LabWindows/CVI 2009 Full Win32Eng LabWindows/CVI2009完整版下载
自2009版LabWindows开始,NI仅提供完整版和运行版,不再提供基本版。
2009
文件大小: 355849099 字节 (339.36 MB)
修改日期: 2019-06-25 02:59
MD5: 670d7e994bc0f2023291e937329ab629
SHA1: 3bbbf5b39d776379195be87bec4a569451b82849
SHA256: cf2083b264b0d414caf3b33cd8403f5c969de00122391c31deac35c69c1e79e5
CRC32: 5b8c1e89
百度和NI官方下载地址:
CVI2009.txt
(614 Bytes, 下载次数: 1, 售价: 15 圆)
LabWindows/CVI for Windows 7/Vista/XP/2000, Version 2009Readme FileThis file contains installation information, programming considerations, and changes that are too recent to be included in the LabWindows/CVI Help. Refer to the LabWindows/CVI Release Notes for more information about new features. ContentsMinimum System Requirements
Installing LabWindows/CVI
Activating LabWindows/CVI
After Installation
Updating to LabWindows/CVI 2009
Updating to LabWindows/CVI 9.0
Bug Fixes Minimum System RequirementsTo run LabWindows/CVI 2009, you must have the following items: - Personal computer using a Pentium 1GHz or higher microprocessor
- Microsoft operating systems:
- Windows 7 (32-bit and 64-bit)
- Windows Vista (32-bit and 64-bit)
- Windows XP (32-bit)
- Windows 2000 Service Pack 3 or later
Note LabWindows/CVI 2009 is the last major release to support Windows 2000. - 1024 × 768 resolution (or higher) video adapter
- Minimum of 128 MB of RAM, 512 MB recommended
- 1.1 GB free hard disk space for full installation, which includes the Interface to Win32 Application Programmatic Interface
Note Installing the Documentation from MSDN Library requires additional disk space. - Microsoft-compatible mouse
Installing LabWindows/CVINational Instruments recommends that you install the complete LabWindows/CVI program to take full advantage of all LabWindows/CVI 2009 functionality. If you choose to install with options, select the options you want and follow the on-screen directions. If necessary, you can run the setup program again to install or remove additional files. Before Installation- If you install the LabWindows/CVI Real-Time Module and device drivers with LabWindows/CVI 2009, you must install these products in the following order:
- LabWindows/CVI 2009
- LabWindows/CVI 2009 Real-Time Module
- Device driver software, using NI Device Drivers media
The LabWindows/CVI package includes the device driver software on a DVD. If you require device driver software on CDs, refer to the National Instruments Web site at ni.com/info and enter the info code drivercd.
If you are installing the LabWindows/CVI Real-Time Module, do not install the device driver software when you are prompted to do so during the LabWindows/CVI 2009 installation. Instead, install the device driver software when you are prompted during the LabWindows/CVI Real-Time Module installation. - When you install LabWindows/CVI, your user account must have administrator privileges.
- You must explicitly select the Interface to Win32 API feature of the LabWindows/CVI installer to install the complete Interface to Win32 API.
The Interface to Win32 API is based on the Windows Server 2003 R2 Platform SDK. The Windows Server 2003 R2 Platform SDK was released in March 2006 and does not include tools or functionality added in later versions of the SDK, such as support for functionality specific to Windows Vista.
Note The complete Interface to Win32 API is available with the LabWindows/CVI Full Development System. Some Win32 API header and import library files are included when you install the LabWindows/CVI Base package. - The LabWindows/CVI installation includes the LabWindows/CVI 2009 Run-Time Engine. This version replaces any previous version of the LabWindows/CVI Run-Time Engine. After you install LabWindows/CVI 2009, executables and DLLs created with previous versions of LabWindows/CVI automatically use the new LabWindows/CVI 2009 Run-Time Engine.
To restore the previous Run-Time Engine, uninstall LabWindows/CVI 2009 and any previous versions of LabWindows/CVI on the computer. Then reinstall the LabWindows/CVI version you want to use, along with any additional National Instruments software you might have installed. - If you install LabWindows/CVI onto a network drive, you might encounter an error during installation that prevents files that the IVI Instrument Driver Wizard requires from being installed. This issue does not affect other functionality in LabWindows/CVI.
