查看: 3700|回复: 0
[NI驱动程序] NI ELVISmx 4.1 Driver Win32Eng NI ELVISmx设备驱动软件4.1下载
    3 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-12-29 23:10:11 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI ELVISmx
    NI-ELVISmx为使用NI ELVIS II和NI ELVIS II +以及myDAQ学生数据采集设备的客户提供支持。
    NI-ELVISmx是支持NI ELVIS II、NI ELVIS II +和myDAQ设备的驱动软件。NI-ELVISmx包括NI ELVISmx Instrument Launcher、LabVIEW Express VI和编程NI ELVIS II/II+硬件的SignalExpress步骤。
    Win32Eng
    4.1
    文件大小: 973569313 字节 (928.47 MB)
    修改日期: 2019-06-25 03:08
    MD5: c7d4400dc67533c7a2b689e5d2b4a264(官方正确)
    SHA1: b8003a25dc63712d5c78b893cf82aead1089175b
    SHA256: 87003e6a6efff0697bf7bb0168f5fd01c4d89c8887a522171a164d30f937a2e5
    CRC32: d10f388d
    ELVISmx4.1.0.txt (589 Bytes, 下载次数: 0, 售价: 10 圆)
    NI ELVISmx 4.1 Readme
    January 2009
    This file contains important information about the NI ELVISmx software and is organized into the following sections:
        Software Requirements
        What's New
        Using the Instruments in Manual Mode
    Refer to ni.com/academic/ni_elvis for the latest information about NI ELVISmx. To download the Introduction to NI ELVIS course document and example VIs, go to ni.com/info and enter elviscourseware.
    You must have LabVIEW 8.2 or later and NI-DAQmx 8.9 or later installed to use NI ELVISmx 4.1 or later. NI ELVISmx 4.1 installs NI-DAQmx 8.9 by default. If you are using LabVIEW SignalExpress, you must use version 3.0 or later.
    Note: Because several of the NI ELVISmx instruments run the device at maximum speed, NI ELVIS II Series devices must be used with Hi-Speed USB interfaces.
    What's New
    NI ELVISmx 4.1 adds support for NI ELVIS II+ hardware. The original NI ELVIS hardware is not supported. If you are unsure which version you have, "NI ELVIS II" or "NI ELVIS II+" is labeled on the NI ELVIS II Series device itself. The original NI ELVIS is labeled "NI ELVIS."
    The Variable Power Supplies and Function Generator can be set to Manual mode or Software mode by using their associated Soft Front Panel Instruments, Express VIs, or SignalExpress Steps. In Manual mode, the knobs on the NI ELVIS II Series Workstation control the instrument outputs.
    The following list describes the documentation that installs with NI ELVISmx:
        Where to Start with NI ELVIS II Series—This document includes important installation and configuration instructions you should read before using the NI ELVISmx software and NI ELVIS II Series hardware.
        NI Educational Laboratory Virtual Instrumentation Suite II Series (NI ELVIS II Series) User Manual—This user manual provides more detailed information about the NI ELVIS II Series hardware, including specifications and safety information.
        NI ELVISmx Help—This help file provides information about the soft front panel (SFP) instruments and the LabVIEW Express VIs that you may need while using the software.
        LabVIEW SignalExpress Help—This help file contains instructions for designing measurement projects using the NI ELVISmx steps in SignalExpress.
        Using NI ELVISmx Instruments in NI Multisim—This help file explains how to use NI ELVISmx instruments in NI Multisim to simulate data, acquire data from hardware, and compare simulated and acquired data.
    To download the latest NI ELVISmx documentation, refer to ni.com/manuals.
       The Vertical Offset and 20 MHz Filter controls are not supported for NI ELVIS II Series devices when using the NI ELVISmx Oscilloscope Express VI.
       Scope Zoom has been hidden. You can enable it using the steps outlined in KB 4T5GG7HF: How Do I Display the Zoom Controls on the NI ELVISmx Scope Soft Front Panel?
       The NI ELVIS II Series device must be plugged into the system and powered on before launching the NI ELVISmx Soft Front Panel Instruments, Express VIs and SignalExpress steps in order for it to be recognized by the software. If the device is plugged in after the software is launched, close the software application and relaunch it.
        When running the NI ELVISmx Express VIs continuously in a loop, wire the Stop input of the Express VI to the Stop control of the loop for optimal performance.
        In LabVIEW SignalExpress, if you drag NI ELVISmx steps data into the SignalExpress Data view, the graph axes always default to voltage versus time. If you want to change these defaults (for instance, to current versus voltage), you must manually change the labels on the graph.
    © 2003—2009 National Instruments Corporation. All rights reserved.
    National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section at ni.com/legal for more information about National Instruments trademarks.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    GMT+8, 2025-11-19 10:52
