查看: 4289|回复: 0
[LV工具模块] LabVIEW Sound and Vibration Measurement Suite 5.0 LabVIEW声音和振动测量套件5.0下载 适用LabVIEW8.2版
    昨天 08:17
  • 签到天数: 3726 天
    连续签到: 53 天
    发表于 2020-12-11 22:52:37 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW声音和振动工具包提供了音频测试、声学测量和振动测量应用所需的函数和显示控件。
    LabVIEW声音和振动工具包是一个软件附加组件,包含易于使用的功率谱、正弦扫频和倍频程分析VI。它还可进行音频和失真测量、频率分析、频率响应测量和瞬态分析。该工具包还对分析解决方案进行了更新,以符合不断发展的IEC标准。LabVIEW声音和振动工具包提供了50多个可立即运行的LabVIEW示例,旨在帮助用户快速开始开发应用程序。
    在2019~2021版本,使用32位、64位分开安装文件的方式,在2018及之前的版本,2023Q3及之后版本则使用同一个安装文件,即同一安装文件可支持32位、64位LabVIEW,与VISION模块类似。具体的请查看下面的自述文件。
    文件名: NI.Sound.and.Vibration.Measurement.Suite.v5.0-LV8.2.rar
    文件大小: 543957024 字节 (518.76 MB)
    修改日期: 2019-12-17 12:25
    MD5: 6d9884e7833d1340f112e416fd76f4f1
    SHA1: 5295f5dd4ce60fb175f4889b308c9795393a50b3
    SHA256: ad1c13c5aea052f37973881936cd65cda65cb03d89491ac35f0454368d2eb907
    CRC32: cd4da4b7
    请注册登陆机器视觉论坛账号,购买附件查看下载地址,充值请联系在线客服
    SV5.0LV86.txt (474 Bytes, 下载次数: 3, 售价: 20 圆)
    LabVIEW Sound and Vibration Analysis VIs ReadmeVersion 5.0
    March 2007
    This file contains information to introduce you to LabVIEW support for sound and vibration analysis. This file contains information about the NI Sound and Vibration Toolkit 5.0 and the NI Sound and Vibration Measurement Suite 5.0. This file also provides you with help resources you can use while working with the software. The file contains the following information:
    Uninstallation Instructions
    Redistributing Executable Sound and Vibration Applications
    LabVIEW Sound and Vibration Analysis VIs include a collection of virtual instruments (VIs) that you can use to perform typical measurements required by audio, acoustics, or vibration applications. The Sound and Vibration Toolkit 5.0 also includes the Sound and Vibration Assistant 1.0. The Sound and Vibration Measurement Suite 5.0 includes the Sound and Vibration Toolkit 5.0 and order analysis VIs and displays.
    Use the Sound and Vibration Toolkit or Sound and Vibration Measurement Suite to perform the following sound and vibration measurements:
    • Scaling a signal to engineering units (EU)
    • Calibrating a measurement channel
    • Applying weighting filters
    • Integrating time-domain signals
    • Performing level measurements
    • Performing swept-sine measurements
    • Performing single-tone measurements
    • Performing limit and mask testing
    • Performing fractional-octave analysis
    • Performing frequency analysis
    • Performing transient analysis
    • Performing distortion analysis
    • Performing order analysis
    • Performing envelope detection
    • Displaying results
    • Loading or saving signals to UFF58 (universal file format) files
    New FeaturesSound and Vibration Toolkit 5.0
    The Sound and Vibration Toolkit 5.0 and Sound and Vibration Measurement Suite 5.0 include the following new features.
    NI Sound and Vibration Assistant 1.0, an interactive environment that simplifies the process of acquiring and analyzing sound and vibration signals. The Sound and Vibration Assistant includes the following features:
    • A drag-and-drop, interactive acquisition and analysis environment
    • Rapid measurement configuration
    • Extended functionality through NI LabVIEW
    • Analysis:
      • FFT analysis support for multichannel power spectrum and zoom power spectrum, and frequency response (1x1)
      • Spectrum measurements support for peak search, power in band, and limit test measurements
      • Level measurements support for sound level and vibration level
      • Fractional-octave analysis
      • Audio measurements support for single tone (distortion and channel evaluation) and noise measurements, and tone extraction
    • Displaying and logging:
      • Octave graph
      • Harmonic and peaks tables
      • Engineering unit support
      • Logging and playback (time-domain only)
      • UFF58 (universal file format) file support to load and save time-domain data
      • Data snap shots and documentation
      • Export (drag and drop) to Microsoft Excel
    Refer to the NI Sound and Vibration Assistant Readme, available by selecting Start» Programs»National Instruments»Sound and Vibration»Readme»Sound and Vibration Assistant Readme, for more information.
