LabWindows/CVI 2013 F1Patch Runtime Win32Eng LabWindows/CVI2013F1补丁下载
自2009版LabWindows开始,NI仅提供完整版和运行版,不再提供基本版。
2013F1Patch
文件大小: 119932220 字节 (114.38 MB)
修改日期: 2019-06-25 03:00
MD5: 981b0b6ae8321ed74cd773c9557f5e10
SHA1: c743a67b21e0e58e13145b17ddea5692d1e1c08a
SHA256: 492a817c8efff2031ccf1f5e80e8d1b62dbb525f9c37ef1a4b31ab301a53941b
CRC32: 8be7f192
百度和NI官方下载地址:
CVI2013Patch.txt
(640 Bytes, 下载次数: 1, 售价: 5 圆)
LabWindows/CVI for Windows, Version 2013Readme FileThis file contains installation information, programming considerations, and changes that are too recent to be included in the LabWindows/CVI Help for LabWindows™/CVI™ 2013. Refer to the LabWindows/CVI Release Notes for more information about new features. Caution Installing LabWindows/CVI 2013 replaces any previous version of the LabWindows/CVI Run-Time Engine with the LabWindows/CVI 2013 Run-Time Engine. To restore the previous Run-Time Engine, uninstall LabWindows/CVI 2013 and any previous versions of LabWindows/CVI on the computer. Then reinstall the LabWindows/CVI version you want to use.
If you have a beta version of LabWindows/CVI, you must uninstall the beta version before you install a non-beta version of LabWindows/CVI. ContentsSystem Requirements Installing LabWindows/CVI Automating the Installation of NI Products Activating LabWindows/CVI After Installation Known Issues Behavior Changes in LabWindows/CVI Behavior Changes Introduced in LabWindows/CVI 2013 Behavior Changes Introduced in LabWindows/CVI 2012 Behavior Changes Introduced in LabWindows/CVI 2010 Behavior Changes Introduced in LabWindows/CVI 2009 Behavior Changes Introduced in LabWindows/CVI 9.0 and Earlier Bug Fixes Using NI Software with Microsoft Windows 8 NI Software Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 System RequirementsTo run LabWindows/CVI 2013, you must have the following: - Personal computer using a Pentium 4/M or equivalent microprocessor
- Microsoft operating systems:
- Windows 8 (32-bit and 64-bit)
- Windows 7 (32-bit and 64-bit), including Starter Edition
- Windows Vista Service Pack 1 (32-bit and 64-bit)
- Windows XP Service Pack 3
- Windows Server 2008 R2 Service Pack 2 (64-bit)
- Windows Server 2003 R2 Service Pack 2 (32-bit)
Note LabWindows/CVI supports only R2 editions of Windows Server - 1024 × 768 resolution (or higher) video adapter
- Minimum of 512 MB of RAM, 2 GB recommended
- 1.4 GB free hard disk space for full installation, which includes the Interface to Win32 Application Programmatic Interface (API); additional space needed for National Instruments Device Drivers and for the Microsoft .NET Framework 4.0
- Microsoft-compatible mouse
Installing LabWindows/CVINational Instruments recommends that you install the complete LabWindows/CVI program to take full advantage of all LabWindows/CVI 2013 functionality. If you choose to install with options, select the options you want and follow the on-screen directions. If necessary, you can run the setup program again to install or remove additional files. The LabWindows/CVI Platform DVD includes LabWindows/CVI and the following modules and toolkits. Modules - Real-Time Module
- Vision Development Module
Toolkits - Real-Time Execution Trace Toolkit
- SQL Toolkit
- Signal Processing Toolkit
- PID Toolkit
- Execution Profiler Toolkit
- ECU Measurement and Calibration Toolkit
- Automotive Diagnostic Command Set
If you purchased any of these modules or toolkits, you can install them using the LabWindows/CVI Platform DVD. If you want to evaluate any of these modules or toolkits before purchasing them, you can install these add-ons from the LabWindows/CVI Platform DVD and try them for 45 days. After an initial 7 day period, you can register on ni.com for access to the remainder of the evaluation period. Note | The Execution Profiler Toolkit does not require a separate license if you have a LabWindows/CVI Full Development System license. If you have the LabWindows/CVI Base Package, you can install the Execution Profiler Toolkit for evaluation. | Installation Considerations- When installing LabWindows/CVI, the LabWindows/CVI Real-Time Module, and NI Device Drivers, install device drivers after the LabWindows/CVI Real-Time Module. If you install all of these products at the same time using the LabWindows/CVI Platform DVD, the products are installed in the correct order. If you install the LabWindows/CVI Real-Time Module on a computer that already has device drivers installed, reinstall the device driver software to ensure that real-time support is installed for the device drivers you selected.
