查看: 2990|回复: 0
[NI驱动程序] NI-FGEN 2.9.3 Driver Win32/64 Eng/Jpn NI-FGEN波形发生器仪器驱动程序2.9.3
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2021-1-17 23:29:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-FGEN
    NI-FGEN为使用NI波形发生器产品的客户提供支持。
    NI-FGEN是一款NI仪器驱动程序,可实现复杂测量解决方案所需的频率扫描和跳频、波形链接和循环以及频移键控(FSK)调制。 NI-FGEN驱动程序可兼容可互换虚拟仪器(IVI),它具有一系列操作和属性,可以执行波形或信号发生器的功能,并提供交互式软件前面板和示例。
    Win32/64Eng/Jpn
    2.9.3
    文件大小: 1925990658 字节 (1.79 GB)
    修改日期: 2013-08-16 05:01
    MD5: fa200bf2068cafa10e0921addd458cfc(官方正确)
    SHA1: 4a5dc42afa18fd8592eaed34686760e28a915814
    SHA256: 4eeb68efdda95bbd819a0b5770e20bea8f15e35158959fa63745fd0229c74c7e
    CRC32: 1e4c93c3
    FGEN2.9.3.txt (586 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-FGEN Instrument Driver Readme
    August 2013
    Version 2.9.3
    Thank you for using NI-FGEN for Windows 8/7/Vista/XP. This file contains important information about NI-FGEN and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
      • Documentation
      • The FGEN Soft Front Panel
    • Updates and Notifications
    • Uninstalling/Modifying NI-FGEN
    • Upgrading Firmware
    • Known Issues
    • Bug Fixes
    • API Changes by Release
    • How to Use NI Software with Microsoft Windows 8
    • NI-FGEN Drops Support for Microsoft Windows XP and Windows Server 2003 in 2016
    • Important Information
    NI-FGEN 2.9.3 includes the following new features:
    • Support for LabVIEW 2013 (32-bit) and LabVIEW 2013 (64-bit).
    • Support removed for LabVIEW 2009.
    NI-FGEN 2.9.1 includes the following new features:
    • Support for LabVIEW 2012 (32-bit) and LabVIEW 2012 (64-bit).
    • Support removed for LabVIEW 8.6.1.
    NI-FGEN 2.9 includes the following new features:
    • Support for streaming write timeout.
    • Improved I/Q rate reconfiguration time for the NI PXIe-5450 and NI PXIe-5451.
    • Support for including NI-FGEN run-time in custom installers built using National Instruments application development environments (ADEs). This installer contains instrument driver run-time components required to deploy applications using NI signal generators.
      Notes:
      • The run-time installer does not contain support for interactively configuring or testing hardware using Measurement & Automation Explorer (MAX), NI SignalExpress, or the FGEN Soft Front Panel.
      • The run-time installer does not support upgrading from NI-FGEN 2.8.x or earlier, or NI-DAQmx 8.9.x or earlier. You must uninstall these products prior to installing the NI-FGEN run-time installer.
      • The run-time installer does not support the NI 5401, NI 5411, or NI 5431.
    NI-FGEN 2.8.1 includes the following new features:
    • Support for LabVIEW 2011 (32-bit) and LabVIEW 2011 (64-bit).
    • Support removed for LabVIEW 8.5.1.
    NI-FGEN 2.8 includes the following new features:
    • Support for peer-to-peer streaming with the NI PXIe-5450 (module revision C only) and NI PXIe-5451.
    • New firmware for the NI PXIe-5450 and NI PXIe-5451. This firmware upgrade is required for all NI PXIe-5450 and NI PXIe-5451 devices. Refer to Upgrading Firmware for more information about this new firmware.
    • Support to reset writeable attributes to driver default values. In C, call the niFgen_ResetAttribute function. In LabVIEW, right-click the niFgen Property Node, and select Change To»Default Value.
    • Support for stream n script instruction.
    NI-FGEN 2.7.4 includes the following new features:
    • Support for LabVIEW 2010 (32-bit) and LabVIEW 2010 (64-bit).
    • Fixed an issue in which a custom installer built on a 32-bit OS using LabVIEW, LabWindows™/CVI™, or NI TestStand does not deploy NI-FGEN or its dependent user applications on a 64-bit OS (ID 228650).
