查看: 2922|回复: 0
[NI驱动程序] NI-DMM 15.1 Driver Win32/64Eng NI数字万用表驱动程序15.1下载
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-14 23:47:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DMM
    NI-DMM支持使用NI数字万用表的客户。
    NI-DMM是与所有NI可编程数字万用表(DMM)进行通信必需的NI仪器驱动程序。NI-DMM是一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,而且包含了交互式软件前面板和示例。
    Win32/64Eng/Jpn
    15.1
    文件大小: 2115979011 字节 (1.97 GB)
    修改日期: 2015-07-17 06:40
    MD5: b5d24676368af464cb207964076a7d46(官方正确)
    SHA1: b81b40190e6ee53134053a491de0d097d3e27ecf
    SHA256: 75a6391c318d0e3d21bb615633b7af848491809c0dee92880a8d0b82efab6deb
    CRC32: dd1a181f
    DMM15.1.txt (573 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DMM Readme
    Version 15.1
    Thank you for using NI-DMM. This file contains important information about NI-DMM and is organized into the following sections:
    Accessing VIs and Functions
    Driver Version Naming Changes
    Uninstalling/Modifying NI-DMM
    NI-DMM Drops Support for Microsoft Windows XP and Windows Server 2003 in 2016
    NI-DMM 15.1 includes the following new features:
    • Support for debugging an NI-DMM device while in use by another application, by monitoring or controlling the device in the NI-DMM Soft Front Panel.
      Note  NI-DMM 15.1 Soft Front Panel no longer supports IVI device simulation.
    NI-DMM 14.0 includes the following new features:
    • Support for LabVIEW 2014 (32- and 64-bit).
    NI-DMM 3.1 includes the following new features:
    • Support for LabVIEW 2013 (32- and 64-bit).
    NI-DMM 3.0.6 includes the following new features:
    • Support for LabVIEW 2012 (32- and 64-bit).
    NI-DMM 3.0.5 includes the following new features:
    • Support for LabVIEW 2011 (32- and 64-bit).
    NI-DMM 3.0.4 includes the following bug fixes:
    • Fix related to code not generating in the Japanese versions of LabVIEW when the NI-DMM/Switch Express VI was used with switch devices (ID 276993).
    • Fix related to a loading issue with the NI-DMM/Switch Express VI in LabVIEW 2010 (64-bit) (ID 246480).
    NI-DMM 3.0.3 includes the following new features:
    • Support for LabVIEW 2010 (32- and 64-bit).
    • Fix related to a custom installer built on a 32-bit OS using LabVIEW, LabWindows™/CVI™, or NI TestStand does not deploy NI-DMM or its dependent user applications on a 64-bit OS (ID 228650).
    NI-DMM 3.0.2 includes the following new features:
    • Updated the external calibration procedure to accommodate a hardware change on newer NI 407x devices. NI-DMM 3.0.2 or later is required for external calibration beginning with NI PCI-4070 revision 189380G-01, NI PXI-4070 revision 191485G-01, NI PXI-4071 revision 191485J-02, and NI PXI-4072 revision 191485F-03.
    • Fixed an issue with NI 407x devices that caused an internal hardware error when taking measurements with autorange (ID 196451).
    NI-DMM 3.0.1 includes the following bug fix:
    • Fix related to offsets in AC current measurements for 407x devices (ID 135829).
    NI-DMM 3.0 includes the following new features:
    • Introduction of the niDMM_GetErrorMessage function.
    • Support for LabVIEW 2009 (32-bit) and LabVIEW 2009 (64-bit).
    • Support for temperature measurements in the NI-DMM/Switch Express VI.
    • Support for temperature measurements in the DMM Soft Front Panel.
    • Support for 64-bit user mode.
    • C examples rewritten in ANSI C and makefile support added for 64-bit targets.
    NI-DMM 2.9 includes the following new features:
    • Support for LabVIEW 8.6.
    • Support for temperature measurements.
    • Japanese localization for driver, LabVIEW API, and documentation.
    • New behavior: Error and self test message strings now return localized values in LabVIEW. User applications that check the value of these strings (or trap errors by comparing the error cluster) may experience a change in behavior.
