NI-VRTS 1.6.1 Driver Win64多国语言 NI-VRTS车辆雷达测试系统1.6.1版驱动下载
NI-VRTS
NI-VRTS为客户使用车辆雷达测试系统(VRTS)提供支持。
NI-VRTS是一款NI仪器驱动程序,可帮助您创建从独立障碍物模拟器到全功能硬件在环(HIL)仿真系统等不同规模的软件应用程序。此驱动程序提供一系列操作、属性和示例,可模拟最多四个障碍物。此外,NI-VRTS可以通过测试辐射方向图、等效同位素辐射功率(EIRP)、噪声、频谱占用率、波束宽度和线性调频分析来帮助您评估雷达设备。
Win64,中文, 德语, 日语, 法语, 英文, 韩语
1.6.1
文件大小: 842653579 字节 (803.62 MB)
修改日期: 2019-08-27 04:15
MD5: e700099d3fdfc549760d377756736941
SHA1: 625cf28659e3e8a62ec95d90e8548802cbadd669
SHA256: 011ae0ef3f436215c6e3e2beb9c505a1e6e799c140dbb9aba26b3af582d86a88
CRC32: 2ff97d62
NI-VRTS1.6.1.txt
(630 Bytes, 下载次数: 0, 售价: 10 圆)
NI-VRTS 1.6.1 ReadmeAugust 2019
This file contains important information about the NI-VRTS, including supported hardware, installation instructions, and new features.
New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates Known Issues Bug Fixes Finding Examples Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 Legal Information New Features
NI-VRTS 1.6.1 adds support for bug fixes.
NI-VRTS 1.6 includes the following new features:
- Support for the latest VRTS hardware configurations.
- Other minor improvements.
NI-VRTS 1.5 includes the following new features:
- Support for the mmRH-3609, a monostatic mmWave radio head.
- Center frequency configurable across the full range of the mmWave radio head (76-81 GHz).1
- Ability to enable or disable the alignment laser.
- Ability to call the Close VI without powering down the mmWave radio head.
- Exportable module calibration constants.
- Ability to read module temperatures.
- Input validation when configuring obstacles.
1By default, the mmWave radio head is calibrated for center frequency of 76.5 GHz. Contact NI for alternative calibrations.
Supported HardwareThe following list details the hardware models supported in NI-VRTS 1.6.1.
- Variable Delay Generator for PXI (VDG)
- PXI Vector Signal Transceiver (VST)
- mmWave Radio Head
System RequirementsNI-VRTS 1.6.1 has the following requirements:
- Processor—1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
- 4 GB RAM
- Pentium 4 G1 equivalent or later (Intel i5 equivalent or higher recommended)
- Windows 10/8.1/7, with all available critical updates and service packs
Supported Operating SystemsNI-VRTS 1.6.1 supports the following operating systems:
- Windows 10/8.11/7 SP12
- Windows Server 2012 R21 (64-bit)
- Windows Server 2008 R2 SP12 (64-bit)
Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/info and enter the Info Code PAESupport.
Application Software SupportNI-VRTS 1.6.1 supports the following application software versions, including service packs. You should install LabVIEW before installing NI-VRTS. To add support for application software installed after installing NI-VRTS, modify your NI-VRTS installation or launch the NI-VRTS installer again.
Application Software | Versions Supported by NI-VRTS | | LabVIEW | 2015 SP1, 2016 |
Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2015 SP1 and LabVIEW 2016.
Accessing the APINI-VRTS palette VIs are available in the following palette location.
User Libraries»NI-VRTS
Installation InstructionsInstalling Dependencies- Ensure that you have installed the latest version of NI Package Manager.
- To access the download page for NI Package Manager, go to ni.com/info and enter info code NIPMDownload.
- Double click the package file to open NI Package Manager.
- Follow the instructions in the installation prompts.
- Install the required drivers.
- Go to ni.com/downloads.
- Click NI Drivers.
- Search the NI Driver Downloads page for the instrument drivers in the following table and install the indicated versions.
Driver Name | Version | | NI-RFSA | 16.0 | | NI-RFSG | 16.0 |
- Install the required software products.
- Click NI Software Products.
- Search the NI Software Product Downloads page for the software in the following table and install the indicated versions.
Driver Name | Version | | NI-RFmx SpecAn | 2.3 | | NI-RFmx DeMod | 2.3 |
Installing NI-VRTS- Ensure that you have installed all previously described dependencies.
- If you installed a beta version of NI-VRTS 1.6, remove it before proceeding.
- Install NI-VRTS 1.6.1 using NI Package Manager.
Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI.
Known IssuesYou can access the software and documentation known issues list online. Refer to the NI-VRTS 1.6.1 Known Issues at ni.com/info and enter the Info Code vrts161 for an up-to-date list of known issues in NI-VRTS 1.6.1.
Bug FixesThe following items are changes in NI-VRTS 1.6.1.
ID | Fixed Issue | | 184024 | Fixed an issue that caused an incorrect gain configuration to be applied to the mmWave radio head | | 172946 | Fixed an issue that caused an incorrect gain configuration to be applied to the mmWave radio head after switching frequency bands. |
There are no changes in NI-VRTS 1.6 from NI-VRTS 1.5.
The following items are changes in NI-VRTS 1.5.
ID | Fixed Issue | | 65191 | Fixed an issue that misapplied delays and gains to VDGs in multi-object configurations. | Finding Examples
NI-VRTS ships with the following examples that can be found at \user.lib\NI-VRTS\API\Examples:
- NI-VRTS - Obstacle Simulation.vi demonstrates obstacle simulation.
- NI-VRTS - Obstacle Simulation and OBW Measurement.vi demonstrates how to simulate obstacles and carry out occupied bandwidth measurement on the RADAR sensor.
- NI-VRTS - Obstacle Simulation and FM Demod Measurement.vi demonstrates how to simulate obstacles and carry out FM demodulation on the RADAR sensor signal.
- NI-VRTS - Obstacle Simulation and TxP Measurement.vi demonstrates obstacle simulation and performs a transmit power measurement on the RADAR sensor signal.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes.
- For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer.
- To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10.
Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
Legal InformationCopyright
© 2018-2019 National Instruments. All rights reserved.
- Notices are located in the \_Legal Information and directories.
377823C-01 |
