查看: 3502|回复: 0
[NI驱动程序] NI FlexRIO 19.6 Driver Win32/64Eng NI-FlexRIO设备驱动程序19.6
    3 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-12-28 23:51:11 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    FlexRIO
    FlexRIO驱动程序为使用NI FlexRIO设备的客户提供支持。
    FlexRIO驱动是用于支持FlexRIO设备的NI仪器驱动。该驱动为基于集成I/O和模块化I/O的FlexRIO设备提供硬件支持,包括用于FlexRIO的PXI FPGA模块以及FlexRIO的各种适配器模块。对于基于集成I/O的FlexRIO设备,FlexRIO驱动还提供用于数据流传输的API以及NI-TClk同步支持。
    Win32/64Eng
    19.6
    文件大小: 9672947712 字节 (9.01 GB)
    修改日期: 2019-12-13 05:39
    MD5: 2ad6214155433a2e605189a7053dcef8(官方正确)
    SHA1: 88a502f325d14d59fd305a2b49f5100b478072a9
    SHA256: c86bd8ccc747d8665857aaf86212a65f1bba44b7daf9a0fbce5ce176151016f5
    CRC32: b709100b
    FlixeRIO19.6.txt (663 Bytes, 下载次数: 0, 售价: 10 圆)
    FlexRIO™ 19.6 Readme
    November 2019
    Thank you for using FlexRIO 19.6. This file contains important information about FlexRIO 19.6 and is organized into the following sections.
    Driver Version Naming Changes
    Installing FlexRIO 19.6
    Uninstalling/Modifying FlexRIO 19.6
    Known Issues and Bug Fixes
    FlexRIO 19.6 supports the following operating systems:
    Operating System64-bit32-bit
    Windows 10 1
    Windows 8.1 1
    Windows 7 Service Pack 1
    Windows Server 2008 R2 2
    Red Hat Enterprise Linux 7.x
    Red Hat Enterprise Linux 6.x
    Scientific Linux 6.x
    CentOS 7
    Note In July 2016, NI dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. FlexRIO 19.6 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use FlexRIO 19.6 to an unsupported OS. Additionally, after installing FlexRIO 19.6, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note: FlexRIO 19.6 does not support Windows Server non-R2 editions.
    FlexRIO 19.6 supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    Note: You should install ADEs before installing FlexRIO 19.6. To add support for ADEs installed after installing FlexRIO 19.6, modify your FlexRIO 19.6 installation or launch the FlexRIO 19.6 installer again.
    • LabVIEW 2016, 2017 SP1, 2018, and 2019
    • LabVIEW NXG 4.0
    • LabVIEW Real-Time Module 2016, 2017, 2018, and 2019
    • LabVIEW FPGA Module 2016, 2017 SP1, 2018, and 2019
    • LabVIEW NXG FPGA Module 4.0
    Note: If you are running your application on an RT target, 128 MB of memory or more is required
    FlexRIO 19.6 includes the following new features.
    • LabVIEW 2019 support for the PXIe-6593.
    FlexRIO 19.5 includes the following new features.
    • FlexRIO with Modular I/O support for LabVIEW NXG 4.0
    • FlexRIO with Integrated I/O support for Linux RT.
    FlexRIO 19.0 includes the following new features.
    • Support for LabVIEW 2019
    FlexRIO 18.7 includes the following new features.
    • LabVIEW 2018 support for the following hardware devices:
      • PXIe-5774
      • PCIe-5774
      • PCIe-5763
      • PCIe-5764
      • PCIe-5775
      • PCIe-5785
    FlexRIO 18.6 includes the following new features.
      • PXIe-5745
      • PXIe-5775
      • PXIe-5785
    FlexRIO 18.1 includes the following new features.
    • LabVIEW 2018 and 2017 support for the following hardware devices:
      • PXIe-7911
      • PXIe-7912
      • PXIe-7915
      • PXIe-5763
      • PXIe-5764
    FlexRIO 18.0 includes the following new features.
