查看: 3607|回复: 0
[NI驱动程序] NI-DNET 1.6.7 Drvier Win32Eng NI-DeviceNet驱动软件1.6.7下载
    2 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-4 22:11:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DNET
    NI-DNET用于支持DeviceNet系统中的设备。
    NI-DNET是一款驱动软件,用于帮助配置和控制DeviceNet接口设备、PXI DeviceNet接口模块和C系列DeviceNet接口模块等DeviceNet硬件。该软件使用面向对象的概念表示DeviceNet系统中的组件。NI-DNET使用Measurement & Automation Explorer (MAX)作为配置和工具的中心节点。NI-DNET可用于监控DeviceNet网络,验证有关连接设备的信息,管理设备参数,并根据DeviceNet协议解读控制区域网(CAN)消息。NI-DNET功能还可用于开发和调试基于LabVIEW、LabWindows/CVI、Microsoft Visual C/C ++、Borland C/C ++、Visual Basic或其他编程语言的应用程序。LabWindows标志经Microsoft公司授权使用。Windows是Microsoft公司在美国和其他国家的注册商标。
    1.6.7
    文件大小: 426412544 字节 (406.66 MB)
    修改日期: 2012-08-07 05:07
    MD5: a1ae124649b3c7907a19c643ac25af7e(官方正确)
    SHA1: 8bba0cd822fd10c38717835300b286adce704c4b
    SHA256: d3871e3f70284c63d2d0821e9e458b460baabe90062f80700bfa2765118df2d8
    CRC32: 242b0ebb
    发布日期
    2012/8/5
    受支持的操作系统
    Windows 7
    Phar Lap ETS
    Windows Vista
    Windows XP 32-bit
    DNET1.6.7.txt (616 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DNET Readme
    Version 1.6.7
    June 2012
    This file contains important information about NI-DNET for Windows and LabVIEW Real-Time, including documentation, the supported hardware and software, the installation and upgrade issues, and additional programming topics.
    Changes in Version 1.6
    Additional Programming Topics
    The NI-DNET Hardware and Software for Windows Installation Guide included with your NI-DNET CD includes instructions for installing your National Instruments CAN hardware and NI-DNET software.
    The NI-DNET User Manual provides an introduction to DeviceNet, hardware specifications, and information about how to get started with application development.
    The NI-DNET Programmer Reference Manual is a complete reference for all NI-DNET functions.
    All manuals are in Adobe Acrobat Portable Document Format (PDF). You can download the Acrobat Reader for free at www.adobe.com.
    Open the documents from Start»All Programs»National Instruments»NI-DNET.
    Within the National Instruments LabVIEW and LabWindows™/CVI™ development environments, links to the NI-DNET Programmer Reference Manual are in the online help for each NI-DNET function.
    Online help for NI-DNET features within Measurement & Automation Explorer (MAX), including the NI-DNET Configurator and Analyzer help, is in the MAX Help Topics menu.
    You must install and run the NI-DNET software on the following operating systems:
    • Windows XP (32-bit)
    The NI-DNET software supports the following National Instruments DeviceNet hardware on Windows 7 32-bit/Windows Vista 32-bit/Windows XP 32-bit:
    • PCI-DNET
    • PCMCIA-DNET
    • PXI-8461/D
    The NI-DNET software supports the following National Instruments DeviceNet hardware on Windows 7 64-bit/Windows Vista 64-bit:
    • PCI-DNET
    • PXI-8461/D
    The NI-DNET software supports the following National Instruments DeviceNet hardware on LabVIEW Real-Time:
    • PXI-8461/D
    The NI-DNET software also supports the following National Instruments CAN hardware:
    • High-Speed Series 1 CAN interfaces
    Although you can use the 2-port CAN card, you can use only the top port with NI-DNET.
    This version of NI-DNET does not support some types of National Instruments Series 1 CAN hardware. Install NI-DNET version 1.4.1 (available at ni.com) to support the following hardware products:
    • PCI-CAN (pre-1998 CAN card, part numbers 183887A-01 and 183887B-01)
    • PCI-CAN/2 (pre-1998 CAN card, part numbers 183887A-02 and 183887B-02)
    • PCMCIA-CAN (pre-1998 CAN card, part numbers 184272A-01, 184272B-01, and 184272C-01)
    • PCMCIA-CAN/2 (pre-1998 CAN card, part numbers 184272A-02, 184272B-02, and 184272C-02)
    The NI-DNET software does not support Series 2 CAN hardware products. For information about CAN hardware support limitations, refer to the NI-DNET Hardware Overview chapter of the NI-DNET User Manual.
    The NI-DNET software supports the following development environments:
    • LabVIEW 2009 (32-bit), 2010 (32-bit), 2011 (32-bit), and 2012 (32-bit)
    • LabVIEW Real-Time (ETS) 2009, 2010, 2011, and 2012
    • LabWindows/CVI 8.0 (or newer)
    • Microsoft Visual Basic 6.0
    • Microsoft Visual C/C++ 6.0
    • Borland C/C++
    • Support for the 32 and 64-bit versions of the Microsoft Windows Vista operating system.
    • Support for the MAX Report Generation utility.
    • (NI-DNET 1.6.1) Support for LabVIEW 8.5 and LabVIEW Real-Time 8.5.
    • (NI-DNET 1.6.2) Dropped the support of LabVIEW 8.0 and LabVIEW Real-Time 8.0.
    • (NI-DNET 1.6.2) Support for LabVIEW 8.6 and LabVIEW Real-Time 8.6.
    • (NI-DNET 1.6.3) Updated the firmware; resolved a connection timeout error on slow slave devices.
    • (NI-DNET 1.6.3) Updated the user manual; added the requirement to connect the Shield pin to comply with a new set of compliance regulations.
    • (NI-DNET 1.6.3) Support for LabVIEW 8.6.1 and LabVIEW Real-Time 8.6.1.
    • (NI-DNET 1.6.4) Support for LabVIEW 2009 and LabVIEW Real-Time 2009.
    • (NI-DNET 1.6.5) Support for LabVIEW 2010 and LabVIEW Real-Time 2010.
    • (NI-DNET 1.6.6) Support for LabVIEW 2011 and LabVIEW Real-Time 2011.
    • (NI-DNET 1.6.7) Support for LabVIEW 2012 and LabVIEW Real-Time 2012.
    Additional Programming TopicsImportant Changes to Existing NI-DNET Applications
    To improve NI-DNET integration into the overall National Instruments product framework, NI-DNET version 1.4 and later uses a different error code format than previous NI-DNET versions.
    This new error code format may require minor changes to your existing NI-DNET application code. For example, some existing C/C++ files with NI-DNET code report compiler errors until you make the appropriate changes.
    The changes to your code entail:
    • Code simplification to convert an NI-DNET error to a useful description.
    • Replacing constants used in comparisons for specific errors.
    For details of the changes required to update your NI-DNET code, go to ni.com and search for KnowledgeBase article 3A2E8THR, Changes in Error Codes as of NI-DNET Version 1.4.
    Important Information
    ©1998–2012 National Instruments. All rights reserved.
    The mark LabWindows is used under a license from Microsoft Corporation. Windows is a registered trademark of Microsoft Corporation in the United States and other countries. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    Members of the National Instruments Alliance Partner Program are business entities independent from National Instruments and have no agency, partnership, or joint-venture relationship with National Instruments.
    GMT+8, 2025-11-19 10:46