    • Support removed for LabVIEW 8.2.1.
    NI-FGEN 2.7.2 includes the following new feature:
    • Fixed a fatal issue when upgrading NI-FGEN 2.7 when using Windows 7 (64-bit) and Windows Server 2008 R2.
    NI-FGEN 2.7 includes the following new features:
    • Support for the NI PXIe-5451 400 MS/s, 16-bit dual-channel arbitrary waveform generator with onboard signal processing (OSP).
    • Support for LabVIEW 2009 (64-bit).
    • Support for 64-bit user mode.
    • Support for new NI PXIe-5442 and NI PXIe-5450 module revisions.
    • Support for Standard Function output mode on the NI PXIe-5450 module revision C.
    • New firmware for the NI PXIe-5442 and NI PXIe-5450. Refer to Upgrading Firmware for more information about this new firmware.
    • Support for wait with marker and break script instructions.
    • New VIs, properties, functions, and attributes.
    The following table shows which hardware products are supported in this release under particular operating systems.
    Hardware ProductSupported Under
    Windows 8/7/Vista1
    Supported Under
    Windows XP1
    NI PXI/PCI-5401 Function Generator
    X2
    NI PXI/PCI-5402 Function Generator
    NI PXI-5404 Frequency Generator
    √3
    NI PXI/PCI-5406 Function Generator
    NI PXI/PCI-5411 Arbitrary Waveform Generator
    X2
    NI PXI/PCI-5412 Arbitrary Waveform Generator
    NI PXI/PCI-5421 Arbitrary Waveform Generator
    NI PXI-5422 Arbitrary Waveform Generator
    NI PXI/PCI-5431 Video Signal Generator
    X2
    NI PXI-5441 Arbitrary Waveform Generator with Onboard Signal Processing
    NI PXIe–5442 Arbitrary Waveform Generator with Onboard Signal Processing
    NI PXIe–5450 Dual-Channel I/Q Generator with Onboard Signal Processing
    NI PXIe–5451 Dual-Channel Arbitrary Waveform Generator with Onboard Signal Processing
    1 MXI Express and MXI-4 are supported on Windows 8/7/Vista/XP, but MXI-3 is supported on only Windows XP.
    2Simulating these devices is also not supported on Windows 8/7/Vista, using either the NI-FGEN or the FGEN Soft Front Panel. Simulating a device that is not supported on your operating system results in indeterminate behavior.
    3 Windows 8/7/Vista support for the NI 5404 does not include support for external calibration. Perform external calibration for the NI 5404 on Windows XP operating systems.
    Device-specific information about these signal generators is included in the NI Signal Generators Help.
    NI-FGEN 2.9.3 supports the following operating systems:
    • Windows XP Service Pack 2 (32-bit)
    Note  NI-FGEN 2.9.3 does not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-FGEN 2.7.3 or earlier.
    NI-FGEN 2.9.3 supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows 8/7/Vista: 512 MB
      • Windows XP Service Pack 3 (SP3): 128 MB
    • Windows 8/7/Vista/XP SP3, with all available critical updates and service packs
    Recommended System
    • RAM—
      • Windows 8/7/Vista: 1 GB
      • Windows XP SP3: 256 MB
    • NI LabVIEW 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 SP1 (32-bit), 2011 SP1 (64-bit), 2012 SP1 (32-bit), 2012 SP1 (64-bit), 2013 (32-bit), or 2013 (64-bit)
    • NI LabVIEW Real-Time Module 2010 SP1, 2011 SP1, 2012 SP1, or 2013 (no support for NI PXI/PCI-5401/5411/5431 devices)
    • LabWindows/CVI 9.0.1 or later
    • LabWindows/CVI Real-Time Module 2009 or later (no support for NI PXI/PCI-5401/5411/5431 devices)
    • Measurement Studio 6.0 or later
    • If you are running your application on an RT target, 128 MB of memory or more is required.
      • Windows 8/7/Vista: Users\Public\Documents\National Instruments
      • Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        NOTES:$(IVIROOTDIR32) is configured as an environment variable on the target system.
