查看: 2084|回复: 0
[NI驱动程序] NI-FGEN 2.8.1 Driver Win32/64 Eng/Jpn NI-FGEN波形发生器仪器驱动程序2.8.1
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2021-1-17 23:25:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-FGEN
    NI-FGEN为使用NI波形发生器产品的客户提供支持。
    NI-FGEN是一款NI仪器驱动程序,可实现复杂测量解决方案所需的频率扫描和跳频、波形链接和循环以及频移键控(FSK)调制。 NI-FGEN驱动程序可兼容可互换虚拟仪器(IVI),它具有一系列操作和属性,可以执行波形或信号发生器的功能,并提供交互式软件前面板和示例。
    Win32/64Eng/Jpn
    2.8.1
    文件大小: 1756548497 字节 (1.64 GB)
    修改日期: 2011-09-20 05:03
    MD5: 5c404c5b189c44d090251d112eaa137a(官方正确)
    SHA1: b12e7983e95c625e1d4350a17bf63792b333acef
    SHA256: 5d30952145796cbc5dd43b941809b4fa80815a35e24116be1b88e5046d5f1b40
    CRC32: e7c32320
    FGEN2.8.1.txt (586 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-FGEN Instrument Driver Readme
    Version 2.8.1
    Thank you for using NI-FGEN for Windows 7/Vista/XP. This file contains important information regarding NI-FGEN and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
      • Documentation
      • The FGEN Soft Front Panel
    • Uninstalling/Modifying NI-FGEN
    • Upgrading Firmware
    • Known Issues
    • Bug Fixes
    • API Changes by Release
    • Notice Regarding Microsoft Silverlight Installation and Redistribution
    NI-FGEN 2.8.1 includes the following new features:
    • Support for LabVIEW 2011 (32-bit) and LabVIEW 2011 (64-bit).
    • Support removed for LabVIEW 8.5.1.
    NI-FGEN 2.8 includes the following new features:
    • Support for peer-to-peer streaming with the NI PXIe-5450 (module revision C only) and NI PXIe-5451.
    • New firmware for the NI PXIe-5450 and NI PXIe-5451. This firmware upgrade is required for all NI PXIe-5450 and NI PXIe-5451 devices. Refer to Upgrading Firmware for more information about this new firmware.
    • Support to reset writeable attributes to driver default values. In C, call the niFgen_ResetAttribute function. In LabVIEW, right-click the niFgen Property Node, and select Change To»Default Value.
    • Support for stream n script instruction.
    NI-FGEN 2.7.4 includes the following new features:
    • Support for LabVIEW 2010 (32-bit) and LabVIEW 2010 (64-bit).
    • Fixed an issue in which a custom installer built on a 32-bit OS using LabVIEW, LabWindows™/CVI™, or NI TestStand does not deploy NI-FGEN or its dependent user applications on a 64-bit OS (ID 228650).
    • Support removed for LabVIEW 8.2.1.
    NI-FGEN 2.7.2 includes the following new feature:
    • Fixed a fatal issue when upgrading NI-FGEN 2.7 when using Windows 7 (64-bit) and Windows Server 2008 R2.
    NI-FGEN 2.7 includes the following new features:
    • Support for the NI PXIe-5451 400 MS/s, 16-bit dual-channel arbitrary waveform generator with onboard signal processing (OSP).
    • Support for LabVIEW 2009 (64-bit).
    • Support for 64-bit user mode.
    • Support for new NI PXIe-5442 and NI PXIe-5450 module revisions.
    • Support for Standard Function output mode on the NI PXIe-5450 module revision C.
    • New firmware for the NI PXIe-5442 and NI PXIe-5450. Refer to Upgrading Firmware for more information about this new firmware.
    • Support for wait with marker and break script instructions.
    • New VIs, properties, functions, and attributes.
    NI-FGEN 2.6.3 includes the following new features:
    • Support for LabVIEW 2009 (32-bit).
    • Support removed for LabVIEW 7.1.1.
    NI-FGEN 2.6.1 includes the following new features:
    • Japanese localization for driver, LabVIEW application programming interface (API), and documentation.
    • New firmware for the NI PXIe-5450 and NI PXIe-5442. Refer to Upgrading Firmware for more information about this new firmware.
    • Toggle markers are supported on the NI PXIe-5450.
    • Reorganized LabVIEW property node and CVI attribute tree.
    NI-FGEN 2.6 includes the following new features:
    • Support for the NI PXIe-5450 dual-channel I/Q generator with OSP.
    • Improved scaled write (DBL) performance.
    NI-FGEN is compliant with the IviFgen Class Specification. For more information about this IVI Foundation class specification, visit www.ivifoundation.org.
    The following table shows which hardware products are supported in this release under particular operating systems.
