NI ELVISmx 16.0 Driver Win32Eng NI ELVISmx设备驱动软件16.0下载
NI ELVISmx
NI-ELVISmx为使用NI ELVIS II和NI ELVIS II +以及myDAQ学生数据采集设备的客户提供支持。
NI-ELVISmx是支持NI ELVIS II、NI ELVIS II +和myDAQ设备的驱动软件。NI-ELVISmx包括NI ELVISmx Instrument Launcher、LabVIEW Express VI和编程NI ELVIS II/II+硬件的SignalExpress步骤。
Win32Eng
16.0
文件大小: 2029273645 字节 (1.89 GB)
修改日期: 2016-08-01 22:08
MD5: 2f367468582e36be9c6fbac537979633(官方正确)
SHA1: 3264f0161a9e4a9b5a9105c145e9a573ab441b61
SHA256: a7eafe5ee2d8e9d2f0bc5aa1209dc4a0aa087b4b951241d570ce9e4e7d6959a3
CRC32: fb872a14
ELVISmx16.0.0.txt
(604 Bytes, 下载次数: 0, 售价: 10 圆)
NI ELVISmx 16.0 ReadmeJune 2016 This file contains important information about the NI ELVISmx software and is organized into the following sections: Supported Operating Systems
Software Requirements
What's New
Driver Version Naming Changes
Using the Instruments in Manual Mode (NI ELVIS II Series Only)
The NI ELVISmx driver provides driver support for NI ELVIS II series and NI myDAQ hardware. Refer to ni.com/downloads for the latest information about the NI ELVISmx driver. For more information on how to get started with NI ELVIS II series, visit ni.com/nielvis. Visit ni.com/mydaq for materials related to NI myDAQ. Note: NI ELVISmx driver software does not support Legacy NI ELVIS workstations. National Instruments recommends NI ELVIS II/II+ programmed with NI ELVISmx driver software for new applications. Refer to ni.com/downloads for the NI ELVIS Software driver for Legacy ELVIS workstations. Supported Operating SystemsNI ELVISmx 16.0 supports the following operating systems: - Windows 10/8.11/7 SP12
- Windows Embedded Standard 7 SP12
- Windows Server 2012 R21
- Windows Server 2008 R2 SP12
1 NI software installs VC2015 Runtime and .NET 4.6.1. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update. Back to Top Software Requirements1You must have NI-DAQmx 16.0 or later installed to use NI ELVISmx 16.0. NI ELVISmx 16.0 installs NI-DAQmx 16.0 by default. NI ELVISmx 16.0 is used with LabVIEW 2013 or later. If you are using NI SignalExpress, you must use version 2013 or later. If you are using NI Multisim, you must use version 12.0 or later. Note: Because several of the NI ELVISmx instruments run the device at maximum speed, NI ELVIS II Series and NI myDAQ devices must be used with Hi-Speed USB interfaces. 1 NI ELVISmx is not supported in LabVIEW (64-bit), but NI ELVISmx software instruments are still available for use. For full programmatic functionality with LabVIEW and NI ELVISmx, you must have LabVIEW (32-bit) installed on a Windows 8.1/8/7/Vista (64-bit) operating system. Back to Top Accessing the HelpRefer to the NI ELVISmx Help, accessible from NI ELVISmx Instrument launcher Resources tab, for information about using NI ELVISmx driver software with your device. Back to Top NI ELVISmx 16.0 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003With this release, NI ELVISmx drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI ELVISmx 16.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI ELVISmx 16.0 to an unsupported OS. Additionally, after installing NI ELVISmx 16.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?. Back to Top Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. Back to Top What's New
- NI ELVISmx 16.0 includes support for LabVIEW 2016.
- Updated web-based installer, available on the NI ELVISmx 16.0 download page.
Back to Top Driver Version Naming ChangesNI ELVISmx versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI ELVISmx 16.0 is the version released with LabVIEW 2016. The last version released under the old numbering scheme is NI ELVISmx 4.5. The first version released under the new numbering scheme is NI ELVISmx 14.0. Back to Top Using the Instruments in Manual Mode (NI ELVIS II Series Only)The Variable Power Supplies and Function Generator can be set to Manual mode or Software mode by using their associated Soft Front Panel Instruments, Express VIs, or SignalExpress Steps. In Manual mode, the knobs on the NI ELVIS II Series Workstation control the instrument outputs. Back to Top DocumentationThe following list describes the documentation that installs with NI ELVISmx: - NI ELVIS II Series Quick Start Guide—This document explains how to install the application and NI ELVISmx driver software, set up your NI ELVIS II/ELVIS II+ device, and take your first measurement.
- NI Educational Laboratory Virtual Instrumentation Suite II Series (NI ELVIS II Series) User Manual—This user manual provides more detailed information about the NI ELVIS II Series hardware, including specifications and safety information.
- NI ELVIS II Series Specifications—This document lists the hardware specifications for the NI ELVIS II series devices.
- NI myDAQ Quick Start Guide—This document explains how to install the application and NI ELVISmx driver software, set up your NI myDAQ device, and take your first measurement.
- NI myDAQ User Guide—This document contains information about the NI myDAQ hardware and the concept of virtual instrumentation for the NI myDAQ device.
- NI myDAQ Specifications—This document lists the hardware specifications for your NI myDAQ device.
- NI ELVISmx Help—This help file provides information about the soft front panel (SFP) instruments and the LabVIEW Express VIs that you may need while using the software.
- SignalExpress Help—This help file contains instructions for designing measurement projects using the NI ELVISmx steps in SignalExpress.
- Using NI ELVISmx Instruments in NI Multisim—This help file explains how to use NI ELVISmx instruments in NI Multisim to simulate data, acquire data from hardware, and compare simulated and acquired data.
To download the latest NI ELVISmx documentation, refer to ni.com/manuals. Back to Top Known Issues- Upgrading the version of Windows on a system with NI ELVISmx installed can result in the loss of device names and device configuration. Devices can also appear disconnected. For information on how to resolve this, see Device Configuration Erased after Upgrade from Windows 8 to 8.1.
- When using NI ELVISmx software instruments, controls can disable/enable incorrectly and/or contain incorrect values when an invalid device is selected. A device becomes invalid when it is disconnected from the PC while the software instrument Device control drop-down dialog is open. If the disconnected device is selected from the drop-down control and then reconnected, the software instrument controls may not update correctly. Selecting the device again from the software instrument Device control corrects the issue.
- Scope Zoom has been hidden. You can enable it using the steps outlined in the KB document, KB 4T5GG7HF: How Do I Display the Zoom Controls on the NI ELVISmx Scope Soft Front Panel?. To access this document, go to ni.com/info and enter the Info Code exh3ma.
- The NI ELVIS II Series device must be plugged into the system and powered on before launching the NI ELVISmx Express VIs and SignalExpress steps in order for it to be recognized by the software. If the device is plugged in after the software is launched, close the software application and relaunch it.
- Some NI ELVISmx instruments are not supported by NI myDAQ. For more information on NI ELVISmx instrument support, refer to the NI ELVISmx Help.
- When running the NI ELVISmx Express VIs continuously in a loop, wire the Stop input of the Express VI to the Stop control of the loop for optimal performance.
- In SignalExpress, if you drag NI ELVISmx steps data into the SignalExpress Data view, the graph axes always default to voltage versus time. If you want to change these defaults (for instance, to current versus voltage), you must manually change the labels on the graph.
Back to Top Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
- To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, How Can I Determine the Type and Version of My NI Installer?.
Back to Top Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Back to Top Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. Back to Top Legal InformationCopyright © 2003–2016 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents.
376384A-01 |
