NI-DMM 17.1 Driver Win32/64Eng NI数字万用表驱动程序17.1下载
NI-DMM
NI-DMM支持使用NI数字万用表的客户。
NI-DMM是与所有NI可编程数字万用表(DMM)进行通信必需的NI仪器驱动程序。NI-DMM是一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,而且包含了交互式软件前面板和示例。
Win32/64Eng/Jpn
文件大小: 1891741576 字节 (1.76 GB)
修改日期: 2017-12-07 03:25
MD5: ba0f333ae2aa718f9d39479b4234e69f(官方正确)
SHA1: cd1fd8df6fca24fa8c6af1362973ead3e28a7c4f
SHA256: b981985b1128ff62094669ebf6bb0a81c57a38c94f437ab7a5d9c7459344fb45
CRC32: 4f4ff15a
DMM17.1.txt
(573 Bytes, 下载次数: 0, 售价: 10 圆)
NI-DMM 17.1 ReadmeJuly 2017 This file contains important information about NI-DMM, including installation instructions, new features, a partial list of bugs fixed for NI-DMM 17.1, and known issues. If you plan to use LabVIEW NXG, refer to LabVIEW NXG Support and Considerations.
Overview System Requirements Supported Operating Systems Application Software Support Product Security and Critical Updates New Features Supported Hardware Behavior Changes Known Issues Bug Fixes Accessing the Help Finding Examples IVI Compliance Package Functionality Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 LabVIEW NXG Support and Considerations Legal Information OverviewNI-DMM is an NI instrument driver that communicates with all NI programmable digital multimeters (DMMs). NI-DMM is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the DMM and includes an interactive soft front panel and examples. System RequirementsMinimum System Requirements- Processor—2.53 GHz Intel Core 2 Duo processor or equivalent
- RAM—1 GB, 800 MHz DDR2 RAM
Recommended System- Processor—2.3 GHz quad-core Intel Core i7 or equivalent
- RAM—4 GB, dual-channel 1600 MHz DDR3 RAM
Supported Operating SystemsNI-DMM supports the following operating systems: - Windows 10/8.11/7 SP12
- Windows Embedded Standard 7 SP12
- Windows Server 2012 R21
- Windows Server 2008 R2 SP12
Note In 2016 NI-DMM dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-DMM 17.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-DMM 17.1 to an unsupported OS. Additionally, after installing NI-DMM 17.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?. Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/info and enter the Info Code PAESupport. 1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update. Application Software SupportNI-DMM supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support. | Application Software | Versions Supported by NI-DMM | | LabVIEW | 2014 SP1, 2015 SP1, 2016, 2017 | | LabVIEW Real-Time Module | 2014 SP1, 2015, 2016, 2017 | | LabWindows™/CVI™ | 2014 and later | | LabWindows/CVI Real-Time Module | 2014 and later | Microsoft Visual Studio SupportIf you are using the NI-DMM .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-DMM .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. New FeaturesNI-DMM 17.1: - Support for Auto Range while using digital or software triggers for the PXIe-4080, PXIe-4081, and PXIe-4082
- Support for Auto Range ONCE (-3) and OFF (-2) for the PXIe-4080, PXIe-4081, and PXIe-4082
NI-DMM 17.0: - Support for LabVIEW 2017 (32- and 64-bit)
- Support for LabVIEW NXG 1.0
NI-DMM 16.0: - Support for LabVIEW 2016 (32- and 64-bit)
NI-DMM 15.2: - Support for the PXIe-4080, PXIe-4081, and PXIe-4082
NI-DMM 15.1: NI-DMM 14.0: - Support for LabVIEW 2014 (32- and 64-bit)
Supported HardwareThe following list details the hardware models supported in NI-DMM 17.1. PXI Amplifier Module PXI Digital Multimeter - PXIe-4080
- PXIe-4081
- PXIe-4082
- PXI-4072
- PXI-4071
- PXI-4070
- PXI-4065
Digital Multimeter Device - PCI-4070
- PCIe-4065
- PCI-4065
- USB-4065
Behavior ChangesThe following items are changes in behavior for 15.2. - Express VIs are not supported with PXIe-408x hardware. For more information on differences between PXI-407x hardware and PXIe-408x hardware, visit ni.com/info and enter Info Code exbgsi.
- The following triggers have been renamed in NI-DMM 15.2.
