查看: 3105|回复: 0
[NI驱动程序] NI FlexRIO 16.0 Driver Win32/64Eng NI-FlexRIO设备驱动程序16.0
    3 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-12-28 23:38:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    FlexRIO
    FlexRIO驱动程序为使用NI FlexRIO设备的客户提供支持。
    FlexRIO驱动是用于支持FlexRIO设备的NI仪器驱动。该驱动为基于集成I/O和模块化I/O的FlexRIO设备提供硬件支持,包括用于FlexRIO的PXI FPGA模块以及FlexRIO的各种适配器模块。对于基于集成I/O的FlexRIO设备,FlexRIO驱动还提供用于数据流传输的API以及NI-TClk同步支持。
    Win32/64Eng
    16.0
    文件大小: 3680545664 字节 (3.43 GB)
    修改日期: 2016-08-01 22:23
    MD5: 2069a20a2d38352624f39538e2f3ab49(官方正确)
    SHA1: d8b259a4d42285cd7f30305f9cf4e4e7c38508df
    SHA256: f0e2b8058da5d7aa7dbeadc6935ccaa64778ca016eb56512b2e9d38fa1ff548b
    CRC32: 1098da6c
    FlixeRIO16.0.txt (613 Bytes, 下载次数: 0, 售价: 10 圆)
    FlexRIO™ Support 16.0 Readme
    August 2016
    Thank you for using FlexRIO Support 16.0. This file contains important information about FlexRIO Support 16.0 and is organized into the following sections.
    Driver Version Naming Changes
    Installing FlexRIO 16.0
    Uninstalling/Modifying FlexRIO 16.0
    Known Issues and Bug Fixes
    FlexRIO Support 16.0 includes the following new features.
    • Support for LabVIEW 2016
    FlexRIO Support 15.5 includes the following new features.
    • Support for LabVIEW 2015 SP1
    • Bug fixes and improvements
    • FlexRIO Adapter Module Support is deprecated and its functionality is combined with the FlexRIO driver as of FlexRIO Support 15.5
    FlexRIO Support 15.1.1 includes the following new features.
    • 10 GbE example support for NI-793xR hardware devices
    • Support for the following FlexRIO adapter modules:
      • NI 5751B
      • NI 5752B
      • NI 6585B
    FlexRIO Support 15.1 includes the following new features.
    • LabVIEW 2015 support for the following hardware devices:
      • NI-7931R
      • NI-7932R
      • NI-7935R
    FlexRIO 16.0 software supports the following FlexRIO hardware:
    Controllers for FlexRIO
    • NI-7931R
    • NI-7932R
    • NI-7935R
    FlexRIO FPGA Modules
    • NI PXI-7951R
    • NI PXI-7952R
    • NI PXI-7953R
    • NI PXI-7954R
    • NI PXIe-7961R
    • NI PXIe-7962R
    • NI PXIe-7965R
    • NI PXIe-7966R
    • NI PXIe-7971R
    • NI PXIe-7972R
    • NI PXIe-7975R
    • NI PXIe-7976R
    FlexRIO Adapter Modules1
    • NI 5731
    • NI 5732
    • NI 5733
    • NI 5734
    • NI 5741
    • NI 5742
    • NI 5751/5751B
    • NI 5752/5752B
    • NI 5761
    • NI 5762
    • NI 5771
    • NI 5772
    • NI 5781
    • NI 5782
    • NI 5783
    • NI 5791
    • NI 5792
    • NI 5793
    • NI 6581/6581B
    • NI 6583
    • NI 6584
    • NI 6585/6585B
    • NI 6587
    • NI 6589
    1 FlexRIO adapter modules are supported only in LabVIEW 2015 and LabVIEW 2016.
    Device-specific information about these modules is included in the FlexRIO Help.