    Hardware ProductSupported Under
    Windows 7
    Supported Under
    Windows Vista
    Supported Under
    Windows XP
    NI PXI/PCI-5401 Function Generator
    X
    X
    NI PXI/PCI-5402 Function Generator
    NI PXI-5404 Frequency Generator
    √1
    √1
    NI PXI/PCI-5406 Function Generator
    NI PXI/PCI-5411 Arbitrary Waveform Generator
    X
    X
    NI PXI/PCI-5412 Arbitrary Waveform Generator
    NI PXI/PCI-5421 Arbitrary Waveform Generator
    NI PXI-5422 Arbitrary Waveform Generator
    NI PXI/PCI-5431 Video Signal Generator
    X
    X
    NI PXI-5441 Arbitrary Waveform Generator with Onboard Signal Processing
    NI PXIe–5442 Arbitrary Waveform Generator with Onboard Signal Processing
    NI PXIe–5450 Dual-Channel I/Q Generator with Onboard Signal Processing
    NI PXIe–5451 Dual-Channel Arbitrary Waveform Generator with Onboard Signal Processing
    1 Windows 7/Vista support for the NI 5404 does not include support for external calibration. Perform external calibration for the NI 5404 on Windows XP operating systems.
    Device-specific information about these signal generators is included in the NI Signal Generators Help file.
    The following table shows which MXI connections are supported under particular operating systems.
    MXI typeSupported Under
    Windows 7
    Supported Under
    Windows Vista
    Supported Under
    Windows XP
    MXI-3
    X
    X
    MXI-4
    MXI-Express
    • Windows XP Service Pack 2 (32-bit)
    Note  NI-FGEN 2.8 does not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-FGEN 2.7.3 or earlier.
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows 7/Vista: 512 MB
      • Windows XP: 128 MB
    • Windows 7/Vista/XP, with all available critical updates and service packs
    Recommended System
    • RAM—
      • Windows 7/Vista: 1 GB
      • Windows XP: 256 MB
    • A screen resolution of 1024 x 768
    Application Development Software
    • NI LabVIEW 8.6.1, 2009 SP1 (32-bit), 2009 SP1 (64-bit), 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 (32-bit), or 2011 (64-bit)
    • NI LabVIEW Real-Time Module 8.6.1, 2009 SP1, 2010 SP1, 2011 (no support for NI PXI/PCI-5401/5411/5431 devices)
    • LabWindows/CVI 8.5.1 or later
    • LabWindows/CVI Real-Time Module 9.0 or later (no support for NI PXI/PCI-5401/5411/5431 devices)
      Note: If you are running your application on an RT target, at least 128 MB of memory is required.
    • Measurement Studio 6.0 or later
    • Microsoft Visual Basic 6.0
      • Windows 7/Vista: Users\Public\Documents\National Instruments
      • Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows 7/Vista/XP 32-bit: Program Files\IVI Foundation\IVI\
      • Windows 7/Vista 64-bit: Program Files (x86)\IVI Foundation\IVI\
        NOTES:$(IVIROOTDIR32) is configured as an environment variable on the target system.
        If you upgraded an installation of IVI, your files may be in the following location:
        • Windows 7/Vista/XP 32-bit: Program Files\IVI\
        • Windows 7/Vista 64-bit: Program Files (x86)\IVI\
      • Windows 7/Vista 64-bit: Program Files\IVI Foundation\IVI\
        NOTE:$(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 7/Vista/XP
    NI-FGEN\Drivers\niFgen
    NI-FGEN Function Panel\Drivers\niFgen\nifgen.fp
    NI-FGEN Examples\NI-FGEN\Examples
    NI-FGEN Header files\Include
    NI-FGEN Import Library files\Lib
    NI-FGEN DLL\Bin
    Additional File Locations for Windows 7/Vista 64-bit
    ItemInstalled Location on Windows 7/Vista 64-bit
    NI-FGEN Import Library files (64-bit)\Lib_x64
    NI-FGEN DLL (64-bit)\Bin
    The following documents are installed with NI-FGEN and are available from Start»All Programs»National Instruments»NI-FGEN»Documentation:
    • NI Signal Generators Getting Started Guide
    • NI Signal Generators Help
    • Specifications
    • Calibration Procedures
    Note  To view many of these documents, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    Visit ni.com/manuals to find the latest versions of product documentation.
    The FGEN Soft Front Panel (SFP)
    The FGEN Soft Front Panel (SFP) is accessible from Start»All Programs»National Instruments»NI-FGEN.
    You can find example waveform and function files in the Program Files\IVI Foundation\IVI\Drivers\niFgen\Examples\Waveforms\ directory and in the Program Files (x86)\IVI Foundation\IVI\Drivers\niFgen\Examples\Waveforms\ directory on the 64-bit version of Windows 7/Vista. Refer to Waveform description.txt in the Waveforms folder for an explanation of the provided waveforms.
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI-FGEN 2.8.1 from the dialog box that appears.
    As part of the NI-FGEN 2.8.1 installation, the following list of software was installed. To completely remove NI-FGEN 2.8.1 from your system, you must remove all of these packages in addition to NI-FGEN.