- The complete Interface to Win32 API is available with the LabWindows/CVI Full Development System. Some Win32 API header and import library files are included when you install the LabWindows/CVI Base Package.
- The LabWindows/CVI installation includes the LabWindows/CVI 2013 Run-Time Engine. This version replaces any previous version of the LabWindows/CVI Run-Time Engine. After you install LabWindows/CVI 2013, executables and DLLs created with previous versions of LabWindows/CVI automatically use the new LabWindows/CVI 2013 Run-Time Engine.
To restore the previous Run-Time Engine, uninstall LabWindows/CVI 2013 and any previous versions of LabWindows/CVI on the computer. Then reinstall the LabWindows/CVI version you want to use. - If you install LabWindows/CVI onto a network drive, you might encounter an error during installation that prevents files that the IVI Instrument Driver Wizard requires from being installed. This issue does not affect other functionality in LabWindows/CVI.
- If you have installed Microsoft Security Update 896358, you might not be able to view topics within the LabWindows/CVI Help if the file is on a network drive. To solve this issue, copy the .chm files that LabWindows/CVI installs to your local hard drive and launch them as normal.
- The IVI Installer Creator and IVI Specific Driver Test Suite items are selected by default in the installer feature tree only if the IVI Compliance Package is installed. You can select these items if the IVI Compliance Package is not installed, but you must then install the IVI Compliance Package, which you can download from ni.com. The IVI Compliance Package is also available on the NI Device Drivers media.
- You can install the Visual Studio Wizards feature only if you have installed the version of Visual Studio corresponding to the Visual Studio Wizard you select.
Running the InstallationComplete the following steps to install LabWindows/CVI: Note | If you already have a different version of LabWindows/CVI installed on your computer, be sure to install version 2013 in a different directory. If you want to install to an existing directory, uninstall the other version before installing LabWindows/CVI 2013.
You must have administrator privileges to install LabWindows/CVI. |
- Insert the LabWindows/CVI media into the disk drive. If the media does not run automatically, open Windows Explorer, right-click the disk drive icon, and select AutoPlay.
- On installation startup, the National Instruments LabWindows/CVI 2013 screen appears. Click Install LabWindows/CVI, Modules, and Toolkits.
- Continue to follow the instructions on the screen.
Note | If you have a serial number for the product you want to install, enter the number during installation when you are prompted. You also can activate the product after installation. For more information about finding serial numbers, refer to ni.com/info and enter SerialNumbers_en as the Info Code.
Each product on the LabWindows/CVI Platform DVD has a different serial number, with the possible exception of the LabWindows/CVI Execution Profiler Toolkit. |
- If you selected Device Drivers in the Product List, the LabWindows/CVI installer prompts you to insert the National Instruments Device Drivers DVD after you install LabWindows/CVI and any selected modules and toolkits. Follow the instructions on the screen to install the device drivers.
- To activate a National Instruments product, refer to the Activating LabWindows/CVI section.
LabWindows/CVI Updates and NotificationsNational Instruments posts information about critical updates and security notifications on ni.com. Visit ni.com/info and enter Info Code updates to access this information. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information, refer to the following KnowledgeBase articles: - For more information on silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information on silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, Automating the Installation of a Suited Installer.
