查看: 3047|回复: 0
[NI驱动程序] NI-FGEN 18.5.1 Driver Win32/64 Eng/Jpn NI-FGEN波形发生器仪器驱动程序18.5.1
    12 小时前
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2021-1-17 23:49:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-FGEN
    NI-FGEN为使用NI波形发生器产品的客户提供支持。
    NI-FGEN是一款NI仪器驱动程序,可实现复杂测量解决方案所需的频率扫描和跳频、波形链接和循环以及频移键控(FSK)调制。 NI-FGEN驱动程序可兼容可互换虚拟仪器(IVI),它具有一系列操作和属性,可以执行波形或信号发生器的功能,并提供交互式软件前面板和示例。
    Win32/64Eng/Jpn
    18.5.1
    文件大小: 2488211278 字节 (2.32 GB)
    修改日期: 2019-11-09 06:19
    MD5: 3e6098ffedf669620259d5252210dd05(官方正确)
    SHA1: 21461169fa483d1cd2216b1db8cbf68b8ccc4054
    SHA256: c78912044058fca8a0c279b441f70b9a078344af77e00ad53da325b62545f45e
    CRC32: 2b00986c
    FGEN18.5.1.txt (588 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-FGEN 18.5.1 Readme
    October 2019
    This file contains important information about NI-FGEN, including installation instructions, a partial list of bugs fixed, and known issues.
    Upgrading Firmware
    NI-FGEN is an NI instrument driver that enables you to implement frequency sweeping and hopping, waveform linking and looping, and frequency shift keying (FSK) modulation for complex measurement solutions. NI-FGEN is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the waveform or signal generator and includes an interactive soft front panel and examples.
    NI-FGEN 18.5.1 has the following requirements:
    • Windows 10/8.1/7 with all available critical updates and service packs
    NI-FGEN 18.5.1 supports the following operating systems:
    Note  In 2016 NI-FGEN dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-FGEN 18.5.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-FGEN 18.5.1 to an unsupported OS. Additionally, after installing NI-FGEN 18.5.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2016, refer to Why Does my NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?.
    NI-FGEN 18.5.1 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-FGEN
    LabVIEW2015, 2016, 2017, 2018
    LabVIEW Real-Time Module32015, 2016, 2017, 2018
    LabVIEW NXG3.0
    LabWindows™/CVI™2013 and later
    LabWindows™/CVI™ Real-Time Module32013 and later
    3No support for PXI/PCI-5401/5411/5431 or PXIe-5413/5423/5433 waveform generators.
    If you are using the NI-FGEN .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-FGEN .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-FGEN installer to install the the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
    • Install an ADE, such as LabVIEW or LabWindows™/CVI™.
    • Visit ni.com/downloads/drivers and search for NI-FGEN.
    • Select NI-FGEN 18.5.1 from the Version drop-down list and then click Download.
    • Run the executable (.exe) file.
    • Follow the instructions in the installation prompts. You may see access and security prompts during installation. Accept the prompts to complete the installation.
    • When the installer completes, select Restart in the dialog box that prompts you to restart, shut down, or restart later.
    Note
    Installing NI-FGEN 18.5.1 for LabVIEW NXG
    Upgrading Firmware
    The PXIe-5442, PXIe-5450, and PXIe-5451 have upgradeable device firmware. It is highly encouraged and may be required that you upgrade the firmware on these devices; newer firmware contains new features and important bug fixes. To update the firmware, run the Firmware Updater application for your device (54xxFirmwareUpdater_X.Y.Z.exe, where 54xx is the name of the device and X.Y.Z is the firmware version) that is installed in the Program Files\IVI Foundation\IVI\Drivers\niFgen\ directory or the Program Files (x86)\IVI Foundation\IVI\Drivers\niFgen\ directory. This application upgrades your firmware to the latest available version that works with this driver. After the application runs, you are required to power down your computer and PXI Express chassis to complete the firmware update.
    The following list details the hardware models supported in NI-FGEN 18.5.1.
    [tr][/tr]
    Hardware ProductSupported Under Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit)1Supported Under Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit)1
    NI-DAQmx-Based Waveform Generators
    PXI/PCI-5401
    X2
    X2
    PXI/PCI-5402
    PXI-5404
    √3
    √3
    PXI/PCI-5406
    PXI/PCI-5411
    X2
    X2
    PXI/PCI-5412
    PXI/PCI-5421
    PXI-5422
    PXI/PCI-5431
    X2
    X2
    PXIe–5413
    PXIe–5423
    PXIe–5433
    PXI-5441
    PXIe–5442
    PXIe–5450
    PXIe–5451
    NI 5413, 5423, and 5433 Waveform Generators
    PXIe–5413
    PXIe–5423
    PXIe–5433
    1 MXI Express and MXI-4 are supported on Windows 10/8.1/7.
    2Simulating these devices is also not supported on Windows 8.1/7, using either NI-FGEN or the FGEN Soft Front Panel. Simulating a device that is not supported on your operating system results in indeterminate behavior.
    3 Windows 8.1/7 support for the PXI-5404 does not include support for external calibration. Perform external calibration for the PXI-5404 on Windows XP operating systems.
    You can access the software and documentation known issues list online. Visit ni.com/info and enter the Info Code exeiuw for an up-to-date list of known issues in NI-FGEN 18.5.1.
    The following items are the IDs and titles of a subset of issues fixed in NI-FGEN. This is not an exhaustive list of issues fixed in the current version of NI-FGEN. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-FGEN 18.5.1 from NI-FGEN 18.5.
    228037Fixed an issue in which the PXI-5404 fails to initialize or—in rare circumstances—generates inaccurate output signal characteristics with computers with high CPU clock rates and/or with NI-ORB 18.5 or later installed. Visit ni.com/r/5404-patch for more information.
    Refer to the NI Signal Generators Help, accessible from Start»All Programs»National Instruments»NI-FGEN»NI-FGEN Documentation, for information about NI-FGEN.
    You can access all the installed NI-FGEN examples for LabVIEW, LabWindows/CVI, C, and .NET at Start»All Programs»National Instruments»NI-FGEN»NI-FGEN Examples and online at ni.com/examples. Examples also are available online that demonstrate integrating NI waveform generators with NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-FGEN are located in the LabVIEW XXXX\examples\instr\niFgen directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–FGEN or by directory structure at instr»niFgen.
    • Click the Search tab to search all installed examples by keyword. For example, search for "FGEN" to locate all waveform generator examples.
    The following sections detail considerations for using LabVIEW NXG with NI-FGEN.
    LabVIEW NXG Hardware Support[tr][/tr]
    Hardware ProductSupported Under Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit)1
    PXI/PCI-5402
    PXI-5404
    √2
    PXI/PCI-5406
    PXI/PCI-5412
    PXI/PCI-5421
    PXI-5422
    PXI-5441
    PXIe–5442
    PXIe–5450
    PXIe–5451
    PXIe–5413
    PXIe–5423
    PXIe–5433
    2 Windows 8.1/7 support for the PXI-5404 does not include support for external calibration. Perform external calibration for the PXI-5404 on Windows XP operating systems.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI-FGEN no longer installs IVI Compliance Package. NI-FGEN supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    © 2007–2019 National Instruments. All rights reserved.
    374945R-01
    GMT+8, 2025-12-12 20:44
