查看: 3243|回复: 0
[NI驱动程序] NI-DMM 2.7.2 Driver Win32/64Eng NI数字万用表驱动程序2.7.2下载
    9 小时前
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2021-1-14 23:28:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DMM
    NI-DMM支持使用NI数字万用表的客户。
    NI-DMM是与所有NI可编程数字万用表(DMM)进行通信必需的NI仪器驱动程序。NI-DMM是一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,而且包含了交互式软件前面板和示例。
    Win32/64Eng
    2.7.2
    文件大小: 981949562 字节 (936.46 MB)
    修改日期: 2009-09-05 04:46
    MD5: e32e765a3951224fc91b370db00ea81b(官方正确)
    SHA1: 90f41e8cdd71f112dcc2911669cf2377e2509e42
    SHA256: 781f0a7c1faefdabb69648e01abee62d58010e06aec33c9e273647259ac58ee6
    CRC32: 9f257eed
    DMM2.7.2.txt (570 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DMM 2.7.2 Readme
    August 2007
    Thank you for using NI-DMM.
    This file contains important information about NI-DMM and is organized into the following sections:
    • New Features in NI-DMM 2.7.2
    • Supported Hardware
    • System Requirements
      • Software
      • Documentation
    • Uninstalling/Modifying NI-DMM 2.7.2
    • Examples
    • Obsolete VIs/Functions
    • Known Issues
    • Changes by Release
    • Support for LabVIEW 8.5.
      NI-DMM 2.7.2 and later supports all of the following devices.
      Devices are listed under supported operating systems:
      Hardware ProductWindows XP/2000Windows Vista
      NI PXI-4072
      √1
      NI PXI-4071
      √1
      NI PXI-4070
      √1
      NI PCI-4070
      NI PXI-4065
      √1
      NI PCIe-4065
      NI PCI-4065
      NI PXI-4060
      X
      NI PCI-4060
      X
      NI PCMCIA-4050
      X
      NI PXI-4022
      √1
      1 Notice that MXI-4 is supported on Windows Vista/XP/2000, but MXI-3 is supported on only Windows XP/2000.
      System RequirementsMinimum System Requirements
      • Processor—Pentium 200 MHz or equivalent
      • RAM—64 MB
      • Windows Vista/XP/2000, with all available critical updates and service packs
      Recommended System
      The performance of waveform acquisitions at full rate (1.8 MS/s) on the NI 4070/4071/4072 depends highly on system-specific factors such as CPU speed, memory architecture, and system chipset characteristics. Simultaneous acquisitions on multiple NI 4070/4071/4072 devices or acquisitions of longer durations may require a faster processor or more memory. Other applications running at the same time may also affect performance.
      • RAM—256 MB
      • A screen resolution of 1024 x 768
      Application Development Environments
      • LabVIEW 7.1, 8.0, 8.2, and 8.5
      • LabVIEW Real-Time Module 7.1.1, 8.0, 8.2, and 8.5 (NI PXI-4065, NI PXI-4070, NI PXI-4071, and NI PXI-4072 devices only)
        Note: If you are running your application on an RT target, at least 128 MB of memory is required.
      • LabWindows™/CVI™ 7.1, 8.0, and 8.1.