Activating LabWindows/CVIYou can activate LabWindows/CVI during or after installation. To activate during installation, enter a serial number when you are prompted by the installer. If you do not activate during installation, you can launch the NI Activation Wizard by selecting Activate Products in the License Status dialog box, which displays when you launch LabWindows/CVI for the first time. For more information about activation, refer to the Activating Your Software topic in the LabWindows/CVI Help. Note | If you are unable to activate LabWindows/CVI, refer to the web page at ni.com/activate. | After Installation- Installing LabWindows/CVI in a New Directory—If you installed driver or toolkit software for LabWindows/CVI 8.1.1 or earlier and you install LabWindows/CVI 2013 in a new directory, you must uninstall and reinstall the LabWindows/CVI portion of the driver or toolkit software.
- Using Example Programs—You can find example programs in the following location on Windows 8/7/Vista/Server 2008: \Users\Public\Documents\National Instruments\CVI2013\samples. On Windows XP/Server 2003, example programs are located in the following location: \Documents and Settings\All Users\Documents\National Instruments\CVI2013\samples.
- Working with Project and File Templates—Save user-defined project and file templates in the LabWindows/CVI public documents directory (\Users\Public\Documents\National Instruments\CVI on Windows 8/7/Vista/Server 2008 and \Documents and Settings\All Users\Documents\National Instruments\CVI on Windows XP/Server 2003). LabWindows/CVI 8.5 and later does not search previous locations, \Documents and Settings\All Users\Application Data\CVI and \Documents and Settings\\Application Data\CVI, for project and file templates.
- Making Backup .uir Files—Make backup copies of your .uir files if you have been using previous versions of LabWindows/CVI. Once you save .uir files in LabWindows/CVI 2013, the .uir files are no longer compatible with versions 8.1.1 or earlier. You cannot load .uir files that you have saved in LabWindows/CVI 2013 in LabWindows/CVI 8.1.1 or earlier.
You can save .uir files you create or load in LabWindows/CVI 2013 in earlier formats. Select File»Save .uir As and specify the format in the Save as type option. If you save a user interface with features that were added in later versions of LabWindows/CVI, those features are removed when you save the file in earlier formats.
Known IssuesThis version of LabWindows/CVI has the following known issues. Refer to the LabWindows/CVI Known Issues web page on ni.com for a complete list of known issues in this version of LabWindows/CVI. - Selecting Values in IviFgen Class Driver—In the IviFgen FP file, the Attribute ID and Attribute Value controls in the Get/Set/CheckAttributeViInt64 functions display an empty field instead of a list of attributes and values. For more information, refer to KnowledgeBase 5WOA752F: Issue Setting IviFgen Attribute ID Using Get/Set/CheckAttributeViInt64 Functions.
- Uninstalling LabWindows/CVI—If you have multiple versions of LabWindows/CVI installed and you uninstall one of the versions, the remaining installation will be missing its file associations, and its automation capabilities will not function properly. To fix this problem, perform a repair installation of the remaining LabWindows/CVI version.
- Error When Building a LabWindows/CVI Project in Visual Studio 2005—If you create a project in Visual Studio 2005 that uses LabWindows/CVI libraries, you will see the following error: fatal error LNK1103: debugging information corrupt; recompile module. To address this issue, install the hotfix available from Microsoft.
- Debugging Executables on Windows—On Windows Vista and later, executables that contain setup, install, or update as part of their name automatically require administrator privileges. If you run these executables as stand-alone from a user-level account, Windows will prompt you for an administrator password. However, LabWindows/CVI cannot debug these applications from a user-level account. When you try to run them, LabWindows/CVI displays a Could not run executable notification. NI recommends that you rename your executable so that it does not contain those words in its name, or that you embed a manifest into the application that marks the application as being Vista-aware. You can embed a manifest using the Target Settings dialog box.
- Viewing Help—If you open the LabWindows/CVI Help outside of LabWindows/CVI, such as launching it through the Start menu, you might not see all driver or toolkit content. Select Help»Contents to open the LabWindows/CVI Help from within LabWindows/CVI to ensure that all driver and toolkit content is available.
- Using the LabWindows/CVI Conversion Wizard in Microsoft Visual Studio—Microsoft Visual Studio 2005 and later do not support the single-threaded version of the Visual Studio C library. Therefore, you must configure your project's linker settings to ignore directives to use the single-threaded C library. In Visual Studio, select Project» Properties and expand the properties tree to the Configuration Properties»Linker»Input item. Add libc to the Ignore Specific Library option. Refer to the I Receive Linker Errors When Using LabWindows/CVI-Generated Static Libraries and Object Files in Microsoft Visual Studio 2005 KnowledgeBase article for more information.
