查看: 2658|回复: 0
[NI驱动程序] NI IVI Compliance Package 4.3 Win32/64Eng NI IVI合规软件包ICP4.3下载
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-12-21 23:39:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    IVI合规软件包
    IVI Compliance Package包含IVI类驱动程序和支持库,用于开发和利用基于IVI互换性的应用程序。
    IVI Compliance Package包含了IVI类驱动程序、仿真驱动程序和基于IVI的NI编程环境的应用案例。IVI Compliance Package基于IVI Foundation制定的最新仪器编程规范,并遵守该规范。IVI Compliance Package中的IVI类驱动程序可与专门IVI专用的驱动程序配合使用。
    Win32/64Eng
    4.3
    文件大小: 135487483 字节 (129.21 MB)
    修改日期: 2019-06-25 02:45
    MD5: ea901757ca74bd9dbfc459cefd6692e3
    SHA1: 6f69296baf04dc925c336c46513c78b1c92d5889
    SHA256: 7d694b5f06b6a6254fbc3b4c60ab3bbaed315241733676de55d2c34054b6c352
    CRC32: 9d05d85e
    ICP4.3.txt (585 Bytes, 下载次数: 0, 售价: 10 圆)
    NI IVI Compliance Package 4.3.0Documentation File
    © Copyright 1999–2010. National Instruments Corporation. All rights reserved.
    CVI™, IVI™, LabVIEW™, Measurement Studio™, National Instruments™, NI™, ni.com™, NI-DMM™, NI-FGEN™, and TestStand™ are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. The mark LabWindows is used under a license from Microsoft Corporation. Windows is a registered trademark of Microsoft Corporation in the United States and other countries. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    Introduction
    IVI Compliance Package (ICP) 4.3 is an update release of IVI Compliance Package 4.2. This release includes the following new features and bug fixes:
    • Includes IVI Shared Components 2.1.1 (CAR 233774)
    • Removal of IVI class driver C++ wrappers for Measurement Studio 6.0 and 2003 (CAR 183015)
    • IVI Measurement and Automation Explorer (MAX) Provider Improvements (CARs 88374,246812,247226)
    • IVI Config Store Improvement (CAR 207884)
    • Other installer updates (CARs 90494,233784,233789)
    Refer to the IVI Compliance Package Release Notes, Version 4.3, for general information about this product.
    This installation requires one of the following Microsoft operating systems:
    • Windows XP
    • Windows Vista (32-bit)
    • Windows Vista (64-bit)
    • Windows 7 (32-bit)
    • Windows 7 (64-bit)
    Availability/Installation
    IVI Compliance Package is included in the National Instruments Device Drivers CD Set. A stand-alone version is available on ni.com.
    Before installing IVI Compliance Package 4.3, consider the following issues:
    • If you plan to use IVI Compliance Package 4.3 with LabVIEW, and/or LabWindows/CVI, make sure that you have already installed LabVIEW version 8.5 or later, and/or LabWindows/CVI version 7.0 or later.
    • For compatibility reasons, the IVI Compliance Package 4.3 installation process enables write permissions for the IVI Standard Root directories (defaults: Program Files\IVI Foundation\IVI and Program Files(x86)\IVI Foundation\IVI) on Windows Vista and Windows 7 systems.
    • National Instruments recommends that you close all other applications before you install IVI Compliance Package 4.3.
    To install the stand-alone, Web-only IVI Compliance Package 4.3 version, complete the following steps:
    • Download the IVI Compliance Package 4.3 self-extracting archive from http://www.ni.com/downloads by navigating through the Drivers and Updates link.
    • Double-click the self-extracting archive to launch the installer.
    • Click OK to begin installation.
    • Follow the directions that appear on the screen.
    Known Incompatibilities
    • IVI Compliance Package 4.3 no longer includes IVI class driver C++ wrappers for Measurement Studio 6.0 and 2003. If you use these C++ wrappers, do not upgrade to IVI Compliance Package 4.3.
    • NI-Spy version 2.2 and earlier is not compatible with IVI Compliance Package 4.3. If you use NI-Spy version 2.2 or earlier, do not upgrade to IVI Compliance Package 4.3.