    • NI Hierarchical Waveform Storage 1.4.9
    • NI IVI Compliance Package 4.4
    • NI Measurement & Automation Explorer 5.0
    • Traditional NI-DAQ 7.4.4 (Windows XP only)
    • NI-DAQmx 9.1.7
    • NI-VISA 5.0
    • NI Spy 2.7.2
    • NI-P2P 1.1.2
    Upgrading Firmware
    The NI PXIe-5442, NI PXIe-5450, and NI PXIe-5451 have upgradeable device firmware. It is highly encouraged and may be required that you upgrade the firmware on these devices; newer firmware contains new features and important bug fixes. To update the firmware, run the Firmware Updater application for your device (54xxFirmwareUpdater_X.Y.Z.exe, where 54xx is the name of the device and X.Y.Z is the firmware version) that is installed in the Program Files\IVI Foundation\IVI\Drivers\niFgen\ directory or the Program Files (x86)\IVI Foundation\IVI\Drivers\niFgen\ directory. This application upgrades your firmware to the latest available version that works with this driver. After the application runs, you are required to power down your computer and PXI Express chassis to complete the firmware update.
    • LabVIEW FPGA 2010 corrupts error reporting for NI-FGEN, and you may receive the following error message: Error information resources required by the driver could not be found on your system. Reinstall the driver, or contact National Instruments Technical support. Visit ni.com/kb and search for 5C1CGPJD for more information about how to correct error reporting behavior.
    • Using dynamic FPGA interfaces (also known as dynamic mode) in the LabVIEW FPGA Module is not supported when using peer-to-peer streaming. Dynamic mode is enabled by default in the LabVIEW FPGA Module 2010, so to disable Dynamic mode, complete the following steps:
      • Place the Open FPGA VI Reference function on the LabVIEW block diagram.
      • Right-click the function and select Configure Open FPGA VI Reference.
      • Remove the checkmark from the Dynamic mode listbox.
    • When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run the installer in silent mode from the command line, you do not receive this prompt, and the installer automatically installs NI's Software Publisher Certificate to the your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    • Windows 7/Vista does not support Traditional DAQ (Legacy) devices. Traditional DAQ devices include the NI PXI/PCI-5401, NI PXI/PCI-5411, and NI PXI/PCI-5431. Simulating these devices is also not supported on Windows 7/Vista, using either the NI-FGEN or the FGEN Soft Front Panel. Simulating a device that is not supported on your operating system results in indeterminate behavior.
    • If you click a topic link in the NI-FGEN C Function Reference section of the NI Signal Generators Help, you cannot use the Back button in the HTML Help window toolbar to return to the original topic.
    • Installing NI-FGEN on a system with NI-DAQmx 7.0 or 7.1, NI-FGEN may return an error about NI-FGEN devices unable to start. To work around this issue, install NI-FGEN, reboot, and then repair NI-FGEN using the Microsoft Windows Control Panel.
    The following items are fixed in NI-FGEN 2.8 from NI-FGEN 2.7.4
    Bug IDFixed Issue
    241656Fixed firmware to synchronize power supplies for improved phase noise performance.
    199899Fixed an issue in which calling calibration utility functions in a normal NI-FGEN session affected output by disabling self-calibration constants.
    182502Fixed an issue in which running test panels for the NI PXIe-5450 and NI PXIe-5451 using the LabVIEW Real-Time Module did not write waveform data. This issue caused the output signal to be random.
    183093Fixed an issue in which waking from sleep mode could crash the operating system in some configurations, especially if the video, network, or other drivers were out of date.
    187791An issue was fixed in which LabVIEW 2009 (64-bit) could crash if you created more than one session using the same resource name. You must install LabVIEW 2009 SP1 (64-bit) for this bug fix.
    The following items are fixed in NI-FGEN 2.7.4 from NI-FGEN 2.7.3
    Bug IDFixed Issue
    228650Fixed an issue in which a custom installer built on a 32-bit OS using LabVIEW, LabWindows/CVI, or NI TestStand does not deploy NI-FGEN or its dependent user applications on a 64-bit OS.
    The following items are fixed in NI-FGEN 2.7.3 from NI-FGEN 2.7.2
    Bug IDFixed Issue
    229602Fixed an issue with clock configuration that can cause memory corruption or blue screen with certain NI PXIe-5450 devices.
    212209Fixed an incorrect calibration DAC setting that could cause self-calibration to fail on the NI PXIe-5451.
    The following items are fixed in NI-FGEN 2.7.2 from NI-FGEN 2.7
    Bug IDFixed Issue
    209051Fixed an issue in which the installer did not stop service nidevldu before upgrading binaries.
    The following items are fixed in NI-FGEN 2.7 from NI-FGEN 2.6.3
    Bug IDFixed Issue
    179935Fixed a streaming issue on the NI PXIe-5442/5450. Streaming with certain combinations of chassis and controllers caused the device to return an invalid thermal error and detach itself from the system. You must upgrade your firmware for this solution.
    157714Fixed a memory leak that occurred when a session was opened and closed dynamically using VI server on LabVIEW Real-Time targets.