Behavior Changes in LabWindows/CVIRefer to the following sections for behavior changes specific to different versions of LabWindows/CVI. Behavior Changes Introduced in LabWindows/CVI 2013- The following product components no longer appear in the tree on the Driver and Components tab of the Edit Installer dialog box:
- Standard Run-Time
- Instrument Driver Run-Time
- Real-Time Run-Time
If you select NI LabWindows/CVI Shared Run-Time Engine from the tree, LabWindows/CVI includes these components automatically. - The minimum installer size when including the run-time engine increased by approximately 41MB compared to previous versions of LabWindows/CVI. To decrease the size of your distribution, you can include LabWindows/CVI merge modules. For more information, refer to KB 6AHC1EQW.
- The Install LabWindows/CVI Shared Run-Time Engine in the application directory option on the Advanced tab of the Edit Installer dialog box is deprecated. If you need to install and preserve a specific version of the LabWindows/CVI Run-Time Engine, consider installing the LabWindows/CVI Side-by-Side Run-Time Engine. Refer to the Binding Executables and DLLs to Side-by-Side Run-Time Engines topic in the LabWindows/CVI Help for more information about the Side-by-Side Run-Time Engine.
- The Project Tree no longer displays the Status column.
- If you enable the Build with C99 extensions option, the Require function prototypes option is always implicitly enabled.
- The results of several mathematical operations performed using floating-point numbers might differ from results returned in previous versions of LabWindows/CVI. The differences are small and within acceptable error ranges for the data types.
- Function calls are no longer allowed in watch expressions or in the condition of a breakpoint.
- You must rebuild any EXEs and DLLs built in LabWindows/CVI 2012 or earlier in LabWindows/CVI 2013 before you can debug them.
- You cannot debug EXEs and DLLs built in LabWindows/CVI 2013 in LabWindows/CVI 2012 or earlier.
- Displaying extended data in the Variables and Call Stack window is available only when a program stops gracefully, for example, as a result of a breakpoint or when stepping through code. Extended data is unavailable in the following instances:
- If the program breaks as a result of an exception
- If you manually break execution, for example, by pressing the Stop button
- Expressions in the Watch window do not update continuously while a program is running.
- You can no longer choose scope in the Watch window. All variables and expressions in the Watch window are evaluated in the current context.
- Watch expressions that you save in LabWindows/CVI 2013 cannot be loaded by LabWindows/CVI 2012 or earlier.
- Some C99 features are available in C89.
- When debugging a real-time application via LabVIEW, LabWindows/CVI does not stop listening when the VI is unloaded. You must either Disconnect or Abort and reboot.
- When graphs scale, they will always scale to the thickness of their line plots. In previous versions of LabWindows/CVI, only plots whose thickness was greater than 1 scaled up or down.
- LabWindows/CVI no longer links to gpibstub.obj or vxistub.obj.
- To use the ExportStyle method in 3DGraphCtrl.fp, you must specify the directories to which you want to export files. Refer to KB 67L8L0QW for more information about using the ExportStyle method.
- LabWindows/CVI 2013 includes updated bracket and indentation styles. You can continue using bracket and indent styles available in previous versions of LabWindows/CVI by selecting the Use CVI legacy formatting option in the Editor Preferences dialog box. Some of the legacy formatting options map to the updated styles except for the following combinations:
- Function brackets set to uneven, left; statement brackets set to uneven, right
- Function brackets set to uneven, left; statement brackets set to flush, left
- Function brackets set to uneven, left; statement brackets set to flush, right
- Function brackets set to uneven, right; statement brackets set to uneven, left
- Function brackets set to uneven, right; statement brackets set to flush, left
- Function brackets set to uneven, right; statement brackets set to flush, right
- Function brackets set to flush, left; statement brackets set to uneven right
- Function brackets set to flush, left; statement brackets set to flush right
- Function brackets set to flush, right; statement brackets set to uneven, left
- Function brackets set to flush, right; statement brackets set to uneven, right
- Function brackets set to flush, right; statement brackets set to flush, left
Note that if you select a legacy formatting option, batch auto indent support (selecting Edit»Format File and Edit»Format Selection), is unavailable. - The LabWindows/CVI Help no longer includes a Font button for increasing or decreasing the font size in the help file.