    • As of IVI Compliance Package 3.1, the IVI Compliance Package distribution no longer includes LabWindows/CVI 6.0 support. Please refer to the Using LabWindows/CVI 6.0 With ICP 3.1 document for details.
    • The IVI Specific Driver Test Suite in LabWindows/CVI 2009 or later requires ICP 4.1 or later.
    Installed Components
    IVI Compliance Package 4.3 installs the following components:
    • IVI class drivers
    • IVI class simulation drivers
    • IVI class driver LabWindows/CVI support
    • IVI class driver wrappers for LabVIEW 8.5, 8.6, 2009, and 2010
    • IVI class driver examples for LabWindows/CVI, LabVIEW, and Measurement Studio
    • IVI-COM adapters (32-bit only)
    • IVI Shared Components, version 2.1.1
    • IVI configuration plug-in for Measurement & Automation Explorer (MAX) 4.2.1 and later
    • Online help
    Note: The IVI Compliance Package 4.3 stand-alone, web-only distribution does not install NI-Spy or MAX. You can install NI-Spy and MAX using several other National Instruments products, including the NI Device Drivers CD Set.
    Note: You must have MAX 4.2.1 or later installed to use the IVI Configuration utility in MAX.
    Note: Installation directory for LabWindows/CVI IVI Class examples and IVI Class Simulation drivers has been changed. The new installation directory is \Documents\National Instruments\CVI\Samples\IVI directory.
    Note: IVI Compliance Package 4.3 includes IVI-COM adapters which enable users to use IVI-C and IVI-COM specific drivers interchangeably in the same 32-bit application. For more information on IVI-COM adapters, refer to the IVI-C Class Driver Support for IVI-COM Specific Drivers document.
    Uninstall Considerations
    Complete the following steps to uninstall IVI Compliance Package 4.3:
    • Select Start»Settings»Control Panel»Add or Remove Programs.
    • Select National Instruments Software and click Change/Remove.
    • Select NI IVI Compliance Package 4.3 and click Remove.
    Note: After you uninstall IVI Compliance Package 4.3, the IVI Shared Components remain on the system. Complete the following steps to uninstall the IVI Shared Components:
    • Select IVI Shared Components and click Change/Remove.
    Note: If you installed IVI Compliance Package 4.3 as part of another distribution that depends on IVI Compliance Package 4.3, you cannot uninstall IVI Compliance Package 4.3 without uninstalling the dependent product.
    • When installing a user-built distribution configured for distribution media smaller than 200MB that includes a Modular Instruments Run-Time distribution, an installation error might occur. Please refer to KnowledgeBase 5CT96RW1: NI IVI Engine Installation Failure When Included in User-built Distribution for more information.
    • If IVI Shared Components 2.1.1 or later is already installed when the ICP 4.3 installer is run, the IVI Shared Components feature(s) in the feature tree will not be displayed.
    • Because it has a ViInt64 attribute, the IviDigitizer Class Driver function panel file is in the CVI 8.5 format, which is incompatible with LabWindows/CVI versions prior to 8.5. Due to a known issue in LabWindows/CVI 8.5, the Get/Set/Check Attribute function panels do not display the enumerated values in the "Attribute Value" field when the FP format is 8.5. To enter a value manually, you may press "Ctrl+T". Because of this known issue, CVI 9.0.1 or later is recommended for use with the IviDigitizer FP file.
    • LabVIEW users: A VI that makes calls to an IVI class driver and an IVI specific driver in parallel by branching off of the same instrument handle will result in an IVI_ERROR_NOT_INITIALIZED error being returned from the call to the class driver. This is only an issue in LabVIEW versions prior to 8.6.
    • National Instruments IVI libraries, tools, and utilities support only single-byte character strings. You cannot use multi-byte characters, such as those commonly used in Chinese, Japanese, and Korean operating systems. Only single-byte characters, such as ASCII characters, may be passed to IVI function calls, used to set directory paths, and used to create entries in the MAX IVI Configuration Utility.
    GMT+8, 2025-11-19 12:45
