NI-Industrial Communications for DeviceNet 2.1 Driver Win32Eng NI-DNet工业通信软件驱动程序2.1下载
NI DeviceNet工业通信软件
NI-Industrial Communications for DeviceNet可帮助您配置和控制DeviceNet网络上DeviceNet设备。
NI-Industrial Communications for DeviceNet是一种驱动程序软件,为您使用DeviceNet接口设备、C系列DeviceNet接口模块和PXI DeviceNet接口模块提供所需的支持。它包含丰富的LabVIEW VI和属性库,因此您可以为兼容的硬件设备创建自定义的DeviceNet应用程序。
Win32Eng
2.1
文件大小: 325978720 字节 (310.88 MB)
修改日期: 2012-06-12 22:05
MD5: 0bcefe1fa97def9d113b063205b3a943(官方正确)
SHA1: 807a40143a3b6ff404f2268bed212729d05fca5a
SHA256: adcd8c90c9bb72adeb8443e0784b4813912a7b31bb0e54925efcaa4ccf7590c5
CRC32: baea7218
DNET2.1.txt
(632 Bytes, 下载次数: 0, 售价: 10 圆)
NI-Industrial Communications for DeviceNet® ReadmeApril 2012 This file contains important information about NI-Industrial Communications for DeviceNet for Windows and LabVIEW Real-Time, including new features and changes, the installation and upgrade issues, compatibility issues, and a partial list of bug fixes. New Features and Changes DeviceNet 2.1 DeviceNet 2.0.2 DeviceNet 2.0.1 DeviceNet 2.0 System Requirements Installation Instructions Accessing the Help Finding Examples Bug Fixes Compatibility with NI-DNET 1.x New Features and ChangesDeviceNet 2.1- Added support for NI 9882 1-Port DeviceNet Module for NI CompactRIO.
- Added NI-DNET 1.x compatible LabVIEW VIs.
DeviceNet 2.0.2- Added support for LabVIEW 2011 (32-bit) and LabVIEW Real-Time 2011.
DeviceNet 2.0.1- Added support for LabVIEW 2010 (32-bit) and LabVIEW Real-Time 2010.
DeviceNet 2.0- Supported NI DeviceNet hardware (PCI-8532 and PXI-8532).
- Supported LabVIEW 2009 (32-bit) and LabVIEW Real-Time 2009.
System RequirementsSupported Operating SystemsYou must install and run the NI-IndCom for DeviceNet software on the following operating systems: - Windows 7 (32-bit and 64-bit)
- Windows Vista (32-bit and 64-bit)
- Windows XP (32-bit)
- Windows Server 2003 R2 (32-bit)
- Windows Server 2008 R2 (64-bit)
The NI-IndCom for DeviceNet installer does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions. Supported HardwareThis version of the NI-IndCom for DeviceNet software supports the following National Instruments hardware products on Windows and LabVIEW RT: - NI PCI-8532 (1-Port DeviceNet Interface for PCI)
- NI PXI-8532 (1-Port DeviceNet Interface for PXI)
- NI 9882 (1-Port C Series DeviceNet module for CompactRIO)
- CompactRIO - NI-RIO 4.1 (or later) and LabVIEW 2011 SP1 (or later) required
- Real-Time Controller: NI cRIO-9012, NI cRIO-9014, NI cRIO-9022, NI cRIO-9023, NI cRIO-9024 and NI cRIO-9025
- CompactRIO Reconfigurable Chassis: NI cRIO-9111, NI cRIO-9112, NI cRIO-9113, NI cRIO-9114, cRIO-9116, and cRIO-9118
- The LabVIEW 2011 SP1 (or later) FPGA Module is required to compile and deploy a bitstream with an NI 9882 module in the project
- CompactRIO - NI-RIO 4.1 (or later) and LabVIEW 2011 SP1 (or later) required for the following targets:
- Integrated CompactRIO Real-Time Controller: NI cRIO-9081, NI cRIO-9082
- LabVIEW FPGA 2011 (or later) is required to compile and deploy a bitstream with an NI 9882 module in the project
The maximum number of devices you can connect to a DeviceNet interface depends on the electrical characteristics of the devices on the network. If all of the devices on the network meet the DeviceNet specifications, 64 devices may be connected to the network. Caution The NI-IndCom for DeviceNet software does not support previous DeviceNet hardware products such as PCI-DNET, PCMCIA-DNET, and PXI-8461/D. Those products require an NI-DNET 1.x driver. Supported Development EnvironmentThe NI-IndCom for DeviceNet software supports the following development environments: - LabVIEW 2011 (32-bit)
- LabVIEW Real-Time 2011
- LabVIEW 2010 (32-bit)
- LabVIEW Real-Time 2010
- LabVIEW 2009 (32-bit)
- LabVIEW Real-Time 2009
Installation InstructionsBefore installing the NI-IndCom for DeviceNet software, log on as Administrator or as a user with Administrator privileges. The NI-IndCom for DeviceNet software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-IndCom for DeviceNet software: - Insert the NI-IndCom for DeviceNet software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-IndCom for DeviceNet software CD.
