查看: 3309|回复: 0
[NI驱动程序] NI IVI Compliance Package 4.1 Win32/64Eng NI IVI合规软件包ICP4.1下载
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-12-21 23:36:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    IVI合规软件包
    IVI Compliance Package包含IVI类驱动程序和支持库,用于开发和利用基于IVI互换性的应用程序。
    IVI Compliance Package包含了IVI类驱动程序、仿真驱动程序和基于IVI的NI编程环境的应用案例。IVI Compliance Package基于IVI Foundation制定的最新仪器编程规范,并遵守该规范。IVI Compliance Package中的IVI类驱动程序可与专门IVI专用的驱动程序配合使用。
    Win32/64Eng
    4.1
    文件大小: 132255159 字节 (126.13 MB)
    修改日期: 2019-06-25 02:45
    MD5: 489c2c119907f7bd6a625cbc559f0f02
    SHA1: e1978a193f84105daff33dd535413292161ccafb
    SHA256: 90ca2f6b7858d13ce3cd7b7e132f86d7efc38f9ba43c9264552c04e30e762a74
    CRC32: 78f96c30
    ICP4.1.txt (580 Bytes, 下载次数: 0, 售价: 10 圆)
    NI IVI Compliance Package 4.1.0Documentation File
    © Copyright 1999–2009. National Instruments Corporation. All rights reserved.
    LabWindows/CVI™, IVI™, LabVIEW™, Measurement Studio™, National Instruments™, NI™, ni.com™, NI-DMM™, NI-FGEN™, and TestStand™ are trademarks of National Instruments Corporation. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    Introduction
    IVI Compliance Package (ICP) 4.1 is an update release of IVI Compliance Package 4.0. This release includes the following new features and bug fixes:
    • Adds support for the IviCounter, IviDigitizer, IviDownconverter, and IviUpconverter classes
    • Adds IVI-COM adapter support for the IviCounter, IviDigitizer, IviDownconverter, and IviUpconverter classes
    • Adds new class simulation drivers and ports them to 64-bit(CAR 161304)
    Refer to the IVI Compliance Package Release Notes, Version 4.0, for general information about this product.
    This installation requires one of the following Microsoft operating systems:
    • Windows 2000 Service Pack 4
    • Windows XP
    • Windows Vista x86
    • Windows Vista x64
    • Windows 7 x86
    • Windows 7 x64
    Availability/Installation
    IVI Compliance Package is included in the National Instruments Device Drivers CD Set. A stand-alone version is available on ni.com.
    Before installing IVI Compliance Package 4.1, consider the following issues:
    • If you plan to use IVI Compliance Package 4.1 with LabVIEW, LabWindows/CVI, and/or Measurement Studio, make sure that you have already installed LabVIEW version 8.2 or later, LabWindows/CVI version 7.0 or later, and/or Measurement Studio version 6.0 or later.
    • For compatibility reasons, the IVI Compliance Package 4.1 installation process enables write permissions for the IVI Standard Root directories (defaults: Program Files\IVI Foundation\IVI and Program Files(x86)\IVI Foundation\IVI) on Windows Vista and Windows 7 systems.
    • National Instruments recommends that you close all other applications before you install IVI Compliance Package 4.1.
    To install the stand-alone, Web-only IVI Compliance Package 4.1 version, complete the following steps:
    • Download the IVI Compliance Package 4.1 self-extracting archive from http://www.ni.com/downloads by navigating through the Drivers and Updates link.
    • Double-click the self-extracting archive to launch the installer.
    • Click OK to begin installation.
    • Follow the directions that appear on the screen.
    Known Incompatibilities
    • There are no known incompatibilities with upgrading from previous IVI Compliance Package versions to IVI Compliance Package 4.1.
    • NI-Spy version 2.2 and earlier is not compatible with IVI Compliance Package 4.1. If you use NI-Spy version 2.2 or earlier, do not upgrade to IVI Compliance Package 4.1.
