查看: 3521|回复: 0
[LV工具模块] LabVIEW SystemLink Toolkit 2020R4 Win32/64Eng LabVIEW系统连接工具包SLT20.6.0下载
    7 小时前
  • 签到天数: 3535 天
    发表于 2021-1-6 23:39:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW SystemLink工具包提供了LabVIEW或LabVIEW NXG与SystemLink Server或SystemLink Cloud账户进行通信的工具。
    LabVIEW SystemLink工具包是一个软件附件,包含用于LabVIEW的SystemLink API。该附件可通过编程方式访问SystemLink数据服务,这样就可在SystemLink Web应用程序之外集成SystemLink和LabVIEW。您可以使用LabVIEW SystemLink工具包为测试和测量系统创建VI或WebVI。
    校验和
    2020R4 20.6.0
    文件大小: 356384768 字节 (339.88 MB)
    修改日期: 2020-12-16 02:15
    MD5: bf7494bcb3fac537eab8d0b0dfca52a8(官方正确)
    SHA1: ca6340efaf692b15ced82376a5a820c93792d70c
    SHA256: b2b0b8aec908d0f061ab3701ca6faab3f69211242084f93ba5af27b9fb1cfd28
    CRC32: 93c376d3
    百度网盘下载地址和NI官方下载地址:
    请注册视觉论坛用户,登录后购买附件下载查看,充值请联系在线客服
    SystemLink LV Support 20.6.txt (676 Bytes, 下载次数: 1, 售价: 10 元)
    NI SystemLink 2020 R4 Readme
    December 2020
    This file contains important information about SystemLink, including system requirements and known issues.
    Licensing Information for SystemLink Clients
    SystemLink Drops Support for Windows 7, Windows 8.1, Windows Server 2008 R2, Windows Server 2012 R2, and All 32-Bit Windows Operating Systems in 2021
    Use SystemLink to discover and manage systems on a server. Create and deploy packages to all your managed systems. Leverage SystemLink data services to visualize data, trigger alarms, monitor tests, manage assets, and transfer files to a server. SystemLink TDM is a Big Analog Data™ solution for automated preparation and analysis of large amounts of data in various formats and structures from different geographic locations.
    SystemLink has the following minimum system requirements:
    Server Requirements
    Windows, less than 50 nodes
    Windows, 50+ nodes, SystemLink TDM
    OS (64-bit only)
    Windows Server 2019 R2
    Windows Server 2016
    Windows Server 2012 R2 1
    Windows 7 SP1 or higher
    Windows Server 2016
    Processor
    4-core recommended or higher
    8-core recommended or higher
    RAM
    16 GB minimum
    32+ GB recommended
    32 GB minimum
    64+ GB recommended
    Disk
    6 GB minimum
    8+ GB recommended
    16+ GB recommended
    1 NI software installs VC2015 runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2, which require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    Note  Refer to SystemLink Drops Support for Windows 7, Windows 8.1, Windows Server 2008 R2, Windows Server 2012 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  SystemLink TDM does not support server versions from the Microsoft Semi-Annual Channel. In addition, SystemLink TDM does not support Windows Server Core mode.
    Target Requirements (Managed Nodes)
    NI Linux Real-Time
    OS
    Windows 7 SP1 (64-bit) or higher
    Windows 7 SP1 (32-bit) or higher
    NI Linux Real-Time 2019, 2020
    (Supports LabVIEW RT 2019, 2020, and NXG 5.0 and later)
    Processor
    Pentium 4 G1 (or equivalent) or later
    All Intel and ARM models supported
    RAM
    2 GB minimum
    4 GB recommended
    512 MB minimum
    1+ GB recommended
    Disk
    1 GB minimum
    2+ GB recommended
    512 MB
    Note: VxWorks and Phar Lap OS are not supported.
    Additional Requirements for Servers and Targets
    • .NET Framework 4.6.2
    • Latest version of one of the following browsers:
      • Chrome
      • Firefox
      • Edge (Chromium)
      • Safari
    Note: SystemLink R4 does not support Microsoft Edge Legacy versions (version 44 and below).
    Supported Software
    SystemLink 2020 R4 supports the following LabVIEW versions:
    • LabVIEW 2017 and later
    • LabVIEW RT 2017 and later
    • LabVIEW NXG 5.0 and later
    SystemLink 2020 R4 supports the following TestStand versions:
    • TestStand 2014 or later
    SystemLink TDM supports the following DIAdem versions as clients:
    • DIAdem 2015 and later (2020 recommended)
    SystemLink 2020 R4 supports the following Python versions:
    • NI SystemLink Python 3.7 SDK
    • NI SystemLink Python 3.8 SDK
    Note: SystemLink TDM Analysis Automation does not support NI SystemLink Python 3.8 SDK. To use Python scripts in Analysis Automation, select NI SystemLink Python 3.7 SDK under “Additional items you may wish to install” when installing SystemLink Suite.
    SystemLink uses Volume License Manager to license server modules and add-ons as well as clients. Download NI Volume License Manager from ni.com and refer to the Get Started with VLA and Set Up NI Volume License Manager (VLM) tutorial for more information on licensing.
    If you evaluate SystemLink Server before activating, any clients you connect will initially appear as Not Activated in Systems Manager. Use SystemLink Web Application to activate the client after you activate the server.
    Known IssuesYou can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in SystemLink.
    Note: When updating from SystemLink version 20.0 or earlier, existing DataFinder privileges do not migrate. Use the Security application to assign DataFinder privileges.
    You can access a list of bugs fixed in this version online. Refer to the public bugs list for a list of fixed bugs.
    Refer to the NI SystemLink Manual, accessible from ni.com, for more information about SystemLink and the services and APIs it offers.
    SystemLink will drop support for Windows 7 (32- and 64-bit), Windows 8.1 (32- and 64-bit), Windows Server 2008 R2, Windows Server 2012 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2017-2020 National Instruments. All rights reserved.
    377243R-01
    GMT+8, 2025-5-10 17:10
