查看: 3025|回复: 0
[NI驱动程序] NI-DMM 20.0 Driver Win32/64Eng NI数字万用表驱动程序20.0下载
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-15 00:08:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DMM
    NI-DMM支持使用NI数字万用表的客户。
    NI-DMM是与所有NI可编程数字万用表(DMM)进行通信必需的NI仪器驱动程序。NI-DMM是一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,而且包含了交互式软件前面板和示例。
    Win32/64Eng/Jpn20.0
    文件大小: 2559176704 字节 (2.38 GB)
    修改日期: 2020-05-12 03:18
    MD5: 2de8c49267f22b99bde56c93f3189343
    SHA1: ecdccb58dfd961e2c6486d6ec84df1e685ed8963
    SHA256: fc13756d4dc9c9f0b9572e5f11143b0b0f62448cceed5840cb98b1d4b141e05b
    CRC32: fd8ad0cd
    DMM20.0.txt (359 Bytes, 下载次数: 1, 售价: 10 圆)
    NI-DMM 20.0 Readme
    April 2020
    This file contains important information about NI-DMM, including installation instructions, new features, bugs fixes, and known issues.
    NI-DMM Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    NI-DMM is an NI instrument driver that communicates with all NI programmable digital multimeters (DMMs). NI-DMM is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the DMM and includes an interactive soft front panel and examples.
    NI-DMM 20.0 has the following requirements:
    Minimum System Requirements
    • RAM—1 GB, 800 MHz DDR2 RAM
    Recommended System
    NI-DMM 20.0 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016 NI-DMM dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-DMM 20.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-DMM 20.0 to an unsupported OS. Additionally, after installing NI-DMM 20.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note  Refer to NI-DMM Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    NI-DMM 20.0 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-DMM
    LabVIEW2017, 2018, 2019, 2020
    LabVIEW Real-Time Module2017, 2018, 2019, 2020
    LabVIEW NXG5.0
    LabWindows™/CVI™2013 and later
    LabWindows/CVI Real-Time Module2013 and later
    If you are using the NI-DMM .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-DMM .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-DMM installer to install the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
    NI installs NI-DMM using NI Package Manager. If you do not already have NI software installed, NI-DMM installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Install an ADE, such as LabVIEW or LabWindows™/CVI™.
    • Visit ni.com/downloads/drivers and search for NI-DMM.
    • Click NI-DMM 20.0 and then the download link and run the executable (.exe) file.
    • Follow the instructions in the installation prompts. You may see access and security prompts during installation. Accept the prompts to complete the installation.
    • When the installer completes, select Restart in the dialog box that prompts you to restart, shut down, or restart later.
    Note
    • NI-DMM 20.0 adds support for LabVIEW 2020 and LabVIEW NXG 5.0.
    The following list details the hardware models supported in NI-DMM 20.0.
    PXI Amplifier Module
    • PXI-4022
    PXI Digital Multimeter
    • PXIe-4080
    • PXIe-4081
    • PXIe-4082
    • PXI-4072
    • PXI-4071
    • PXI-4070
    • PXI-4065
    Digital Multimeter Device
    • PCI-4070
    • PCIe-4065
    • PCI-4065
    • USB-4065
    You can access the software and documentation known issues list online. Visit NI-DMM 20.0 Known Issues for an up-to-date list of known issues.
    You can access the NI-DMM 20.0 bug fix list online at NI-DMM 20.0 Bug Fixes. This list describes a subset of issues fixed in NI-DMM 20.0. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    Refer to the NI Digital Multimeters Help, accessible from Start»All Programs»National Instruments»NI-DMM»NI-DMM Documentation, for information about NI-DMM.
    You can access all the installed NI-DMM examples at Start»All Programs»National Instruments»NI-DMM»NI-DMM Examples and online at ni.com/examples.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-DMM are located in the LabVIEW XXXX\examples\instr\niDMM directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–DMM or by directory structure at instr»niDMM.
    • Click the Search tab to search all installed examples by keyword. For example, search for "DMM" to locate all NI-DMM examples.
    The following sections detail considerations for using LabVIEW NXG with NI-DMM.
    LabVIEW NXG Hardware Support
    407x and 406x DMMs
    • PCI-4065
    • PCI-4070
    • PCIe-4065
    • PXI-4065
    • PXI-4070
    • PXI-4071
    • PXI-4072
    • USB-4065
    408x DMMs
    • PXIe-4080
    • PXIe-4081
    • PXIe-4082
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI-DMM no longer installs IVI Compliance Package. NI-DMM supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    NI-DMM will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 2007–2020 National Instruments. All rights reserved.
    376310M-01
    GMT+8, 2025-11-19 09:04