- The Options»Generate Visual Basic Include menu item is no longer available.
- LabWindows/CVI 2013 now returns 2 as the size of variables of type wchar_t, which is consistent with the ANSI C specification. You must recompile existing code in LabWindows/CVI 2013 to see the change in behavior.
- LabWindows/CVI 2012 returned certain compiler errors that are now returned as warnings. Refer to KB 6A9GOOQW for more information.
- LabWindows/CVI 2012 returned certain compiler errors that are no longer errors. Refer to KB 6A9GO5QW for more information.
- Using the token-pasting operator (##) might return compiler errors that were not returned in LabWindows/CVI 2012.
- The Conservative and Aggressive levels of unitialized local variables detection are now combined into one compiler warning. You might notice more unitialized local variables warnings because LabWindows/CVI now flags all variables that may or may not have values assigned to them. This behavior more closely matches the Aggressive level for the Uninitialized local variables detection option in previous versions of LabWindows/CVI.
- You must enable the Include project files in Interactive window or Include loaded instrument drivers in Interactive window options if you run code in a function panel or in the Interactive Execution window that has dependencies on other files in the project or on a loaded instrument driver.
- You cannot view the values of #define macros when you are debugging.
- You cannot specify a .c file as the module to load to the LoadExternalModule and LoadExternalModuleEx functions.
Behavior Changes Introduced in LabWindows/CVI 2012- The Physical Memory Access functions, located in the Utility Library, are deprecated. Refer to KB 5QCCQSQW for more information.
- If your program includes any Port IO functions, located in the Utility Library, the program will require administrator privileges to run. Refer to KB 5Q5FO1QW for more information.
- The LabWindows/CVI low-level support driver can be loaded only by applications running with administrator privileges on 32-bit systems. Refer to KB 5Q5FJ4QW for more information.
- You can no longer create a reduced-size distribution that includes the low-level support driver. If your application uses the low-level support driver, you must include the full LabWindows/CVI Run-Time Engine in your installer. To include the full run-time engine in your installer, complete the following:
- Select the NI LabWindows/CVI Shared Run-Time Engine item in the Drivers & Components tab of the Edit Installer dialog box.
- Ensure that you deselect the Install the LabWindows/CVI Shared Run-Time Engine in the application directory option in the Advanced tab of the Edit Installer dialog box.
Refer to KB 5R6A4SQW for more information. - The GetFontTypefaceName function, when used on VAL_DIALOG_FONT or VAL_DIALOG_META_FONT, now returns the actual typeface of the dialog font on your system, rather than the substitute for that font that Windows uses.
- LabWindows/CVI 2013 supports the Perforce SCC Plug-in (P4SCC) 2006.1 and later.
- For projects you save in LabWindows/CVI 2013, LabWindows/CVI attempts to resolve paths that were previously saved as absolute paths to be relative to the project. You can override this behavior by specifying the following options in the .prj file:
For a target file, specify the following in the [Create Executable] section of the .prj file:
Executable File_Configuration Force Path Absolute = True
where _Configuration is the configuration of your target, such as Debug, Release, or Debug64.
For a file in the project list, specify the following in the [File nnnn] section of the .prj file, where nnnn is the index of the file in the project list:
Path Force Path Absolute = True - You can call .NET Library functions from multiple threads simultaneously without getting blocked.
- Previous versions of LabWindows/CVI did not recognize numbers entered in scientific notation for numeric controls of type int64 or unsigned int64. Starting with LabWindows/CVI 2010 SP1, you can enter numbers in scientific notation. When you enter a number in scientific notation into numeric controls of type int64 or unsigned int64, LabWindows/CVI converts the number to a double and then to a 64-bit integer. This conversion may cause a loss of precision after 15 decimal digits.
