NI-CAN 14.0 Driver Win32Eng/Ger/Fre/Jpn NI控制器局域网驱动软件14.0下载
NI-CAN
NI-CAN用于支持开发和部署多个控制器局域网(CAN)应用程序。
NI-CAN驱动软件适用于多种类型的CAN硬件应用程序,如高速CAN、容错CAN和LIN接口。NI-CAN具有强大的底层框架API和上层通道,可实现快速开发。NI-CAN用于为LabVIEW、LabWindows/CVI和ANSI C/C++提供本地支持。此外,NI-CAN还包括通道测试面板、总线监控器和记录器以及数据库编辑器等工具。LabWindows标志经Microsoft公司授权使用。Windows是Microsoft公司在美国和其他国家的注册商标。
14.0
文件大小: 409089824 字节 (390.14 MB)
修改日期: 2014-09-22 22:46
MD5: 42e78e048df144ab565e762e6b607099(官方正确)
SHA1: a976b95b6b28dff0c0619a23f467d3140f7bc33a
SHA256: ebac008102dd0d7af81932a103617dc2530833499ce7ba4d999c2f69da0dc62c
CRC32: 2297e9f3
CAN14.0.txt
(580 Bytes, 下载次数: 0, 售价: 10 圆)
NI-CAN 14.0 ReadmeAugust 2014 ni.com/support This file contains information about the NI-CAN™ driver software for Windows 8/7/Vista/XP and LabVIEW™ Real-Time (ETS). Information in this file is organized in the following sections: - Documentation
- Supported Platforms
- Installing NI-CAN
- New Features and Changes
- Known Issues
- Bug Fixes
- Additional Programming Topics
- Release Notes
- Automating the Installation of NI Products
- How to Use NI Software with Microsoft Windows 8.x
- NI Software Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003
- Legal Information
DocumentationThe CAN Hardware and NI-CAN Software for Windows Installation Guide included with the NI-CAN CD includes instructions for installing National Instruments CAN hardware and software. The NI-CAN Hardware and Software Manual is the primary document for NI-CAN products. This manual includes an introduction to CAN, specifications for hardware, information about how to get started with application development, and a complete reference for all NI-CAN functions. The NI-CAN Hardware and Software Manual is in Adobe Acrobat Portable Document Format (PDF). You can download the Acrobat Reader for free at: www.adobe.com.Open the manual from Start»All Programs»National Instruments»NI-CAN. Links to the NI-CAN Hardware and Software Manual are in the online help for each NI-CAN function within the National Instruments LabVIEW and LabWindows™/CVI™ development environments. Online help for the NI-CAN features within Measurement & Automation Explorer (MAX) is in the MAX Help Topics menu. The MAX Help Topics menu for NI-CAN also includes a link to the NI-CAN Hardware and Software Manual. Back to Top Supported PlatformsSupported Operating SystemsYou must install and run this version of the NI-CAN software on the following operating systems: - Windows 8 (32-bit and 64-bit)
- Windows 7 (32-bit and 64-bit)
- Windows Vista Business edition, Service Pack (SP) 1 or greater (32-bit and 64-bit)
- Windows XP (32-bit) SP3 or later
The NI-CAN installer does not support Windows NT/Me/2000/98/95. Supported HardwareThis version of the NI-CAN software supports the following National Instruments hardware products on Windows and LabVIEW RT: - PCI-CAN, PCI-CAN/2 (High-Speed; Series 1 and 2)
- PCI-CAN/LS, PCI-CAN/LS2 (Low-Speed/Fault-Tolerant; Series 1 and 2)
- PCI-CAN/DS, (Dual Speed: Port-1 High-Speed, Port-2 Low-Speed; Series 1)
- PCI-CAN/XS, PCI-CAN/XS2, (Software-Selectable HS/LS/SW; Series 2)
- PXI-8460, one-port or two-port (Low-Speed/Fault-Tolerant; Series 1 and 2)
- PXI-8461, one-port or two-port (High-Speed; Series 1 and 2)
- PXI-8462, (Dual Speed: Port-1 High-Speed, Port-2 Low-Speed; Series 1)
- PXI-8464, one-port or two-port (Software-Selectable HS/LS/SW; Series 2)
This version of the NI-CAN software supports the following National Instruments hardware products on Windows: - USB-8472 (Low-Speed/Fault-Tolerant CAN)
- USB-8472s (Low-Speed/Fault-Tolerant CAN with synchronization)
- USB-8473 (High-Speed CAN)
- USB-8473s (High-Speed CAN with synchronization)
- USB-8476 (LIN)
- USB-8476s (LIN with synchronization)
- PCMCIA-CAN, PCMCIA-CAN/2 (Series 1 and 2)
Note: PCMCIA-CAN and PCMCIA-CAN/2 interfaces are not supported on the 64-bit version of Windows Vista. Several National Instruments Series 1 CAN hardware products are not supported in this version of NI-CAN. Install NI-CAN version 2.2 for support of the following hardware products (available on ni.com): - PCI-CAN, (pre-1998 CAN card, part numbers 183887A-01 and 183887B-01)
