查看: 3001|回复: 0
[NI驱动程序] NI-Industrial Communications for DeviceNet 2.2 Driver Win32Eng NI-DNet工业通信软件驱动程序2.2下载
    3 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-4 22:46:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI DeviceNet工业通信软件
    NI-Industrial Communications for DeviceNet可帮助您配置和控制DeviceNet网络上DeviceNet设备。
    NI-Industrial Communications for DeviceNet是一种驱动程序软件,为您使用DeviceNet接口设备、C系列DeviceNet接口模块和PXI DeviceNet接口模块提供所需的支持。它包含丰富的LabVIEW VI和属性库,因此您可以为兼容的硬件设备创建自定义的DeviceNet应用程序。
    Win32Eng
    2.2
    文件大小: 411158744 字节 (392.11 MB)
    修改日期: 2013-08-15 05:00
    MD5: 0c5fdb05aa3326541160c22647a9399f(官方正确)
    SHA1: 8644e622b63c514c5d50cbb5d60871820ba64842
    SHA256: 220393a4195a9b7d73411aa50b3f09af14caf9b9e57f27a988f17f75ebb1eaed
    CRC32: bb26e0db
    DNET2.2.txt (616 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for DeviceNet™ 2.2 Readme
    November 2012
    This file contains important information about NI-Industrial Communications for DeviceNet for Windows and LabVIEW Real-Time, including new features and changes, the installation and upgrade issues, compatibility issues, and a partial list of bug fixes.
    New Features and Changes
    DeviceNet 2.2
    DeviceNet 2.1
    DeviceNet 2.0.2
    DeviceNet 2.0.1
    DeviceNet 2.0
    Compatibility with NI-DNET 1.x
    New Features and ChangesDeviceNet 2.2
    • Added slave support for NI 9882, PCI-8532, and PXI-8532
    • Added VIs for reading and writing the raw CAN frames
    • Added an example VI for monitoring and analyzing DeviceNet packets
    • Added support for LabVIEW 2012 (32-bit) and LabVIEW Real-Time 2012
    DeviceNet 2.1
    • Added support for NI 9882 1-Port DeviceNet Module for NI CompactRIO
    • Added NI-DNET 1.x compatible LabVIEW VIs
    DeviceNet 2.0.2
    • Added support for LabVIEW 2011 (32-bit) and LabVIEW Real-Time 2011
    DeviceNet 2.0.1
    • Added support for LabVIEW 2010 (32-bit) and LabVIEW Real-Time 2010
    DeviceNet 2.0
    • Supported NI DeviceNet hardware: PCI-8532 and PXI-8532
    • Supported LabVIEW 2009 (32-bit) and LabVIEW Real-Time 2009
    You must install and run the NI-IndCom for DeviceNet software on the following operating systems:
    • Windows XP SP3 (32-bit)
    The NI-IndCom for DeviceNet installer does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
    This version of the NI-IndCom for DeviceNet software supports the following National Instruments hardware products on Windows and LabVIEW RT:
    • NI PCI-8532 (1-Port DeviceNet Interface for PCI)
    • NI PXI-8532 (1-Port DeviceNet Interface for PXI)
    • NI 9882 (1-Port C Series DeviceNet module for CompactRIO)
      • CompactRIO - NI-RIO 4.1 (or later) and LabVIEW 2011 SP1 (or later) required
        • Real-Time Controller (NI cRIO-9012, NI cRIO-9014, NI cRIO-9022, NI cRIO-9023, NI cRIO-9024, and NI cRIO-9025) with CompactRIO Reconfigurable Chassis (NI cRIO-9111, NI cRIO-9112, NI cRIO-9113, NI cRIO-9114, cRIO-9116, and cRIO-9118)
        • Integrated CompactRIO Real-Time Controller: NI cRIO-9081 and NI cRIO-9082
        Note  The LabVIEW 2011 SP1 (or later) FPGA Module is required to compile and deploy a bitstream with an NI 9882 module in the project.
    The maximum number of devices you can connect to a DeviceNet interface depends on the electrical characteristics of the devices on the network. If all of the devices on the network meet the DeviceNet specifications, you may connect 64 devices to the network.
    Caution  The NI-IndCom for DeviceNet software does not support previous DeviceNet hardware products such as PCI-DNET, PCMCIA-DNET, and PXI-8461/D. Those products require an NI-DNET 1.x driver.
    Supported Development Environment
    The NI-IndCom for DeviceNet software supports the following development environments:
    • LabVIEW 2009 (32-bit), LabVIEW 2010 (32-bit), LabVIEW 2011 (32-bit), and LabVIEW 2012 (32-bit)
    • LabVIEW Real-Time 2009, LabVIEW Real-Time 2010, LabVIEW Real-Time 2011, and LabVIEW Real-Time 2012
    Before installing the NI-IndCom for DeviceNet software, log on as Administrator or as a user with Administrator privileges. The NI-IndCom for DeviceNet software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-IndCom for DeviceNet software:
    • Insert the NI-IndCom for DeviceNet software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-IndCom for DeviceNet software CD.
    • The installation wizard guides you through the necessary steps to install the NI-IndCom for DeviceNet software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
    Installing the Software on a Real-Time Target
    Complete the following steps to install the NI-IndCom for DeviceNet software on a real-time target in Measurement & Automation Explorer (MAX):
    • Expand Remote Systems in the configuration tree and expand your real-time target.
    • Select the Software category. Click the Add/Remove Software icon on the toolbar to launch the LabVIEW Real-Time Software Wizard.
    • If the real-time target is a CompactRIO controller, select Custom software installation.
    • Select NI-IndCom for DeviceNet in the feature list and click Next.
    • Follow the remaining installation instructions until installation is complete.
    Refer to the NI-Industrial Communications for DeviceNet Help, accessible by selecting Help»NI-Industrial Communications for DeviceNet from the pull-down menu in LabVIEW, for information about using the NI-IndCom for DeviceNet software.
    LabVIEW examples for the NI-IndCom for DeviceNet software are in the labview\examples\NI-Industrial Communications for DeviceNet folder. You can modify an example VI to fit an application or copy and paste from one or more examples into a VI you create.
    The following table contains the ID and title of the issue fixed in the NI-IndCom for DeviceNet 2.1. This table is not an exhaustive list of issues fixed in the current version of NI-IndCom for DeviceNet.
    198387Explicit messaging function block help does not explain how to write attributes
    185016PCI/PXI 8532 boards manual lacks hardware specifications section
    The following table contains the ID and title of the issue fixed in the NI-IndCom for DeviceNet 2.0.2. This table is not an exhaustive list of issues fixed in this version of NI-IndCom for DeviceNet.
    288931DeviceNet deployment executable fails to execute on a machine without LabVIEW
    NI-Industrial Communications for DeviceNet 2.1 or later is not an update for NI-DNET 1.x and the two products can be installed on the same system side by side. DeviceNet 2.1 or later provides NI-DNET 1.x compatible LabVIEW VIs, so the application using NI-DNET 1.x LabVIEW VIs can work with DeviceNet 2.1 or later on PCI-8532, PXI-8532 and NI 9882 with very limited code change.
    When you install National Instruments software on Microsoft Windows 8, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products such as NI LabVIEW and Measurement & Automation Explorer (MAX).
    Finding All Programs
    Important Information
    ©2009–2012 National Instruments. All rights reserved.
    Members of the National Instruments Alliance Partner Program are business entities independent from National Instruments and have no agency, partnership, or joint-venture relationship with National Instruments.
    GMT+8, 2025-11-19 10:54