    FlexRIO 16.0 supports the following operating systems:
    Operating System64-bit32-bit
    Windows 10 1
    Windows 8.1 1
    Windows 7 Service Pack 1
    Windows Server 2008 R2 2
    Red Hat Enterprise Linux 7.x
    Red Hat Enterprise Linux 6.x
    Scientific Linux 6.x
    CentOS 7
    Note: FlexRIO 16.0 does not support Windows Server non-R2 editions.
    FlexRIO 16.0 supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    Note: You should install ADEs before installing FlexRIO Support 16.0. To add support for ADEs installed after installing FlexRIO Support 16.0, modify your FlexRIO 16.0 installation or launch the FlexRIO 16.0 installer again.
    • LabVIEW 2013 SP1, 2014 SP1, 2015 SP1, and 2016
    • LabVIEW Real-Time Module 2013 SP1, 2014 SP1, 2015 SP1, and 2016
    • LabVIEW FPGA Module 2013 SP1, 2014 SP1, 2015 SP1, and 2016
    • If you are running your application on an RT target, 128 MB of memory or more is required
        • (32-bit) Program Files\IVI\
    The product documentation is available at Start»All Programs»National Instruments»NI FlexRIO. Visit ni.com/manuals for the latest versions of product documentation.
    To view these documents, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/reader.
    The documentation set is composed of the following documents:
    DocumentDescription
    FlexRIO HelpContains information about FlexRIO device support. This book also provides instructions for using LabVIEW and the LabVIEW FPGA Module with FlexRIO devices.
    NI-7931R/7932R/7935R User ManualContains information about how to develop applications for your NI-793xR module.
    Getting started guide for your deviceContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
    Specifications document for your deviceLists technical specifications for your device.
    FlexRIO Support 16.0 Readme (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    To use the .NET API, you must install the the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    Refer to ni.com/flexrio for additional FlexRIO product support and information.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. FlexRIO examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including FlexRIO) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»FlexRIO.
    • Click the Search tab to search all installed examples by keyword. For example, search for "FlexRIO" to locate all FlexRIO examples.
    Examples also are available online that demonstrate applications using FlexRIO. Refer to ni.com/examples for these examples and for more information.
    FlexRIO Support 16.0 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, FlexRIO Support 16.0 drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. FlexRIO Support 16.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use FlexRIO Support 16.0 to an unsupported OS. Additionally, after installing FlexRIO Support 16.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    FlexRIO Support versions are aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions start with a two-digit year indicator: <;ProductName>. For example, FlexRIO 16.0 is the version released with LabVIEW 2016.
    Complete the following steps to install FlexRIO 16.0 for use with LabVIEW:
    • Install LabVIEW.
    • (Optional) Install LabVIEW Real-Time.
    • Install LabVIEW FPGA .
      Note: In the LabVIEW FPGA installation menu, you must also install the Compilation Tools for FPGA Devices other than Virtex-II to use these examples.
    • Install FlexRIO 16.0.
    Note: Visit ni.com/info and enter rdsoftwareversion as the Info Code for more information about which minimum software versions you need for your device.
    For Windows 7 Service Pack 1, complete the following steps:
    • Select FlexRIO 16.0 from the dialog box that appears.
    For Windows 8.1, complete the following steps:
    • Select All apps and launch the Control Panel.
    • Click the Uninstall button.
    You can access the software and documentation known issues list online at ni.com/info by entering the info code exzh5x.
    When you install National Instruments software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Windows 8.1 DesktopDesktop TaskbarRight-click application and select Pin to Taskbar
    Windows 8.1 DesktopStart screenRight-click application and select Pin to Start
    Windows 8.1 Start screenDesktop TaskbarRight-click application and select Pin to taskbar from the menu bar on the bottom of the screen
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and click the down arrow on the bottom left of the screen.
    For more information about NI support for Windows 8.1, visit ni.com/windows8.
    ©2008–2016 National Instruments. All rights reserved.
    374872G-01
    GMT+8, 2025-11-19 10:56
