)/Vista (64-bit)
    NI-HSDIO DLL (64-bit)\Bin
    National Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates.
    National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications.
    The product documentation is available at Start» Programs»National Instruments»NI-HSDIO»Documentation. Visit ni.com/manuals for the latest versions of product documentation. The documentation for NI-HSDIO and NI Digital Waveform Generator/Analyzer modules includes the following items:
    • NI Digital Waveform Generator/Analyzer Getting Started Guide—Explains how to install, configure, and test a National Instruments digital waveform generator/analyzer.
    • NI Digital Waveform Generator/Analyzer Help—Contains instructions for opening, configuring, initiating signal generation, and closing the session. Also, contains information about programming and fundamentals.
    • Specifications document for your device—Contains specifications for the capabilities and valid operating conditions of your NI device.
    Note  To view the specifications, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    Uninstalling/Modifying the Instrument Driver
    Perform the following procedure to uninstall NI-HSDIO 1.8.1:
    • Click Change/Remove.
    • Select NI-HSDIO 1.8.1 from the dialog box that appears.
    As part of the NI-HSDIO installation, the following software is installed. To completely remove the NI-HSDIO installation from your system, you must also remove all of the following packages:
    • NI LabVIEW SignalExpress 2010
    • NI IVI Compliance Package 4.2
    • NI Measurement & Automation Explorer 4.7.2
    • NI-DAQmx 9.1.7
    • NI-VISA 5.0
    • NI-SPY 2.7.2
    Obsolete Properties and Attributes
    The Hardware Compare Mode property and the NIHSDIO_ATTR_HWC_HARDWARE_COMPARE_MODE attribute are obsolete. They are replaced by the Supported Data States property and the NIHSDIO_ATTR_SUPPORTED_DATA_STATES attribute.
    You can access the software and documentation known issues list online. Refer to the NI-HSDIO 1.8.1 Known Issues List at ni.com for an up-to-date list of known issues in NI-HSDIO 1.8.1.
    The following items are changes in NI–HSDIO 1.8.1 from NI–HSDIO 1.7. This table is not an exhaustive list of issues fixed in the current version of NI–HSDIO.
    327476Fixed an issue in which, in certain cases, the clock frequency or requested source may not be the same clock used when acquiring or generating data on NI 6545/6548 devices.
    246065Fixed an issue in which an NI-HSDIO kernel crash occurred when waking up from sleep mode.
    208009Fixed an issue in which a crash occurs when upgrading NI-HSDIO on Windows 7/Vista (64-bit).
    293330Fixed an issue in which the niHSDIO HWC Fetch Sample Errors (U32) VI was broken on LabVIEW (64-bit).
    245495Fixed an issue in which NI PXI High-Speed Digital I/O devices may fail to initialize when using an NI PXIe-8133 controller. This may manifest itself as an error when initializing a new device session or by not being properly identified in Measurement and Automation Explorer.
    209053Fixed an issue in which the installer needs to stop service nidevldu before upgrading binaries.
    195356Fixed an issue in which the Test Panel in Measurement & Automation Explorer (MAX) reported an unsupported device error when using the NI PXI-6561 hardware.
    193283Fixed an issue in which NI 6545/6548 devices may experience the internal underflow error -200316 when running scripted generation above 100 MHz with the following statements: repeat until, if else, and break. For more information, search ni.com/kb using the code 52RESNHB.
    181331Fixed an issue in which setting the data position of higher channels to Delay from Sample Clock Rising Edge caused lower channels to change from falling edge to rising edge.
    183454Removed support for round trip delay values from 22 to 24 because they are not properly supported in hardware.
    176994NI-HSDIO can now be deployed to Industrial Controller Real Time (NI 31xxRT) targets.
    37746Added shipping examples that demonstrate setting up a triggered acquisition and generation session on the same device using NI-TClk.
    Using Microsoft Silverlight
    Important Information
    © 2003–2011 National Instruments Corporation. All rights reserved.
    CVI, National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    GMT+8, 2025-11-19 09:04