- PCI-CAN/2, (pre-1998 CAN card, part numbers 183887A-02 and 183887B-02)
- PCMCIA-CAN, (pre-1998 CAN card, part numbers 184272A-01, 184272B-01, and 184272C-01)
- PCMCIA-CAN/2, (pre-1998 CAN card, part numbers 184272A-02, 184272B-02, and 184272C-02)
Install NI-CAN version 2.1.3 for support of the following AT (ISA) hardware products (available on ni.com): - AT-CAN
- AT-CAN/2 (ISAPNP cards; High Speed; Series 1)
The NI-CAN software supports only National Instruments CAN hardware products. For information about software for CAN products from other vendors, refer to the documentation you received with those products. Supported Development EnvironmentsThis version of the NI-CAN software supports the following development environments: - LabVIEW 2011 (32-bit), LabVIEW 2012 (32-bit), and LabVIEW 2013 (32-bit), LabVIEW 2014 (32-bit)
- LabVIEW Real-Time (ETS) 2011, 2012, 2013, and 2014
- LabWindows/CVI 8.0 (or newer)
- Microsoft Visual Basic 6.0
- Microsoft Visual C/C++ 6.0
- Borland C/C++
Back to Top Installing NI-CANBefore installing the NI-CAN software, log on as Administrator or as a user with Administrator privileges. The NI-CAN software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-CAN software. - Insert the NI-CAN software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-CAN software CD.
- The installation wizard guides you through the necessary steps to install the NI-CAN software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
- When the installation is complete, click Finish.
NI-CAN Updates and NotificationsNational Instruments posts information about critical updates and security notifications on ni.com. For more information on critical updates and security notifications, refer to Available Critical and Security Updates for NI Software. Back to Top New Features and Changes as Compared to NI-CAN 2.7.4The NI-CAN 14.0 release adds the following features: - Added support for LabVIEW 2014 (32-bit).
- Removed support for LabVIEW 2010.
The NI-CAN 2.7.5 release adds the following features: - Added support for LabVIEW 2013 (32-bit).
- Removed support for LabVIEW 2009.
New Features and Changes as Compared to NI-CAN 2.7.3The NI-CAN 2.7.4 release adds the following features: - Added support for LabVIEW 2012 (32-bit).
- Removed support for LabVIEW 8.6.
- Removed support for Windows XP prior to Service Pack 3.
New Features and Changes as Compared to NI-CAN 2.7.2The NI-CAN 2.7.3 release adds the following features: - Added support for LabVIEW 2011 (32-bit).
- Removed support for LabVIEW 8.5.
New Features and Changes as Compared to NI-CAN 2.7The NI-CAN 2.7.2 release adds the following features: - Added support for LabVIEW 2010 (32-bit).
- Removed support for LabVIEW 8.2.
New Features and Changes as Compared to NI-CAN 2.6.xThe NI-CAN 2.7 release adds the following features: - Added support for PCI-8511, 8512, and 8513 devices through NI-XNET (LabVIEW 8.5 or newer)
- Added support for PXI-8511, 8512, and 8513 devices through NI-XNET (LabVIEW 8.5 or newer)
For more information about running NI-CAN code on NI-XNET hardware, see the NI-XNET Compatibility for NI-CAN appendix in the NI-CAN Hardware and Software Manual. New Features and Changes as Compared to NI-CAN 2.5.xThe NI-CAN 2.6.3 release adds the following features: - Added support for LabVIEW 2009.
- Removed support for LabVIEW 7.1.
The NI-CAN 2.6 release adds the following features: - Added support for LabVIEW 8.6.
- Removed support for LabVIEW 8.0.x.
- Location of the C language interface and example files changed:
The language interface and example files for Microsoft Visual C/C++ 6.0 and Borland C have moved from the Program Files\National Instruments\NI-CAN\MS Visual C\ directory to the Users\Public\Documents\National Instruments\NI-CAN\MS Visual C\ directory on Windows Vista and the Documents and Settings\All Users\Shared Documents\National Instruments\NI-CAN\Examples\MS Visual C\ directory on Windows XP/2000. This change satisfies Windows Vista requirements when allowing users to save changes or add files to the directory.
