查看: 3861|回复: 0
[NI驱动程序] NI IVI Compliance Package 14.0 Win32/64Eng NI IVI合规软件包ICP14.0下载
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-12-21 23:49:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    IVI合规软件包
    IVI Compliance Package包含IVI类驱动程序和支持库,用于开发和利用基于IVI互换性的应用程序。
    IVI Compliance Package包含了IVI类驱动程序、仿真驱动程序和基于IVI的NI编程环境的应用案例。IVI Compliance Package基于IVI Foundation制定的最新仪器编程规范,并遵守该规范。IVI Compliance Package中的IVI类驱动程序可与专门IVI专用的驱动程序配合使用。
    Win32/64Eng
    14.0
    文件大小: 194513830 字节 (185.50 MB)
    修改日期: 2019-06-25 02:45
    MD5: 066d9bb8757b71f39c336a470add2913
    SHA1: feab5d29534480be37f743542716b68a60590525
    SHA256: 9cc7f19b6d6ad57d97a9f702327f68dc5c665f33a8e6e265b72ff5c2f5f9e13b
    CRC32: 661fa50e
    ICP14.0.txt (599 Bytes, 下载次数: 0, 售价: 10 圆)
    NI IVI Compliance Package 14.0 Readme
    2014
    Version 14.0
    August 2014
    This file contains important information about the IVI Compliance Package, including installation instructions, new features, a partial list of bugs fixed for the IVI Compliance Package 14.0, and known issues.
    Uninstall Considerations
    New Features and Bug Fixes
    Driver Version Naming Changes
    Known Incompatibilities
    IVI Compliance Package (ICP) 14.0 is an update release of IVI Compliance Package 4.6.1. IVI Compliance Package 14.0 installs the following components:
    • IVI class drivers
    • IVI class simulation drivers
    • IVI class driver LabWindows/CVI support
    • IVI class driver wrappers for LabVIEW 2011, 2012, 2013 and 2014
    • IVI class driver examples for LabWindows/CVI, LabVIEW, and Measurement Studio
    • IVI-COM adapters (32-bit only)
    • IVI Shared Components, version 2.2.1
    • IVI configuration plug-in for Measurement & Automation Explorer (MAX) 4.7.0 and later
    • Online help
    IVI Compliance Package has the following requirements:
    • Windows 8.1 (32-bit or 64-bit)
    • Windows 8 (32-bit or 64-bit)
    • Windows 7 (32-bit or 64-bit), including Starter Edition (32-bit)
    • Windows Vista (32-bit or 64-bit)
    • Windows XP Service Pack 3 or later
    Note  IVI Compliance Package supports only R2 editions for Windows Server.
    The following table lists the NI application software versions, including service packs, supported by IVI Compliance Package. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    NI Application SoftwareVersions Supported by IVI Compliance Package
    NI LabVIEWLabVIEW version 2011 or later
    NI LabWindows™/CVI™LabWindows/CVI version 7.1 or later
    IVI Compliance Package is included in the National Instruments Device Drivers media. A stand-alone version is available on ni.com.
    Before installing IVI Compliance Package 14.0, consider the following issues:
    • For compatibility reasons, the IVI Compliance Package 14.0 installation process enables write permissions for the IVI Standard Root directories (defaults: Program Files\IVI Foundation\IVI and Program Files(x86)\IVI Foundation\IVI) on Windows Vista, Windows 7 and Windows 8 systems.
    • National Instruments recommends that you close all other applications before you install IVI Compliance Package 14.0.
    To install the stand-alone, Web-only IVI Compliance Package 14.0 version, complete the following steps:
    • Download the IVI Compliance Package 14.0 self-extracting archive from http://www.ni.com/downloads by navigating through the Drivers and Updates link.
    • Double-click the self-extracting archive to launch the installer.
    • Click OK to begin installation.
    • Follow the directions that appear on the screen.
    Notes:
    • The IVI Compliance Package 14.0 stand-alone, web-only distribution does not install NI I/O Trace (formerly known as NI-Spy) or MAX. You can install NI I/O Trace and MAX using several other National Instruments products, including the NI Device Drivers media.
    • You must have MAX 4.7.0 or later installed to use the IVI Configuration utility in MAX.
    • The installation directory for LabWindows/CVI IVI Class examples and IVI Class Simulation drivers has been changed. The new installation directory is \Documents\National Instruments\CVI\Samples\IVI directory.
    • IVI Compliance Package 3.2 and later includes IVI-COM adapters which enable users to use IVI-C and IVI-COM specific drivers interchangeably in the same 32-bit application. For more information on IVI-COM adapters, refer to the IVI-C Class Driver Support for IVI-COM Specific Drivers document.
