查看: 2958|回复: 0
[NI驱动程序] NI-FGEN 16.0.1 Driver Win32/64 Eng/Jpn NI-FGEN波形发生器仪器驱动程序16.0.1
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2021-1-17 23:38:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-FGEN
    NI-FGEN为使用NI波形发生器产品的客户提供支持。
    NI-FGEN是一款NI仪器驱动程序,可实现复杂测量解决方案所需的频率扫描和跳频、波形链接和循环以及频移键控(FSK)调制。 NI-FGEN驱动程序可兼容可互换虚拟仪器(IVI),它具有一系列操作和属性,可以执行波形或信号发生器的功能,并提供交互式软件前面板和示例。
    Win32/64Eng/Jpn
    16.0.1
    文件大小: 1924978033 字节 (1.79 GB)
    修改日期: 2017-01-19 01:55
    MD5: 4f9b55c0daf943636c578dabaff9ce68(官方正确)
    SHA1: aec9444d1009bd14f5d0a3d4f53970df94c12680
    SHA256: 717561227272c89b12ece0bf7bc8c024d679c771a1bade57907ffcde044f0387
    CRC32: 1e4f017f
    FGEN16.0.1.txt (594 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-FGEN 16.0.1 Readme
    January 2017
    Thank you for using NI-FGEN. This file contains important information about NI-FGEN and is organized into the following sections:
    Accessing VIs and Functions
    NI Software Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    Driver Version Naming Changes
    Uninstalling/Modifying NI-FGEN
    Upgrading Firmware
    NI-FGEN 16.0 adds support for LabVIEW 2016 (32- and 64-bit).
    NI-FGEN 15.0 adds support for LabVIEW 2015 (32- and 64-bit).
    NI-FGEN 14.0 adds support for LabVIEW 2014 (32- and 64-bit).
    NI-FGEN 2.9.4 includes the following new features:
    • Enhanced support for filter group delay compensation for NI PXIe-5442 Rev D or higher.
    • Support for allowing I/Q rates up to 400 MS/s when using onboard signal processing mode on the NI PXIe-5450/5451.
    The following table shows which hardware products are supported under particular operating systems.
    Hardware ProductSupported Under Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit)1Supported Under Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit)
    NI PXI/PCI-5401 Function Generator
    X2
    NI PXI/PCI-5402 Function Generator
    NI PXI-5404 Frequency Generator
    √3
    NI PXI/PCI-5406 Function Generator
    NI PXI/PCI-5411 Arbitrary Waveform Generator
    X2
    NI PXI/PCI-5412 Arbitrary Waveform Generator
    NI PXI/PCI-5421 Arbitrary Waveform Generator
    NI PXI-5422 Arbitrary Waveform Generator
    NI PXI/PCI-5431 Video Signal Generator
    X2
    NI PXI-5441 Arbitrary Waveform Generator with Onboard Signal Processing
    NI PXIe–5442 Arbitrary Waveform Generator with Onboard Signal Processing
    NI PXIe–5450 Dual-Channel I/Q Generator with Onboard Signal Processing
    NI PXIe–5451 Dual-Channel Arbitrary Waveform Generator with Onboard Signal Processing
    1 MXI Express and MXI-4 are supported on Windows 10/8.1/7.
    2Simulating these devices is also not supported on Windows 8.1/7, using either the NI-FGEN or the NI-FGEN Soft Front Panel. Simulating a device that is not supported on your operating system results in indeterminate behavior.
    3 Windows 8.1/7 support for the NI 5404 does not include support for external calibration. Perform external calibration for the NI 5404 on Windows XP operating systems.
    Device-specific information about these signal generators is included in the NI Signal Generators Help.
    NI-FGEN 16.0.1 and later supports the following operating systems:
    2 NI software is signed with an SHA-256 certificate. Windows 7 SP1 and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Note   NI-FGEN 16.0.1 and later does not support Windows Server non-R2 editions.
    NI-FGEN 16.0.1 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    • LabWindows™/CVI™ Real-Time Module
    Minimum Requirements
    • Windows 10/8.1/7 with all available critical updates and service packs
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-FGEN. To add support for ADEs installed after installing NI-FGEN, modify your NI-FGEN installation or launch the NI-FGEN installer again.
    • NI LabVIEW 2013 SP1, 2014 SP1, 2015 SP1, or 2016
    • LabVIEW Real-Time Module 2013 SP1, 2014 SP1, 2015 SP1, or 2016 (no support for NI PXI/PCI-5401/5411/5431 devices)
    • LabWindows/CVI 2013 or later
    • LabWindows/CVI Real-Time Module 2013 or later (no support for NI PXI/PCI-5401/5411/5431 devices)
    • Measurement Studio 6.0 or later
        • (32-bit) Program Files\IVI\
    ItemInstalled Location
    NI-FGEN\Drivers\niFgen
    NI-FGEN Function Panel\Drivers\niFgen\niFgen.fp
    NI-FGEN Examples\NI-FGEN\Examples
    NI-FGEN Header files\Include
    NI-FGEN Import Library files (32-bit)\Lib
    NI-FGEN Import Library files (64-bit)\Lib_x64
    NI-FGEN DLL (32-bit)\Bin
    Additional File Locations for 64-bit operating systems
    NI-FGEN DLL (64-bit)\Bin
    Select Start»All Programs»National Instruments»NI-FGEN»FGEN Soft Front Panel to launch the NI-FGEN Soft Front Panel.
