查看: 3508|回复: 0
[NI驱动程序] NI-HSDIO 1.0 Driver Win32Eng NI高速数字输入输出仪器驱动程序1.0
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-18 23:45:33 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-HSDIO
    NI-HSDIO为使用NI PXI数字波形仪器或数字波形设备的客户提供支持。
    NI-HSDIO是与数字波形硬件进行通信的NI仪器驱动程序,用于执行高速DIO  (HSDIO)任务。该驱动程序软件包含基于IVI准则的灵活API、完整的硬件支持文档,以及配置和测试实用程序。
    Win32Eng
    1.0
    文件大小: 429977480 字节 (410.06 MB)
    修改日期: 2018-03-27 04:25
    MD5: ccb2af7896488543eafe21e0fc333ac3(官方正确)
    SHA1: 4c29a12957a0e02dc70f77e46711c176ed425e40
    SHA256: fe0ce6024071042cf7dd820f49bc52d0a74d953f6daaa343665bbfea7ae1dc4b
    CRC32: 2efc1fb4
    HSDIO1.0.txt (560 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-HSDIO Instrument Driver Readme
    (c) 2003 National Instruments Corporation. All rights reserved.
    Thank you for using NI-HSDIO for Windows 2000/NT 4.0/XP/Me/98. This file contains important information regarding NI-HSDIO and is organized into the following sections:
    • System Requirements
    • Software Files
    • Documentation
    • Uninstalling NI-HSDIO
    • Supported Hardware
    • Known Issues
    Recommended System
    • Processor: Pentium III/Celeron 600 MHz or equivalent
    • RAM: 256 MB
      • Windows 2000
      • Windows NT 4.0 SP6A
      • Windows XP
      • Windows Me
      • Windows 98 SE
    • One of the following application development environments (ADEs):
      • LabVIEW 7.0
      • LabWindows/CVI 6.0 or later
    Installed File Names and LocationsSoftware Files
    The niHSDIO folder contains the documentation, examples, license files, and FPGA files for NI-HSDIO and the associated hardware.
    LabVIEW examples are installed in the \examples\instr\niHSDIO\ directory unless you select a different location during installation.
    C examples are installed in the <;Program Files>\IVI\Drivers\niHSDIO\Examples\c\ directory.
    The product documentation is available at Start» Programs»National Instruments»NI-HSDIO»Documentation. Visit ni.com/manuals to find the latest versions of product documentation. The documentation for NI-HSDIO and NI  Digital Waveform Generator/Analyzer modules include the following items:
    • NI Digital Waveform Generator/Analyzer Getting Started Guide–Explains how to install, configure, and test a National Instruments signal sources module to generate various waveforms.
    • NI Digital Waveform Generator/Analyzer Help–Contains instructions for opening, configuring, initiating signal generation, and closing the session. Also, contains information about programming and fundamentals.
    • NI PXI-6552/6551 Specifications–Contains specifications for the capabilities and valid operating conditions of the NI PXI-6551/6552.
    For Windows 2000/NT/XP/Me/9x, complete the following steps:
    • Launch the Control Panel by selecting Start»Settings.
    • Double-click Add/Remove Programs.
    • Click Change or Modify.
    • Select NI-HSDIO 1.0.
    • Click Uninstall.
    Device-specific information about these modules is included in the NI Digital Waveform Generator/Analyzer Help.
    Note  Review the specifications document at Start» Programs»National Instruments»NI-HSDIO»Documentation to ensure that the clock and trigger signals you connect to the instrument meet the amplitude, jitter, and duty cycle requirements of your device.
    GMT+8, 2025-11-19 09:04