- If you have installed Microsoft Security Update 896358, you might not be able to view topics within the LabWindows/CVI Help if the file is on a network drive. To solve this issue, copy the .chm files that LabWindows/CVI installs to your local hard drive and launch them as normal.
- The IVI Installer Creator and IVI Specific Driver Test Suite items are selected by default in the installer feature tree only if the IVI Compliance Package is installed. You can select these items if the IVI Compliance Package is not installed, but you must then install the IVI Compliance Package, which you can download from ni.com.
- You can install the Visual Studio 2005 Wizards and Visual Studio 2008 Wizards features only if you have installed Visual Studio 2005 and Visual Studio 2008, respectively.
Running the InstallationThe LabWindows/CVI Platform DVD includes LabWindows/CVI and the following modules and toolkits. Modules - Real-Time Module
- Vision Development Module
Toolkits - Execution Profiler Toolkit
- PID Toolkit
- Real-Time Execution Trace Toolkit
- Signal Processing Toolkit
- SQL Toolkit
Note The LabWindows/CVI Platform DVD also includes the Documentation from MSDN Library. If you purchased any of these modules or toolkits, you can install them using the LabWindows/CVI Platform DVD. If you want to evaluate any of these modules or toolkits before purchasing them, you can install these add-ons from the LabWindows/CVI Platform DVD and try them for free for 30 days. Refer to each toolkit or module Readme for more information about installing with media other than the LabWindows/CVI Platform DVD. Complete the following steps to install LabWindows/CVI 2009: Note If you already have a different version of LabWindows/CVI installed on your computer, be sure to install version 2009 in a different directory. If you want to install to an existing directory, uninstall the other version before installing LabWindows/CVI 2009. - Insert the LabWindows/CVI media into the disk drive. If the media does not run automatically, open Windows Explorer, right-click the disk drive icon, and select AutoPlay.
- On installation startup, the National Instruments LabWindows/CVI 2009 screen appears. Click Install LabWindows/CVI, Modules, and Toolkits.
- In the Product List panel, select all the products you want to install. Select Install to install products using default options. Selecting Install with customization opens additional dialog boxes that require your input.
- In the Product Information panel, determine whether to allow the installer to contact National Instruments to search for new notifications, such as critical updates, on the products you are installing. The checkbox is enabled by default.
- In the User Information panel, enter your name and organization.
- Enter the serial number, from the Certificate of Ownership card in the software kit, in the appropriate field for each product you install. LabWindows/CVI uses this serial number when you run the NI Activation Wizard. Leave the Serial Number field blank to evaluate the product.
Note To activate a National Instruments product after you evaluate it, refer to the Activation Instructions. - Continue to follow the instructions on the screen.
Note If you selected Device Drivers in the Product List, after installing LabWindows/CVI and any selected modules and toolkits, the LabWindows/CVI installer prompts you to insert the National Instruments Device Drivers DVD. Follow the instructions on the screen to install the device drivers. Activating LabWindows/CVIYou can activate licenses you have purchased for LabWindows/CVI, modules, and toolkits during installation. If you do not activate a valid license for LabWindows/CVI or any modules and toolkits that you install, the unlicensed product operates in evaluation mode. After you install the product, the evaluation begins the first time you launch the product and lasts 30 consecutive days. When the evaluation period expires, you must activate a valid license to continue using the product. You can activate LabWindows/CVI, module, or toolkit in the following ways: - During installation, as described in the Installation Instructions.
- After installation, by enabling the Run License Manager to activate the product(s) checkbox on the Installation Summary panel of the LabWindows/CVI Platform DVD installer.
- After you launch LabWindows/CVI for the first time with any product in evaluation mode, click the Activate Products button in the LabWindows/CVI Message dialog box.
- Select Help»Activate LabWindows/CVI while LabWindows/CVI is running in evaluation mode or select Start»All Programs»National Instruments»NI License Manager to launch the NI License Manager.
