查看: 2846|回复: 0
[NI驱动程序] NI-CAN 2.2.1 Driver Win32Eng NI控制器局域网驱动软件2.2.1下载
    5 小时前
  • 签到天数: 3535 天
    发表于 2021-1-2 22:28:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-CAN
    NI-CAN用于支持开发和部署多个控制器局域网(CAN)应用程序。
    NI-CAN驱动软件适用于多种类型的CAN硬件应用程序,如高速CAN、容错CAN和LIN接口。NI-CAN具有强大的底层框架API和上层通道,可实现快速开发。NI-CAN用于为LabVIEW、LabWindows/CVI和ANSI C/C++提供本地支持。此外,NI-CAN还包括通道测试面板、总线监控器和记录器以及数据库编辑器等工具。LabWindows标志经Microsoft公司授权使用。Windows是Microsoft公司在美国和其他国家的注册商标。
    Win32Eng
    2.2.1
    文件大小: 77355008 字节 (73.77 MB)
    修改日期: 2010-04-25 03:19
    MD5: c5137fe5ab850412bb5fb4a88b12944d(官方正确)
    SHA1: dfab8babbe12c0c7dde7e5f0ee294a807bd8e338
    SHA256: af79ed35b8c994af1d577bd9951c5d7a84751a95626b70cd04856c3dea4ad274
    CRC32: 2e8a815e
    CAN2.2.1.txt (544 Bytes, 下载次数: 0, 售价: 10 元)
    NI-CANTM Software for Windows 2000/NT/XP/Me/98 and LabVIEWTM Real-Time (RT)
    Version 2.2.1
    © 1996-2005 National Instruments Corporation, All Rights Reserved.
    Thank you for using National Instruments products for CAN.
    Information in this file is organized in the following sections:
    • Documentation
    • Supported Hardware
    • Supported Development Environments
    • New Features as Compared to 2.1
    The Installation Guide: CAN Hardware and NI-CAN Software For Windows jewel case insert included with your NI-CAN CD includes instructions for installing your National Instruments CAN hardware and software.
    The NI-CAN Hardware and Software Manual is the primary document for NI CAN products. This manual includes an introduction to CAN, specifications for hardware, information on how to get started with application development, and a complete reference for all NI-CAN functions.
    The NI-CAN Hardware and Software Manual is provided in Adobe Acrobat Portable Document Format (PDF). You can download the Acrobat Reader for free at: www.adobe.com.
    Open the manual from your Start menu in:
    Start» Programs»National Instruments»NI-CAN
    Within the National Instruments LabVIEW and LabWindows/CVITM development environments, links to the NI-CAN Hardware and Software Manual are provided in the online help for each NI-CAN function.
    Online help for the NI-CAN features within Measurement & Automation Explorer (MAX) can be found in the MAX Help Topics menu. The MAX Help Topics for NI-CAN also include a link to the NI-CAN Hardware and Software Manual.
    NI-CAN Software for Windows 2000/NT/XP/Me/98 supports the following National Instruments hardware products:
    • PCI-CAN, PCI-CAN/2 (High-Speed; Series 1 and 2)
    • PCI-CAN/LS, PCI-CAN/LS2 (Low-Speed/Fault-Tolerant; Series 1 and 2)
    • PCI-CAN/SW, PCI-CAN/SW2 (Single Wire; Series 2)
    • PCI-CAN/DS, (Dual Speed: Port-1 High-Speed, Port-2 Low-Speed; Series 1)
    • PCI-CAN/XS, PCI-CAN/XS2, (Software-Switchable HS/LS/SW; Series 2)
    • PCMCIA-CAN, PCMCIA-CAN/2 (Series 1 and 2)
    • PXI-8461, one-port or two-port (High-Speed; Series 1 and 2)
    • PXI-8460, one-port or two-port (Low-Speed/Fault-Tolerant; Series 1 and 2)
    • PXI-8463, one-port or two-port (Single Wire; Series 2)
    • PXI-8462, (Dual Speed: Port-1 High-Speed, Port-2 Low-Speed; Series 1)
    • PXI-8464, one-port or two-port (Software-Switchable HS/LS/SW; Series 2)
    NI-CAN Software for LabVIEW RT supports the following National Instruments hardware products:
    The following National Instruments hardware is not supported in this version of NI-CAN. Install NI-CAN version 2.1.3 for support of AT (ISA) hardware products (available on ni.com):
    • AT-CAN
    • AT-CAN/2 (ISAPNP cards; High Speed; Series 1)
    The NI-CAN software supports only National Instruments CAN hardware products. For information about software for CAN products from other vendors, refer to the documentation you received with those products.
