查看: 3385|回复: 0
[NI驱动程序] NI-DMM 3.0.6 Driver Win32/64Eng NI数字万用表驱动程序3.0.6下载
    9 小时前
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2021-1-14 23:38:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DMM
    NI-DMM支持使用NI数字万用表的客户。
    NI-DMM是与所有NI可编程数字万用表(DMM)进行通信必需的NI仪器驱动程序。NI-DMM是一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,而且包含了交互式软件前面板和示例。
    Win32/64Eng/Jpn
    3.0.6
    文件大小: 1949153928 字节 (1.82 GB)
    修改日期: 2012-08-14 03:26
    MD5: aeae9fba1ad7a363d526563717d8ab80(网盘可秒传)
    SHA1: f82d1e00e5e87aebdccf1cf44e49b7aab8edc5ac
    SHA256: 73ae712f4e3597e0d5098cee8711a2d45f5439e7504d9a6bad47289a2a9d7b19
    CRC32: 9b680604
    DMM3.0.6.txt (575 Bytes, 下载次数: 1, 售价: 10 圆)
    NI-DMM Readme
    Version 3.0.6
    Thank you for using NI-DMM. This file contains important information about NI-DMM and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Uninstalling/Modifying NI-DMM
    • Examples
    • Obsolete VIs/Functions
    • Known Issues
    • Bug Fixes
    NI-DMM 3.0.6 includes the following new features:
    • Support for LabVIEW 2012 (32-bit) and LabVIEW 2012 (64-bit).
    NI-DMM 3.0.5 includes the following new features:
    • Support for LabVIEW 2011 (32-bit) and LabVIEW 2011 (64-bit).
    NI-DMM 3.0.4 includes the following bug fixes:
    • Fix related to code not generating in the Japanese versions of LabVIEW when the NI-DMM/Switch Express VI was used with switch devices (ID 276993).
    • Fix related to a loading issue with the NI-DMM/Switch Express VI in LabVIEW 2010 (64-bit) (ID 246480).
    NI-DMM 3.0.3 includes the following new features:
    • Support for LabVIEW 2010 (32-bit) and LabVIEW 2010 (64-bit).
    • Fix related to a custom installer built on a 32-bit OS using LabVIEW, LabWindows™/CVI™, or NI TestStand does not deploy NI-DMM or its dependent user applications on a 64-bit OS (ID 228650).
    NI-DMM 3.0.2 includes the following new features:
    • Updated the external calibration procedure to accommodate a hardware change on newer NI 407x devices. NI-DMM 3.0.2 or later is required for external calibration beginning with NI PCI-4070 revision 189380G-01, NI PXI-4070 revision 191485G-01, NI PXI-4071 revision 191485J-02, and NI PXI-4072 revision 191485F-03.
    • Fixed an issue with NI 407x devices that caused an internal hardware error when taking measurements with autorange (ID 196451).
    NI-DMM 3.0.1 includes the following bug fix:
    • Fix related to offsets in AC current measurements for 407x devices (ID 135829).
    NI-DMM 3.0 includes the following new features:
    • Introduction of the niDMM_GetErrorMessage function.
    • Support for LabVIEW 2009 (32-bit) and LabVIEW 2009 (64-bit).
    • Support for temperature measurements in the NI-DMM/Switch Express VI.
    • Support for temperature measurements in the DMM Soft Front Panel.
    • Support for 64-bit user mode.
    • C examples rewritten in ANSI C and makefile support added for 64-bit targets.
    NI-DMM 2.9 includes the following new features:
    • Support for LabVIEW 8.6.
    • Support for temperature measurements.
    • Japanese localization for driver, LabVIEW API, and documentation.
    • New behavior: Error and self test message strings now return localized values in LabVIEW. User applications that check the value of these strings (or trap errors by comparing the error cluster) may experience a change in behavior.
    • New behavior: Simulation now has increased realism. Timing and error reporting are more representative of an actual device.
    • Reset Device button in MAX has improved functionality. If you have selected an NI 4065/407x in the Devices and Interfaces configuration tree, the Reset Device button aborts any ongoing acquisitions before resetting the device to factory default.
