查看: 3503|回复: 0
[NI驱动程序] NI FlexRIO 15.1.1 Driver Win32/64Eng NI-FlexRIO设备驱动程序15.1.1
    3 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-12-28 23:34:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    FlexRIO
    FlexRIO驱动程序为使用NI FlexRIO设备的客户提供支持。
    FlexRIO驱动是用于支持FlexRIO设备的NI仪器驱动。该驱动为基于集成I/O和模块化I/O的FlexRIO设备提供硬件支持,包括用于FlexRIO的PXI FPGA模块以及FlexRIO的各种适配器模块。对于基于集成I/O的FlexRIO设备,FlexRIO驱动还提供用于数据流传输的API以及NI-TClk同步支持。
    Win32/64Eng
    15.1.1
    文件大小: 3378821689 字节 (3.15 GB)
    修改日期: 2016-01-06 04:25
    MD5: 887c0ae456768b0b85f9188b31131de0(官方正确)
    SHA1: eefbd3a80daa696e89ebd2814c6a023733ef318b
    SHA256: 30d35f148b4876c67af5377083a9e3044d03addfe27c8fd5842aae3439c85b0a
    CRC32: f8fc7214
    FlixeRIO15.1.1.txt (622 Bytes, 下载次数: 0, 售价: 10 圆)
    FlexRIO™ Support 15.1.1 Readme
    November 2015
    This file contains important information about FlexRIO Support 15.1.1, including installation instructions, new features, and legal information.
    Supported Software
    Driver Version Naming Changes
    Installing FlexRIO 15.1.1
    Uninstalling/Modifying FlexRIO 15.1.1
    How to Use NI Software with Microsoft Windows 8.1/8.0
    FlexRIO Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    For information about FlexRIO Adapter Module Support and FlexRIO adapter modules, refer to the FlexRIO Adapter Module Support Readme.
    FlexRIO Support 15.1.1 includes the following new features.
    • 10 GbE example support for NI-793xR hardware devices
    FlexRIO Support 15.1 includes the following new features.
    • LabVIEW 2015 support for the following hardware devices:
      • NI-7931R
      • NI-7932R
      • NI-7935R
    FlexRIO Support 15.0 includes the following new features.
    • Support for LabVIEW 2015
    FlexRIO Support 14.5 includes minor bug fixes.
    FlexRIO 15.1.1 software supports the following FlexRIO modules:
    • NI-7931R
    • NI-7932R
    • NI-7935R
    • NI PXI-7951R
    • NI PXI-7952R
    • NI PXI-7953R
    • NI PXI-7954R
    • NI PXIe-7961R
    • NI PXIe-7962R
    • NI PXIe-7965R
    • NI PXIe-7966R
    • NI PXIe-7971R
    • NI PXIe-7972R
    • NI PXIe-7975R
    • NI PXIe-7976R
    Device-specific information about these modules is included in the FlexRIO Help.
    FlexRIO 15.1.1 supports the following operating systems:
    Operating System64-bit32-bit
    Windows 8.1/8.0
    Windows 7 Professional
    Windows Vista Business
    Windows XP Professional SP2 or higher
    Windows Server 2008 R2
    Windows Server 2003 R21
    Red Hat Enterprise Linux 7.x
    Red Hat Enterprise Linux 6.x
    Scientific Linux 6.x
    CentOS 7
    1 Support for Windows Server 2003 R2 may require disabling physical address extensions.
    Note: FlexRIO 15.1.1 does not support Windows Server non-R2 editions.