    118345Toggle markers are now allowed below 200 MS/s sample rates on the NI PXIe-5450.
    39796An error is now returned when PXI_STAR is used as a trigger source for the NI PXIe-5442. This configuration is not supported.
    118500The NI PXIe-5450 now supports the Oscillator Phase DAC property and NIFGEN_ATTR_OSCILLATOR_PHASE_DAC_VALUE attribute for external Sample clocks.
    The following items are fixed in NI-FGEN 2.6.1 from NI-FGEN 2.6
    Bug IDFixed Issue
    119090Fixed an issue that prevented using all device memory for a single-channel generation on channel 1.
    120854Fixed a memory leak that occurred when writing less than 128 samples at a time.
    118735Fixed an issue that caused the NI 5450 and NI 5442 to skip samples when responding to a Script trigger.
    120220Fixed a 16-sample data corruption issue that occurred when using more than half of the device memory on the NI 5442 and NI 5450.
    133813Alignment of markers and other events to the analog output has been improved slightly within the existing specifications. The default unit for setting event delays on the NI 5450 is now samples, as it is on other signal generators.
    The following items are fixed in NI-FGEN 2.6 from NI-FGEN 2.5.2
    Bug IDFixed Issue
    104259Fixed an issue that incorrectly allowed users to write scripts while in the Generating state.
    103305Decreased minimum frequency step duration in Frequency List output mode for the NI 5402, NI 5406, NI 5441, and NI 5442 devices. The on-the-fly OSP carrier frequency change time for the NI 5441 and NI 5442 devices was also decreased.
    95208Fixed an issue that caused sine waves to have incorrect amplitudes when an offset was applied and flatness correction was enabled on the NI 5402, NI 5406, NI 5441, and NI 5442 devices.
    39673Improved streaming ease-of-use by automatically wrapping writes to streaming waveforms that cross the waveform boundary.
    The following items are fixed in NI-FGEN 2.5.1 from NI-FGEN 2.5
    Bug IDFixed Issue
    4E094973Fixed a streaming issue on the NI PXIe-5442. Streaming data to large waveforms that cross the midpoint of the device onboard memory may cause glitches to appear in the generated signal.
    4DQCUIFHImproved internal clocking reliability for the NI PXIe-5442.
    4DJH2HJR,
    4CQDTAAD
    Fixed several issues with NI-FGEN for LabVIEW Real-Time systems. Upgrading from a previous version of NI-FGEN to NI-FGEN 2.5 could cause you to be unable to download the software to the target. Additionally, some devices may not have been usable with the LabVIEW Real-Time Module.
    Changes in NI-FGEN 2.8 from NI-FGEN 2.7.4
    VIsniFgen Get Stream Endpoint Handle
    niFgen Manual Enable P2P Stream
    niFgen Configure P2P Endpoint Fullness Start Trigger
    niFgen Write P2P Endpoint I16
    FunctionsViStatus _VI_FUNC niFgen_GetStreamEndpointHandle (ViSession vi, ViConstString streamEndpoint, ViInt32* readerHandle);
    ViStatus _VI_FUNC niFgen_ManualEnableP2PStream (ViSession vi, ViConstString endpointName);
    ViStatus _VI_FUNC niFgen_ConfigureP2PEndpointFullnessStartTrigger (ViSession vi, ViInt32 p2pEndpointFullnessLevel);
    ViStatus _VI_FUNC niFgen_WriteP2PEndpointI16 (ViSession vi, ViConstString endpointName, ViInt32 numberOfSamples, ViInt16 endpointData[]);
    ViStatus _VI_FUNC niFgen_ResetAttribute (ViSession vi, ViConstString channelName, ViAttr attributeId);