    LabVIEW Analysis
    • Express VIs, including Swept Sine, Load from UFF58, Save to UFF58, Tone Measurements (single-tone distortion and channel evaluation), Noise Measurements, and Tone Extraction
    • UFF58 (universal file format) file support to load and save time-domain and frequency-domain (real and complex) data
    • Multi-channel zoom power spectrum
    • Extended phase measurements
    • Weighting filters for NI USB-9233 sampling rates
    LabVIEW Display
    • Waterfall Graph
    • Octave Waterfall Graph
    • Colormap
    • Intensity Graph
    • Waterfall buffering
    • Waterfall to colormap conversion VIs
    In addition to the new features listed above, the Sound and Vibration Measurement Suite also includes the following new features in LabVIEW:
    • Express VIs, including Analog Tachometer Processing, Spectral Map, Order Spectrum, Order Tracking, and Order Waveform
    • Envelope detection
    • AC and DC separation for even-angle signals
    • Even-time or even-speed segment VIs
    • Conversion between XY speed profile and speed profile waveform
    • Improved examples supporting all NI DAQ devices
    To run the Sound and Vibration Toolkit or Sound and Vibration Measurement Suite 5.0, your computer must meet the following minimum system requirements:
    • Microsoft Windows Vista/XP/2000
    • Minimum of 512 MB of RAM
    • Pentium 4/M or equivalent processor
    • LabVIEW 8.2 or later Full Development System or Professional Development System installed and properly licensed
    • NI-DAQ 8.5 or later installed for NI-DAQmx support
    Note  To install the Sound and Vibration Toolkit or Sound and Vibration Measurement Suite on a Windows Vista/XP/2000 system, you must be logged in with administrator privileges.
    Complete the following steps to install the Sound and Vibration Toolkit or Sound and Vibration Measurement Suite:
    • Remove any previously installed versions of the Sound and Vibration Toolkit or Order Analysis Toolkit. Refer to the Uninstallation Instructions section below for information about uninstalling previous or current versions of the Sound and Vibration Toolkit or Order Analysis Toolkit.
    • Insert the Sound and Vibration Toolkit or Sound and Vibration Measurement Suite CD into the CD-ROM drive of the computer. If the CD startup screen does not appear, use Windows Explorer to run the autorun.exe program located in the top-level folder on the CD.
    • Follow the setup instructions that appear on the screen.
    You must uninstall the Sound and Vibration Toolkit 4.0 or earlier and the Order Analysis Toolkit 2.1 or earlier before you install the Sound and Vibration Toolkit 5.0 or the Sound and Vibration Measurement Suite 5.0. If you want to upgrade the Sound and Vibration Toolkit from a previous version and you have the Order Analysis Toolkit 2.1 or earlier, you must purchase and install the Sound and Vibration Measurement Suite 5.0, because you cannot install the Sound and Vibration Toolkit 5.0 on a computer that has the Order Analysis Toolkit.
    Complete the following steps to uninstall previous versions of the Sound and Vibration Toolkit or Order Analysis Toolkit.
    • Open the Add or Remove Programs dialog box from the Control Panel.
    • Select National Instruments Software and click the Change/Remove button.
    • Under NI Products, select NI LabVIEW Sound and Vibration Toolkit or NI LabVIEW Order Analysis Toolkit and click the Remove button.
    If you are redistributing executables built with the Sound and Vibration Measurement Suite or any of its components, you are required to purchase the appropriate NI Sound and Vibration Software Run-Time License. The part number for the NI Sound and Vibration Software Run-Time License is 779875-01.
    Refer to the LabVIEW Help, accessible by selecting Help»Search the LabVIEW Help in LabVIEW, for information about the Sound and Vibration and Order Analysis VIs. Help specific to the Sound and Vibration VIs is available from the VI and Function Reference»Toolkits»Sound and Vibration VIs book on the Contents tab of the LabVIEW Help. Help specific to the Order Analysis VIs is available from the VI and Function Reference»Toolkits»Order Analysis VIs book on the Contents tab of the LabVIEW Help.
