查看: 3489|回复: 0
[NI驱动程序] NI-Industrial Communications for DeviceNet 2.0.1 Driver Win32Eng NI-DNet工业通信软件驱动程序2.0.1下载
    3 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-4 22:19:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI DeviceNet工业通信软件
    NI-Industrial Communications for DeviceNet可帮助您配置和控制DeviceNet网络上DeviceNet设备。
    NI-Industrial Communications for DeviceNet是一种驱动程序软件,为您使用DeviceNet接口设备、C系列DeviceNet接口模块和PXI DeviceNet接口模块提供所需的支持。它包含丰富的LabVIEW VI和属性库,因此您可以为兼容的硬件设备创建自定义的DeviceNet应用程序。
    Win32Eng
    2.0.1
    文件大小: 201632352 字节 (192.29 MB)
    修改日期: 2010-10-30 03:25
    MD5: ff66eabfb0530af15b694958a3f14ff5(官方正确)
    SHA1: 9cb166ed18aa795efd1d881caf47ee20a144e72f
    SHA256: d4359deb497973bfefe00bf4ac6a3713a9373fc5dc4809236c79770d79376e49
    CRC32: 1997ddb0
    DNET2.0.1.txt (632 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for DeviceNet Software for Windows and LabVIEW Real-Time (RT)Version 2.0.1
    © Copyright 1998–2010 National Instruments Corporation. All Rights Reserved.
    Thank you for using National Instruments products for DeviceNet.
    Information in this file is divided into the following sections:
    Compatibility with NI-DNET 1.x
    Credits
    The NI-Industrial Communications for DeviceNet Help explains how to install, configure, and use the NI-Industrial Communications for DeviceNet software to control DeviceNet networks. It includes:
    • How to install NI-Industrial Communications for DeviceNet software
    • How to configure NI-Industrial Communications for DeviceNet hardware
    • How to get started with NI-Industrial Communications for DeviceNet software
    • How to configure a DeviceNet Network and develop the DeviceNet application in LabVIEW
    • Measurement & Automation Explorer Help for NI-Industrial Communications for DeviceNet
    Open this document from Start»All Programs»National Instruments»NI-Industrial Communications for DeviceNet.
    Online help for NI-Industrial Communications for DeviceNet features within Measurement & Automation Explorer (MAX) is in the MAX Help Topics menu and National Instruments on the Web menu.
    You must install and run the NI-Industrial Communications for DeviceNet software on the following operating systems:
    • Windows 7 x64 Edition (64-bit version)
    • Windows 7 (32-bit version)
    • Windows Vista x64 Edition (64-bit version)
    • Windows Vista (32-bit edition)
    • Windows XP
    The National Instruments DeviceNet hardware products supported by the NI-Industrial Communications for DeviceNet software are listed below, and are fully compliant with the DeviceNet Specification.
    • PCI-8532—Compliant with the PCI Local Bus Specification. This hardware allows you to use a PC-compatible computer with PCI Local Bus slots to communicate with and control DeviceNet devices.
    • PXI-8532—Compliant with the PXI Specification and CompactPCI Specification. This hardware allows you to use your PXI or CompactPCI chassis to communicate with and control DeviceNet devices.
    The maximum number of devices that you can connect to a DeviceNet interface depends on the electrical characteristics of the devices on the network. If all of the devices on the network meet the DeviceNet specifications, 64 devices may be connected to the network.
    The NI-Industrial Communications for DeviceNet software doesn't support older DeviceNet hardware products such as PCI-DNET, PCMCIA-DNET, and PXI-8461/D. Those products require an NI-DNET 1.x driver.
    The NI-Industrial Communications for DeviceNet software supports the following development environments:
    • LabVIEW 2010 (32-bit)
    • LabVIEW Real-Time 2010
    • LabVIEW 2009 (32-bit)
    • LabVIEW Real-Time 2009
    Compatiblity with NI-DNET 1.x
    NI-Industrial Communications for DeviceNet 2.0.x is completely separate from NI-DNET 1.x. It is not an update for NI-DNET 1.x, which means that an application using NI-DNET 1.x is not compatible with NI-Industrial Communications for DeviceNet 2.0.x. However, both NI-Industrial Communications for DeviceNet 2.0.x and NI-DNET 1.x may be installed and used on the same system.
    Credits
    This product includes components that use the Expat XML Parser. In regards to the Expat XML Parser, the following notice applies:
    Copyright © 1998, 1999, 2000 Thai Open Source Software Center Ltd and Clark Cooper. Copyright © 2001, 2002, 2003, 2004, 2005, 2006 Expat maintainers.
    GMT+8, 2025-11-19 10:52
