查看: 3157|回复: 0
[NI驱动程序] NI IVI Compliance Package 3.3 Win32Eng NI IVI合规软件包ICP3.3下载
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-12-21 23:32:01 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    IVI合规软件包
    IVI Compliance Package包含IVI类驱动程序和支持库,用于开发和利用基于IVI互换性的应用程序。
    IVI Compliance Package包含了IVI类驱动程序、仿真驱动程序和基于IVI的NI编程环境的应用案例。IVI Compliance Package基于IVI Foundation制定的最新仪器编程规范,并遵守该规范。IVI Compliance Package中的IVI类驱动程序可与专门IVI专用的驱动程序配合使用。
    Win32Eng
    3.3
    文件大小: 65929259 字节 (62.88 MB)
    修改日期: 2019-06-25 02:45
    MD5: c7f71881ceb1836e8935e9cd200a5064
    SHA1: 965a3fdb371ee6b1d279262dbbb89ff4a9920df5
    SHA256: af6d83779665c3d77bfc80573c620a5101ff7a60303bed45af33be74f6d503cb
    CRC32: a96b6ff8
    ICP3.3.txt (571 Bytes, 下载次数: 0, 售价: 10 圆)
    NI IVI Compliance Package 3.3.0Documentation File
    © Copyright 1999–2008. National Instruments Corporation. All rights reserved.
    CVI™, IVI™, LabVIEW™, Measurement Studio™, National Instruments™, NI™, ni.com™, NI-DMM™, NI-FGEN™, and TestStand™ are trademarks of National Instruments Corporation. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    Introduction
    IVI Compliance Package (ICP) 3.3 is an update release of IVI Compliance Package 3.2. This release includes the following new features and bug fixes:
    • Inclusion of the latest version of IVI Shared Components 1.5.1 (CAR 53790)
    • The error handling code updates in all LabVIEW class driver VIs (CAR 53836)
    • The IviConfig.dll updates to support new LabVIEW API requirements for the logical name control (CAR 48443)
    • Installer updates to remove LabVIEW 8.0 support and to add LabVIEW 8.6 support (CAR 53822)
    • Other installer updates (CARs 53820, 52970)
    ICP 3.3.0f2 improves the logic that determines when to use the IVI-COM Adapters. If the Software Module for an IVI-COM driver has non-empty values for both Module Path and Prog ID, the Published API list for the Software Module is used to determine whether or not to use the IVI-COM Adapters.
    Note: IVI Compliance Package 3.3 includes IVI-COM adapters which enable users to use IVI-C and IVI-COM specific drivers interchangeably in the same application. For more information on IVI-COM adapters, refer to the IVI-C Class Driver Support for IVI-COM Specific Drivers document.
    Note: IVI Compliance Package 3.3 supports only 32-bit applications on 64-bit Windows Vista. For more information on using National Instruments products with Windows Vista, visit ni.com/vista.
    Note: Installation directory for LabWindows/CVI IVI Class examples and IVI Class Simulation drivers has been changed. The new installation directory is \Documents\National Instruments\CVI\Samples\IVI directory.
    Refer to the IVI Compliance Package Release Notes, Version 3.0, for general information about this product.
    This installation requires one of the following Microsoft operating systems:
    • Windows 2000 Service Pack 4
    • Windows XP
    • Windows Vista x86
    • Windows Vista x64
    Availability/Installation
    IVI Compliance Package is included in the National Instruments Device Drivers CD Set. A stand-alone version is available on ni.com.
    Before installing IVI Compliance Package 3.3, consider the following issues:
    • If you plan to use IVI Compliance Package 3.3 with LabVIEW, LabWindows™/CVI™, and/or Measurement Studio, make sure that you have already installed LabVIEW version 7.1 or later, LabWindows/CVI version 7.0 or later, and/or Measurement Studio version 6.0 or later.
    • For compatibility reasons, the IVI Compliance Package 3.3 installation process enables write permissions for the IVI Standard Root directory (default: Program Files (x86)\IVI Foundation\IVI) on Windows Vista systems.
    • National Instruments recommends that you close all other applications before you install IVI Compliance Package 3.3.
    To install the stand-alone, Web-only IVI Compliance Package 3.3 version, complete the following steps:
    • Download the IVI Compliance Package 3.3 self-extracting archive from http://www.ni.com/downloads by navigating through the Drivers and Updates link.
    • Double-click the self-extracting archive to launch the installer.
    • Click OK to begin installation.
    • Follow the directions that appear on the screen.
    Known Incompatibilities
    • There are no known incompatibilities with upgrading from previous IVI Compliance Package versions to IVI Compliance Package 3.3.
