查看: 3175|回复: 0
[NI驱动程序] NI ELVISmx 4.3 Driver Win32Eng NI ELVISmx设备驱动软件4.3下载
    3 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-12-29 23:14:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI ELVISmx
    NI-ELVISmx为使用NI ELVIS II和NI ELVIS II +以及myDAQ学生数据采集设备的客户提供支持。
    NI-ELVISmx是支持NI ELVIS II、NI ELVIS II +和myDAQ设备的驱动软件。NI-ELVISmx包括NI ELVISmx Instrument Launcher、LabVIEW Express VI和编程NI ELVIS II/II+硬件的SignalExpress步骤。
    Win32Eng
    4.3
    文件大小: 1438654064 字节 (1.34 GB)
    修改日期: 2019-06-25 03:08
    MD5: c86a0fcdaf57a3baa68c6604ea509a34(官方正确)
    SHA1: 6e79403bd8074c803fe23dff1e63a5219e50e404
    SHA256: 92d8365ddc21a74dc954f5cfc3957cfad1604edf5854952a8174dac43d83e05c
    CRC32: bec83f18
    ELVISmx4.3.0.txt (593 Bytes, 下载次数: 0, 售价: 10 圆)
    NI ELVISmx 4.3 Readme
    June 2011
    This file contains important information about the NI ELVISmx software and is organized into the following sections:
    Operating System Support
    Software Requirements
    What's New
    Using the Instruments in Manual Mode
    Notice Regarding Microsoft Silverlight Installation and Redistribution
    The NI ELVISmx driver provides driver support for NI ELVIS II series hardware and NI myDAQ. Refer to ni.com/downloads for the latest information about the NI ELVISmx driver.
    For more information on how to get started with NI ELVIS II series, visit ni.com/nielvis. Visit ni.com/mydaq for materials related to NI myDAQ.
    Note:  NI ELVISmx driver software does not support Legacy NI ELVIS workstations. National Instruments recommends NI ELVIS II/II+ programmed with NI ELVISmx driver software for new applications. Refer to ni.com/downloads for the NI ELVIS Software driver for Legacy ELVIS workstations.
    The following operating systems are supported in NI ELVISmx 4.3:
    • Windows 7 (32-bit and 64-bit)*
    • Windows Vista Business edition (32-bit and 64-bit)*
    • Windows XP, Service Pack 2 or greater (32-bit)
    * NI ELVISmx is not supported in LabVIEW (64 bit). To use LabVIEW with NI ELVISmx on a Windows 7/Vista (64 bit) operating system, you must have LabVIEW (32 bit) installed.
    Back to Top
    You must have NI-DAQmx 9.3.5 or later installed to use NI ELVISmx 4.3. NI ELVISmx 4.3 installs NI-DAQmx 9.3.5 by default. NI ELVISmx 4.3 is used with LabVIEW 8.6.1 or later. If you are using LabVIEW SignalExpress, you must use version 3.0 or later.
    Note: Because several of the NI ELVISmx instruments run the device at maximum speed, NI ELVIS II Series and NI myDAQ devices must be used with Hi-Speed USB interfaces.
    Back to Top
    What's New
    NI ELVISmx Instrument Launcher has added new features to extend the functionality of the NI ELVISmx user interface and functionality, including the following:
    • Allowing users to print from the Bode Analyzer, Dynamic Signal Analyzer, and Oscilloscope instrument Soft Front Panels. NI ELVIS II Series users can also print from the Impedance Analyzer, Two-Wire Current-Voltage Analyzer, and Three-Wire Current-Voltage Analyzer instrument Soft Front Panels.
    • Customize Oscilloscope Soft Front Panel instrument plots, cursors, and measurements with Graph Properties
    • Switch the Oscilloscope Soft Front Panel background color of the instrument graph between black and white
    • Enabled AO 0 and AO 1 channels for the NI myDAQ Function Generator Soft Front Panel instrument
    • Tab section to the NI ELVISmx Instrument Launcher containing the following content:
      • Featured Instruments—Customized instruments and LabVIEW examples
      • Resources—Documentation and tutorial resources
      • My Files—A customizable tab that can be populated with user files and instruments
    NI ELVISmx 4.3 has added support for LabVIEW 2011.
    Back to Top
    Using the Instruments in Manual Mode (NI ELVIS II Series Only)
    The Variable Power Supplies and Function Generator can be set to Manual mode or Software mode by using their associated Soft Front Panel Instruments, Express VIs, or SignalExpress Steps. In Manual mode, the knobs on the NI ELVIS II Series Workstation control the instrument outputs.
    Back to Top
    The following list describes the documentation that installs with NI ELVISmx:
    • Where to Start with NI ELVIS II Series—This document includes important installation and configuration instructions you should read before using the NI ELVISmx software and NI ELVIS II Series hardware.
    • NI Educational Laboratory Virtual Instrumentation Suite II Series (NI ELVIS II Series) User Manual—This user manual provides more detailed information about the NI ELVIS II Series hardware, including specifications and safety information.
    • NI myDAQ User Guide and Specifications—This user guide provides more detailed information about the NI myDAQ hardware, including specifications and safety information.
    • NI ELVISmx Help—This help file provides information about the soft front panel (SFP) instruments and the LabVIEW Express VIs that you may need while using the software.
    • LabVIEW SignalExpress Help—This help file contains instructions for designing measurement projects using the NI ELVISmx steps in SignalExpress.
    • Using NI ELVISmx Instruments in NI Multisim—This help file explains how to use NI ELVISmx instruments in NI Multisim to simulate data, acquire data from hardware, and compare simulated and acquired data.
    To download the latest NI ELVISmx documentation, refer to ni.com/manuals.
    Back to Top
    • Scope Zoom has been hidden. You can enable it using the steps outlined in the KB document, KB 4T5GG7HF: How Do I Display the Zoom Controls on the NI ELVISmx Scope Soft Front Panel?. To access this document, go to ni.com/info and enter the info code exh3ma.
    • The NI ELVIS II Series device must be plugged into the system and powered on before launching the NI ELVISmx Soft Front Panel Instruments, Express VIs and SignalExpress steps in order for it to be recognized by the software. If the device is plugged in after the software is launched, close the software application and relaunch it.
    • NI ELVIS II Series hardware is supported by NI ELVISmx 4.0 and later. The original NI ELVIS hardware is not supported. If you are unsure which version you have, "NI ELVIS II" or "NI ELVIS II+" is labeled on the NI ELVIS II Series device itself. The original NI ELVIS is labeled "NI ELVIS."
    • Some NI ELVISmx instruments are not supported by NI myDAQ. For more information on NI ELVISmx instrument support, refer to the NI ELVISmx Help.
    • When running the NI ELVISmx Express VIs continuously in a loop, wire the Stop input of the Express VI to the Stop control of the loop for optimal performance.
    • In LabVIEW SignalExpress, if you drag NI ELVISmx steps data into the SignalExpress Data view, the graph axes always default to voltage versus time. If you want to change these defaults (for instance, to current versus voltage), you must manually change the labels on the graph.
    Back to Top
    Using Microsoft Silverlight
    Back to Top
    Important Information
    © 2003–2011 National Instruments Corporation. All rights reserved.
    For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in NI ELVISmx, refer to the Copyright topic of the NI ELVISmx Help.
    GMT+8, 2025-11-19 10:52