The NIEXTCCOMPILERSUPP environment variable is provided as an alias to the location of C language support files (.h and .lib). You can use this variable when compiling and linking an application.
The NI-CAN 2.5.1 release adds the following features: - Added support for LabVIEW 8.5.
Back to Top Known issuesThe following items are the IDs and titles of a subset of issues known to be present in NI-CAN 2.7.5. If you have a CAR ID, you can search this list to validate issues known not to have been addressed for this release. This is not an exhaustive list of known issues in the current version of NI-CAN. | Issue Number | Issue | | 414367 | When viewing NI-XNET cards on the monitor when using a Real-Time target, some cards may display as "Unknown Device." You can view the cards correctly through the NI-CAN RT Configuration Utility in MAX. |
Back to Top Bug FixesThe following items are the IDs and titles of a subset of issues fixed between NI-CAN 2.7.4 and NI-CAN 2.7.5. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-CAN. | Bug ID | Fixed Issue | | 361899 | Memory corruption possible when reading data in LabVIEW. |
The following items are the IDs and titles of a subset of issues fixed between NI-CAN 2.7.2 and NI-CAN 2.7.3. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-CAN. | Bug ID | Fixed Issue | | 251950 | System hangs with ncAction Start when Log Start Trigger attribute is enabled. | | 282965 | USB CAN modules disappear from MAX when multiple processes are executed at the same time. |
The following items are the IDs and titles of a subset of issues fixed between NI-CAN 2.7.1 and NI-CAN 2.7.2. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-CAN. | Bug ID | Fixed Issue | | 145168 | MUX in Motorola byte order does not work properly when sending less than a full 8-byte frame. | | 242580 | Scheduler assertion error on NI PXI-8109 real-time controller when using ports on two different devices. |
The following items are the IDs and titles of a subset of issues fixed between NI-CAN 2.6.2 and NI-CAN 2.7.1. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-CAN. | Bug ID | Fixed Issue | | 142729 | NI USB-8473s synchronization fails with traffic on the bus. | | 226671 | Error R6030 when compiling NI-CAN application in Visual Studio 2008. | | 233936 | The nctInitStart function fails with NI-XNET compatibility error. |
The following items are the IDs and titles of a subset of issues fixed between NI-CAN 2.6.1 and NI-CAN 2.6.2. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-CAN. | Bug ID | Fixed Issue | | 139394 | Terminating an NI-CAN process on one CAN port might affect other CAN ports or cards. |
The following items are the IDs and titles of a subset of issues fixed between NI-CAN 2.6 and NI-CAN 2.6.1. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-CAN. | Bug ID | Fixed Issue | | 122723 | Blue screen when removing an NI USB-847x or PCMCIA CAN interface while running an NI-CAN application on it. | | 120242 | Warning states should not trigger a notification callback. |
The following items are the IDs and titles of a subset of issues fixed between NI-CAN 2.5.2 and NI-CAN 2.6. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-CAN. | Bug ID | Fixed Issue | | 103680 | Timeline Recovery attribute for ncWriteNetMult VI/function does not work. | | 55364 | Importing a CAN database in MAX incorrectly changes datatype for extended arbitration IDs. | | 93911 | Calling ncClose frequently may result in a firmware no response error. | | 95354 | Notification functions/ncWait for Read operations do not work on NI-847x interfaces. | | 42012 | Using the timestamped input read mode with 64 tasks causes a kernel overflow error. | | 40750 | You cannot set the Single Shot property when the Network Interface Object is running. | | 94653 | The ncOpen function/VI could fail to start communication fast computers. |
The following items are the IDs and titles of a subset of issues fixed between NI-CAN 2.5.1 and NI-CAN 2.5.2. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-CAN. | Bug ID | Fixed Issue | | 4DAGR870 | NI-CAN 2.5.1 does not install VIs to support synchronization between Traditional NI-DAQ and CAN for LabVIEW 8.5. |
The following items are the IDs and titles of a subset of issues fixed between NI-CAN 2.5 and NI-CAN 2.5.1. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-CAN. | Bug ID | Fixed Issue | | 47P90370 | Fixed an issue where the LIN firmware was incorrectly calculating the enhanced checksum using the unprotected ID. | | 47ICPNSP | Fixed an issue where CAN objects would not restart correctly when the Network Interface is restarted. | | 48H8PQ70 | Fixed an issue where the computer would crash when the function SetProcessWorkingSetSize() is used to increase buffer memory. |
Back to Top Additional Programming TopicsNI-DAQ Synchronization VIsAs the Traditional NI-DAQ driver software is not supported on Windows Vista or Windows 7, the following CAN/DAQ synchronization VIs are not available on Windows Vista or Windows 7: - CAN Clear with NI-DAQ.vi
- CAN Clear Multiple with NI-DAQ.vi
- CAN Sync Start with NI-DAQ.vi
- CAN Sync Start Multiple with NI-DAQ.vi
