查看: 2947|回复: 0
[NI驱动程序] NI-DMM 2.2 Driver Win32/64Eng NI数字万用表驱动程序2.2下载
    昨天 09:17
  • 签到天数: 3713 天
    连续签到: 40 天
    发表于 2021-1-14 23:05:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DMM
    NI-DMM支持使用NI数字万用表的客户。
    NI-DMM是与所有NI可编程数字万用表(DMM)进行通信必需的NI仪器驱动程序。NI-DMM是一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,而且包含了交互式软件前面板和示例。
    Win32/64Eng
    2.2
    文件大小: 33727488 字节 (32.17 MB)
    修改日期: 2010-04-25 03:22
    MD5: fe21b064f328f15375430ad235f6a9f3(官方正确)
    SHA1: b8deb589a73241697b268f09d32f0cbc27f7c7b5
    SHA256: 230a5691bfdf3a15a7a2a595f92152aea8ec6e3149434306022b8b40da25426a
    CRC32: 05c7249f
    DMM2.2.txt (567 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DMM 2.2 Readme File
    (c) Copyright 1999–2003 National Instruments Corporation. All rights reserved.
    Trademarks: CVI, LabVIEW, National Instruments, ni.com, and NI-DMM are trademarks of National Instruments Corporation. Product and company names mentioned herein are trademarks or trade names of their respective companies.
    This file contains the following information:
    • New Features in NI-DMM 2.2
    • Supported DMMs
    • System Requirements
    • Installation Instructions
      • Software Files
      • Documentation Files
    • Uninstalling/Modifying NI-DMM 2.2
    • New Examples
    • Obsolete/VIs Functions
    • Changes in NI-DMM 2.2 from NI-DMM 2.1.2
    • Changes in NI-DMM 2.1.2 from NI-DMM 2.1.1
    • Changes in NI-DMM 2.1.1 from NI-DMM 2.1
    • Changes in NI-DMM 2.1 from NI-DMM 2.0.1
    • Changes in NI-DMM 2.0.1 from NI-DMM 2.0
    • Changes in NI-DMM 2.0 from NI-DMM 1.6
    • Known Issues
    • Support for the NI PCI-4070
    • Support for the NI PXI/PCI-4070 devices to control an SCXI chassis that contains NI-DAQmx SCXI modules (NI PXI/PCI-4070 only)
    • Support for the Self-Test and Self-Calibrate buttons in Measurement & Automation Explorer (MAX) for NI-DAQmx devices (NI PXI/PCI-4070 only)
    • Support for LabWindowsTM/CVITM user protection
    Supported DMMs
    NI-DMM 2.2 and later supports the following DMMs:
    • NI PXI-4070
    • NI PCI-4070
    • NI PXI-4060
    • NI PCI-4060
    • NI PCMCIA-4050
    System RequirementsMinimum System Requirements
    • Processor: Pentium 200 MHz or equivalent
    • RAM: 64 MB
    • A PXI chassis and controller, a desktop computer, or a laptop with a PCMCIA slot
    • 1/8 in. flathead screwdriver
    • Number 1 Phillips screwdriver
    Recommended System
    The performance of waveform acquisitions at full rate (1.8 MS/s) on the NI PXI-4070 depends highly on system-specific factors such as CPU speed, memory architecture, and system chipset characteristics. Simultaneous acquisitions on multiple NI PXI-4070s or acquisitions of longer durations may require a faster processor or more memory. Other applications running at the same time may also affect performance.
    • Processor: Pentium III/Celeron 600 MHz or equivalent
    • RAM: 256 MB
      • Windows 2000
      • Windows NT 4.0 service pack 6
      • Windows XP
      • Windows Me
      • Windows 98SE
    • One of the following Application Development Environments (ADE) is recommended:
      • LabVIEW 6.1 or later
      • LabWindows/CVI 6.0 or later
      • Microsoft Visual C++ 6.0 or later
      • Microsoft Visual Basic 6.0
    The NI-DMM 2.2 Web installation requires the following software components, which can be downloaded from ni.com:
    • NI-DAQ version 7.0 or higher.