    • New behavior: Simulation now has increased realism. Timing and error reporting are more representative of an actual device.
    • Reset Device button in MAX has improved functionality. If you have selected an NI 4065/407x in the Devices and Interfaces configuration tree, the Reset Device button aborts any ongoing acquisitions before resetting the device to factory default.
    • New behavior: If you have selected an NI 4065/407x in MAX, the Test Panels button in MAX will launch the NI-DMM Soft Front Panel.
    • Temperature has been added to function.ctl. If this type def is being used in the prototype for a TestStand step, the step prototype will need to be reloaded before the sequence can be executed.
    NI-DMM 15.1 and later supports all of the following devices. Devices are listed under supported operating systems:
    Hardware ProductWindows XP SP3Windows 8.1/8.0/7/Vista
    NI PXI-4072
    √1
    NI PXI-4071
    √1
    NI PXI-4070
    √1
    NI PCI-4070
    NI PXI-4065
    √1
    NI PCIe-4065
    NI PCI-4065
    NI USB-4065
    NI PXI-4060
    X
    NI PCI-4060
    X
    NI PCMCIA-4050
    X
    NI PXI-4022
    √1
    1 MXI Express and MXI-4 are supported on Windows 8.1/8.0/7/Vista/XP SP3, but MXI-3 is supported on only Windows XP SP3.
    NI-DMM 15.1 and later supports the following operating systems:
    • Windows 8.1/8.0 (32- and 64-bit)
    • Windows 7 (32- and 64-bit)
    • Windows Vista (32- and 64-bit)
    Note  NI-DMM 3.0.4 and later does not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-DMM 3.0.2 or earlier.
    NI-DMM 15.1 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows XP Service Pack 3 (SP3): 128 MB
      • Windows 8.1/8.0/7/Windows Vista: 512 MB
    • Windows 8.1/8.0/7/Vista/XP SP3, with all available critical updates and service packs
    Recommended System
    The performance of waveform acquisitions at full rate (1.8 MS/s) on the NI 4070/4071/4072 depends highly on system-specific factors such as CPU speed, memory architecture, and system chipset characteristics. Simultaneous acquisitions on multiple NI 4070/4071/4072 devices or acquisitions of longer durations may require a faster processor or more memory. Other applications running at the same time may also affect performance.
    • RAM—
      • Windows XP SP3: 256 MB
      • Windows 8.1/8.0/7/Windows Vista: 1 GB
    • A screen resolution of 1024 x 768
    Note:  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-DMM. To add support for ADEs installed after installing NI-DMM, modify your NI-DMM installation or launch the NI-DMM installer again.
    • NI Labview 2012 SP1 (32- and 64-bit), 2013 SP1 (32- and 64-bit), 2014 SP1 (32- and 64-bit), 2015 (32- and 64-bit)
    • LabVIEW Real-Time Module 2012 SP1, 2013 SP1 (NI PXI-4065, NI PXI-4070, NI PXI-4071, and NI PXI-4072 devices only), 2014 (NI PXI-4065, NI PXI-4070, NI PXI-4071, and NI PXI-4072 devices only), 2015 (NI PXI-4065, NI PXI-4070, NI PXI-4071, and NI PXI-4072 devices only)
    • LabWindows™/CVI™ 2009 or later
    • LabWindows/CVI Real-Time Module 2010 or later (NI PXI-4065, NI PXI-4070, NI PXI-4071, and NI PXI-4072 devices only)
    • If you are running your application on an RT target, 128 MB of memory or more is required.
      • Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows 7/Vista: Users\Public\Documents\National Instruments
      • Windows 8.1 (32-bit)/8.0 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        • Windows 8.1 (32-bit)/8.0 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        Note  $(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 8.1/8.0/7/Vista/XP
    NI-DMM\Drivers\niDMM
    NI-DMM Function Panel\Drivers\niDMM\nidmm.fp
    NI-DMM Examples\niDMM\Examples
    NI-DMM Header files\Include
    NI-DMM Import Library files (32-bit)\Lib
    NI-DMM Import Library files (64-bit)\Lib_x64
    NI-DMM DLL (32-bit)\Bin
    Additional File Locations for Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI-DMM DLL (64-bit)\Bin
    Select Start»All Programs»National Instruments»NI-DMM»NI-DMM Soft Front Panel to launch the NI-DMM Soft Front Panel.
