查看: 3080|回复: 0
[NI驱动程序] NI-HSDIO 1.4.3 Driver Win32Eng NI高速数字输入输出仪器驱动程序1.4.3(DCD Aug06)
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-18 23:54:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-HSDIO
    NI-HSDIO为使用NI PXI数字波形仪器或数字波形设备的客户提供支持。
    NI-HSDIO是与数字波形硬件进行通信的NI仪器驱动程序,用于执行高速DIO  (HSDIO)任务。该驱动程序软件包含基于IVI准则的灵活API、完整的硬件支持文档,以及配置和测试实用程序。
    Win32Eng
    1.4.3
    文件大小: 1165248752 字节 (1.09 GB)
    修改日期: 2010-04-25 03:01
    MD5: d8c0756f7da3e21215f21e1dd224f0c2(官方正确)
    SHA1: 645b696c00ae84c5edd6c255241e22e21745cb11
    SHA256: 032bf8474aa4854438dc87a6a24339d12cc49bc34babab0e8937d19e6875b85c
    CRC32: 3e0e6ece
    HSDIO1.4.3.txt (561 Bytes, 下载次数: 0, 售价: 20 圆)
    NI-HSDIO Instrument Driver Readme
    National Instruments™, NI™ ni.com™, and LabVIEW™ are trademarks of National Instruments Corporation.
    Product and company names mentioned herein are trademarks or trade names of their respective companies.
    (c) 2003—2005 National Instruments Corporation. All rights reserved.
    Version 1.4.3
    Thank you for using NI-HSDIO for Windows 2000/XP. This file contains important information regarding NI-HSDIO and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Software Files
    • Documentation
    • Uninstalling/Modifying NI-HSDIO
    • Known Issues
    NI-HSDIO 1.4.3 adds support for LabVIEW 8.2.
    NI-HSDIO 1.4 includes the following new features:
    • Support for open collector generation on the NI 654X/655X devices
    • Support for per cycle, per pin tristate for NI 655X devices
    • Addition of real-time hardware comparison of actual response data with expected resposne data. For more information on this feature, visit ni.com/info and enter the info code nsi5410
    • Support for using the waveform data type (WDT) in C application development environments
    • Addition of an "if/else/end if" instruction in the supported scripting language
    • Addition of the niHSDIO_WriteNamedWaveformFromFileHWS function and a Write from HWS File instance of the niHSDIO Write Named Waveform VI
    • Changes to the possible values of input impedance for NI 655X devices; refer to device specifications for details
    • Changes to recommended input voltage thresholds; refer to device specifications for details
    NI-HSDIO 1.3.1 included the following new features:
    • Support for multirecord acquisitions
    • Support for configurable data width for acquisition operation
    • Support for NI 656X hardware, including configuring it for use in DDR mode and selectable terminal configuration
    • Support for configuring trigger impedance
    NI-HSDIO 1.2.1 included the following new features:
    • Support for the LabVIEW Real-Time Module 7.1. For more information about using NI-HSDIO with the LabVIEW Real-Time Module, launch the NI Digital Waveform Generator Help and select Programming»Getting Started with NI-HSDIO»Using NI-HSDIO with LabVIEW»Considerations for using the LabVIEW Real-Time Module.
    • Initializing a generation or acquisition session now closes any other sessions open in the same process, starting a fresh session. If a calibration session is open, all new sessions will return an error.
    • Removed support for exporting triggers and events other than the Onboard Reference Clock (PCI devices only) to PXI trigger line 7/RTSI 7, although you can still use this channel to import triggers and events.
    NI-HSDIO supports the following NI digital waveform generator/analyzers:
    • NI PXI/PCI-6541
    • NI PXI/PCI-6542
    • NI PXI/PCI-6551
    • NI PXI/PCI-6552
    • NI PXI/PCI-6561
    • NI PXI/PCI-6562
    Device-specific information about these modules is included in the NI Digital Waveform Generator/Analyzer Help.
    Minimum System Requirements
    • Processor: Pentium 200 MHz or equivalent
    • RAM: 64 MB
    • A screen resolution of 800×600 with 256 colors (required for the NI Script Editor)
    Recommended System
    • Processor: Pentium III/Celeron 600 MHz or equivalent
    • RAM: 256 MB
      • Windows 2000
      • Windows XP
    • One of the following application development environments (ADEs):
      • LabVIEW 7.1 or later
      • LabVIEW Real-Time Module 7.1.1 or later
      • LabWindowsTM/CVITM 7.0 or later
      • LabWindowsTM/CVITM Real-Time Module
    • If you are running your application on an RT target, 64 MB of memory or more is recommended.
    Installed File Names and LocationsSoftware Files
    Most NI-HSDIO files are installed in the <;Program Files>\IVI\Drivers\niHSDIO\ directory.
    The niHSDIO folder contains the documentation, examples, license files, and FPGA files for NI-HSDIO and the associated hardware.
    The niHSDIO\Examples\ directory contains links to all of the examples.
    LabVIEW examples are installed in the \examples\instr\niHSDIO\ directory unless you select a different location during installation.
    LabWindows™/CVI™ examples are installed in the \samples\niHSDIO\ directory.
    C examples are installed in the <;Program Files>\IVI\Drivers\niHSDIO\Examples\c\ directory.
    The Script Editor is installed in the /Script Editor directory.
    Product Documentation
    The product documentation is available at Start» Programs»National Instruments»NI-HSDIO»Documentation. Visit ni.com/manuals to find the latest versions of product documentation. The documentation for NI-HSDIO and NI  Digital Waveform Generator/Analyzer modules include the following items:
    • NI Digital Waveform Generator/Analyzer Getting Started Guide–Explains how to install, configure, and test a National Instruments digital waveform generator/analyzer.
    • NI Digital Waveform Generator/Analyzer Help–Contains instructions for opening, configuring, initiating signal generation, and closing the session. Also, contains information about programming and fundamentals.
    • Specifications document for your device–Contains specifications for the capabilities and valid operating conditions of your NI device.
    Note  To view the specifications, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    Uninstalling/Modifying the Instrument Driver
    For Windows 2000/XP, complete the following steps:
    • Launch the Control Panel by selecting Start»Settings.
    • Double-click Add/Remove Programs.
    • Click Change or Modify.
    • Select NI-HSDIO 1.4.3.
    • Click Uninstall.
    As part of the NI-HSDIO installation, the following list of software was installed. To completely remove NI-HSDIO from your system, you must remove all of these packages also.
    • NI IVI Compliance Package 2.2
    • NI LabVIEW Run-Time Engine 7.0
    • NI Measurement & Automation Explorer 3.1.1
    • NI-DAQ 7.5
    • NI-VISA 3.2
    • When using NI-HSDIO 1.4 with the LabVIEW Real-Time Module, the text of some error descriptions are not returned by NI-HSDIO. Error codes that are returned are returned correctly. Refer to Knowledgebase 3OOFLT0Q for information on how to resolve this issue.
    • NI-HSDIO Express steps in NI Signal Express 1.0—The NI-HSDIO Express steps that ship with NI-HSDIO 1.3.1 were designed for use with NI SignalExpress 1.1 or later. The NI-HSDIO Express steps are compatible with NI SignalExpress 1.0 with the exception that software start triggers are not supported.
    • Review the specifications document at Start» Programs»National Instruments»NI-HSDIO»Documentation to ensure that the clock and trigger signals you connect to the instrument meet the amplitude, jitter, and duty cycle requirements of your device.
    GMT+8, 2025-11-19 09:06