If you do not activate LabWindows/CVI or any modules and toolkits during installation, LabWindows/CVI prompts you to activate when you launch LabWindows/CVI. After you activate the licenses for all LabWindows/CVI products you installed, you no longer see this prompt. Once you choose your activation method and launch the NI Activation Wizard, complete the following steps to activate LabWindows/CVI and any modules or toolkits: - Select the Automatically activate through a secure Internet connection option and click Next.
Your computer must be connected to the Internet for this option to work. - Enter the serial numbers for the products you want to activate. Click Next.
- Fill in the necessary information and click Next.
- Check the option and enter an email address if you would like to receive a confirmation email of your activation and click Next.
- After a brief moment, a message appears, indicating whether LabWindows/CVI has been activated. Click Next.
- When you successfully activate LabWindows/CVI and any modules or toolkits, click Finish. LabWindows/CVI displays a window indicating when your license expires.
For more information about activation, refer to the LabWindows/CVI Release Notes. After Installation- Installing LabWindows/CVI in a New Directory—If you installed driver or toolkit software for LabWindows/CVI 8.1.1 or earlier and you install LabWindows/CVI 2009 in a new directory, you must uninstall and reinstall the LabWindows/CVI portion of the driver or toolkit software.
- Using Example Programs—You can find example programs in the following location on Windows 7/Vista: \Users\Public\Documents\National Instruments\CVI2009\samples. On Windows 2000/XP, example programs are located in the following location: \Documents and Settings\All Users\Documents\National Instruments\CVI2009\samples.
- Working with Project and File Templates—Save user-defined project and file templates in the LabWindows/CVI public documents directory (\Documents and Settings\All Users\Documents\National Instruments\CVI on Windows XP/2000 and \Users\Public\Documents\National Instruments\CVI on Windows 7/Vista). LabWindows/CVI 8.5 and later does not search previous locations, \Documents and Settings\All Users\Application Data\CVI and \Documents and Settings\\Application Data\CVI, for project and file templates.
Updating to LabWindows/CVI 2009- Borland is no longer supported as a compatible compiler or as a third-party compiler in LabWindows/CVI.
- Starting with this version of LabWindows/CVI, major versions align with the year in which they release. For example, this version of LabWindows/CVI is called LabWindows/CVI 2009. You can find installed files in the CVI2009 folder in the various locations where LabWindows/CVI installs files. The registry keys corresponding to this version of LabWindows/CVI are located in CVI\9.1 in the registry.
- The NI Distributed System Manager replaces the NI Variable Manager. Use the System Manager to create and monitor network variables, processes, and I/O servers. For more information about the System Manager, refer to the NI Distributed System Manager Help, which you can access from the System Manager.
- The Translate LW DOS Program option is no longer available.
- The LabWindows/CVI compiler now defines the NDEBUG macro for release configuration builds.
- LabWindows/CVI no longer adds _dbg suffix to the base name of the debug target of a project.
- The data type of the targetThreadId parameter of the PostDeferredCallToThread and PostDeferredCallToThreadAndWait functions has been changed from unsigned long to unsigned int.
Updating to LabWindows/CVI 9.0- toolbox.h now includes some LabWindows/CVI headers that must be included after including windows.h. Therefore, if your code includes toolbox.h before including windows.h, reverse the order of these includes.
- Network variable processes that begin with NI_ are disallowed. The CNVNewProcess function returns an error if the process name you specify begins with NI_.
- The following macros have been renamed:
Library | Previous Macro Name | New Macro Name | WordReport.fp Instrument Driver | NONE | WR_NONE | Analysis Library | SORT_ASCENDING | ANALYSIS_SORT_ASCENDING | Analysis Library | SORT_DESCENDING | ANALYSIS_SORT_DESCENDING |
- The enum value CVIConst_CVI_FPVERSION_90 has been changed to CVIConst_CVI_FPVERSION_85 for the fpVersion parameter of the FPGenCreateFunctionTree function of the LabWindows/CVI ActiveX Server Interface Library.
- The modini utility and related source code as well as the modreg source code are deprecated and no longer installed with LabWindows/CVI.
- The LabWindows/CVI Quick Reference card is no longer published and is not installed with LabWindows/CVI.
- The option to create Microsoft Windows WinHelp files (.hlp) from LabWindows/CVI, Generate»Documentation»Windows Help, is no longer available.