        If you upgraded an installation of IVI, your files may be in the following location:
        • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        NOTE:$(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP
    NI-FGEN\Drivers\niFgen
    NI-FGEN Function Panel\Drivers\niFgen\nifgen.fp
    NI-FGEN Examples\NI-FGEN\Examples
    NI-FGEN Header files\Include
    NI-FGEN Import Library files\Lib
    NI-FGEN DLL\Bin
    Additional File Locations for Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8/7 (64-bit)/Vista (64-bit)
    NI-FGEN Import Library files (64-bit)\Lib_x64
    NI-FGEN DLL (64-bit)\Bin
    Documentation is available at Start»All Programs»National Instruments»NI-FGEN»Documentation. The documentation set is composed of the following documents:
    • NI Signal Generators Getting Started Guide
    • NI Signal Generators Help
    • Specifications
    • Calibration procedures
    Note  To view many of these documents, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    Visit ni.com/manuals to find the latest versions of product documentation.
    The FGEN Soft Front Panel (SFP)
    The FGEN Soft Front Panel (SFP) is accessible from Start»All Programs»National Instruments»NI-FGEN.
    You can find example waveform and function files in the Program Files\IVI Foundation\IVI\Drivers\niFgen\Examples\Waveforms\ directory and in the Program Files (x86)\IVI Foundation\IVI\Drivers\niFgen\Examples\Waveforms\ directory on the 64-bit version of Windows 8/7/Vista. Refer to Waveform description.txt in the Waveforms folder for an explanation of the provided waveforms.
    National Instruments posts information about critical updates and security notifications on ni.com. Visit ni.com/info, and enter the info code updates to access this information.
    Perform the following procedure to uninstall NI-FGEN 2.9.3:
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI-FGEN 2.9.3 from the dialog box that appears.
    For Windows 8, complete the following steps:
    • Right-click the Start screen.
    • Select All apps and launch the Control Panel.
    • Click the Uninstall button.
    As part of the NI-FGEN 2.9.3 installation, the following list of software was installed. To completely remove NI-FGEN 2.9.3 from your system, you must remove all of these packages in addition to NI-FGEN.
    • NI-FGEN Run-Time 2.9.3
    • NI Hierarchical Waveform Storage 1.5.1
    • NI IVI Compliance Package 4.4
    • NI Measurement & Automation Explorer 5.4
    • Traditional NI-DAQ 7.4.4 (Windows XP only)
    • NI-DAQmx 9.1.7
    • NI-VISA Run-Time 5.0
    • NI I/O Trace 3.0
    Upgrading Firmware
    The NI PXIe-5442, NI PXIe-5450, and NI PXIe-5451 have upgradeable device firmware. It is highly encouraged and may be required that you upgrade the firmware on these devices; newer firmware contains new features and important bug fixes. To update the firmware, run the Firmware Updater application for your device (54xxFirmwareUpdater_X.Y.Z.exe, where 54xx is the name of the device and X.Y.Z is the firmware version) that is installed in the Program Files\IVI Foundation\IVI\Drivers\niFgen\ directory or the Program Files (x86)\IVI Foundation\IVI\Drivers\niFgen\ directory. This application upgrades your firmware to the latest available version that works with this driver. After the application runs, you are required to power down your computer and PXI Express chassis to complete the firmware update.
    You can access the software and documentation known issues list online. Refer to the NI-FGEN 2.9 Known Issues List at ni.com for an up-to-date list of known issues in NI-FGEN 2.9.3.
    The following items are fixed in NI-FGEN 2.9.1 from NI-FGEN 2.9
    Bug IDFixed Issue
    317520Fixed an issue in which an error occured when trying to build an installer in LabVIEW for an NI-FGEN 2.9 executable.
    The following items are fixed in NI-FGEN 2.9 from NI-FGEN 2.8.1
    Bug IDFixed Issue
    242645Fixed an issue in which NI-FGEN does not report the correct error when LabVIEW FPGA 2010 is installed. You must install LabVIEW FPGA 2010 SP1 for this bug fix.
    240183Fixed an issue in which using dynamic FPGA interfaces in the LabVIEW FPGA Module were not supported when using peer-to-peer streaming. You must install NI-RIO 3.5.1 for this bug fix.