    • New behavior: If you have selected an NI 4065/407x in MAX, the Test Panels button in MAX will launch the NI-DMM Soft Front Panel.
    • Temperature has been added to function.ctl. If this type def is being used in the prototype for a TestStand step, the step prototype will need to be reloaded before the sequence can be executed.
    NI-DMM 3.0.6 and later supports all of the following devices. Devices are listed under supported operating systems:
    Hardware ProductWindows XP SP3Windows 7/Vista
    NI PXI-4072
    √1
    NI PXI-4071
    √1
    NI PXI-4070
    √1
    NI PCI-4070
    NI PXI-4065
    √1
    NI PCIe-4065
    NI PCI-4065
    NI USB-4065
    NI PXI-4060
    X
    NI PCI-4060
    X
    NI PCMCIA-4050
    X
    NI PXI-4022
    √1
    1 MXI Express and MXI-4 are supported on Windows 7/Vista/XP SP3, but MXI-3 is supported on only Windows XP SP3.
    NI-DMM 3.0.6 and later supports the following operating systems:
    Note  NI-DMM 3.0.4 and later does not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-DMM 3.0.2 or earlier.
    NI-DMM 3.0.6 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows XP Service Pack 3 (SP3): 128 MB
      • Windows 7/Windows Vista: 512 MB
    • Windows 7/Vista/XP SP3, with all available critical updates and service packs
    Recommended System
    The performance of waveform acquisitions at full rate (1.8 MS/s) on the NI 4070/4071/4072 depends highly on system-specific factors such as CPU speed, memory architecture, and system chipset characteristics. Simultaneous acquisitions on multiple NI 4070/4071/4072 devices or acquisitions of longer durations may require a faster processor or more memory. Other applications running at the same time may also affect performance.
    • RAM—
      • Windows XP SP3: 256 MB
      • Windows 7/Windows Vista: 1 GB
    • A screen resolution of 1024 x 768
    • LabVIEW 2009 SP 1 (32-bit), 2009 SP 1 (64-bit), 2010 SP 1 (32-bit), 2010 SP 1 (64-bit), 2011 SP1 (32-bit), 2011 SP1 (64-bit), 2012 (32-bit), or 2012 (64-bit)
    • LabVIEW Real-Time Module 2009 SP 1, 2010 SP 1, 2011 SP 1, or 2012 (NI PXI-4065, NI PXI-4070, NI PXI-4071, and NI PXI-4072 devices only)
    • LabWindows/CVI 9.0.1 or later
    • LabWindows/CVI Real-Time Module 2009 or later (NI PXI-4065, NI PXI-4070, NI PXI-4071, and NI PXI-4072 devices only)
    • If you are running your application on an RT target, 128 MB of memory or more is required.
      • Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows 7/Vista: Users\Public\Documents\National Instruments
      • Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        • Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        Note  $(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 7 (32-bit)/Vista (32-bit)/XP
    NI-DMM\Drivers\niDMM
    NI-DMM Function Panel\Drivers\niDMM\nidmm.fp
    NI-DMM Examples\niDMM\Examples
    NI-DMM Header files\Include
    NI-DMM Import Library files (32-bit)\Lib
    NI-DMM Import Library files (64-bit)\Lib_x64
    NI-DMM DLL (32-bit)\Bin
    Additional File Locations for Windows 7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 7 (64-bit)/Vista (64-bit)
    NI-DMM DLL (64-bit)\Bin
    Most documentation is available at Start»All Programs»National Instruments»NI-DMM»Documentation. The documentation set is composed of the following documents:
    • NI-DMM 3.0.6 Readme
    • NI Digital Multimeters Getting Started Guide—Printed and PDF format. Contains hardware and software installation, MAX configuration, and signal connection information.
    • NI Digital Multimeters Help—HTML help format. Contains power supply fundamentals, hardware device overview, programming information, LabVIEW reference, and C/CVI/VB reference sections.
    • NI DMM Specifications—Printed and PDF format. Lists specifications for NI DMMs.
