查看: 3774|回复: 0
[NI驱动程序] NI ELVISmx 19.0 Driver Win32/64Eng NI ELVISmx设备驱动软件19.0下载
    昨天 07:18
  • 签到天数: 3558 天
    连续签到: 3 天
    发表于 2020-12-29 23:27:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI ELVISmx
    NI-ELVISmx为使用NI ELVIS II和NI ELVIS II +以及myDAQ学生数据采集设备的客户提供支持。
    NI-ELVISmx是支持NI ELVIS II、NI ELVIS II +和myDAQ设备的驱动软件。NI-ELVISmx包括NI ELVISmx Instrument Launcher、LabVIEW Express VI和编程NI ELVIS II/II+硬件的SignalExpress步骤。
    Win32Eng
    19.0Win32/64
    文件大小: 3704184832 字节 (3.45 GB)
    修改日期: 2019-05-14 22:57
    MD5: 5a6978c0d0178fca4f7ad866b681d5ba(官方正确)
    SHA1: 4e0e89ccb67ea68e9756e9ca89aa0aa858a0646b
    SHA256: 70df9f635b8540206d1912a0a38c4c132851e1ae371d726eaa719900f4e42c06
    CRC32: 00bb78b4
    ELVISmx19.0.0.txt (643 Bytes, 下载次数: 6, 售价: 10 元)
    NI ELVISmx 19.0 Readme
    March 2019
    This file contains important information about the NI ELVISmx software, including supported operating systems, software requirements, and known issues.
    Software Requirements
    Driver Version Naming Changes
    Using the Instruments in Manual Mode (NI ELVIS II Series Only)
    NI ELVISmx Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    The NI ELVISmx driver provides driver support for NI ELVIS II series and NI myDAQ hardware. Refer to ni.com/downloads for the latest information about the NI ELVISmx driver.
    For more information on how to get started with NI ELVIS II series, visit ni.com/nielvis. Visit ni.com/mydaq for materials related to NI myDAQ.
    Note:  NI ELVISmx driver software does not support Legacy NI ELVIS workstations. NI recommends NI ELVIS II/II+ programmed with NI ELVISmx driver software for new applications. Refer to ni.com/downloads for the NI ELVIS Software driver for Legacy ELVIS workstations.
    NI ELVISmx 19.0 supports the following operating systems:
    • Windows 10 (version 1809)/8.1 Update 11/7 SP12
    Note
    • In 2016 NI ELVISmx dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI ELVISmx 19.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI ELVISmx 19.0 to an unsupported OS. Additionally, after installing NI ELVISmx 19.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?.
    • Refer to NI ELVISmx Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Software Requirements1
    You must have NI-DAQmx 19.0 or later installed to use NI ELVISmx 19.0. NI ELVISmx 19.0 installs NI-DAQmx 19.0 by default. NI ELVISmx 19.0 is used with LabVIEW 2016 or later. If you are using NI SignalExpress, you must use version 2014 or later. If you are using NI Multisim, you must use version 13.0 or later.
    Note: Because several of the NI ELVISmx instruments run the device at maximum speed, NI ELVIS II Series and NI myDAQ devices must be used with Hi-Speed USB interfaces.
    1 NI ELVISmx is not supported in LabVIEW (64-bit), but NI ELVISmx software instruments are still available for use. For full programmatic functionality with LabVIEW and NI ELVISmx, you must have LabVIEW (32-bit) installed on a Windows 10/8.1/7 (64-bit) operating system.
    NI ELVISmx versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI ELVISmx 19.0 is the version released with LabVIEW 2019. The last version released under the old numbering scheme is NI ELVISmx 4.5. The first version released under the new numbering scheme is NI ELVISmx 14.0.
    The Variable Power Supplies and Function Generator can be set to Manual mode or Software mode by using their associated Soft Front Panel Instruments, Express VIs, or SignalExpress Steps. In Manual mode, the knobs on the NI ELVIS II Series Workstation control the instrument outputs.
    The following list describes the documentation that installs with NI ELVISmx:
    • NI ELVIS II Series Quick Start Guide—This document explains how to install the application and NI ELVISmx driver software, set up your NI ELVIS II/ELVIS II+ device, and take your first measurement.
    • NI Educational Laboratory Virtual Instrumentation Suite II Series (NI ELVIS II Series) User Manual—This user manual provides more detailed information about the NI ELVIS II Series hardware, including specifications and safety information.
    • NI ELVIS II Series Specifications—This document lists the hardware specifications for the NI ELVIS II series devices.
    • NI myDAQ Quick Start Guide—This document explains how to install the application and NI ELVISmx driver software, set up your NI myDAQ device, and take your first measurement.
    • NI myDAQ User Guide—This document contains information about the NI myDAQ hardware and the concept of virtual instrumentation for the NI myDAQ device.
    • NI myDAQ Specifications—This document lists the hardware specifications for your NI myDAQ device.
    • NI ELVISmx Help—This help file provides information about the soft front panel (SFP) instruments and the LabVIEW Express VIs that you may need while using the software.
    • SignalExpress Help—This help file contains instructions for designing measurement projects using the NI ELVISmx steps in SignalExpress.
    • Using NI ELVISmx Instruments in NI Multisim—This help file explains how to use NI ELVISmx instruments in NI Multisim to simulate data, acquire data from hardware, and compare simulated and acquired data.
    To download the latest NI ELVISmx documentation, refer to ni.com/manuals.
    • Upgrading the version of Windows on a system with NI ELVISmx installed can result in the loss of device names and device configuration. Devices can also appear disconnected. For information on how to resolve this, see Device Configuration Erased after Upgrade from Windows 8 to 8.1.
    • When using NI ELVISmx software instruments, controls can disable/enable incorrectly and/or contain incorrect values when an invalid device is selected. A device becomes invalid when it is disconnected from the PC while the software instrument Device control drop-down dialog is open. If the disconnected device is selected from the drop-down control and then reconnected, the software instrument controls may not update correctly. Selecting the device again from the software instrument Device control corrects the issue.
    • Scope Zoom has been hidden. You can enable it using the steps outlined in the KB document, KB 4T5GG7HF: How Do I Display the Zoom Controls on the NI ELVISmx Scope Soft Front Panel?. To access this document, go to ni.com/info and enter the Info Code exh3ma.
    • The NI ELVIS II Series device must be plugged into the system and powered on before launching the NI ELVISmx Express VIs and SignalExpress steps in order for it to be recognized by the software. If the device is plugged in after the software is launched, close the software application and relaunch it.
    • Some NI ELVISmx instruments are not supported by NI myDAQ. For more information on NI ELVISmx instrument support, refer to the NI ELVISmx Help.
    • When running the NI ELVISmx Express VIs continuously in a loop, wire the Stop input of the Express VI to the Stop control of the loop for optimal performance.
    • In SignalExpress, if you drag NI ELVISmx steps data into the SignalExpress Data view, the graph axes always default to voltage versus time. If you want to change these defaults (for instance, to current versus voltage), you must manually change the labels on the graph.
    Refer to the NI ELVISmx Help, accessible from NI ELVISmx Instrument launcher Resources tab, for information about using NI ELVISmx driver software with your device.
    NI ELVISmx will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2003–2019 National Instruments. All rights reserved.
    376384D-01
    GMT+8, 2025-6-6 07:34
