NI FlexRIO 15.0 Driver Win32/64Eng NI-FlexRIO设备驱动程序15.0
FlexRIO
FlexRIO驱动程序为使用NI FlexRIO设备的客户提供支持。
FlexRIO驱动是用于支持FlexRIO设备的NI仪器驱动。该驱动为基于集成I/O和模块化I/O的FlexRIO设备提供硬件支持,包括用于FlexRIO的PXI FPGA模块以及FlexRIO的各种适配器模块。对于基于集成I/O的FlexRIO设备,FlexRIO驱动还提供用于数据流传输的API以及NI-TClk同步支持。
Win32/64Eng
15.0
文件大小: 2786634409 字节 (2.60 GB)
修改日期: 2015-08-04 00:25
MD5: 92a0bb34ab6df2b2daaf76707324c719(官方正确)
SHA1: 77c477b55e7dfd25b0ce2f0e16bf7e513a412096
SHA256: bc90db324074c27cfa7c2e66e9b25cd97b1065a8ca99273f594d09d9a3c61902
CRC32: 991a3b6d
FlixeRIO15.0.txt
(609 Bytes, 下载次数: 0, 售价: 10 圆)
FlexRIO™ Support 15.0 ReadmeJune 2015 This file contains important information about FlexRIO 15.0, including installation instructions, new features, and legal information. New Features Supported Hardware System Requirements Supported Software Application Development Environments (ADEs) Product Security and Critical Updates Driver Version Naming Changes Installing FlexRIO 15.0 Uninstalling/Modifying FlexRIO 15.0 Finding Examples Automating the Installation of NI Products How to Use NI Software with Microsoft Windows 8.1/8.0 FlexRIO Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016 Documentation Legal Information For information about FlexRIO Adapter Module Support and FlexRIO adapter modules, refer to the FlexRIO Adapter Module Support Readme. New FeaturesFlexRIO Support 15.0 includes the following new features. FlexRIO Support 14.5 includes minor bug fixes. FlexRIO Support 14.1 includes minor bug fixes. FlexRIO Support 14.0 includes the following new features. - Support for the following FlexRIO FPGA modules:
- NI PXIe-7971R
- NI PXIe-7972R
- NI PXIe-7976R
- Vivado compilation support for NI PXIe-797xR FPGA modules
- NI MAX support for FlexRIO adapter modules
Supported HardwareFlexRIO 15.0 software supports the following FlexRIO modules: - NI PXI-7951R
- NI PXI-7952R
- NI PXI-7953R
- NI PXI-7954R
- NI PXIe-7961R
- NI PXIe-7962R
- NI PXIe-7965R
- NI PXIe-7966R
- NI PXIe-7971R
- NI PXIe-7972R
- NI PXIe-7975R
- NI PXIe-7976R
Device-specific information about these modules in included in the FlexRIO Help. System RequirementsSupported Operating SystemsFlexRIO 15.0 supports the following operating systems:
| Operating System | 64-bit | 32-bit | | Windows 8.1 | ✓ | ✓ | | Windows 8.0 | ✓ | ✓ | | Windows 7 Professional | ✓ | ✓ | | Windows Vista Business | ✓ | ✓ | | Windows XP Professional SP2 or higher | — | ✓ | | Windows Server 2008 R2 | ✓ | — | | Windows Server 2003 R21 | — | ✓ | | Red Hat Enterprise Linux 7.x | ✓ | — | | Red Hat Enterprise Linux 6.x | ✓ | ✓ | | Scientific Linux 6.x | ✓ | ✓ | | CentOS 7 | ✓ | — |
1 Support for Windows Server 2003 R2 may require disabling physical address extensions. Note: FlexRIO 15.0 does not support Windows Server non-R2 editions. NI recommends that you have the most recent service pack for your operating system installed. Supported Real-Time Operating EnvironmentsFlexRIO 15.0 supports the following real-time operating environments: Minimum System Requirements- Processor—Pentium III/Celeron 600 MHz or equivalent
- RAM—
- Windows XP: 128 MB
- Windows 8.1/8.0/7/Vista: 512 MB
- Microsoft Internet Explorer 5.5 or later
- A screen resolution of 800 x 600 with 256 colors
- Windows 8.1/8.0/7/Vista/XP, with all available critical updates and service packs
Recommended System- Processor—Pentium 4 or equivalent
- RAM—
- Windows XP: 256 MB
- Windows 8.1/8.0/7/Vista: 1 GB
Supported SoftwareLabVIEW 2015 (32-bit and 64-bit)LabVIEW 2014 SP1 (32-bit and 64-bit)LabVIEW 2013 SP1 (32-bit and 64-bit)LabVIEW 2012 SP1 (32-bit and 64-bit)Application Development Environments (ADEs)Note: You should install ADEs before installing FlexRIO Support 15.0. To add support for ADEs installed after installing FlexRIO Support 15.0, modify your FlexRIO 15.0 installation or launch the FlexRIO 15.0 installer again. - LabVIEW 2012 SP1 (32-bit and 64-bit), 2013 SP1 (32-bit and 64-bit), 2014 SP1 (32-bit and 64-bit), and 2015 (32-bit and 64-bit)
- LabVIEW Real-Time Module 2012 SP1, 2013 SP1, 2014 SP1, and 2015
- LabVIEW FPGA Module 2012 SP1, 2013 SP1, 2014 SP1, and 2015
Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments. Driver Version Naming ChangesFlexRIO Support versions are aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions start with a two-digit year indicator: <;ProductName>. For example, FlexRIO 15.0 is the version released with LabVIEW 2015. Installing FlexRIO 15.0Complete the following steps to install FlexRIO 15.0 for use with LabVIEW: Note: Visit ni.com/info and enter rdsoftwareversion as the Info Code for more information about which minimum software versions you need for your device. Uninstalling/Modifying FlexRIO 15.0For Windows XP, complete the following steps: - Launch the Control Panel by selecting Start»Control Panel.