    • As of IVI Compliance Package 3.1, the IVI Compliance Package distribution no longer includes LabWindows/CVI 6.0 support. Please refer to the Using LabWindows/CVI 6.0 With ICP 3.1 document for details.
    • The IVI Specific Driver Test Suite in LabWindows/CVI 2009 requires ICP 4.1 or later.
    Installed Components
    IVI Compliance Package 4.1 installs the following components:
    • IVI class drivers
    • IVI class simulation drivers
    • IVI class driver LabWindows/CVI support
    • IVI class driver wrappers for LabVIEW 8.2, 8.5, 8.6, and 2009
    • IVI class driver examples for LabWindows/CVI, LabVIEW, and Measurement Studio
    • IVI-COM adapters (32-bit only)
    • IVI Shared Components, version 2.0.0
    • IVI configuration plug-in for Measurement & Automation Explorer (MAX) 4.2.1 and later
    • Online help
    • IVI class driver C++ wrappers for Measurement Studio (Windows 2000 and XP only)
    Note: The IVI Compliance Package 4.1 stand-alone, web-only distribution does not install NI-Spy or MAX. You can install NI-Spy and MAX using several other National Instruments products, including the NI Device Drivers CD Set.
    Note: You must have MAX 4.2.1 or later installed to use the IVI Configuration utility in MAX.
    Note: Installation directory for LabWindows/CVI IVI Class examples and IVI Class Simulation drivers has been changed. The new installation directory is \Documents\National Instruments\CVI\Samples\IVI directory.
    Note: IVI Compliance Package 4.1 includes IVI-COM adapters which enable users to use IVI-C and IVI-COM specific drivers interchangeably in the same 32-bit application. For more information on IVI-COM adapters, refer to the IVI-C Class Driver Support for IVI-COM Specific Drivers document.
    Uninstall Considerations
    Complete the following steps to uninstall IVI Compliance Package 4.1:
    • Select Start»Settings»Control Panel»Add or Remove Programs.
    • Select National Instruments Software and click Change/Remove.
    • Select NI IVI Compliance Package 4.1 and click Remove.
    Note: After you uninstall IVI Compliance Package 4.1, the IVI Shared Components remain on the system. Complete the following steps to uninstall the IVI Shared Components:
    • Select IVI Shared Components and click Change/Remove.
    Note: If you installed IVI Compliance Package 4.1 as part of another distribution that depends on IVI Compliance Package 4.1, you cannot uninstall IVI Compliance Package 4.1 without uninstalling the dependent product.
    • If IVI Shared Components 2.0.0 is already installed when the ICP 4.1 installer is run, the IVI Shared Components feature(s) in the feature tree will not be displayed.
    • Because it has a ViInt64 attribute, the IviDigitizer Class Driver function panel file is in the CVI 8.5 format, which is incompatible with LabWindows/CVI versions prior to 8.5. Due to a known issue in LabWindows/CVI 8.5, the Get/Set/Check Attribute function panels do not display the enumerated values in the "Attribute Value" field when the FP format is 8.5. To enter a value manually, you may press "Ctrl+T". Because of this known issue, CVI 9.0.1 or later is recommended for use with the IviDigitizer FP file.
    • LabVIEW users: A VI that makes calls to an IVI class driver and an IVI specific driver in parallel by branching off of the same instrument handle will result in an IVI_ERROR_NOT_INITIALIZED error being returned from the call to the class driver.
    • National Instruments IVI libraries, tools, and utilities support only single-byte character strings. You cannot use multi-byte characters, such as those commonly used in Chinese, Japanese, and Korean operating systems. Only single-byte characters, such as ASCII characters, may be passed to IVI function calls, used to set directory paths, and used to create entries in the MAX IVI Configuration Utility.
    • IVI help in MAX requires Internet Explorer 5.0 or higher. Without Internet Explorer 5.0 or higher, IVI category help and the dynamic item help does not appear in MAX.
    GMT+8, 2025-11-19 12:45