    Most documentation is available at Start»All Programs»National Instruments»NI-DMM»Documentation. The documentation set is composed of the following documents:
    DocumentFormatDescription
    NI Digital Multimeters HelpHTML/Windows HelpContains primary help content for NI-DMM. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to multimeter fundamentals.
    • Hardware device information
    • A complete reference for all NI-DMM programming functions and VIs
    NI Digital Multimeters Getting Started GuidePrinted and PDFContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
    Specifications for your devicePrinted and PDFLists technical specifications for your device.
    NI-DMM ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Introduction to NI-DMMHTMLContains information about driver documentation, examples, connecting to your instrument, configuring instrument settings, and known issues.
    NI-DMM IVI Compliance DocumentTXTContains information about IVI compliance.
    Note  To view the specifications, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    To use the .NET API, you must install the the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information on versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    NI-DMM Updates and Notifications
    National Instruments posts information about critical updates and security notifications on ni.com. Visit ni.com/info, and enter the info code updates to access this information.
    NI–DMM palette VIs are available from the Functions»Measurement I/O»NI–DMM palette.
    NI–DMM functions are available in LabWindows/CVI from the Instrument menu. To load the NI–DMM function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\niDMM\niDMM.fp.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI–DMM examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–DMM examples) and their descriptions:
    • Click the Browse tab to locate examples by task at Hardware Input and Output»Modular Instruments»NI–DMM or by directory structure at instr»niDMM.
    • Click the Search tab to search all installed examples by keyword. For example, search for "DMM" to locate all NI-DMM examples.
    You can also access all the installed NI–DMM examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-DMM»Examples.
    Examples also are available online that demonstrate NI-DMM functionality. Refer to ni.com/examples for these examples and for more information.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    NI-DMM versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: . For example, NI-DMM 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-DMM 3.1. The first version released under the new numbering scheme is NI-DMM 14.0.
    Perform the following procedure to uninstall NI-DMM 15.1:
    • Click Change/Remove.
    • Select NI-DMM 15.1 from the dialog box that appears.
    For Windows 8.x, complete the following steps:
    • Click the Uninstall button.
    As part of the NI–DMM installation, the following software is installed. To completely remove the NI–DMM installation from your system, you must also remove all of the following products:
    • NI-DMM Runtime 15.1 and later
    • NI LabVIEW SignalExpress 2012 (optional)
    • NI IVI Compliance Package 4.4
    • NI Measurement & Automation Explorer 14.5
    • NI-DAQmx 14.5.1
    • Traditional NI-DAQ 7.4.4 (optional)
    • NI-VISA 5.1.2
    • NI I/O Trace 3.0.1
    • NI System Configuration 15.0
    Caution  Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent upon, a message warns you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    Obsolete VIs/Functions
    The following VIs/functions are obsolete, and no maintenance is provided for these VIs/functions:
    Obsolete
    niDMM Calculate Accuracy
    niDMM Clear Error Info
    niDMM Get Error Info
    niDMM Configure Auto Zero Mode (LabVIEW only)
    niDMM Configure Measurement
    niDMM Configure Sample Delay Mode
    niDMM Error Query
    niDMM Get Error (LabVIEW only)
    niDMM Error Message (LabWindows/CVI only)
    Note  Obsolete VIs/functions may cause a warning popup in existing LabVIEW DMM applications after NI-DMM 3.1 is installed.
    The following triggers have been renamed in NI-DMM 15.1.