NI-DMM C/CVI/VB Trigger Naming Changes[tr][/tr]
| Former name | New name | | NIDMM_VAL_TTL0 | NIDMM_VAL_PXI_TRIG0 | | NIDMM_VAL_TTL1 | NIDMM_VAL_PXI_TRIG1 | | NIDMM_VAL_TTL2 | NIDMM_VAL_PXI_TRIG2 | | NIDMM_VAL_TTL3 | NIDMM_VAL_PXI_TRIG3 | | NIDMM_VAL_TTL4 | NIDMM_VAL_PXI_TRIG4 | | NIDMM_VAL_TTL5 | NIDMM_VAL_PXI_TRIG5 | | NIDMM_VAL_TLL6 | NIDMM_VAL_PXI_TRIG6 | | NIDMM_VAL_TTL7 | NIDMM_VAL_PXI_TRIG7 | | NIDMM_VAL_LBR_TRIG_0 | NIDMM_VAL_LBR_TRIG0 | | NIDMM_VAL_LBR_TRIG_1 | NIDMM_VAL_LBR_TRIG1 | | NIDMM_VAL_AUX_TRIG_1 | NIDMM_VAL_AUX_TRIG1 | Known IssuesYou can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-DMM 17.1. Bug FixesThe following items are the IDs and titles of a subset of issues fixed in NI-DMM. This is not an exhaustive list of issues fixed in the current version of NI-DMM. If you have a CAR ID, you can search this list to validate that the issue has been fixed. The following items are changes in NI-DMM 15.2 from NI-DMM 14.0. | ID | Fixed Issue | | 507445 | Fixed an issue in NI-DMM 14.0 where the Capacitance, Susceptance, Resistance, and Reactance attributes had incorrect IDs and wrote to the incorrect attributes in the NI-DMM property node. The attributes have been fixed with the correct IDs and now write to the correct attribute. The Susceptance and Resistance attributes were incorrectly set as integer types, producing an IVI_ERROR_TYPES_DO_NOT_MATCH error. The attributes have been fixed to doubles. | Accessing the HelpRefer to the NI Digital Multimeters Help, accessible from the Start menu under National Instruments and NI-DMM Documentation, for information about NI-DMM. Finding ExamplesIn LabVIEW, you can use the NI Example Finder to search or browse examples. NI–DMM examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–DMM examples) and their descriptions: - Click the Browse tab to locate examples by task at Hardware Input and Output»Modular Instruments»NI–DMM or by directory structure at instr»niDMM.
- Click the Search tab to search all installed examples by keyword. For example, search for "DMM" to locate all NI-DMM examples.
The NI Example Finder is also available in LabWindows/CVI by selecting Help»Find Examples. You can also access all the installed NI–DMM examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-DMM»Examples. Examples also are available online that demonstrate NI-DMM functionality. Refer to ni.com/examples for these examples and for more information. IVI Compliance Package FunctionalityNI-DMM no longer installs IVI Compliance Package. NI-DMM supports IVI configuration and runtime, but no longer supports the following features: - LabVIEW and CVI IVI class driver APIs for developing IVI interchangeable applications
- IVI Class Simulation drivers
- IVI-COM Adapters
If you want to use the above features, you must install IVI Compliance Package separately, either from ni.com/downloads or from the NI Device Drivers 2017 DVD. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
- To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, How Can I Determine the Type and Version of My NI Installer?.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. LabVIEW NXG Support and ConsiderationsThe following sections detail considerations for using LabVIEW NXG with NI-DMM. LabVIEW NXG Operating Systems and System RequirementsSoftware support for LabVIEW NXG differs in the following ways: - System requirements—Only 64-bit (x64) processors are supported.
- Operating system—Only 64-bit operating systems are supported. Refer to the Supported Operating Systems section for more information.
LabVIEW NXG Hardware Support407x, 406x, and 4050 DMMs - PCI-4065
- PCI-4070
- PCIe-4065
- PXI-4065
- PXI-4070
- PXI-4071
- PXI-4072
- USB-4065
408x DMMs - PXIe-4080
- PXIe-4081
- PXIe-4082
Installing NI-DMM for LabVIEW NXGNI automates LabVIEW NXG installation using a package manager. Complete the following steps to install NI-DMM for LabVIEW NXG. - Visit ni.com/info and enter the info code NXGDownload to access the LabVIEW NXG download page.
- Click Download LabVIEW NXG 1.0.
- NI Package Manager installs, then automatically opens a download window.
- Select LabVIEW NXG Suite and click the green Install button.
- Select LabVIEW NXG 1.0 and NI-DMM.
- Complete the installer instructions to download LabVIEW NXG 1.0 and NI-DMM.
LabVIEW NXG HelpView context help in LabVIEW by pressing and hovering over an object. Search for items using the search bar in the upper right corner of the LabVIEW window. You can also view context help for the search results. Additional documentation is available online at ni.com/manuals. LabVIEW NXG ExamplesLaunch LabVIEW and click the Learning tab. LabVIEW lessons are located in the Lessons tab, and LabVIEW Examples are located in the Examples tab. Follow the instructions in the lessons and examples. Legal InformationCopyright © 2007–2017 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 376310D-01 |