    • NI-VISA or NI-VISA Run-Time Engine version 2.6.0 or higher.
    • IVI Compliance Package 2.0 or higher.
    • NI LabVIEW 7.0 Run-Time Engine.
    The following components are installed for NI-DMM 2.2:
    Software Files
    ItemInstalled Location
    NI-DMMProgram Files\IVI\Drivers\niDMM
    DocumentationProgram Files\IVI\Drivers\niDMM\Documentation
    NI-DMM LabVIEW support\instr.lib\NIDMM
    NI-DMM LabVIEW Examples\examples\instr\NIDMM
    NI-DMM CVI 6.0 supportVXIpnp\WIN[95|NT]\NIDMM
    NI-DMM CVI 7.0 supportProgram Files\IVI\Drivers\niDMM
    NI-DMM CVI Examples\samples\NIDMM
    NI-DMM C/C++ Examples\VC\Examples\niDMM
    NI-DMM VB Examples\VB\Samples\niDMM
    DMM-SFP (Soft Front Panel)Program Files\IVI\Drivers\niDMM
    Documentation Files
    Most documentation is available at Start與rograms臧ational Instruments臧I-DMM聞ocumentation. The documentation set is composed of the following documents:
    NI-DMM 2.2 Readme FileNI Digital Multimeters Getting Started Guide
    Printed and PDF format. Includes safety, hardware & software installation, configuration in MAX, and wiring for common measurements information.
    NI Digital Multimeters Help
    HTML help format. Inlcudes DMM fundamentals, device overviews, programming information, tutorials, and VI and CVI/C++/VB function references.
    NI-DMM Instrument Driver Quick Reference Guide
    Printed and PDF formats. Lists the VIs/Functions, the parameters, and the parameter types available with NI-DMM 2.2.
    Specifications for the NI PCMCIA-4050Specifications for the NI PXI/PCI-4060Specifications for the NI PXI/PCI-4070
    NI PXI-4070 61/2 Digit FlexDMM Calibration ProcedureUninstalling/Modifying NI-DMM 2.2
    For Windows 2000/NT/XP/Me/98, complete the following:
    • Open the Control Panel from the Start\Settings\Control Panel Menu and select Add\Remove Programs.
    • Select National Instruments Software from the list provided and click Change or Remove.
    • Select NI-DMM 2.2 from the list provided and choose the appropriate action.
    New Examples
    NI-DMM 2.0 included a completely new set of examples covering single point measurements, multipoint measurements, and triggering. NI-DMM 2.1 added new examples for waveform acquisitions and performance for the NI 4070.
    Refer to Start與rograms臧ational Instruments臧I-DMM聚xamples for the examples for each ADE.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    A complete example list is available in the NI Digital Multimeters Help at Start與rograms臧ational Instruments臧I-DMM聞ocumentation臧I Digital Multimeters Help.
    Any C and VB examples installed by a previous version of NI-DMM are copied to VXIpnp\WIN[95|NT]\NIDMM\Examplesxx, where xx is the previous version number of NI-DMM. You can delete this directory if you do not need the old examples.
    Obsolete Functions/VIs
    The following functions are considered obsolete in NI-DMM 2.0 and later:
    Note: The listed functions are obsolete and are replaced by new ones as described below. However, NI-DMM 2.0 still supports the use of obsolete functions, which means that you can run programs containing these functions. We suggest, however, that your future development should use the new model as obsolete functions will not be supported in versions of NI-DMM beyond 2.0. Obsolete functions are not supported by the NI 4070. No maintenance will be provided for these functions.
    ObsoleteReplacement
    niDMM Calculate Accuracy.vi
    niDMM_ClearErrorInfoniDMM_ClearError
    niDMM_GetErrorInfoniDMM_GetError
    niDMM Configure Auto Zero Mode.vi (LabVIEW only)niDMM Configure Auto Zero.vi
    • Support for the NI PCI-4070 has been added.
    • Support for the NI PXI/PCI-4070 devices to control an SCXI chassis that contains NI-DAQmx SCXI modules has been added (NI PXI/PCI-4070 only).
