查看: 3003|回复: 0
[NI驱动程序] NI-Digital Pattern Driver 16.0 Win32/64Eng NI数字向量仪器驱动程序16.0下载
    2 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-5 22:18:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Digital Pattern Driver为用户使用NI PXI数字pattern仪器提供支持。
    NI-Digital Pattern Driver是用于配置和控制数字向量仪器的NI仪器驱动程序。该驱动程序可让您在NI-Digital Pattern Driver LabVIEW或.NET API中,调用使用数字向量编辑器创建的引脚和通道图、规格、电平、时序、向量、波形文件。NI-Digital Pattern Driver还包含高级和底层实用工具和示例,可帮助您轻松创建应用程序。
    Win32/64ENG
    16.0
    文件大小: 846630792 字节 (807.41 MB)
    修改日期: 2016-10-26 03:35
    MD5: 2b4c97272af837a2f48f70ae228fcae6(官方正确)
    SHA1: b1af0e3472f537f36c169206971c4626adf8a571
    SHA256: 88c7ab7342e237bb41d0a5530bf12f59bcd5fe2ffcc0b3029a9ea5524d0d8ad4
    CRC32: 10a5fe1b
    Digital16.0.txt (630 Bytes, 下载次数: 0, 售价: 10 圆)
    Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor Readme
    September 2016
    Use the Digital Pattern Editor with the Digital Pattern Instrument (PXIe-6570) and the NI-Digital Pattern Driver software for digital testing of semiconductors, or devices under test (DUTs). This file contains important information about the Digital Pattern Instrument, the NI-Digital Pattern Driver, and the Digital Pattern Editor and is organized into the following sections:
    The NI-Digital Pattern Driver supports the following NI product:
    • PXIe-6570
    System RequirementsMinimum System Requirements
    • RAM—4 GB
    • A screen resolution of 1024 x 768
    Recommended System
    • RAM—8 GB
    The NI-Digital Pattern Driver and the Digital Pattern Editor support the following operating systems with all available critical updates and service packs:
    • Windows 10 (64-bit)
    • Windows 7 SP11 (64-bit)
    1 NI software is signed with a SHA-256 certificate. Windows 7 SP1 requires Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Note:  The NI-Digital Pattern Driver and the Digital Pattern Editor support only 64-bit operating systems for development. You can deploy runtime solutions on Windows 10 (32-bit and 64-bit) and Windows 7 (32-bit and 64-bit). Refer to your ADE documentation for more information about creating a runtime deployment.
    Note:  The Digital Pattern Editor does not support Guest user accounts on Windows. The Digital Pattern Editor supports Administrator and Limited accounts on Windows 7.
    Note:  NI recommends that you install Microsoft Hotfix 2588507 for 64-bit Windows operating systems. Visit ni.com/info and enter the Info Code mshotfix for more information about Microsoft Hotfix 2588507.
    Note:  You should install ADEs, such as LabVIEW or Microsoft Visual Studio, before installing the NI-Digital Pattern Driver. To add support for ADEs installed after installing the NI-Digital Pattern Driver, modify your NI-Digital Pattern Driver installation or launch the NI-Digital Pattern Driver installer again.
    The NI-Digital Pattern Driver and the Digital Pattern Editor support the following ADEs:
    • LabVIEW 2014 (32-bit and 64-bit)
    • LabVIEW 2015 (32-bit and 64-bit)
    • LabVIEW 2016 (32-bit and 64-bit)
    • TestStand 2016 (64-bit)
    • TestStand 2016 Semiconductor Module (64-bit)
    • Microsoft Visual Studio 2010 (minimum)
      If you are using the NI-Digital .NET Class Library, the .NET 4.0 Framework (minimum) is required. The NI-Digital .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET 4.0 Framework or the .NET 4.5 Framework. Ensure that you select .NET Framework 4.0 Support or .NET Framework 4.5 Support in the NI-Digital Pattern Driver installer to install .NET support for the NI-Digital Pattern Driver software.
    Note:  You must install the NI-DCPower driver to access NI-DCPower-related functionality.
    Note:  You must install the NI-Sync driver to access NI-Sync-related functionality.
    Documentation for the Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor is available from the Start menu by navigating to NI Digital Pattern Documentation in the National Instruments folder. The documentation set is composed of the following documents:
    DocumentFormatDescription
    Digital Pattern HelpHTML/Windows HelpContains primary help content for the Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor and compiler. The help is an HTML version of a traditional user manual that includes the following information:
    • Digital Pattern Editor information
    • Hardware device information
    • A reference for NI-Digital Pattern Driver VIs and properties
    • A reference for the NI-Digital Pattern .NET Class Library
    Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor ReadmeHTML (this document)Contains information about supported hardware, system requirements, documentation, examples, known issues, and legal notices.
    To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    Accessing the APILabVIEW
    The NI–Digital Pattern Driver palette VIs are available from the following locations:
    • LabVIEW 2015 and earlier—Functions»Instrument I/O»Instrument Drivers»NI–Digital palette
    • LabVIEW 2016 and later—Functions»Measurement I/O»NI–Digital palette or Functions»Instrument I/O»Instrument Drivers»NI–Digital palette
    .NET Class Library
    You can use the NI-Digital Pattern .NET class library by adding a reference to NationalInstruments.ModularInstruments.NIDigital.Fx40 or NationalInstruments.ModularInstruments.NIDigital.Fx45 and any dependent class libraries from within the Solution Explorer in Visual Studio.
    Finding ExamplesGetting Started Examples
    Use the getting started examples, located by default in the <;Public Documents>\National Instruments\NI-Digital\Examples\Getting Started directory, to help you learn key concepts or to serve as a starting point for applications you create. You can also access the getting started examples by selecting the Start menu and navigating to NI Digital Pattern Examples in the National Instruments folder.
    In the Welcome window of the Digital Pattern Editor, click Examples or click the Learning tab to launch the Learning window, which includes examples of common usages of digital patterns.
    NI-Digital Pattern Driver Examples
    Use the NI-Digital Pattern Driver example programs to learn more about how to use the NI-Digital Pattern Driver software to configure and control digital pattern instruments.
    LabVIEW Examples
    Use the NI Example Finder to locate LabVIEW examples. In LabVIEW, select Help»Find Examples to launch the NI Example Finder.
    Microsoft .NET Examples
    The Microsoft .NET examples are located in the <;Public Documents>\National Instruments\NI-Digital\Examples\DotNET 4.x directory.
    You can also access the Microsoft .NET examples by selecting the Start menu and navigating to NI Digital Pattern Examples in the National Instruments folder.
    Refer to the NI website for an up-to-date list of known issues.
    © 2015-2016 National Instruments. All rights reserved.
    376615A-01
    GMT+8, 2025-11-19 10:50