    280577Fixed an issue in which NI-FGEN returns an incorrect error description when an invalid session handle is passed into NI-FGEN VIs.
    314922Fixed an issue in which NI-FGEN returns an incorrect maximum waveform size after you call the niFgen Clear Arbitrary Memory VI on NI PXIe-5450 and NI PXIe-5451.
    313189Fixed an issue in which LabVIEW could crash when reading the Gain DAC Value property.
    N/AFixed an issue in which NI-FGEN could return an unrecoverable error when transitioning to the Committed state by calling the niFgen Commit VI, the niFgen_Commit function, or calling a create or write waveform VI or function. You must install NI-DAQmx 9.0 or later for this bug fix.
    The following items are fixed in NI-FGEN 2.8 from NI-FGEN 2.7.4
    Bug IDFixed Issue
    241656Fixed firmware to synchronize power supplies for improved phase noise performance.
    199899Fixed an issue in which calling calibration utility functions in a normal NI-FGEN session affected output by disabling self-calibration constants.
    182502Fixed an issue in which running test panels for the NI PXIe-5450 and NI PXIe-5451 using the LabVIEW Real-Time Module did not write waveform data. This issue caused the output signal to be random.
    183093Fixed an issue in which waking from sleep mode could crash the operating system in some configurations, especially if the video, network, or other drivers were out of date.
    187791An issue was fixed in which LabVIEW 2009 (64-bit) could crash if you created more than one session using the same resource name. You must install LabVIEW 2009 SP1 (64-bit) for this bug fix.
    The following items are fixed in NI-FGEN 2.7.4 from NI-FGEN 2.7.3
    Bug IDFixed Issue
    228650Fixed an issue in which a custom installer built on a 32-bit OS using LabVIEW, LabWindows/CVI, or NI TestStand does not deploy NI-FGEN or its dependent user applications on a 64-bit OS.
    The following items are fixed in NI-FGEN 2.7.3 from NI-FGEN 2.7.2
    Bug IDFixed Issue
    229602Fixed an issue with clock configuration that can cause memory corruption or blue screen with certain NI PXIe-5450 devices.
    212209Fixed an incorrect calibration DAC setting that could cause self-calibration to fail on the NI PXIe-5451.
    The following items are fixed in NI-FGEN 2.7.2 from NI-FGEN 2.7
    Bug IDFixed Issue
    209051Fixed an issue in which the installer did not stop service nidevldu before upgrading binaries.
    The following items are fixed in NI-FGEN 2.7 from NI-FGEN 2.6.3
    Bug IDFixed Issue
    179935Fixed a streaming issue on the NI PXIe-5442/5450. Streaming with certain combinations of chassis and controllers caused the device to return an invalid thermal error and detach itself from the system. You must upgrade your firmware for this solution.
    157714Fixed a memory leak that occurred when a session was opened and closed dynamically using VI server on LabVIEW Real-Time targets.
    118345Toggle markers are now allowed below 200 MS/s sample rates on the NI PXIe-5450.
    39796An error is now returned when PXI_STAR is used as a trigger source for the NI PXIe-5442. This configuration is not supported.
    118500The NI PXIe-5450 now supports the Oscillator Phase DAC property and NIFGEN_ATTR_OSCILLATOR_PHASE_DAC_VALUE attribute for external Sample clocks.
