查看: 3182|回复: 0
[NI驱动程序] NI-VirtualBench Software 1.1.1 Win32/64 中文/德语/日语/法语/英文/韩语 NI虚拟工作台软件1.1.1版下载
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-12-18 23:54:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    VirtualBench软件
    VirtualBench软件为VirtualBench多功能一体式仪器提供支持。
    VirtualBench软件是一个驱动软件,包含一个Windows应用程序,可以让用户通过集成的视图来查看VirtualBench多功能一体式仪器中所有五种仪器的数据。该软件还为LabVIEW和C提供API支持,并提供随附范例和详细的帮助文件。VirtualBench Software Windows应用程序包含工作流功能,例如仪器配置导入和导出以及数据捕获。此外,这一Windows应用程序还提供数字荧光密度图、XY模式和免持智能捕获等高级功能。
    Win32/64中文, 德语, 日语, 法语, 英文, 韩语
    1.1.1
    文件大小: 201712464 字节 (192.37 MB)
    修改日期: 2014-12-20 00:30
    MD5: 9c7aabd4ca2fbdc736bd9bb569f7cc8d(官方正确)
    SHA1: f7b19bacf318a92c1dc322a26962b759b09d96c0
    SHA256: 5c3a618dbb550b3b6c37cf63f9294f0923c432d548ae511c2cd2977bf70cacac
    CRC32: 91b63783
    NIVB1.1.1.txt (635 Bytes, 下载次数: 0, 售价: 10 圆)
    NI VirtualBench 1.1.1 Readme
    December 2014
    This file contains important information about NI VirtualBench, including any system requirements and any known issues for the application and the driver software.
    VirtualBench has the following operating system requirements:
    • Windows 8.1 (32-bit and 64-bit)
    • Windows Vista, Service Pack (SP) 1 or greater (32-bit and 64-bit)
    • Windows XP, SP3 or greater
    • Windows Server 2003 R2, SP2 or greater (32-bit)
    • Windows Server 2008 R2, SP1 or greater (64-bit)
    • Windows Server 2012 R2
    The following table lists the NI application software versions, including service packs, supported by NI VirtualBench.
    NI Application SoftwareVersions Supported by VirtualBench
    NI LabVIEW2013, 2014
    The following features and enhancements were added in this release:
    • Digital buses—Grouped mixed-signal oscilloscope digital channels into buses.
    • Protocol analyzer—Added SPI, I2C, and parallel protocols decoding with the mixed-signal oscilloscope.
    • Custom digital thresholds—Added configurable logic thresholds for mixed-signal oscilloscope digital channels.
    • New languages—Added support for French, German, Japanese, Korean, and simplified Chinese.
    • Divide math function—Add ability to do division operations on two analog oscilloscope channels.
    • New VirtualBench driver functionality—Added SPI and I2C bus protocol mastering and 20 MHz bandwidth limit filtering.
    • New application development environment support—Added ANSI C support for automating measurements.
    Using NI Launcher
    Finding All Programs
    VirtualBench Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of VirtualBench that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2014 National Instruments. All rights reserved.
    374955A-01
    GMT+8, 2025-11-19 12:47
