NI-DMM 19.1 Driver Win32/64Eng NI数字万用表驱动程序19.1下载
NI-DMM
NI-DMM支持使用NI数字万用表的客户。
NI-DMM是与所有NI可编程数字万用表(DMM)进行通信必需的NI仪器驱动程序。NI-DMM是一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,而且包含了交互式软件前面板和示例。
Win32/64Eng/Jpn
19.1
文件大小: 2082357248 字节 (1.94 GB)
修改日期: 2019-09-07 01:31
MD5: 1269ae9ab30f92f08a3a3367e2ff1c24(官方正确)
SHA1: 6eade20fe17dd41a9b6cbcd0b945caae4dfdba2d
SHA256: fc1d0b6168ad04b6f5bcd6c1b8fb9dbeaf3a92ffee0c9f7247a7eea8b32e11d2
CRC32: e4029021
DMM19.1.txt
(598 Bytes, 下载次数: 0, 售价: 10 圆)
NI-DMM 19.1 ReadmeJune 2019 This file contains important information about NI-DMM, including installation instructions, new features, a partial list of bugs fixed, and known issues. If you plan to use LabVIEW NXG, refer to LabVIEW NXG Support and Considerations.
Overview System Requirements Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates Supported Hardware Known Issues Bug Fixes Accessing the Help Finding Examples LabVIEW NXG Support and Considerations IVI Compliance Package Functionality Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 Legal Information OverviewNI-DMM is an NI instrument driver that communicates with all NI programmable digital multimeters (DMMs). NI-DMM is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the DMM and includes an interactive soft front panel and examples. System RequirementsNI-DMM 19.1 has the following requirements: Minimum System Requirements- Processor—2.53 GHz Intel Core 2 Duo processor or equivalent
- RAM—1 GB, 800 MHz DDR2 RAM
Recommended System- Processor—2.3 GHz quad-core Intel Core i7 or equivalent
- RAM—4 GB, dual-channel 1600 MHz DDR3 RAM
Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW. Supported Operating SystemsNI-DMM 19.1 supports the following operating systems: - Windows 10/8.11/7 SP12
- Windows Server 2012 R21
- Windows Server 2008 R2 SP12
1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update. Note In 2016 NI-DMM dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-DMM 19.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-DMM 19.1 to an unsupported OS. Additionally, after installing NI-DMM 19.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?. Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/r/PAESupport. Note Refer to NI-DMM Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support. Application Software SupportNI-DMM 19.1 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support. | Application Software | Versions Supported by NI-DMM | | LabVIEW | 2016, 2017, 2018, 2019 | | LabVIEW Real-Time Module | 2016, 2017, 2018, 2019 | | LabVIEW NXG | 3.0, 3.1 | | LabWindows™/CVI™ | 2013 and later | | LabWindows/CVI Real-Time Module | 2013 and later | Microsoft Visual Studio SupportIf you are using the NI-DMM .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-DMM .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5. To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-DMM installer to install the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support. Installation InstructionsNI installs NI-DMM using NI Package Manager. If you do not already have NI software installed, NI-DMM installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. - Install an ADE, such as LabVIEW or LabWindows™/CVI™.
- Visit ni.com/downloads and search for NI-DMM 19.1.
- Click NI-DMM 19.1 and then the download link and run the executable (.exe) file.
- Follow the instructions in the installation prompts. You may see access and security prompts during installation. Accept the prompts to complete the installation.
- When the installer completes, select Restart in the dialog box that prompts you to restart, shut down, or restart later.
Note - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. Supported HardwareThe following list details the hardware models supported in NI-DMM 19.1. PXI Amplifier Module PXI Digital Multimeter - PXIe-4080
- PXIe-4081
- PXIe-4082
- PXI-4072
- PXI-4071
- PXI-4070
- PXI-4065
Digital Multimeter Device - PCI-4070
- PCIe-4065
- PCI-4065
- USB-4065
Behavior ChangesNI-DMM 19.0 drops support for Traditional DAQ (NI-DAQ) and the PCI/PXI-4060 and DAQCard-4050 (PCMCIA-4050) digital multimeters. NI-DMM 19.0 drops support for Express VIs in LabVIEW. Existing code created with earlier versions of NI-DMM and that contains Express VIs will continue to execute, but the Express VI cannot be reconfigured from a dialog box. To reconfigure an Express VI, right-click the Express VI and select Open Front Panel»Convert. This will convert the Express VI to code that you can configure on the block diagram. NI recommends converting Express VIs to code before using the Code Conversion Utility in LabVIEW NXG to convert code for LabVIEW NXG.