- The installation wizard guides you through the necessary steps to install the NI-IndCom for DeviceNet software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
- When the installation is complete, click Finish.
Installing the Software on a Real-Time TargetComplete the following steps to install the NI-IndCom for DeviceNet software on a real-time target in Measurement & Automation Explorer (MAX): - Expand Remote Systems in the configuration tree and expand your real-time target.
- Select the Software category. Click the Add/Remove Software icon on the toolbar to launch the LabVIEW Real-Time Software Wizard.
- If the real-time target is a CompactRIO controller, select Custom software installation.
- Select NI-IndCom for DeviceNet in the feature list and click Next.
- Follow the remaining installation instructions until installation is complete.
Accessing the HelpRefer to the NI-Industrial Communications for DeviceNet Help, accessible by selecting Help»NI-Industrial Communications for DeviceNet from the pull-down menu in LabVIEW, for information about using the NI-IndCom for DeviceNet software. Finding ExamplesLabVIEW examples for the NI-IndCom for DeviceNet software are in the labview\examples\NI-Industrial Communications for DeviceNet folder. You can modify an example VI to fit an application or copy and paste from one or more examples into a VI you create. Bug FixesThe following table contains the ID and title of the issue fixed in the NI-IndCom for DeviceNet 2.1. This table is not an exhaustive list of issues fixed in the current version of NI-IndCom for DeviceNet. | ID | Fixed Issue | | 198387 | Explicit messaging function block help does not explain how to write attributes | | 185016 | PCI/PXI 8532 boards manual lacks hardware specifications section |
The following table contains the ID and title of the issue fixed in the NI-IndCom for DeviceNet 2.0.2. This table is not an exhaustive list of issues fixed in this version of NI-IndCom for DeviceNet. | ID | Fixed Issue | | 288931 | DeviceNet deployment executable fails to execute on a machine without LabVIEW | Compatibility with NI-DNET 1.xNI-Industrial Communications for DeviceNet 2.1 or later is not an update for NI-DNET 1.x and the two software can be installed on the same system side by side. However, since DeviceNet 2.1 or later provides NI-DNET 1.x compatible LabVIEW VIs, the application using NI-DNET 1.x LabVIEW VIs can work with DeviceNet 2.1 or later on PCI-8532, PXI-8532 and NI 9882 with very limited code change. Important InformationCopyright ©2009–2012 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. Copyright (c) 1998, 1999, 2000 Thai Open Source Software Center Ltd and Clark Cooper Copyright (c) 2001, 2002, 2003, 2004, 2005, 2006 Expat maintainers. Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software. THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations: - Notices are located in the \_Legal Information and directories.
- EULAs are located in the \Shared\MDF\EULAs directory.
Trademarks LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Members of the National Instruments Alliance Partner Program are business entities independent from National Instruments and have no agency, partnership, or joint-venture relationship with National Instruments. Patents For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents. |