- Double-click Add or Remove Programs.
- Select National Instruments Software.
- Click Change/Remove.
- Select FlexRIO 15.0 from the dialog box that appears.
- Click Remove to uninstall the product; click Modify to change the components that are installed.
For Windows 7/Vista, complete the following steps: - Launch the Control Panel by selecting Start»Control Panel.
- Double-click Programs and Features.
- Click the Uninstall/Change button.
For Windows 8.1/8.0, complete the following steps: - Right-click on the Start screen.
- Select All apps and launch the Control Panel.
- Select Programs» Programs and Features.
- Click the Uninstall button.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
Finding ExamplesTo access FlexRIO examples using the NI Example Finder, open LabVIEW and select Help»Find Examples, then select Hardware Input and Output»FlexRIO. How to Use NI Software with Microsoft Windows 8.1/8.0When you install National Instruments software on Microsoft Windows 8.1/8.0, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. Using NI LauncherNI Launcher helps you find and launch installed NI products. It provides you with a method of finding NI products similar to the Start menu in previous versions of Microsoft Windows. To use NI Launcher, click the NI Launcher tile in the Apps view. NI Launcher launches the desktop and opens a menu containing a list of NI products. Click any NI product to launch it. | Note NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.1/8.0. You can launch NI MAX either from the Apps view or from within NI Launcher. | Pinning Frequently Used ApplicationsFor convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary: | Current Application | Icon Location | Pin to Action | | Windows 8.1/8.0 Desktop | Desktop Taskbar | Right-click application and select Pin to Taskbar | | Windows 8.1/8.0 Desktop | Start screen | Right-click application and select Pin to Start | | Windows 8.1/8.0 Start screen | Desktop Taskbar | Right-click application and select Pin to taskbar from the menu bar on the bottom of the screen | Finding All ProgramsIf you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.0) or click the down arrow on the bottom left of the screen (Windows 8.1). For more information about NI support for Windows 8.1/8.0, visit ni.com/windows8. FlexRIO Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016National Instruments FlexRIO will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of FlexRIO that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes: | Product | Info Code | | NI LabVIEW | lifecycle | | NI LabWindows™/CVI™ | cvi_lifecycle | | NI Measurement Studio | mstudiolifecycle | | NI TestStand | tslcp | | NI DIAdem | ddlcp | | NI SignalExpress | selcp | | NI VeriStand | nivslifecycle | DocumentationThe product documentation is available at Start»All Programs»National Instruments»NI FlexRIO. Visit ni.com/manuals for the latest versions of product documentation. To view these documents, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.The documentation set is composed of the following documents: | Document | Description | | FlexRIO Help | Contains information about FlexRIO device support. This book also provides instructions for using LabVIEW and the LabVIEW FPGA Module with FlexRIO devices. | | FlexRIO Adapter Module Development Kit User Manual | Contains information about how to develop custom adapter modules for use with your FlexRIO FPGA module. | | Getting started guide for your FlexRIO FPGA module | Contains installation instructions and configuration information for your FlexRIO FPGA module. | | Specifications document for your FlexRIO FPGA module | Contains specifications for your FlexRIO FPGA module. | | Getting started guide for your FlexRIO adapter module | Contains installation instructions and configuration information for your FlexRIO adapter module. | | Specifications document for your FlexRIO adapter module | Contains specifications for your FlexRIO adapter module. | | FlexRIO Support 15.0 Readme (this document) | Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices. |
Refer to ni.com/flexrio for additional FlexRIO product support and information.
Legal InformationCopyright ©2008–2015 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents. 374872C-01 |