    • NI-Spy version 2.2 and earlier is not compatible with IVI Compliance Package 3.3. If you use NI-Spy version 2.2 or earlier, do not upgrade to IVI Compliance Package 3.3.
    • NI TestStand version 2.0.1 is not compatible with IVI Compliance Package 3.3. If you use NI TestStand version 2.0.1 and want to install IVI Compliance Package for the first time, do not upgrade to IVI Compliance Package 3.3, because it does not include support for NI TestStand version 2.0.1. Versions of IVI Compliance Package prior to version 3.1 can be installed instead. Please refer to the Installing the IVI Compliance Package 3.0 or later With TestStand 2.0.1 document for details.
    • As of IVI Compliance Package 3.1, the IVI Compliance Package distribution no longer includes LabWindows/CVI 6.0 support. Please refer to the Using LabWindows/CVI 6.0 With ICP 3.1 document for details.
    Installed Components
    IVI Compliance Package 3.3 installs the following components:
    • IVI class drivers
    • IVI class driver LabWindows/CVI support
    • IVI class driver C++ wrappers for Measurement Studio (Windows 2000 and XP only)
    • IVI class driver wrappers for LabVIEW 7.1, 8.2, 8.5, and 8.6
    • IVI class simulation drivers
    • IVI class driver examples for LabWindows/CVI, LabVIEW, and Measurement Studio
    • IVI-COM adapters
    • IVI Shared Components, version 1.5.1
    • IVI configuration plug-in for Measurement & Automation Explorer (MAX) 4.2.1 and later
    • Online help
    Note: The IVI Compliance Package 3.3 stand-alone, web-only distribution does not install NI-Spy or MAX. You can install NI-Spy and MAX using several other National Instruments products, including the NI Device Drivers CD Set.
    Note: You must have MAX 4.2.1 or later installed to use the IVI Configuration utility in MAX.
    Note: As of IVI Compliance Package 2.5, the IVI Class Driver files are no longer installed in the VXIPNP directory. These files will continue to be installed in the IVI directory.
    Note: IVI class simulation drivers and IVI Soft Front Panels used to be distributed with the IVI Driver Toolset. Since the IVI Driver Toolset has been discontinued, the IVI class simulation drivers are now distributed with the IVI Compliance Package 2.5 and later. The IVI Soft Front Panels are available upon request to instrument.drivers@ni.com.
    Note: As of IVI Compliance Package 3.0, the LabWindows/CVI Instrument Driver Developers Guide (iddg.pdf) is no longer installed with ICP. This file gets installed with LabWindows/CVI. When you upgrade to ICP 3.3, the file will be removed from your system. To replace the file, run the LabWindows/CVI installation in the Repair mode.
    Uninstall Considerations
    Complete the following steps to uninstall IVI Compliance Package 3.3:
    • Select Start»Settings»Control Panel»Add or Remove Programs.
    • Select National Instruments Software and click Change/Remove.
    • Select NI IVI Compliance Package 3.3 and click Remove.
    Note: After you uninstall IVI Compliance Package 3.3, the IVI Shared Components remain on the system. Complete the following steps to uninstall the IVI Shared Components:
    • Select IVI Shared Components and click Change/Remove.
    Note: If you installed IVI Compliance Package 3.3 as part of another distribution that depends on IVI Compliance Package 3.3, you cannot uninstall IVI Compliance Package 3.3 without uninstalling the dependent product.
    • LabVIEW users: Downcasting from a class driver to a specific driver using property nodes may return an error in the following cases:
      • You use a combination of specific driver VIs and specific driver property nodes.
      • You use a specific driver property node with inherent properties.
      Use one of the following workarounds to avoid this error:
      • Do not use specific driver property nodes.
      • Use specific driver property nodes but without any inherent properties and not in the conjunction with specific driver VIs.
    • LabVIEW users: A VI that makes calls to an IVI class driver and an IVI specific driver in parallel by branching off of the same instrument handle will result in an IVI_ERROR_NOT_INITIALIZED error being returned from the call to the class driver.
    • National Instruments IVI libraries, tools, and utilities support only single-byte character strings. You cannot use multi-byte characters, such as those commonly used in Chinese, Japanese, and Korean operating systems. Only single-byte characters, such as ASCII characters, may be passed to IVI function calls, used to set directory paths, and used to create entries in the MAX IVI Configuration Utility.
    • IVI help in MAX requires Internet Explorer 5.0 or higher. Without Internet Explorer 5.0 or higher, IVI category help and the dynamic item help does not appear in MAX.
    GMT+8, 2025-11-19 12:46