    Refer to the LabVIEW Sound and Vibration Analysis User Manual, available by selecting Start» Programs»National Instruments»Sound and Vibration»Manuals»LabVIEW Sound and Vibration Analysis User Manual, for information about the different measurements offered by the Sound and Vibration VIs.
    Refer to the Getting Started with Order Analysis document, available by selecting Start» Programs»National Instruments»Sound and Vibration»Manuals»Getting Started with Order Analysis, for an introduction to the Order Analysis VIs. Refer to the LabVIEW Help and navigate to the Toolkits»Order Analysis»Order Analysis Concepts book on the Contents tab for more information about order analysis concepts and functionality available in the Sound and Vibration Measurement Suite. You must have LabVIEW 8.2.1 or later installed to view conceptual topics about order analysis functionality.
    LabVIEW examples for the Sound and Vibration VIs are located in the examples\Sound and Vibration folder of the LabVIEW installation directory. LabVIEW examples for the Order Analysis VIs are located in the examples\Order Analysis folder of the LabVIEW installation directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find example VIs using the NI Example Finder. Select Help»Find Examples to launch the NI Example Finder. You also can click the arrow on the Open button on the LabVIEW dialog box and select Examples from the shortcut menu to launch the NI Example Finder.
    Use the Browse or Search page of the NI Example Finder to find an example VI. On the Browse page, the Sound and Vibration VI examples are located in the Toolkits and Modules»Sound and Vibration folder. The Order Analysis VI examples are located in the Toolkits and Modules»Order Analysis folder.
    The following list describes known issues at the time of release. Refer to the Knowledge Base at ni.com for the most recent information about known issues.
    • If you want to install the Sound and Vibration Toolkit 5.0 or Sound and Vibration Measurement Suite 5.0 and the System Identification Toolkit 3.0.0, you must install the System Identification Toolkit 3.0.1 before you install the Sound and Vibration Toolkit or Sound and Vibration Measurement Suite. If you already have the System Identification Toolkit 3.0.0 installed, you must uninstall any of the following software that you have installed: Sound and Vibration Toolkit or Sound and Vibration Measurement Suite, System Identification Toolkit, Control Design Toolkit, and LabVIEW SignalExpress. You then can install the System Identification Toolkit 3.0.1. Refer to ni.com for information about obtaining the System Identification Toolkit 3.0.1 upgrade CD.
    • If you have the Sound and Vibration Toolkit 5.0 and multiple versions of LabVIEW installed, the Sound and Vibration Measurement Suite 5.0 can only install in the same version of LabVIEW that the Sound and Vibration Toolkit 5.0 is installed in.
    • To color the 3-D box decoration of the Waterfall and Octave Waterfall Graphs, you must paint behind the two transparent graphs. If the hidden graphs are colored, those colors will not be saved and will return to transparent the next time the VI is opened. Paint the bottom right corner of the decoration to ensure proper coloring of the decoration.
    • The shortcut menu of the Waterfall and Octave Waterfall Graph might seem unresponsive when the VI is running. Continual selection of the menu item eventually executes the selection.
    • If you write to two UFF58 (universal file format) files in a loop or in two different VIs without changing the names of the files, LabVIEW returns error -2570 and you cannot flush data back to disk.
    • The default value of the reset control in the Order Analysis VIs is now FALSE. The default value in the Order Analysis Toolkit 2.1 or earlier was TRUE.
    • You must have LabVIEW 8.2.1 or later installed to view order analysis conceptual topics in the LabVIEW Help. If you do not have LabVIEW 8.2.1 or later installed, you can navigate to the Program Files\National Instruments\LabVIEW 8.2\help directory and double-click the lvoatconcepts.chm file to view the order analysis conceptual topics.
    • If you have an application that uses the SVT Integration (frequency) VI that shipped with version 2.0 or 3.0 of the Sound and Vibration Toolkit, the application will be broken in this version of the Sound and Vibration Toolkit. The connector pane for the SVT Integration (frequency) VI changed between version 3.0 and version 3.1 of the Sound and Vibration Toolkit. To fix the application, replace the SVT Integration (frequency) VI with the SVL Integration (frequency) VI, located on the Spectrum Extended Measurements palette, and reconnect the input and output terminals.
    © 1999–2007 National Instruments Corporation. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    GMT+8, 2025-11-29 04:01