    • Support for LabVIEW 2018
    Project export for the Vivado Design Suite—The LabVIEW 2017 FPGA Module provides an option to export FPGA VIs to the Vivado Design Suite projects. This option allows you to design the exported project and compile it into a bitfile in the Vivado Design Suite. You can then run a bitfile on an FPGA target in the FPGA Module.Supported Hardware
    FlexRIO 19.6 software supports the following FlexRIO hardware:
    FlexRIO with Integrated I/O1
    • FlexRIO High-Speed Serial Modules
      • PXIe-6593
    • FlexRIO Coprocessor Modules
      • PXIe-7911
      • PXIe-7912
      • PXIe-7915
    • FlexRIO Digitizer Modules
      • PXIe-5763
      • PXIe-5764
      • PXIe-5775
      • PXIe-5774
      • PCIe-5774
      • PCIe-5763
      • PCIe-5764
      • PCIe-5775
    • FlexRIO Signal Generator Modules
      • PXIe-5745
    • FlexRIO IF Transceiver Modules
      • PXIe-5785
      • PCIe-5785
    • Controllers for FlexRIO
      • NI-7931R
      • NI-7932R
      • NI-7935R
    • FlexRIO FPGA Modules
      • PXI-7951R1
      • PXI-7952R1
      • PXI-7953R1
      • PXI-7954R1
      • PXIe-7961R1
      • PXIe-7962R1
      • PXIe-7965R1
      • PXIe-7966R1
      • PXIe-7971R
      • PXIe-7972R
      • PXIe-7975R
      • PXIe-7976R
    • FlexRIO Adapter Modules2
      • NI 57311
      • NI 5732
      • NI 5733
      • NI 5734
      • NI 57411
      • NI 57421
      • NI 5751/5751B
      • NI 5752/5752B1
      • NI 57531
      • NI 5761
      • NI 57621
      • NI 5771
      • NI 5772
      • NI 57811
      • NI 5782
      • NI 5783
      • NI 5791
      • NI 5792
      • NI 5793
      • NI 6581/6581B
      • NI 6583
      • NI 6584
      • NI 6585/6585B
      • NI 6587
      • NI 6589
    1 Not supported in LabVIEW NXG.
    2 FlexRIO adapter modules are supported only in LabVIEW 2017, LabVIEW 2018, LabVIEW 2019, and LabVIEW NXG.
    Device-specific information about these modules is included in the FlexRIO Help.
        • (32-bit) Program Files\IVI\
    The product documentation is available at Start»All Programs»National Instruments»NI FlexRIO. Visit ni.com/manuals for the latest versions of product documentation.
    To view these documents, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/reader.
    The documentation set is composed of the following documents:
    DocumentDescription
    FlexRIO HelpContains information about FlexRIO device support. This book also provides instructions for using LabVIEW and the LabVIEW FPGA Module with FlexRIO devices.
    NI-7931R/7932R/7935R User ManualContains information about how to develop applications for your NI-793xR module.
    Getting started guide for your deviceContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
    Specifications document for your deviceLists technical specifications for your device.
    FlexRIO 19.6 Readme (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    To use the .NET API, you must install the the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    Refer to ni.com/flexrio for additional FlexRIO product support and information.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. FlexRIO examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including FlexRIO) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»FlexRIO.
    • Click the Search tab to search all installed examples by keyword. For example, search for "FlexRIO" to locate all FlexRIO examples.
    Examples also are available online that demonstrate applications using FlexRIO. Refer to ni.com/examples for these examples and for more information.
    FlexRIO versions are aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions start with a two-digit year indicator: <;ProductName>. For example, FlexRIO 19.6 is the version released with LabVIEW 2019.
    Complete the following steps to install FlexRIO 19.6 for use with LabVIEW:
    • Install LabVIEW.
    • (Optional) Install LabVIEW Real-Time.
    • Install LabVIEW FPGA.
      Note: In the LabVIEW FPGA installation menu, you must also install the Compilation Tools for FPGA Devices other than Virtex-II to use these examples.
    • Install FlexRIO 19.6.
    Note: Visit ni.com/info and enter rdsoftwareversion as the Info Code for more information about which minimum software versions you need for your device.
    FlexRIO no longer installs IVI Compliance Package. FlexRIO supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    If you want to use the above features, you must install IVI Compliance Package separately, either from ni.com/downloads or from the NI Device Drivers 2019 DVD.
    For Windows 7 Service Pack 1, complete the following steps:
    • Select FlexRIO 19.6 from the dialog box that appears.
    For Windows 8.1, complete the following steps:
    • Select All apps and launch the Control Panel.
    • Click the Uninstall button.
    You can access the software and documentation known issues and bug fixes list online at ni.com/r/flexrio195ki.
    Note: FlexRIO 19.6 includes the LabVIEW 2018 FPGA Module f1 patch. Refer to Info Code FPGA2018f1 for more information.
    ©2008–2019 National Instruments. All rights reserved.
    374872V-01
    GMT+8, 2025-11-19 10:51