      • LabWindows™/CVI™ Real-Time Module (NI PXI-4065, NI PXI-4070, NI PXI-4071, and NI PXI-4072 devices only)
      • Microsoft Visual Basic 6.0
    Installed File Names and LocationsSoftware
    ItemInstalled Location on Windows XP/2000
    and Windows Vista (32-bit version)
    Windows Vista x64 Edition
    NI-DMMProgram Files\IVI\Drivers\niDMMProgram Files (x86)\IVI\Drivers\niDMM
    DocumentationProgram Files\IVI\Drivers\niDMM\DocumentationProgram Files (x86)\IVI\Drivers\niDMM\Documentation
    NI-DMM LabVIEW support\instr.lib\niDMM\instr.lib\niDMM
    NI-DMM LabVIEW Examples\examples\instr\niDMM\examples\instr\niDMM
    NI-DMM CVI supportProgram Files\IVI\Drivers\niDMMProgram Files (x86)\IVI\Drivers\niDMM
    NI-DMM CVI Examples\samples\niDMM\samples\niDMM
    NI-DMM Function PanelProgram Files\IVI\Drivers\niDMM\nidmm.fpProgram Files (x86)\IVI\Drivers\niDMM\nidmm.fp
    NI-DMM C/C++ Examples\VC\Examples\niDMM\VC\Examples\niDMM
    NI-DMM Header filesProgram Files\IVI\includeProgram Files (x86)\IVI\include
    NI-DMM Import Library filesProgram Files\IVI\LibProgram Files (x86)\IVI\Lib
    NI-DMM VB Examples\VB\Samples\niDMM\VB\Samples\niDMM
    NI-DMM DLLProgram Files\IVI\BinProgram Files (x86)\IVI\Bin
    DMM SFP (Soft Front Panel)Program Files\IVI\Drivers\niDMMProgram Files (x86)\IVI\Drivers\niDMM
    LabVIEW Run-Time Engine 8.2Program Files\National Instruments\Shared\
    LabVIEW Run-Time\8.2
    Program Files (x86)\National Instruments\Shared\
    NI SignalExpress 2.0Program Files\IVI\Drivers\niDMM\SignalExpressProgram Files (x86)\IVI\Drivers\niDMM\SignalExpress
    NI-DAQ 8.6Program Files\National Instruments\NI-DAQ\Program Files (x86)\National Instruments\NI-DAQ\
    IVI Compliance Package 3.0Program Files\National Instruments\IVIProgram Files (x86)\National Instruments\IVI
    NI-VISA 4.1WINDOWS\system32WINDOWS\system32
    Most documentation is available at Start»All Programs»National Instruments»NI-DMM»Documentation. The documentation set is composed of the following documents:
    NI-DMM 2.7.2 ReadmeNI Digital Multimeters Getting Started Guide
    Printed and PDF format. Includes safety, hardware & software installation, configuration in MAX, and wiring for common measurements information.
    NI Digital Multimeters Help
    HTML help format. Includes DMM fundamentals, device overviews, programming information, tutorials, LabVIEW reference, and C/C++/CVI/VB reference sections.
    NI PCMCIA-4050 SpecificationsNI PXI/PCI-4060 SpecificationsNI 4065 SpecificationsNI 4070/4072 SpecificationsNI 4071 SpecificationsNI 4065 6½—Digit Calibration ProcedureNI 4070/4072 6½—Digit FlexDMM Calibration Procedure
    NI 4071 7½—Digit FlexDMM Calibration ProcedureUninstalling/Modifying NI-DMM 2.7.2
    Perform the following procedure to uninstall NI-DMM 2.7.2:
    For Windows 2000/XP, complete the following steps:
    • Click Change/Remove.
    • Select NI-DMM 2.7.2 from the dialog box that appears.
    For Windows Vista, complete the following steps:
    Examples
    Refer to Start»All Programs»National Instruments»NI-DMM»Examples for the examples for each ADE.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    Any C and VB examples installed by a previous version of NI-DMM are copied to VXIpnp\WinNT\NIDMM\Examplesxx, where xx is the previous version number of NI-DMM. You can delete this directory if you do not need the old examples.
    The following VIs/functions are obsolete, and no maintenance is provided for these VIs/functions:
    Obsolete
    niDMM Calculate Accuracy
    niDMM Clear Error Info
    niDMM Get Error Info
    niDMM Configure Auto Zero Mode (LabVIEW only)
    • If you click a topic link in the NI-DMM C Reference Help section of the NI Digital Multimeters Help, you cannot use the Back button in the HTML Help window toolbar to return to the original topic.
    • The NI PCI/PCIe-4065 may produce undesired triggers on the Voltmeter Complete signal when configured for Auto Range measurements. To avoid undesired performance, do not trigger while configured for an Auto Range acquisition.
    • NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate, when using this product. These modes terminate any NI-DMM operation in progress. Notice that in Windows Vista or on a laptop computer, the default power management settings are likely to enable sleep mode.
    • When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run setup from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to the your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    • The NI PXI-4070 can not operate as a Traditional DAQ (Legacy) SCXI controller in Windows Vista.
    • The NI PXI-4070 was upgraded and new revisions of the device beginning with 191485A-01 are incompatible with versions of NI-DMM prior to 2.3. NI-DMM 2.3 and later provides support for all revisions of the NI PXI-4070.
    • The IVI Configuration Store file format now requires that all names be case-sensitive. If you use logical names, driver session names, or virtual names in your program, make sure that the name you use matches the name defined in the IVI Configuration Store file exactly, without any variations in the case of the characters in the name.
    • The NI 4065/4070/4071/4072 can be programmed only with NI-DMM. NI-DAQ function calls and DAQ virtual channels are not supported by the NI 4065/4070/4071/4072. Using NI-DAQ with the NI 4065/4070/4071/4072 can cause an error that requires a system reboot.
    • In MAX under the Configuring Device window for the NI 4065/4070/4071/4072, Run Test Panels is grayed out.
    • In MAX under the Configuring Device window for the NI 4065/4070/4071/4072, Test Resources always indicates that the device has passed the test regardless of the condition of the device.
    • If you are replacing the NI 4060 with the NI 4065 or NI 4070/4071/4072 in an application that uses triggering, consider the following differences in behavior:
      • The NI 4060 configured as an SCXI controller automatically sets the Measurement Complete (MC) destination to the location where SCXI is configured (external or internal PXI/SCXI trigger lines).
      • The NI 4065 and NI 4070/4071/4072 configured as an SCXI controller automatically sets the MC destination to NONE.
      If your application relies on the routing behavior of the NI 4060 by not explicitly calling niDMM Configure Measurement Complete Destination, you must modify your application by calling the VI/function. Alternately, the NI 4065 and NI 4070/4071/4072 can emulate NI 4060 routing behavior by specifying the following registry key:
      HKEY_LOCAL_MACHINE\Software\National Instruments\NI-DMM\CurrentVersion\legacyMCRoute
      where the value is a DWORD set to 1.
      Note: For Windows Vista x64, specify the following registry key:
      HKEY_LOCAL_MACHINE\Software\Wow6432Node\National Instruments\NI-DMM\CurrentVersion\legacyMCRoute
      Without this registry key, NI-DMM sets NIDMM_ATTR_MEAS_COMPLETE_DEST to NONE for the NI 4065 and NI 4070/4071/4072. With this registry key, NI-DMM sets NIDMM_ATTR_MEAS_COMPLETE_DEST to the location where SCXI communication is configured in the application.
    • There are known DLL collision issues with the Visual Basic debugger and National Instruments device drivers. A support DLL used by NI-DMM fails to load if Visual Basic has already loaded another DLL into the same address space. More information on this issue and solution are documented in KnowledgeBase entry 2Q1HG8A6. Refer to ni.com/support to access the KnowledgeBase.
    Changes by ReleaseChanges in NI-DMM 2.7.2 from NI-DMM 2.7.1
    Changes in NI-DMM 2.7.1 from NI-DMM 2.7
    • Support for the NI PXI-4065.
    • New behavior: For NI 4065 and NI 407x devices, NI-DMM 2.7 incorrectly swapped the Settling Time behavior of triggered and non-triggered multipoint measurements. This behavior resulted in overly-short Settling Times in triggering/switching applications, which could affect measurement quality, and overly-long Settling Times in non-triggered applications. This behavior has been corrected in NI-DMM 2.7.1.
    Changes in NI-DMM 2.7 from NI-DMM 2.6
    • Support for Windows Vista.
    • Datalogger support in NI LabVIEW SignalExpress 2.0 and later.
    Changes in NI-DMM 2.6 from NI-DMM 2.5
    • Support for the NI PCI/PCIe-4065.