- LabWindows/CVI 2010 SP1 includes the GaussHypergeometric function, which you should use instead of the GaussHG function.
Behavior Changes Introduced in LabWindows/CVI 2010- Build Options and Target Settings dialog box options apply per configuration. The options on these dialog boxes are no longer global as in previous releases.
- National Instruments no longer supports Windows 2000.
- The minimum operating system version for distributions is Windows XP. If you open an existing distribution that specifies Windows 2000 as the minimum operating system, LabWindows/CVI updates the minimum operating system to Windows XP.
- If you install the Full Development System, the Interface to Win32 Application Programmatic Interface (API) is installed by default.
- The glaux.lib import library is deprecated and is no longer included with LabWindows/CVI. The glaux.prj sample program is no longer installed.
- The Save changes before debugging option in the Environment dialog box is now a global option. In previous releases, this option was workspace-specific.
- The Save changes before compiling option in the Environment dialog box is enabled by default. This global option allows LabWindows/CVI to save all modified files before compiling and debugging.
- LabWindows/CVI no longer installs the Documentation from MSDN Library. National Instruments recommends that you view the latest version of this documentation at www.msdn.com. For more information, visit ni.com.
Behavior Changes Introduced in LabWindows/CVI 2009- Borland is no longer supported as a compatible compiler or as a third-party compiler in LabWindows/CVI.
- Starting with the 2009 version of LabWindows/CVI, major versions align with the year in which they release. For example, this version of LabWindows/CVI is called LabWindows/CVI 2013. You can find installed files in the CVI2013 folder in the various locations where LabWindows/CVI installs files. The registry keys corresponding to this version of LabWindows/CVI are located in CVI\12.0 in the registry.
- The NI Distributed System Manager replaces the NI Variable Manager. Use the System Manager to create and monitor network variables, processes, and I/O servers. For more information about the System Manager, refer to the NI Distributed System Manager Help, which you can access from the System Manager.
- The Translate LW DOS Program option is no longer available.
- The LabWindows/CVI compiler now defines the NDEBUG macro for release configuration builds.
- LabWindows/CVI no longer adds _dbg suffix to the base name of the debug target of a project.
- The data type of the targetThreadId parameter of the PostDeferredCallToThread and PostDeferredCallToThreadAndWait functions has been changed from unsigned long to unsigned int.
Behavior Changes Introduced in LabWindows/CVI 9.0 and Earlier- toolbox.h now includes some LabWindows/CVI headers that must be included after including windows.h. Therefore, if your code includes toolbox.h before including windows.h, reverse the order of these includes.
- Network variable processes that begin with NI_ are disallowed. The CNVNewProcess function returns an error if the process name you specify begins with NI_.
- The following macros have been renamed:
Library | Previous Macro Name | New Macro Name | WordReport.fp Instrument Driver | NONE | WR_NONE | Analysis Library | SORT_ASCENDING | ANALYSIS_SORT_ASCENDING | Analysis Library | SORT_DESCENDING | ANALYSIS_SORT_DESCENDING |
- Upgrading to LabWindows/CVI 8.5 and later may cause the Advanced Analysis or Analysis Library to produce numerical differences in floating point results and different results for exceptional inputs, such as positive or negative infinity and NaN. These differences may occur because the underlying C Analysis library has been recompiled in LabWindows/CVI 8.5 to take advantage of new processors and operating systems.
- The enum value CVIConst_CVI_FPVERSION_90 has been changed to CVIConst_CVI_FPVERSION_85 for the fpVersion parameter of the FPGenCreateFunctionTree function of the LabWindows/CVI ActiveX Server Interface Library.
- The modini utility and related source code as well as the modreg source code are deprecated and no longer installed with LabWindows/CVI.
- The LabWindows/CVI Quick Reference card is no longer published and is not installed with LabWindows/CVI.
- The option to create Microsoft Windows WinHelp files (.hlp) from LabWindows/CVI, Generate»Documentation»Windows Help, is no longer available.
- The Network Variable Library flushes all internal buffers in a write operation, which improves network variable performance.