    ViStatus _VI_FUNC niFgen_SetAttributeViInt64 (ViSession vi, ViConstString channelName, ViAttr attributeId, ViInt64 value);
    ViStatus _VI_FUNC niFgen_CheckAttributeViInt64 (ViSession vi, ViConstString channelName, ViAttr attributeId, ViInt64 value);
    ViStatus _VI_FUNC niFgen_GetAttributeViInt64 (ViSession vi, ViConstString channelName, ViAttr attributeId, ViInt64 *value);
    PropertiesP2P Enabled
    Destination Channels
    Endpoint Size
    Space Available in Endpoint
    Most Space Available in Endpoint
    Endpoint Count
    Data Transfer Permission Interval
    Data Transfer Permission Initial Credits
    Manual Configuration Enabled
    Data Transfer Permission Address
    Data Transfer Permission Address Type
    Endpoint Window Address
    Endpoint Window Address Type
    Endpoint Window Size
    Done Notification Address
    Done Notification Address Type
    Done Notification Value
    P2P Endpoint Fullness Start Trigger Level
    AttributesNIFGEN_ATTR_P2P_ENABLED
    NIFGEN_ATTR_P2P_DESTINATION_CHANNELS
    NIFGEN_ATTR_P2P_ENDPOINT_SIZE
    NIFGEN_ATTR_P2P_SPACE_AVAILABLE_IN_ENDPOINT
    NIFGEN_ATTR_P2P_MOST_SPACE_AVAILABLE_IN_ENDPOINT
    NIFGEN_ATTR_P2P_ENDPOINT_COUNT
    NIFGEN_ATTR_P2P_DATA_TRANSFER_PERMISSION_INTERVAL
    NIFGEN_ATTR_P2P_DATA_TRANSFER_PERMISSION_INITIAL_CREDITS
    NIFGEN_ATTR_P2P_MANUAL_CONFIGURATION_ENABLED
    NIFGEN_ATTR_P2P_DATA_TRANSFER_PERMISSION_ADDRESS
    NIFGEN_ATTR_P2P_DATA_TRANSFER_PERMISSION_ADDRESS_TYPE
    NIFGEN_ATTR_P2P_ENDPOINT_WINDOW_ADDRESS
    NIFGEN_ATTR_P2P_ENDPOINT_WINDOW_ADDRESS_TYPE
    NIFGEN_ATTR_P2P_ENDPOINT_WINDOW_SIZE
    NIFGEN_ATTR_P2P_DONE_NOTIFICATION_ADDRESS
    NIFGEN_ATTR_P2P_DONE_NOTIFICATION_ADDRESS_TYPE
    NIFGEN_ATTR_P2P_DONE_NOTIFICATION_VALUE
    NIFGEN_ATTR_P2P_ENDPOINT_FULLNESS_START_TRIGGER_LEVEL
    Changes in NI-FGEN 2.7 from NI-FGEN 2.6.3
    VIniFgen Create Waveform (Complex WDT)
    FunctionViStatus _VI_FUNC niFgen_CalAdjustADC (ViSession vi, ViConstString Channel_Name, ViInt32 Configuration, ViReal64 Voltages_Measured_Externally[], ViReal64 Voltages_Measured_With_CalADC[]);
    PropertiesModule Revision
    Compensate for Filter Group Delay
    AttributesNIFGEN_ATTR_MODULE_REVISION
    NIFGEN_ATTR_OSP_COMPENSATE_FOR_FILTER_GROUP_DELAY
    Made the following function obsolete and moved it to niFgenObsolete.h:
    • niFgen_CalAdjustCalADC
    Changes in NI-FGEN 2.6 from NI-FGEN 2.5.2
    VIniFgen Configure Channels
    FunctionViStatus _VI_FUNC niFgen_ConfigureChannels(ViSession vi, ViConstString channels);
    PropertiesChannel Delay
    Common Mode Offset
    Exported Sample Clock Timebase Output Terminal
    External Sample Clock Multiplier
    Frequency Shift
    Idle Behavior
    Idle Value
    Maximum Bandwidth
    Maximum In-Flight Read Requests
    OSP Mode
    PCI DMA Optimizations Enabled
    Preferred Packet Size
    Sample Clock Timebase Rate
    Sample Clock Timebase Source
    Terminal Configuration
    Wait Behavior
    Wait Value
    AttributesNIFGEN_ATTR_CHANNEL_DELAY
    NIFGEN_ATTR_COMMON_MODE_OFFSET
    NIFGEN_ATTR_DATA_TRANSFER_MAXIMUM_BANDWIDTH
    NIFGEN_ATTR_DATA_TRANSFER_MAXIMUM_IN_FLIGHT_READS
    NIFGEN_ATTR_DATA_TRANSFER_PCI_DMA_OPTIMIZATIONS_ENABLED
    NIFGEN_ATTR_DATA_TRANSFER_PREFERRED_PACKET_SIZE
    NIFGEN_ATTR_EXPORTED_SAMPLE_CLOCK_TIMEBASE_OUTPUT_TERMINAL
    NIFGEN_ATTR_EXTERNAL_SAMPLE_CLOCK_MULTIPLIER
    NIFGEN_ATTR_IDLE_BEHAVIOR
    NIFGEN_ATTR_IDLE_VALUE
    NIFGEN_ATTR_OSP_FREQUENCY_SHIFT
    NIFGEN_ATTR_OSP_MODE