Support of CANdb (*.DBC) FilesNI-CAN provides support for CANdb network files created using the Vector CANdb or CANdb++ editor. You can use the information from the CANdb file in Measurement & Automation Explorer (MAX) or with the NI-CAN Channel API. For more information, refer to the Using the Channel API chapter in the NI-CAN Hardware and Software Manual. NI-CAN supports CANdb network files created using the CAN module of Vector products. NI-CAN does not provide complete support of CANdb files created using modules for higher-layer CAN protocols, such as J1939, ISO11783, or NMEA2000. To view the set of features supported for these modules, import the CANdb file into MAX. NI-CAN displays an error dialog for any unsupported object and displays those objects with a red mark. For example, the J1939 protocol for multiframe messages (greater than 8 bytes) is not supported in the current version of NI-CAN. Updating Get/Set Attribute in Frame API for LabVIEWNI-CAN 2.4 (or newer) includes several new Frame API attributes. If you have a LabVIEW VI written for an earlier version of NI-CAN, upgrading to NI-CAN 2.4 (or newer) will not automatically update constants or controls for the AttrId input. To use the new attributes, replace your older constants and controls using the AttrId input of the updated NI-CAN VIs. If you do not want to use new Frame API attributes, you can continue to use the older constants and controls for compatibility. This issue does not apply to the Channel API for LabVIEW. Because the Get/Set Property functions are provided as polymorphic VIs, they are automatically updated. Back to Top Release Notes- The NI-XNET Compatibility Layer for NI-CAN currently supports NI-XNET CAN PCI and PXI hardware only. It does not support C Series hardware.
- The NI-XNET Compatibility Layer for NI-CAN currently does not support the LabVIEW example Channel Monitor.vi.
- For USB-LIN interfaces, the LIN bus must be terminated. This is typically done at the master node. For information about how to enable or disable termination on the USB-LIN, refer to the ncSetAttribute attribute function with the Frame API.
- The USB-LIN interfaces require external power from 8–18 V. For more details on the power requirements, refer to the USB-LIN specifications sections in the NI-CAN Hardware and Software Manual.
- The USB LED quickly switches between green and amber when the hardware is first detected.
- Fatal errors may cause the USB LED to flash in an error code pattern. Count the number of long and short flashes, then contact National Instruments support.
- If using the USB CAN or LIN products with a USB hub, the hub must be powered.
- Due to the inherent latencies of the Universal Serial Bus (USB), the driver on the host side might process data or states that the NI USB-847x series devices receive later than data from a plug-in (PCI, PXI, or PCMCIA) interface. This does not affect the timestamps, as those are generated on the hardware, but could cause timeout failures with the NI USB-847x series devices that will not happen on plug-in hardware. To avoid these timeout failures, increase the timeout value for functions that perform a wait for a certain state.
Back to Top Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
Back to Top How to Use NI Software with Microsoft Windows 8.xWhen you install National Instruments software on Microsoft Windows 8.x, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. Using NI LauncherNI Launcher helps you find and launch installed NI products. It provides you with a method of finding NI products similar to the Start menu in previous versions of Microsoft Windows. To use NI Launcher, click the NI Launcher tile in the Apps view. NI Launcher launches the desktop and opens a menu containing a list of NI products. Click any NI product to launch it. | Note NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch NI MAX either from the Apps view or from within NI Launcher. | Pinning Frequently Used ApplicationsFor convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary: | Current Application | Icon Location | Pin to Action | | Windows 8.x Desktop | Desktop Taskbar | Right-click application and select Pin to Taskbar | | Windows 8.x Desktop | Start screen | Right-click application and select Pin to Start | | Windows 8.x Start screen | Desktop Taskbar | Right-click application and select Pin to taskbar from the menu bar on the bottom of the screen | Finding All ProgramsIf you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8) or click the down arrow on the bottom left of the screen (Windows 8.1). For more information about NI support for Windows 8.x, visit ni.com/windows8. Back to Top NI-CAN Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016National Instruments NI-CAN will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-CAN that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes: | Product | Info Code | | NI LabVIEW | lifecycle | | NI LabWindows™/CVI™ | cvi_lifecycle | | NI Measurement Studio | mstudiolifecycle | | NI TestStand | tslcp | | NI DIAdem | ddlcp | | NI SignalExpress | selcp | | NI VeriStand | nivslifecycle |
Back to Top Legal InformationCopyright © 1996–2014 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents.
374799A-01 |