Flushing on write may cause lower throughput in some high bandwidth conditions, in which case you can set CNVFlushOnWriteAttribute to 0 (FALSE). In high bandwidth conditions, National Instruments recommends using the CNVBufferedWriter connection. - During a read operation, the Network Variable Library flushes all network variable connections in your program, including data in writer connections, for better performance.
- Registering ActiveX Servers—When you build ActiveX servers in LabWindows/CVI 8.1.1 and later on Windows XP and later, the ActiveX servers are registered in your user profile. This registration is not visible to other users on your system. On versions of Windows prior to Windows XP, ActiveX servers are registered for all users. When you register these servers outside the LabWindows/CVI environment, they are always registered for all users; this option requires administrator privileges on Windows Vista and later.
- Analysis Function Behavior Changes—The following function behavior has changed from LabWindows/CVI 7.1 to LabWindows/CVI 8.x:
- SVD and CxSVD—The following formula defines the SVD factorization of an n-by-m matrix A: A = USVT.
In LabWindows/CVI 7.1 and earlier, CxSVD has the following requirement: If numberOfRows (n) < numberOfColumns (m), you must allocate m*m*sizeof(ComplexNum) bytes of memory to the input matrix and the U orthogonal matrix. LabWindows/CVI 8.x and later no longer has this requirement. - Lu and CxLU—In LabWindows/CVI 7.1 and earlier, if the input matrix is singular, the functions stop the decomposition and return SingularMatrixErr. In LabWindows/CVI 8.x and later, if the input matrix is singular, the functions complete the decomposition and return SingularMatrixWarn. In this case, there are one or more zero elements along the diagonal of U.
- CxTrace—CxTrace accepts only a square matrix. In LabWindows/CVI 7.1 and earlier, the function requires both the number of rows and the number of columns as input parameters. In LabWindows/CVI 8.x and later, matrixSize specifies both the number of rows and the number of columns. The numberOfColumns parameter in LabWindows/CVI 7.1 and earlier is a reserved parameter in LabWindows/CVI 8.x and later. This parameter is not referenced in the function.
- ConditionNumber and CxConditionNumber—In LabWindows/CVI 7.1 and earlier, these functions return NaN for singular input matrices. In LabWindows/CVI 8.x and later, these functions return Inf for singular input matrices.
- GenLSFit—In LabWindows/CVI 8.x and later, GenLSFit calculates the mean squared error as the weighted mean square error, which differs from the prior implementation of the function.
Bug FixesRefer to the LabWindows/CVI Bug Fix Information web page on ni.com for an up-to-date list of bug fixes in this version of LabWindows/CVI 2013. How to Use NI Software with Microsoft Windows 8When you install National Instruments software on Microsoft Windows 8, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (MAX), and the new NI Launcher. Using NI LauncherNI Launcher helps you find and launch installed NI products. It provides you with a method of finding NI products similar to the Start menu in previous versions of Microsoft Windows. To use NI Launcher, click the NI Launcher tile on the Start screen. NI Launcher launches the desktop and opens a menu containing a list of NI products. Click any NI product to launch it. Note MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher. | Pinning Frequently Used ApplicationsFor convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary: Current Application | Icon Location | Pin to Action | Windows 8 Desktop | Desktop Taskbar | Right-click application and select Pin to Taskbar | Windows 8 Desktop | Start screen | Right-click application and select Pin to Start | Windows 8 Start screen | Desktop Taskbar | Right-click application and select Pin to taskbar from the menu bar on the bottom of the screen | Finding All ProgramsIf you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files by right-clicking anywhere on the Start screen and selecting All apps. A list of all installed software and related files appears, in alphabetical order by creator or type. For more information about NI support for Windows 8, visit ni.com/windows8. NI LabWindows/CVI Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016National Instruments LabWindows/CVI will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of LabWindows/CVI that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes: Product | Info Code | NI LabVIEW | lifecycle | NI LabWindows/CVI | cvi_lifecycle | NI Measurement Studio | mstudiolifecycle | NI TestStand | tslcp | NI DIAdem | ddlcp | NI SignalExpress | selcp | NI VeriStand | nivslifecycle |
Important InformationCopyright © 1993–2013 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents
For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents. |