    NIFGEN_ATTR_SAMPLE_CLOCK_TIMEBASE_RATE
    NIFGEN_ATTR_SAMPLE_CLOCK_TIMEBASE_SOURCE
    NIFGEN_ATTR_TERMINAL_CONFIGURATION
    NIFGEN_ATTR_WAIT_BEHAVIOR
    NIFGEN_ATTR_WAIT_VALUE
    Changes in NI-FGEN 2.5 from NI-FGEN 2.4.6
    PropertiesDone Event Delay
    Marker Event Delay
    Started Event Delay
    Done Event Delay Units
    Marker Event Delay Units
    Started Event Delay Units
    AttributesNIFGEN_ATTR_DONE_EVENT_DELAY
    NIFGEN_ATTR_MARKER_EVENT_DELAY
    NIFGEN_ATTR_STARTED_EVENT_DELAY
    NIFGEN_ATTR_DONE_EVENT_DELAY_UNITS
    NIFGEN_ATTR_MARKER_EVENT_DELAY_UNITS
    NIFGEN_ATTR_STARTED_EVENT_DELAY_UNITS
    Changes in NI-FGEN 2.4 from NI-FGEN 2.3
    AttributesNIFGEN_ATTR_STREAMING_WAVEFORM_HANDLE
    NIFGEN_ATTR_ARB_MARKER_POSITION
    NIFGEN_ATTR_ARB_REPEAT_COUNT
    NIFGEN_ATTR_STREAMING_SPACE_AVAILABLE_IN_WAVEFORM
    NIFGEN_ATTR_SAMPLE_CLOCK_SOURCE
    NIFGEN_ATTR_REFERENCE_CLOCK_SOURCE
    NIFGEN_ATTR_FLATNESS_CORRECTION_ENABLED
    NIFGEN_ATTR_SCRIPT_TO_GENERATE
    NIFGEN_ATTR_MARKER_EVENTS_COUNT
    NIFGEN_ATTR_SCRIPT_TRIGGERS_COUNT
    NIFGEN_ATTR_DATA_MARKER_EVENTS_COUNT
    NIFGEN_ATTR_STREAMING_WAVEFORM_NAME
    NIFGEN_ATTR_SCRIPT_TRIGGER_TYPE
    NIFGEN_ATTR_DIGITAL_EDGE_SCRIPT_TRIGGER_SOURCE
    NIFGEN_ATTR_DIGITAL_EDGE_SCRIPT_TRIGGER_EDGE
    NIFGEN_ATTR_DIGITAL_LEVEL_SCRIPT_TRIGGER_SOURCE
    NIFGEN_ATTR_DIGITAL_LEVEL_SCRIPT_TRIGGER_ACTIVE_LEVEL
    NIFGEN_ATTR_EXPORTED_SCRIPT_TRIGGER_OUTPUT_TERMINAL
    NIFGEN_ATTR_START_TRIGGER_TYPE
    NIFGEN_ATTR_DIGITAL_EDGE_START_TRIGGER_SOURCE
    NIFGEN_ATTR_DIGITAL_EDGE_TRIGGER_EDGE
    NIFGEN_ATTR_EXPORTED_START_TRIGGER_OUTPUT_TERMINAL
    NIFGEN_ATTR_READY_FOR_START_EVENT_OUTPUT_TERMINAL
    NIFGEN_ATTR_READY_FOR_START_EVENT_LEVEL_ACTIVE_LEVEL
    NIFGEN_ATTR_MARKER_EVENT_OUTPUT_TERMINAL
    NIFGEN_ATTR_MARKER_EVENT_PULSE_POLARITY
    NIFGEN_ATTR_MARKER_EVENT_PULSE_WIDTH
    NIFGEN_ATTR_MARKER_EVENT_PULSE_WIDTH_UNITS
    NIFGEN_ATTR_MARKER_EVENT_OUTPUT_BEHAVIOR
    NIFGEN_ATTR_MARKER_EVENT_TOGGLE_INITIAL_STATE
    NIFGEN_ATTR_STARTED_EVENT_OUTPUT_TERMINAL
    NIFGEN_ATTR_STARTED_EVENT_LEVEL_ACTIVE_LEVEL
    NIFGEN_ATTR_STARTED_EVENT_PULSE_POLARITY
    NIFGEN_ATTR_STARTED_EVENT_OUTPUT_BEHAVIOR
    NIFGEN_ATTR_STARTED_EVENT_PULSE_WIDTH_UNITS
    NIFGEN_ATTR_DONE_EVENT_OUTPUT_TERMINAL
    NIFGEN_ATTR_DONE_EVENT_LEVEL_ACTIVE_LEVEL
    NIFGEN_ATTR_DONE_EVENT_PULSE_POLARITY
    NIFGEN_ATTR_DONE_EVENT_OUTPUT_BEHAVIOR
    NIFGEN_ATTR_DONE_EVENT_PULSE_WIDTH_UNITS
    NIFGEN_ATTR_DATA_MARKER_EVENT_DATA_BIT_NUMBER
    NIFGEN_ATTR_DATA_MARKER_EVENT_LEVEL_POLARITY
    NIFGEN_ATTR_DATA_MARKER_EVENT_OUTPUT_TERMINAL
    NIFGEN_ATTR_ALL_MARKER_EVENTS_LIVE_STATUS
    NIFGEN_ATTR_MARKER_EVENT_LIVE_STATUS
    NIFGEN_ATTR_READY_FOR_START_EVENT_LIVE_STATUS
    NIFGEN_ATTR_ALL_MARKER_EVENTS_LATCHED_STATUS
    NIFGEN_ATTR_MARKER_EVENT_LATCHED_STATUS
    NIFGEN_ATTR_DONE_EVENT_LATCHED_STATUS
    NIFGEN_ATTR_STARTED_EVENT_LATCHED_STATUS
    NIFGEN_ATTR_EXPORTED_SAMPLE_CLOCK_OUTPUT_TERMINAL
    NIFGEN_ATTR_EXPORTED_REFERENCE_CLOCK_OUTPUT_TERMINAL
    NIFGEN_ATTR_EXPORTED_ONBOARD_REFERENCE_CLOCK_OUTPUT_TERMINAL
    NIFGEN_ATTR_SYNC_OUT_OUTPUT_TERMINAL
    NIFGEN_ATTR_DIRECT_DMA_ENABLE
    NIFGEN_ATTR_DIRECT_DMA_WINDOW_SIZE
    NIFGEN_ATTR_DIRECT_DMA_WINDOW_ADDRESS
    FunctionsViStatus _VI_FUNC niFgen_AllocateNamedWaveform(ViSession vi, ViConstString channelName, ViConstString wfmName, ViInt32 numberOfSamples);