    The NI-CAN software supports the following development environments:
    ·        LabVIEW 6.1, 7.0, and 7.1
    ·        LabVIEW Real-Time 6.1, 7.0, and 7.1
    ·        LabWindows/CVI 6.0, 7.0, and 7.1
    ·        Microsoft Visual Basic 6.0
    ·        Microsoft Visual C/C++ 6.0
    ·        Borland C/C++
    The NI-CAN 2.2 release adds the following features:
    • Support of mode dependent channels
    • Use of NI-CAN and NI-DNET (DeviceNet) software on the same system
    • New Connect Terminals function for the Frame API
    • Synchronization examples with NI-DAQmx
    • Support for new PCMCIA-CAN dongles: Single-Wire, sleep/wakeup
    • New features in Bus Monitor: ID Logger and Bus Statistics
    Additional Programming TopicsChannel API Examples for Visual Basic 6
    NI-CAN provides Channel API examples for Microsoft Visual Basic version 6. These examples are installed within the MS Visual Basic folder of the NI-CAN folder.
    The typical path to this folder is
          \Program Files\National Instruments\NI-CAN\MS Visual Basic
    Updating Get/Set Attribute in Frame API for LabVIEW
    NI-CAN includes several Frame API attributes for Series 2 hardware features. If you have a LabVIEW VI written for NI-CAN 2.0 or earlier, upgrading to NI-CAN 2.1 or later will not automatically update constants or controls for the AttrId input. To use the new attributes, replace your older constants and controls using the AttrId input of the updated NI-CAN VIs.
    If you do not want to use new Frame API attributes, you can continue to use the older constants and controls for compatibility.
    This issue does not apply to the Channel API for LabVIEW. Because the Get/Set Property functions are provided as polymorphic VIs, they are automatically updated.
    Clarification Regarding Frame API Filters
    NI-CAN has two different sets of attributes to filter received CAN frames.
    The new attributes for Series 2 hardware include the Series 2 Filter Mode, Series 2 Comparator, and Series 2 Mask. This filter is programmed into the Series 2 hardware (Philips SJA1000), and applies to all received frames. The default value enables reception of all standard and extended frames.
    The legacy Series 1 attributes include the Standard Comparator, Standard Mask, Extended Comparator, and Extended Mask. For Series 1 hardware, this filter is programmed into the hardware (Intel 82527) and applies to all received frames. For Series 2 hardware, this filter is implemented in software and applies only after a received frame has passed through the Series 2 filter. For Series 2, if the legacy attributes are programmed to don’t-care (all zero), the software filter is bypassed, and only the Series 2 filter applies.
    Support of CANdb (*.DBC) Files
    NI-CAN provides support for CANdb network files created using the Vector CANdb or CANdb++ editor. The information from the CANdb file can be used in the Measurement & Automation Explorer (MAX) or with the NI-CAN Channel API. For more information, refer to the Using the Channel API chapter in the NI-CAN Hardware and Software Manual.
    NI-CAN supports CANdb network files created using the CAN module of Vector products. NI-CAN does not provide complete support of CANdb files created using modules for higher-layer CAN protocols, such as J1939, ISO11783, or NMEA2000. In order to view the set of features supported for these modules, import the CANdb file into MAX. NI-CAN will display an error dialog for any unsupported object, and will display those objects with a red mark. For example, the J1939 protocol for multi-frame messages (greater than 8 bytes) is not supported in the current version of NI-CAN.
    GMT+8, 2025-5-10 15:30