Known Issues- Microsoft Windows 7 Support—National Instruments is committed to maintaining compatibility with Microsoft Windows technology changes. While most NI products work with Windows 7, NI has become aware of some compatibility issues regarding Windows 7. To learn more about Windows 7 and NI products, visit ni.com/info and enter the Info Code windows7.
- User Interface Controls in 64-bit Mode—Some drawing artifacts (black dots) can appear in the top-left parts of some user interface controls when running in 64-bit mode.
- Linking Import Libraries for .NET—LabWindows/CVI cannot link in the import library for a .NET mixed mode DLL.
- Selecting Files Using Libraries Shortcut—In Windows 7, the Libraries shortcut item in file dialog boxes does not work correctly.
- Zooming Graph Axis—Zooming a graph axis can skew a plot when the magnification becomes too large.
- Resizing Slide Controls—Numeric markers do not always adjust correctly to the resizing of a slide control.
- Setting Inc/Dec Arrow Width—ATTR_INCDEC_WIDTH has no effect if the inc/dec arrows are not visible.
- Using Perforce with LabWindows/CVI—LabWindows/CVI crashes when using the Perforce 2009.1 source code control plug-in.
- Specifying ATTR_MOVABLE Attribute—ATTR_MOVABLE does not work in Windows 7 with Aero enabled.
- Displaying Popups—Second popup can appear behind another popup if the application is not in the foreground when the second popup is displayed.
- Displaying Panels and Windows in Windows 7—LabWindows/CVI panels and windows do not support Aero Shake.
- Availability of Example Programs for Base Package—Examples that only work in FDS are listed in Example Finder when Base version is activated.
- Displaying PNG Images—PNG images with alpha-channel transparency lose their transparency when displayed on transparent classic-style picture controls.
- Numerical Differences in Analysis Function Results—LabWindows/CVI 2009 uses the latest version of the Intel® Math Kernel Library (MKL). Some of the functions in the Intel MKL return different results compared to previous versions of MKL due to optimization, causing slight numerical differences between results from Vector and Matrix Algebra, Statistics, and Curve Fitting functions in LabWindows/CVI 2009 and previous versions of LabWindows/CVI.
- Error When Building a LabWindows/CVI Project in Visual Studio 2005—If you create a project in Visual Studio 2005 that uses LabWindows/CVI libraries, you will see the following error: fatal error LNK1103: debugging information corrupt; recompile module. To address this issue, install the hotfix available from Microsoft.
- Editing Controls Using the Attribute Browser—The control you are currently editing loses focus as you update values in the Property Browser.
- Flushing Internal Buffers in a Network Variable Write Operation—Starting with LabWindows/CVI 8.5.1, the Network Variable Library flushes all internal buffers in a write operation, which improves network variable performance.
Flushing on write may cause lower throughput in some high bandwidth conditions, in which case you can set CNVFlushOnWriteAttribute to 0 (FALSE). In high bandwidth conditions, National Instruments recommends using the CNVBufferedWriter connection. - Flushing Internal Buffers in a Network Variable Read Operation—During a read operation, the Network Variable Library flushes all network variable connections in your program, including data in writer connections, for better performance.
- Debugging Executables on Windows Vista—On Windows Vista, executables that contain setup, install, or update as part of their name automatically require administrator privileges. If you run these executables as stand-alone from a user-level account, Windows will prompt you for an administrator password. However, LabWindows/CVI cannot debug these applications from a user-level account. When you try to run them, LabWindows/CVI displays a Could not run executable notification. NI recommends that you rename your executable so that it does not contain those words in its name, or that you embed a manifest into the application that marks the application as being Vista-aware. You can embed a manifest using the Target Settings dialog box.
- Using Compressed Icons—To use an icon featuring PNG compression, you must replace the resource compiler shipped with LabWindows/CVI with the one included in the Windows SDK released with Windows Vista. Install the SDK and copy the rc.exe and rcdll.dll files from C:\Program Files\Microsoft SDKs\Windows\v6.0\Bin to CVIversion\sdk\bin.