    • Introduction of the niDMM Cal Adjust Linearization VI and the niDMM_CalAdjustLinearization function.
    • A change was made in NI-DMM 2.6 to ensure that NI 407x devices operate as expected in industrial PC chassis and across MXI configurations (including MXI Express).
    • A change was made in NI-DMM 2.6 to ensure that the NI 407x front-end is fully configured before returning from niDMM Initiate or niDMM Control (when the Control Action parameter is set to "Commit").
    • On versions of NI-DMM prior to 2.6, NI 4060 users may encounter a rare intermittent behavior that results in a hang or crash. This behavior is typically encountered upon initializing the device a second time within the same instance of an application environment such as LabVIEW. This behavior may also be seen during a calibration routine within Calibration Executive and has been corrected as of NI-DMM version 2.6.
    Changes in NI-DMM 2.5 from NI-DMM 2.4
    • Introduction of the DMM/Switch Express VI.
    • Introduction of the niDMM Control VI and the niDMM_Control function.
    • Support for LabVIEW 8.0.
    • Support for LabVIEW Real-Time Module 8.0 (NI PXI/PCI-4070, NI PXI-4071, and NI PXI-4072 only)
    • New behavior: Initializing a session with the niDMM Initialize VI or the niDMM_init function now closes any other existing sessions open to the same device in the same process. Calling the niDMM Initialize VI or the niDMM_init function therefore always results in the creation of a new session rather than returning an existing session.
    Changes in NI-DMM 2.4 from NI-DMM 2.3
    • Support for the NI PXI-4071.
    • Introduction of the NI-DMM Express VI.
    • Support for NI SignalExpress 1.1.
    • Introduction of the niDMM Config Measurement VI and the niDMM_ConfigureMeasurementDigits and niDMM_ConfigureMeasurementAbsolute functions.
    Changes in NI-DMM 2.3 from NI-DMM 2.2
    • Support for the NI PXI-4072.
    • Support for the LabVIEW Real-Time Module has been added. For more information about using NI-DMM with the LabVIEW Real-Time Module, launch the NI Digital Multimeters Help and select Programming with NI-DMM»Getting Started»Using NI-DMM in LabVIEW»Considerations for Using the LabVIEW Real-Time Module.
    • Inclusion of Measurement Studio C++ interface to NI-DMM.
    Changes in NI-DMM 2.2 from NI-DMM 2.1
    • Support for the NI PCI-4070.
    • Support for the NI PXI/PCI-4070 devices to control an SCXI chassis that contains NI-DAQmx SCXI modules has been added (NI PXI/PCI-4070 only).
    • Support in MAX for the Self-Test and Self-Calibrate buttons for NI-DAQmx devices has been added (NI PXI/PCI-4070 only).
    • Support for the "break-on-library-error" feature in LabWindows/CVI (CVI user protection).
    • NI-DMM removes Offset Compensation Ohms capability for ranges 100 kΩ and greater.
    • NI-DMM corrects the resistance reference adjustment function of the external calibration procedure.
    Changes in NI-DMM 2.1 from NI-DMM 2.0
    • Self-test and simulation have been added for the NI PXI-4070.
    • The 1 MΩ input resistance value is no longer valid for DC voltage measurements on the NI PXI-4070.
    • AC voltage measurements using the DC coupling on the NI PXI-4070 have been improved to account for a computational error.
    • A new error code, NIDMM_ERROR_INVALID_MEAS_COMP_DEST has been created. This error is returned if an Input Trigger or Sample Trigger source is set to the same value as the Measurement Complete (MC) destination.
    • The self-calibration algorithm for the NI PXI-4070 has been updated to improve the gain correction.
    • Resistance measurements have been improved for low resolutions that enable both ADC calibration and offset compensated ohms.
    © 1999–2007 National Instruments Corporation. All rights reserved.
    National Instruments, NI, ni.com, CVI, FlexDMM, LabVIEW, Measurement Studio, and NI-DMM are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    GMT+8, 2025-12-12 18:08