    NI-DMM C/CVI/VB Trigger Naming Changes[tr][/tr]
    Former nameNew name
    NIDMM_VAL_TTL0NIDMM_VAL_PXI_TRIG0
    NIDMM_VAL_TTL1NIDMM_VAL_PXI_TRIG1
    NIDMM_VAL_TTL2NIDMM_VAL_PXI_TRIG2
    NIDMM_VAL_TTL3NIDMM_VAL_PXI_TRIG3
    NIDMM_VAL_TTL4NIDMM_VAL_PXI_TRIG4
    NIDMM_VAL_TTL5NIDMM_VAL_PXI_TRIG5
    NIDMM_VAL_TLL6NIDMM_VAL_PXI_TRIG6
    NIDMM_VAL_TTL7NIDMM_VAL_PXI_TRIG7
    NIDMM_VAL_LBR_TRIG_0NIDMM_VAL_LBR_TRIG0
    NIDMM_VAL_LBR_TRIG_1NIDMM_VAL_LBR_TRIG1
    NIDMM_VAL_AUX_TRIG_1NIDMM_VAL_AUX_TRIG1
    You can access the software and documentation known issues list online. Refer to the NI-DMM 3.0.5, 3.0.6, 3.1, and 14.0 Known Issues at ni.com/info and enter Info Code extvks for an up-to-date list of known issues in NI-DMM 15.1.
    The following items are changes in NI-DMM 15.1 from NI-DMM 14.0.
    507445Fixed an issue in NI-DMM 14.0 where the Capacitance, Susceptance, Resistance, and Reactance attributes had incorrect IDs and wrote to the incorrect attributes in the NI-DMM property node. The attributes have been fixed with the correct IDs and now write to the correct attribute. The Susceptance and Resistance attributes were incorrectly set as integer types, producing an IVI_ERROR_TYPES_DO_NOT_MATCH error. The attributes have been fixed to doubles.
    There are no changes in NI-DMM 14.0 from NI-DMM 3.1.
    The following items are changes in NI-DMM 3.0.6 from NI-DMM 3.0.5.
    305548Fixed an issue in NI-DMM 3.0.5 where you could not change the calibration password on the NI 4070/4071/4072.
    The following items are changes in NI-DMM 3.0.4 from NI-DMM 3.0.3.
    276993Fixed an issue in NI-DMM 3.0.3 where code was not generating in the Japanese versions of LabVIEW when the NI-DMM/Switch Express VI was used with switch devices.
    246480Fixed an issue where the NI-DMM/Switch Express VI did not load in LabVIEW 2010 (64-bit).
    The following items are changes in NI-DMM 3.0.3 from NI-DMM 3.0.2.
    228650Fixed an issue in which a custom installer built on a 32-bit OS using LabVIEW, LabWindows/CVI, or NI TestStand does not deploy NI-DMM or its dependent user applications on a 64-bit OS.
    The following items are changes in NI-DMM 3.0.2 from NI-DMM 3.0.1.
    196451Fixed an issue with NI 407x devices that caused an internal hardware error when taking measurements with autorange.
    The following items are changes in NI-DMM 3.0.1 from NI-DMM 3.0.
    135829Fixed an issue where NI 407x devices exhibited larger than normal offsets in AC current measurements when the Auto Zero property/attribute was set to Auto or Off after performing a self-calibration or external calibration.
    The following items are changes in NI-DMM 3.0 from NI-DMM 2.9.
    112297Fixed an issue where, when taking LC measurements, the backlog returned from the niDMM_FetchMultipoint function returned the number of points sampled prior to averaging rather than the number of points available.
    116484Fixed an issue where, if the error message was too long, the buffer returned by the niDMM_error_message function was not null-terminated. Now, the buffer returned by the niDMM_error_message function is always null-terminated.
    131868Fixed an issue where niDMM_ConfigureRTDCustom and niDMM_ConfigureThermistorCustom set the C value to the user-specified value from the B parameter rather than from the C parameter.
    157349If you upgraded to NI-DAQmx 8.9.0 or later after installing NI-DMM 2.9, then installing NI-DMM 3.0 or later will again enable switch devices to be used in the NI-DMM/Switch Express VI.
    When you install National Instruments software on Microsoft Windows 8.x, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (MAX), and the new NI Launcher.
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.x) or click the down arrow on the bottom left of the screen (Windows 8.1).
    NI-DMM Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments NI-DMM will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-DMM that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2007–2015 National Instruments Corporation. All rights reserved.
    Members of the National Instruments Alliance Partner Program are business entities independent from National Instruments and have no agency, partnership, or joint-venture relationship with National Instruments.
    GMT+8, 2025-11-19 09:01