    • NI DMM Calibration Procedures—PDF format. Contains calibration instructions for NI DMMs.
    Note  To view the specifications, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    Perform the following procedure to uninstall NI-DMM 3.0.6:
    • Click Change/Remove.
    • Select NI-DMM 3.0.6 from the dialog box that appears.
    As part of the NI–DMM installation, the following software is installed. To completely remove the NI–DMM installation from your system, you must also remove all of the following packages:
    • NI LabVIEW SignalExpress 2010 (optional)
    • NI IVI Compliance Package 4.4
    • NI Measurement & Automation Explorer 5.0
    • NI-DAQmx 9.1.7
    • Traditional NI-DAQ 7.4.4 (optional)
    • NI-VISA 5.0
    • NI Spy 2.7.2
    Caution  Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent upon, a message warns you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    Examples
    Refer to Start»All Programs»National Instruments»NI-DMM»Examples for the examples for each ADE.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    The following VIs/functions are obsolete, and no maintenance is provided for these VIs/functions:
    Obsolete
    niDMM Calculate Accuracy
    niDMM Clear Error Info
    niDMM Get Error Info
    niDMM Configure Auto Zero Mode (LabVIEW only)
    niDMM Configure Measurement
    niDMM Configure Sample Delay Mode
    niDMM Error Query
    niDMM Get Error (LabVIEW only)
    niDMM Error Message (LabWindows/CVI only)
    Note  Obsolete VIs/functions may cause a warning popup in existing LabVIEW DMM applications after NI-DMM 3.0.6 is installed.
    You can access the software and documentation known issues list online. Refer to the NI-DMM 3.0.5 and 3.0.6 Known Issues List web page on the National Instruments Web site for an up-to-date list of known issues in NI-DMM 3.0.6.
    The following items are changes in NI-DMM 3.0.6 from NI-DMM 3.0.5.
    305548Fixed an issue in NI-DMM 3.0.5 where you could not change the calibration password on the NI 4070/4071/4072.
    The following items are changes in NI-DMM 3.0.4 from NI-DMM 3.0.3.
    276993Fixed an issue in NI-DMM 3.0.3 where code was not generating in the Japanese versions of LabVIEW when the NI-DMM/Switch Express VI was used with switch devices.
    246480Fixed an issue where the NI-DMM/Switch Express VI did not load in LabVIEW 2010 (64-bit).
    The following items are changes in NI-DMM 3.0.3 from NI-DMM 3.0.2.
    228650Fixed an issue in which a custom installer built on a 32-bit OS using LabVIEW, LabWindows/CVI, or NI TestStand does not deploy NI-DMM or its dependent user applications on a 64-bit OS.
    The following items are changes in NI-DMM 3.0.2 from NI-DMM 3.0.1.
    196451Fixed an issue with NI 407x devices that caused an internal hardware error when taking measurements with autorange.
    The following items are changes in NI-DMM 3.0.1 from NI-DMM 3.0.
    135829Fixed an issue where NI 407x devices exhibited larger than normal offsets in AC current measurements when the Auto Zero property/attribute was set to Auto or Off after performing a self-calibration or external calibration.
    The following items are changes in NI-DMM 3.0 from NI-DMM 2.9.
    112297Fixed an issue where, when taking LC measurements, the backlog returned from the niDMM_FetchMultipoint function returned the number of points sampled prior to averaging rather than the number of points available.
    116484Fixed an issue where, if the error message was too long, the buffer returned by the niDMM_error_message function was not null-terminated. Now, the buffer returned by the niDMM_error_message function is always null-terminated.
    131868Fixed an issue where niDMM_ConfigureRTDCustom and niDMM_ConfigureThermistorCustom set the C value to the user-specified value from the B parameter rather than from the C parameter.
    157349If you upgraded to NI-DAQmx 8.9.0 or later after installing NI-DMM 2.9, then installing NI-DMM 3.0 or later will again enable switch devices to be used in the NI-DMM/Switch Express VI.
    © 2007–2012 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-12-12 18:08