    ViStatus _VI_FUNC niFgen_SetNamedWaveformNextWritePosition(ViSession vi, ViConstString channelName, ViConstString wfmName, ViInt32 relativeTo, ViInt32 offset);
    ViStatus _VI_FUNC niFgen_WriteNamedWaveformF64(ViSession vi, ViConstString channelName, ViConstString wfmName, ViInt32 numberOfSamples, ViReal64 wfmData[]);
    ViStatus _VI_FUNC niFgen_WriteNamedWaveformI16(ViSession vi, ViConstString channelName, ViConstString wfmName, ViInt32 numberOfSamples, ViInt16 wfmData[]);
    ViStatus _VI_FUNC niFgen_WriteNamedWaveformComplexF64(ViSession vi, ViConstString channelName, ViConstString wfmName, ViInt32 numberOfSamples, NIComplexNumber wfmData[]);
    ViStatus _VI_FUNC niFgen_WriteNamedWaveformComplexI16(ViSession vi, ViConstString channelName, ViConstString wfmName, ViInt32 numberOfSamples, NIComplexI16 wfmData[]);
    ViStatus _VI_FUNC niFgen_DeleteNamedWaveform(ViSession vi, ViConstString channelName, ViConstString wfmName);
    ViStatus _VI_FUNC niFgen_WriteScript(ViSession vi, ViConstString channelName, ViConstString script);
    ViStatus _VI_FUNC niFgen_DeleteScript(ViSession vi, ViConstString channelName, ViConstString scriptName);
    ViStatus _VI_FUNC niFgen_ExportSignal(ViSession vi, ViInt32 signal, ViConstString signalIdentifier, ViConstString outputTerminal);
    ViStatus _VI_FUNC niFgen_SendSoftwareEdgeTrigger(ViSession vi, ViInt32 triggerName, ViConstString triggerIdentifier);
    ViStatus _VI_FUNC niFgen_ConfigureDigitalEdgeStartTrigger(ViSession vi, ViConstString source, ViInt32 edge);
    ViStatus _VI_FUNC niFgen_ConfigureSoftwareEdgeStartTrigger(ViSession vi);
    ViStatus _VI_FUNC niFgen_DisableStartTrigger(ViSession vi);
    ViStatus _VI_FUNC niFgen_ConfigureDigitalEdgeScriptTrigger(ViSession vi, ViConstString triggerID, ViConstString source, ViInt32 edge);
    ViStatus _VI_FUNC niFgen_ConfigureDigitalLevelScriptTrigger(ViSession vi, ViConstString triggerID, ViConstString source, ViInt32 level);
    ViStatus _VI_FUNC niFgen_ConfigureSoftwareEdgeScriptTrigger(ViSession vi, ViConstString triggerID);
    ViStatus _VI_FUNC niFgen_DisableScriptTrigger(ViSession vi, ViConstString triggerID);
    ViStatus _VI_FUNC niFgen_WriteComplexBinary16Waveform(ViSession vi, ViConstString channelName, ViInt32 waveformHandle, ViInt32 numberOfSamples, NIComplexI16 wfmData[]);
    ViStatus _VI_FUNC niFgen_InitializeFlatnessCalibration(ViSession vi);
    ViStatus _VI_FUNC niFgen_CalAdjustFlatness(ViSession vi, ViConstString channelName, ViInt32 configuration, ViReal64 requestedAmplitude, ViReal64* frequencies, ViReal64* measuredAmplitudes, ViInt32 numberOfMeasurements);
    ViStatus _VI_FUNC niFgen_ConfigureSampleClockSource(ViSession vi, ViConstString sampleClockSource);
    ValuesOutput Mode:
    NIFGEN_VAL_OUTPUT_SCRIPT
    New attributes and functions:
    See niFgen.h file for values supported by new attributes and functions
    Made the following VIs obsolete and moved them to niFgenObsolete_2_4.llb:
    • niFgen Configure Ref Clock Frequency VI
    • niFgen Configure Ref Clock Source VI
    • niFgen Configure Trigger VI
    • niFgen Configure Update Clock Source VI
    • niFgen Send Software Trigger VI
    Made the following functions obsolete and moved them to niFgenObsolete.h:
    • niFgen_ConfigureReferenceClockFrequency
    • niFgen_ConfigureReferenceClockSource
    • niFgen_ConfigureTriggerSource
    • niFgen_ConfigureUpdateClockSource
    • niFgen_SendSoftwareTrigger
    Made the niFgen_ComplexF64 type obsolete and moved it to niFgenObsolete.h.