    FlexRIO 15.1.1 supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows XP: 128 MB
      • Windows 8.1/8.0/7/Vista: 512 MB
    • Windows 8.1/8.0/7/Vista/XP, with all available critical updates and service packs
    Recommended System
    • RAM—
      • Windows XP: 256 MB
      • Windows 8.1/8.0/7/Vista: 1 GB
    Supported SoftwareLabVIEW 2015 (32-bit and 64-bit)LabVIEW 2014 SP1 (32-bit and 64-bit)LabVIEW 2013 SP1 (32-bit and 64-bit)LabVIEW 2012 SP1 (32-bit and 64-bit)Application Development Environments (ADEs)
    Note: You should install ADEs before installing FlexRIO Support 15.1.1. To add support for ADEs installed after installing FlexRIO Support 15.1.1, modify your FlexRIO 15.1.1 installation or launch the FlexRIO 15.1.1 installer again.
    • LabVIEW 2012 SP1 (32-bit and 64-bit), 2013 SP1 (32-bit and 64-bit), 2014 SP1 (32-bit and 64-bit), and 2015 (32-bit and 64-bit)
    • LabVIEW Real-Time Module 2012 SP1, 2013 SP1, 2014 SP1, and 2015
    • LabVIEW FPGA Module 2012 SP1, 2013 SP1, 2014 SP1, and 2015
    FlexRIO Support versions are aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions start with a two-digit year indicator: <;ProductName>. For example, FlexRIO 15.0 is the version released with LabVIEW 2015.
    Complete the following steps to install FlexRIO 15.1.1 for use with LabVIEW:
    • Install LabVIEW.
    • (Optional) Install LabVIEW Real-Time.
    • Install LabVIEW FPGA .
      Note: In the LabVIEW FPGA installation menu, you must also install the Compilation Tools for FPGA Devices other than Virtex-II to use these examples.
    • Install FlexRIO 15.1.1.
    Note: Visit ni.com/info and enter rdsoftwareversion as the Info Code for more information about which minimum software versions you need for your device.
    • Click Change/Remove.
    • Select FlexRIO 15.1.1 from the dialog box that appears.
    For Windows 8.1/8.0, complete the following steps:
    • Select All apps and launch the Control Panel.
    • Click the Uninstall button.
    To access FlexRIO examples using the NI Example Finder, open LabVIEW and select Help»Find Examples, then select Hardware Input and Output»FlexRIO.
    When you install National Instruments software on Microsoft Windows 8.1/8.0, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Windows 8.1/8.0 DesktopDesktop TaskbarRight-click application and select Pin to Taskbar
    Windows 8.1/8.0 DesktopStart screenRight-click application and select Pin to Start
    Windows 8.1/8.0 Start screenDesktop TaskbarRight-click application and select Pin to taskbar from the menu bar on the bottom of the screen
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.0) or click the down arrow on the bottom left of the screen (Windows 8.1).
    For more information about NI support for Windows 8.1/8.0, visit ni.com/windows8.
    FlexRIO will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of FlexRIO that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    The product documentation is available at Start»All Programs»National Instruments»NI FlexRIO. Visit ni.com/manuals for the latest versions of product documentation.
    To view these documents, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    The documentation set is composed of the following documents:
    DocumentDescription
    FlexRIO HelpContains information about FlexRIO device support. This book also provides instructions for using LabVIEW and the LabVIEW FPGA Module with FlexRIO devices.
    NI-7931R/7932R/7935R User ManualContains information about how to develop applications for your NI-793xR module.
    FlexRIO Adapter Module Development Kit User ManualContains information about how to develop custom adapter modules for use with your FlexRIO FPGA module.
    Getting started guide for your FlexRIO FPGA moduleContains installation instructions and configuration information for your FlexRIO FPGA module.
    Specifications document for your FlexRIO FPGA moduleContains specifications for your FlexRIO FPGA module.
    Getting started guide for your FlexRIO adapter moduleContains installation instructions and configuration information for your FlexRIO adapter module.
    Specifications document for your FlexRIO adapter moduleContains specifications for your FlexRIO adapter module.
    FlexRIO Support 15.1.1 Readme (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Refer to ni.com/flexrio for additional FlexRIO product support and information.
    ©2008–2015 National Instruments. All rights reserved.
    374872E-01
    GMT+8, 2025-11-19 10:58
