NI-ATCA Driver 16.0 Win32/64Eng NI高级电信计算架构驱动程序16.0
NI-ATCA
NI-ATCA为用户使用ATCA FPGA模块提供支持。
NI-ATCA是NI的一个仪器驱动程序,可帮助您使用高级电信计算架构(ATCA)硬件创建LabVIEW FPGA应用程序。它包含LabVIEW VI、示例和产品文档。
Win32/64Eng
16.0
文件大小: 2334111412 字节 (2.17 GB)
修改日期: 2017-03-30 05:45
MD5: f2964c03b55adedc5e2fd084ce1e3702(官方一致)
SHA1: c8c41735291af8d44a003322ff54545b098c2027
SHA256: a9a89ab6f86b697eca68d5f6be774823c8fb500ba12ba118e7e2f80d49d81b19
CRC32: 12ff0e98
ATCA16.0.txt
(594 Bytes, 下载次数: 0, 售价: 10 圆)
NI ATCA FPGA Modules 16.0 ReadmeMarch 2017
This file contains important information about NI ATCA FPGA Modules and is organized into the following sections:
New Features Supported Hardware System Requirements Installed Software, Documentation, and Examples Documentation Finding Examples Product Security and Critical Updates Uninstalling/Modifying NI ATCA FPGA Modules Known Issues Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 Legal Information New FeaturesNI ATCA FPGA Modules 16.0 includes the following new features:
- Support for LabVIEW 2016
- Support for the following devices:
- ATCA-3671 FPGA Module for ATCA
- RTM-3661 PCI Express Rear Transition Module for ATCA
- AIO-3681 Digitizer Module for FMC
- AIO-3682 Signal Generator Module for FMC
- AIO-3691 High-Speed Serial Adapter Module
Supported Hardware- ATCA-3671 FPGA Module for ATCA
System RequirementsSupported Operating Systems- Windows 10/8.11/7 SP12 (32-bit and 64-bit)
Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/info and enter the Info Code PAESupport.
Note NI ATCA FPGA Modules 16.0 and later does not support Windows Server non-R2 editions.
Minimum Requirements- Processor—1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
- RAM—1 GB RAM (32-bit) or 2 GB RAM (64-bit)
- Windows 10/8.1/7, with all available critical updates and service packs
Application Development Environments (ADEs)Note You should install an ADE, such as LabVIEW, before installing NI ATCA FPGA Modules. To add support for ADEs installed after installing NI ATCA FPGA Modules, modify your NI ATCA FPGA Modules installation or launch the NI ATCA FPGA Modules installer again.
Installed Software, Documentation, and ExamplesInstalled Software- is an alias for the following National Instruments file folder location: Users\Public\Public Documents\National Instruments
- (32-bit) Program Files\National Instruments\
- (64-bit) Program Files (x86)\National Instruments\
File LocationsItem | Installed Location | | NI ATCA FPGA Modules Examples | \LabVIEW \examples\instr\ATCA | DocumentationThe documentation set is composed of the following documents.
Document | Format | Description | Location | | NI ATCA FPGA Modules Help | HTML/Windows Help | Contains primary help content for NI ATCA FPGA Modules products. The help is an HTML version of a traditional user manual that includes the following information:- An introduction to NI ATCA FPGA Modules
- Hardware device information
- A complete reference for all NI ATCA FPGA Modules programming functions and VIs
| Start»All Programs»National Instruments»NI ATCA FPGA Modules»NI ATCA Documentation | | Getting Started Guide for your device | Printed and PDF | Contains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device. | Available at ni.com/manuals | | Specifications for your device | PDF | Lists technical specifications for your device. | Available at ni.com/manuals | | NI ATCA FPGA Modules 16.0 Readme | HTML (this document) | Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices. | Start»All Programs»National Instruments»NI ATCA FPGA Modules»NI ATCA Documentation |
Note To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/reader.
Finding ExamplesIn LabVIEW, you can use the NI Example Finder to search or browse examples. NI ATCA FPGA Modules examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI ATCA FPGA Modules and Modulation Toolkit examples) and their descriptions:
- Click the Browse tab to locate modulation examples by task at Hardware Input and Output»ATCA or by directory structure at instr»niDriver.
- Click the Search tab to search all installed examples by keyword. For example, search for "ATCA" to locate all NI ATCA FPGA Modules examples.
You can also access all the installed NI ATCA FPGA Modules examples for LabVIEW at Start»All Programs»National Instruments»NI ATCA FPGA Modules»NI ATCA Examples.
Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments.
Uninstalling/Modifying NI ATCA FPGA ModulesFor Windows 7, complete the following steps:
- Launch the Control Panel by selecting Start»Control Panel.
- Double-click Programs and Features.
- Select National Instruments Software.
- Click the Uninstall/Change button.
- Select NI ATCA FPGA Modules 16.0 from the dialog box that appears.
- Click Remove to uninstall the product; click Modify to change the components that are installed.
- Right-click on the Start button.
- Select Control Panel.
- Select Programs» Programs and Features.
- Click the Uninstall button.
As part of the NI ATCA FPGA Modules 16.0 installation, the following software is installed. To completely remove the NI ATCA FPGA Modules 16.0 installation from your system, you must also remove all of the following packages:
- FlexRIO 16.1 LabVIEW Support
- FlexRIO Adapter Module Support 16.1.0
- FlexRIO Runtime 16.1
- NI ATCA FPGA Modules LabVIEW 2016 Support (32-bit)
- NI ATCA FPGA Modules LabVIEW 2016 Support (64-bit)
- NI ATCA FPGA Modules Runtime
- NI Measurement & Automation Explorer 16.0.0
- NI PXI Platform Services Runtime 16.0
- NI System Configuration Runtime 16.0.0
- NI Update Service 16.0
- NI-RIO 16.0.1
Caution Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
Note Do not attempt to uninstall by manually deleting files.
Known IssuesYou can access the software and documentation known issues list online. Refer to the NI ATCA FPGA Modules 16.0 Known Issues at ni.com/info and enter the Info Code exw365 for an up-to-date list of known issues in NI ATCA FPGA Modules 16.0.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software.
- For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
- To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, How Can I Determine the Type and Version of My NI Installer?.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10.
Using NI Software with Microsoft Windows 8.1When you install National Instruments software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
Legal InformationCopyright
© 2017 National Instruments. All rights reserved.
- Notices are located in the \_Legal Information and directories.
376642A-01 |