    Changes in NI-FGEN 2.3 from NI-FGEN 2.2
    AttributesNIFGEN_ATTR_DIGITAL_GAIN
    NIFGEN_ATTR_OSP_ENABLED
    NIFGEN_ATTR_OSP_DATA_PROCESSING_MODE
    NIFGEN_ATTR_OSP_IQ_RATE
    NIFGEN_ATTR_OSP_CARRIER_ENABLED
    NIFGEN_ATTR_OSP_CARRIER_FREQUENCY
    NIFGEN_ATTR_OSP_CARRIER_PHASE_I
    NIFGEN_ATTR_OSP_CARRIER_PHASE_Q
    NIFGEN_ATTR_OSP_FIR_FILTER_TYPE
    NIFGEN_ATTR_OSP_FIR_FILTER_ENABLED
    NIFGEN_ATTR_OSP_FIR_FILTER_INTERPOLATION
    NIFGEN_ATTR_OSP_CIC_FILTER_ENABLED
    NIFGEN_ATTR_OSP_CIC_FILTER_INTERPOLATION
    NIFGEN_ATTR_OSP_FIR_FILTER_ROOT_RAISED_COSINE_ALPHA
    NIFGEN_ATTR_OSP_FIR_FILTER_RAISED_COSINE_ALPHA
    NIFGEN_ATTR_OSP_FIR_FILTER_FLAT_PASSBAND
    NIFGEN_ATTR_OSP_FIR_FILTER_GAUSSIAN_BT
    NIFGEN_ATTR_OSP_CIC_FILTER_GAIN
    NIFGEN_ATTR_OSP_PRE_FILTER_GAIN_I
    NIFGEN_ATTR_OSP_PRE_FILTER_GAIN_Q
    NIFGEN_ATTR_OSP_PRE_FILTER_OFFSET_I
    NIFGEN_ATTR_OSP_PRE_FILTER_OFFSET_Q
    NIFGEN_ATTR_OSP_OVERFLOW_ERROR_REPORTING
    NIFGEN_ATTR_OSP_OVERFLOW_STATUS
    FunctionsViStatus niFgen_ConfigureCustomFIRFilterCoefficients (ViSession vi, ViConstString channelName, ViInt32 numberOfCoefficients, ViReal64* coefficients)
    ViStatus niFgen_GetFIRFilterCoefficients (ViSession vi, ViConstString channelName, ViInt32 arraySize, ViReal64* coefficients, ViInt32* numberOfCoefficientsRead)
    ViStatus niFgen_CreateWaveformComplexF64 (ViSession vi, ViConstString channelName, ViInt32 numberOfSamples, niFgen_ComplexF64 wfmData[], ViInt32 *wfmHandle)
    ViStatus niFgen_WriteWaveformComplexF6 (ViSession vi, ViConstString channelName, ViInt32 numberOfSamples, niFgen_ComplexF64 data[], ViInt32 wfmHandle)
    ValuesOSP Data Processing Mode:
    NIFGEN_VAL_OSP_REAL
    NIFGEN_VAL_OSP_COMPLEX
    OSP FIR Filter Type:
    NIFGEN_VAL_OSP_FLAT
    NIFGEN_VAL_OSP_RAISED_COSINE
    NIFGEN_VAL_OSP_ROOT_RAISED_COSINE
    NIFGEN_VAL_OSP_GAUSSIAN
    NIFGEN_VAL_OSP_CUSTOM
    OSP Overflow Error Reporting:
    NIFGEN_VAL_ERROR_REPORTING_ERROR
    NIFGEN_VAL_ERROR_REPORTING_DISABLED
    OSP Overflow Status:
    NIFGEN_VAL_OSP_OVERFLOW_NONE
    NIFGEN_VAL_OSP_OVERFLOW_PRE_FILTER_GAIN_I
    NIFGEN_VAL_OSP_OVERFLOW_PRE_FILTER_GAIN_Q
    NIFGEN_VAL_OSP_OVERFLOW_PRE_FILTER_OFFSET_I
    NIFGEN_VAL_OSP_OVERFLOW_PRE_FILTER_OFFSET_Q
    NIFGEN_VAL_OSP_OVERFLOW_FIR_FILTER_I
    NIFGEN_VAL_OSP_OVERFLOW_FIR_FILTER_Q
    NIFGEN_VAL_OSP_OVERFLOW_CIC_FILTER_I
    NIFGEN_VAL_OSP_OVERFLOW_CIC_FILTER_Q
    NIFGEN_VAL_OSP_OVERFLOW_COMPLEX_DATA
    Using Microsoft Silverlight
    © 2007–2011 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-12-12 19:29