    Changes in NI-FGEN 2.9 from NI-FGEN 2.8.1
    PropertyniFgen Streaming Write Timeout
    AttributeNIFGEN_ATTR_STREAMING_WRITE_TIMEOUT
    Changes in NI-FGEN 2.8 from NI-FGEN 2.7.4
    VIsniFgen Get Stream Endpoint Handle
    niFgen Manual Enable P2P Stream
    niFgen Configure P2P Endpoint Fullness Start Trigger
    niFgen Write P2P Endpoint I16
    FunctionsViStatus _VI_FUNC niFgen_GetStreamEndpointHandle (ViSession vi, ViConstString streamEndpoint, ViInt32* readerHandle);
    ViStatus _VI_FUNC niFgen_ManualEnableP2PStream (ViSession vi, ViConstString endpointName);
    ViStatus _VI_FUNC niFgen_ConfigureP2PEndpointFullnessStartTrigger (ViSession vi, ViInt32 p2pEndpointFullnessLevel);
    ViStatus _VI_FUNC niFgen_WriteP2PEndpointI16 (ViSession vi, ViConstString endpointName, ViInt32 numberOfSamples, ViInt16 endpointData[]);
    ViStatus _VI_FUNC niFgen_ResetAttribute (ViSession vi, ViConstString channelName, ViAttr attributeId);
    ViStatus _VI_FUNC niFgen_SetAttributeViInt64 (ViSession vi, ViConstString channelName, ViAttr attributeId, ViInt64 value);
    ViStatus _VI_FUNC niFgen_CheckAttributeViInt64 (ViSession vi, ViConstString channelName, ViAttr attributeId, ViInt64 value);
    ViStatus _VI_FUNC niFgen_GetAttributeViInt64 (ViSession vi, ViConstString channelName, ViAttr attributeId, ViInt64 *value);
    PropertiesP2P Enabled
    Destination Channels
    Endpoint Size
    Space Available in Endpoint
    Most Space Available in Endpoint
    Endpoint Count
    Data Transfer Permission Interval
    Data Transfer Permission Initial Credits
    Manual Configuration Enabled
    Data Transfer Permission Address
    Data Transfer Permission Address Type
    Endpoint Window Address
    Endpoint Window Address Type
    Endpoint Window Size
    Done Notification Address
    Done Notification Address Type
    Done Notification Value
    P2P Endpoint Fullness Start Trigger Level
    AttributesNIFGEN_ATTR_P2P_ENABLED
    NIFGEN_ATTR_P2P_DESTINATION_CHANNELS
    NIFGEN_ATTR_P2P_ENDPOINT_SIZE
    NIFGEN_ATTR_P2P_SPACE_AVAILABLE_IN_ENDPOINT
    NIFGEN_ATTR_P2P_MOST_SPACE_AVAILABLE_IN_ENDPOINT
    NIFGEN_ATTR_P2P_ENDPOINT_COUNT
    NIFGEN_ATTR_P2P_DATA_TRANSFER_PERMISSION_INTERVAL
    NIFGEN_ATTR_P2P_DATA_TRANSFER_PERMISSION_INITIAL_CREDITS
    NIFGEN_ATTR_P2P_MANUAL_CONFIGURATION_ENABLED
    NIFGEN_ATTR_P2P_DATA_TRANSFER_PERMISSION_ADDRESS
    NIFGEN_ATTR_P2P_DATA_TRANSFER_PERMISSION_ADDRESS_TYPE
    NIFGEN_ATTR_P2P_ENDPOINT_WINDOW_ADDRESS
    NIFGEN_ATTR_P2P_ENDPOINT_WINDOW_ADDRESS_TYPE
    NIFGEN_ATTR_P2P_ENDPOINT_WINDOW_SIZE
    NIFGEN_ATTR_P2P_DONE_NOTIFICATION_ADDRESS
    NIFGEN_ATTR_P2P_DONE_NOTIFICATION_ADDRESS_TYPE
    NIFGEN_ATTR_P2P_DONE_NOTIFICATION_VALUE
    NIFGEN_ATTR_P2P_ENDPOINT_FULLNESS_START_TRIGGER_LEVEL
    Changes in NI-FGEN 2.7 from NI-FGEN 2.6.3
    VIniFgen Create Waveform (Complex WDT)
    FunctionViStatus _VI_FUNC niFgen_CalAdjustADC (ViSession vi, ViConstString Channel_Name, ViInt32 Configuration, ViReal64 Voltages_Measured_Externally[], ViReal64 Voltages_Measured_With_CalADC[]);
    PropertiesModule Revision
    Compensate for Filter Group Delay
    AttributesNIFGEN_ATTR_MODULE_REVISION
    NIFGEN_ATTR_OSP_COMPENSATE_FOR_FILTER_GROUP_DELAY
    Made the following function obsolete and moved it to niFgenObsolete.h:
    • niFgen_CalAdjustCalADC
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI-FGEN Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-FGEN will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-FGEN that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2007–2013 National Instruments. All rights reserved.
    GMT+8, 2025-12-12 19:29