    Documentation for NI-FGEN is located at Start»All Programs»National Instruments»NI-FGEN»Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI Signal Generators HelpHTML/Windows HelpContains primary help content for NI-FGEN products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-FGEN
    • Hardware device information
    • A complete reference for all NI-FGEN programming functions and VIs
    NI-FGEN ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Introduction to niFgenHTMLContains information about driver documentation, examples, connecting to your instrument, configuring instrument settings, and known issues.
    NI-FGEN IVI Compliance DocumentTXTContains information about IVI compliance.
    To use the .NET API, you must install the the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    NI-FGEN palette VIs are available from the Functions»Measurement I/O»NI-FGEN palette.
    NI-FGEN functions are available in LabWindows/CVI from the Instrument menu. To load the NI-FGEN function panel (.fp), select Instrument»Load, and navigate to \Drivers\niFgen\niFgen.fp.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI–FGEN examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–FGEN and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–FGEN or by directory structure at instr»niFgen.
    • Click the Search tab to search all installed examples by keyword. For example, search for "FGEN" to locate all NI signal generator examples.
    You can also access all the installed NI-FGEN examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-FGEN»NI-FGEN Examples.
    Examples also are available online that demonstrate integrating NI signal generators with NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    NI-FGEN 16.0 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-FGEN dropped support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-FGEN 16.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-FGEN 16.0 or later to an unsupported OS. Additionally, after installing NI-FGEN 16.0 or later, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-FGEN versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-FGEN 15.0 is the version released with LabVIEW 2015. The last version released under the old numbering scheme is NI-FGEN 2.9.4. The first version released under the new numbering scheme is NI-FGEN 14.0.
    • Select NI-FGEN 16.0.1 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI-FGEN 16.0.1 installation, the following software is installed. To completely remove the NI-FGEN 16.0.1 installation from your system, you must also remove all of the following packages:
    • NI-FGEN Runtime 16.0.1
    • NI Hierarchical Waveform Storage 16.0
    • NI IVI Compliance Package 16.0
    • NI Measurement & Automation Explorer 16.0
    • NI-DAQmx 15.0
    • NI-DAQmx MAX Configuration Support 15.0
    • NI-DAQmx Runtime 16.0 with Configuration Support
    • NI-VISA 16.0
    • NI I/O Trace 15.0
    Upgrading Firmware
    The NI PXIe-5442, NI PXIe-5450, and NI PXIe-5451 have upgradeable device firmware. It is highly encouraged and may be required that you upgrade the firmware on these devices; newer firmware contains new features and important bug fixes. To update the firmware, run the Firmware Updater application for your device (54xxFirmwareUpdater_X.Y.Z.exe, where 54xx is the name of the device and X.Y.Z is the firmware version) that is installed in the Program Files\IVI Foundation\IVI\Drivers\niFgen\ directory or the Program Files (x86)\IVI Foundation\IVI\Drivers\niFgen\ directory. This application upgrades your firmware to the latest available version that works with this driver. After the application runs, you are required to power down your computer and PXI Express chassis to complete the firmware update.
    You can access the software and documentation known issues list online. Refer to the NI-FGEN 16.0.1 Known Issues at ni.com/info and enter the Info Code exb3in for an up-to-date list of known issues in NI-FGEN 16.0.1.
    The following items are the IDs and titles of a subset of issues fixed in NI-FGEN. This is not an exhaustive list of issues fixed in the current version of NI-FGEN. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-FGEN 16.0.1 from NI-FGEN 16.0.
    585040Fixed an issue in which a timeout occurred in systems with a high number of PXI modules.
    The following items are changes in NI-FGEN 2.9.1 from NI-FGEN 2.9.
    317520Fixed an issue in which an error occurred when trying to build an installer in LabVIEW for an NI-FGEN 2.9 executable.
    The following items are changes in NI-FGEN 2.9 from NI-FGEN 2.8.1.
    242645Fixed an issue in which NI-FGEN does not report the correct error when LabVIEW FPGA 2010 is installed. You must install LabVIEW FPGA 2010 SP1 for this bug fix.
    240183Fixed an issue in which using dynamic FPGA interfaces in the LabVIEW FPGA Module were not supported when using peer-to-peer streaming. You must install NI-RIO 3.5.1 for this bug fix.
    280577Fixed an issue in which NI-FGEN returns an incorrect error description when an invalid session handle is passed into NI-FGEN VIs.
    314922Fixed an issue in which NI-FGEN returns an incorrect maximum waveform size after you call the niFgen Clear Arbitrary Memory VI on NI PXIe-5450 and NI PXIe-5451.
    313189Fixed an issue in which LabVIEW could crash when reading the Gain DAC Value property.
    N/AFixed an issue in which NI-FGEN could return an unrecoverable error when transitioning to the Committed state by calling the niFgen Commit VI, the niFgen_Commit function, or calling a create or write waveform VI or function. You must install NI-DAQmx 9.0 or later for this bug fix.
    © 2007–2017 National Instruments. All rights reserved.
    374945C-01
    GMT+8, 2025-12-12 19:29