Known IssuesYou can access the software and documentation known issues list online. Visit NI-DMM 19.1 Known Issues for an up-to-date list of known issues. Bug FixesThe following items are the IDs and titles of a subset of issues fixed in NI-DMM. This is not an exhaustive list of issues fixed in the current version of NI-DMM. If you have a CAR ID, you can search this list to validate that the issue has been fixed. The following items are changes in NI-DMM 19.1 from NI-DMM 19.0. | ID | Fixed Issue | | 726548 | Fixed an issue in which the PXIe‑4080, PXIe‑4081, and PXIe‑4082 could use an incorrect default value for the Settle Time property after setting the Range property to -3.0 (Auto Range Once). |
The following items are changes in NI-DMM 18.1 from NI-DMM 18.0. | ID | Fixed Issue | | 575369 | Fixed an issue affecting the PXIe‑4080, PXIe‑4081, and PXIe‑4082 that caused additional trigger latency in waveform mode. | | 682078 | Fixed an issue affecting the PXI/PCI/PCIe/USB‑4065 when the Range property was set to Auto Range Once that caused the device to perform an autorange each time the Read or Initiate VIs were called rather than for only the first measurement of an acquisition. | Accessing the HelpRefer to the NI Digital Multimeters Help, accessible from Start»All Programs»National Instruments»NI-DMM»NI-DMM Documentation, for information about NI-DMM. Finding ExamplesYou can access all the installed NI-DMM examples at Start»All Programs»National Instruments»NI-DMM»NI-DMM Examples and online at ni.com/examples. Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-DMM are located in the LabVIEW XXXX\examples\instr\niDMM directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. The NI Example Finder offers two ways to access all installed LabVIEW example VIs and their descriptions: - Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–DMM or by directory structure at instr»niDMM.
- Click the Search tab to search all installed examples by keyword. For example, search for "DMM" to locate all NI-DMM examples.
LabVIEW NXG Support and ConsiderationsThe following sections detail considerations for using LabVIEW NXG with NI-DMM. LabVIEW NXG Operating Systems and System RequirementsSoftware support for LabVIEW NXG differs in the following ways: - System requirements—Only 64-bit (x64) processors are supported.
- Operating system—Only 64-bit operating systems are supported. Refer to the Supported Operating Systems section for more information.
LabVIEW NXG Hardware Support407x, 406x, and 4050 DMMs - PCI-4065
- PCI-4070
- PCIe-4065
- PXI-4065
- PXI-4070
- PXI-4071
- PXI-4072
- USB-4065
408x DMMs - PXIe-4080
- PXIe-4081
- PXIe-4082
LabVIEW NXG HelpView context help in LabVIEW by pressing and hovering over an object. Search for items using the search bar in the upper right corner of the LabVIEW window. You can also view context help for the search results. Additional documentation is available online at ni.com/manuals. LabVIEW NXG ExamplesLaunch LabVIEW and click the Learning tab. LabVIEW lessons are located in the Lessons tab, and LabVIEW Examples are located in the Examples tab. Follow the instructions in the lessons and examples. IVI Compliance Package FunctionalityNI-DMM no longer installs IVI Compliance Package. NI-DMM supports IVI configuration and runtime, but no longer installs the following IVI components: - LabVIEW and CVI IVI class driver APIs for developing IVI interchangeable applications
- IVI Class Simulation drivers
- IVI-COM Adapters
To use these features, you must install ICP separately. ICP is included in the Software Platform Bundle media. A stand-alone web distribution is available from ni.com/downloads. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer.
- To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. NI-DMM Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021NI-DMM will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes: | Product | Info Code | | LabVIEW | lifecycle | | LabWindows/CVI | cvi_lifecycle | | Measurement Studio | mstudiolifecycle | | TestStand | tslcp | | DIAdem | ddlcp | | SignalExpress | selcp | | VeriStand | nivslifecycle |
Legal InformationCopyright © 2007–2019 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents.
376310K-01 |