    • IVI Compliance Package 4.5 and later installs alternate FP and SUB files for the IviFgen class driver in order to support setting 64-bit integer attributes. For more information, refer to KnowledgeBase 5WOA752F: Issue Setting IviFgen Attribute ID Using Get/Set/CheckAttributeViInt64 Functions.
    • If you use IVI Compliance Package 4.5 or later to build a driver, it will work on a system that has IVI Compliance Package 2.5 or later. In addition, all specific drivers on IDNet have been rebuilt with IVI Compliance Package 4.5.
    Complete the following steps to uninstall IVI Compliance Package 14.0:
    • From the Control Panel, select Uninstall a Program.
    • Select NI IVI Compliance Package 14.0 and click Remove.
    Note: After you uninstall IVI Compliance Package 14.0, the IVI Shared Components remain on the system. To remove the remaining components, right-click IVI Shared Components 2.2.1 and select Uninstall/Change.
    Note: If you installed IVI Compliance Package 14.0 as part of another distribution that depends on IVI Compliance Package 14.0, you cannot uninstall IVI Compliance Package 14.0 without uninstalling the dependent product.
    This release includes the following new features and bug fixes:
    • Update IVI Class Driver LabVIEW Examples (CAR 420898)
    • Update IVI Class Driver FP interface format (CAR 378997)
    • IVI Measurement and Automation Explorer (MAX) Provider improvements (CAR 394960)
    • IVI Logical Name control performance improvement (CAR 408857)
    Refer to the IVI Compliance Package Release Notes, Version 14.0, for general information about this product.
    IVI Compliance Package versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: . For example, IVI Compliance Package 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is IVI Compliance Package 4.6.1. The first version released under the new numbering scheme is IVI Compliance Package 14.0.
    • When installing a user-built distribution configured for distribution media smaller than 200MB that includes a Modular Instruments Run-Time distribution, an installation error might occur. Please refer to KnowledgeBase 5CT96RW1: NI IVI Engine Installation Failure When Included in User-built Distribution for more information.
    • If IVI Shared Components 2.2.1 or later is already installed when the ICP 14.0 installer is run, the IVI Shared Components feature(s) in the feature tree will not be displayed.
    • Because it has a ViInt64 attribute, the IviDigitizer Class Driver function panel file is in the CVI 8.5 format, which is incompatible with LabWindows/CVI versions prior to 8.5. Due to a known issue in LabWindows/CVI 8.5, the Get/Set/Check Attribute function panels do not display the enumerated values in the "Attribute Value" field when the FP format is 8.5. To enter a value manually, you may press "Ctrl+T". Because of this known issue, CVI 9.0.1 or later is recommended for use with the IviDigitizer FP file.
    • In the IviFgen FP file, the Attribute ID and Attribute Value controls in the Get/Set/CheckAttributeViInt64 function display an empty field instead of a list of attributes and values. For more information, refer to KnowledgeBase 5WOA752F: Issue Setting IviFgen Attribute ID Using Get/Set/CheckAttributeViInt64 Functions.
    • In the IVI Configuration Utility in MAX, the DAQmx devices (both simulated devices and real devices) will appear in the Resource Descriptor list in the Hardware Assets table only if you have DAQmx 9.2 or later installed.
    • National Instruments IVI libraries, tools, and utilities support only single-byte character strings. You cannot use multi-byte characters, such as those commonly used in Chinese, Japanese, and Korean operating systems. Only single-byte characters, such as ASCII characters, may be passed to IVI function calls, used to set directory paths, and used to create entries in the MAX IVI Configuration Utility.
    • NI-Spy is now known as NI I/O Trace. Images in the National Instruments IVI Driver Help continue to reflect the NI-Spy name. However, the general functionality depicted in the images remains the same.
    • As of IVI Compliance Package 3.1, the IVI Compliance Package distribution no longer includes LabWindows/CVI 6.0 support. Please refer to the Using LabWindows/CVI 6.0 With ICP 3.1 document for details.
    • The IVI Specific Driver Test Suite in LabWindows/CVI 2009 requires ICP 4.1 or later.
    • The IVI Specific Driver Test Suite in LabWindows/CVI 2010 SP1 or later requires ICP 4.5 or later.
    Using NI Launcher
    Finding All Programs
    NI IVI Compliance Package Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments IVI Compliance Package will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of IVI Compliance Package that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 1999–2014 National Instruments. All rights reserved.
    GMT+8, 2025-11-19 12:46