    • Support in MAX for the Self-Test and Self-Calibrate buttons for NI-DAQmx devices has been added (NI PXI/PCI-4070 only).
    • Support for the "break-on-library-error" feature in LabWindows/CVI (CVI user protection).
    • NI-DMM removes Offset Compensation Ohms capability for ranges 100 kΩ and greater.
    • NI-DMM corrects the resistance reference adjustment function of the external calibration procedure.
    • Self-test and simulation have been added for the NI 4070.
    • The 1 MΩ input resistance value is no longer valid for DC voltage measurements on the NI 4070.
    • AC voltage measurements using the DC coupling on the NI 4070 have been improved to account for a computational error.
    • A new error code, NIDMM_ERROR_INVALID_MEAS_COMP_DEST has been created. This error is returned if an Input Trigger or Sample Trigger source is set to the same value as the Measurement Complete (MC) destination.
    • The self-calibration algorithm for the PXI-4070 has been updated to improve the gain correction.
    • Resistance measurements have been improved for low resolutions that enable both ADC calibration and offset compensated ohms.
    Changes in NI-DMM 2.0 from 1.6
    • The NI PCI-4060 supports Sample Trigger set to Software.
    • Interaction problems with TestStand have been resolved.
    • The DMM-SFP (soft front panel) supports device numbers greater than 15.
    • Application examples were removed from the NI-DMM palette and are located at \instr.lib\NIDMM\nidmm_apps.llb.
    • Trigger Delay parameter can be set to Auto Delay OFF (-2).
    • Range parameter can be set to AutoRange OFF (-2).
    • Upgrading from NI-DMM 1.5 to NI-DMM 2.2 on a Windows NT 4.0 system can result in one or more error messages. To completely install NI-DMM 2.2 on such a system, you must acknowledge these error messages by clicking the OK dialog boxes.
    • The IVI Configuration Store file format now requires that all names be case-sensitive. If you use logical names, driver session names, or virtual names in your program, make sure that the name you use matches the name defined in the IVI Configuration Store file exactly, without any variations in the case of the characters in the name.
    • The NI 4070 can be programmed only with NI-DMM. NI-DAQ function calls and DAQ virtual channels are not supported by the NI 4070. Using NI-DAQ with the NI 4070 can cause an error that requires a system reboot.
    • In Measurement & Automation Explorer (MAX) under the Configuring Device window for the NI 4070, Run Test Panels is grayed out.
    • In MAX under the Configuring Device window for the NI 4070, Test Resources always indicates that the device has passed the test regardless of the condition of the device.
    • If you are replacing the NI PXI-4060 with the NI PXI-4070 in an application that uses triggering, consider the following differences in behavior:
      • The NI 4060 configured as an SCXI controller automatically sets the Measurement Complete (MC) destination to the location where SCXI is configured (external or internal PXI/SCXI trigger lines).
      • The NI 4070 configured as an SCXI controller automatically sets the MC destination to NONE.
      If your application relies on the routing behavior of the NI 4060 by not explicitly calling niDMM Configure Measurement Complete Destination, you must modify your application by calling the VI/function. Alternately, the NI 4070 can emulate NI 4060 routing behavior by specifying the following registry key:
      HKEY_LOCAL_MACHINE\Software\National Instruments\NI-DMM\CurrentVersion\legacyMCRoute
      where the value is a DWORD set to 1.
      Without this registry key, NI-DMM sets NIDMM_ATTR_MEAS_COMPLETE_DEST to NONE for the NI 4070. With this registry key, NI-DMM sets NIDMM_ATTR_MEAS_COMPLETE_DEST to the location where SCXI communication is configured in the application.
    • There are known DLL collision issues with the Visual Basic debugger and National Instruments device drivers. A support DLL used by NI-DMM fails to load if Visual Basic has already loaded another DLL into the same address space. More information on this issue and solution are documented in KnowledgeBase entry 2Q1HG8A6. Refer to ni.com/support to access the KnowledgeBase.
    GMT+8, 2025-11-16 10:59