- Performing DAQmx USB Buffered Operations on Windows Vista—On Windows Vista x64 Edition, running a program that uses NI-DAQmx 8.5 and terminating the program while it is performing DAQmx USB buffered operations can cause the machine to reboot or to display a Windows kernel bugcheck.
The following may cause a process to terminate unexpectedly:
- Selecting the End Process option in the Task Manager to kill the process.
- Using a utility such as pskill to request process termination.
- Shutting down the computer from the command line using shutdown -r -t 0 while the task is still running.
- The process encountering an access violation, breakpoint, or other unhandled exception.
- Attempting to log off, restart, or shutdown and clicking Cancel when the process prompts you to quit or cancel.
- Choosing to stop the process from the LabWindows/CVI debugger while it is running or suspended.
- Using Functions Requiring the Low-Level Driver—The LabWindows/CVI low-level driver is not supported on Windows Vista x64 Edition. The following functions are affected: inp, inpd, inpw, MapPhysicalMemory, outp, outpd, outpw, ReadFromPhysicalMemory, ReadFromPhysicalMemoryEx, StartPCSound, StopPCSound, UnMapPhysicalMemory, WriteToPhysicalMemory, WriteToPhysicalMemoryEx.
- Registering ActiveX Servers—When you build ActiveX servers in LabWindows/CVI 8.1.1 and later on Windows Vista and XP, the ActiveX servers are registered in your user profile. This registration is not visible to other users on your system. On previous versions of Windows, ActiveX servers are registered for all users. When you register these servers outside the LabWindows/CVI environment, they are always registered for all users; this option requires administrator privileges on Windows Vista.
- Registering LabWindows/CVI as an ActiveX Server—Installing LabWindows/CVI registers it for all users. Launching LabWindows/CVI registers LabWindows/CVI as an ActiveX server. LabWindows/CVI is registered in your user profile on all versions of Windows.
- Viewing Help—If you open the LabWindows/CVI Help outside of LabWindows/CVI, such as launching it through the Start menu, you might not see all driver or toolkit content. Select Help»Contents to open the LabWindows/CVI Help from within LabWindows/CVI to ensure that all driver and toolkit content is available.
- Creating and Deleting Network Variables and Processes—You may notice that about 50 bytes of memory are lost when you create and delete a network variable or process.
- Setting the Compatibility Mode for Real-Time DLLs—When you create a DLL to run on a real-time target, you must use the Visual C/C++ compatibility mode. The Borland C/C++ compatibility mode is not supported for real-time DLLs.
- Using the LabWindows/CVI Conversion Wizard in Microsoft Visual Studio 2005 or Microsoft Visual Studio 2008—Microsoft Visual Studio 2005 and later do not support the single-threaded version of the Visual Studio C library. Therefore, you must configure your project's linker settings to ignore directives to use the single-threaded C library. In Visual Studio, select Project» Properties and expand the properties tree to the Configuration Properties»Linker»Input item. Add libc to the Ignore Specific Library option. Refer to the I Receive Linker Errors When Using LabWindows/CVI-Generated Static Libraries and Object Files in Microsoft Visual Studio 2005 KnowlegeBase article for more information.
- Updating an Existing Distribution—The LabWindows/CVI distribution creation feature does not provide the option to include .obj files for both compatible compilers. If you convert an existing distribution that has this option enabled, LabWindows/CVI includes the .obj files only for the current compatible compiler in the updated distribution.
- Using the NI Instrument I/O Assistant—The Instrument I/O Assistant 2.0 generates LabWindows/CVI code that is not backward compatible with code that previous versions of the Instrument I/O Assistant generated. If you run code generated with the Instrument I/O Assistant 2.0 with an existing application, the code in that application might not compile.
- Uninstalling LabWindows/CVI—If you have multiple versions of LabWindows/CVI installed and you uninstall one of the versions, the remaining installation will be missing its file associations, and its automation capabilities will not function properly. To fix this problem, perform a repair installation of the remaining LabWindows/CVI version.
- Making Backup .uir Files—Make backup copies of your .uir files if you have been using previous versions of LabWindows/CVI. Once you save .uir files in LabWindows/CVI 2009, the .uir files are no longer compatible with versions 8.1.1 or earlier. You cannot load .uir files that you have saved in LabWindows/CVI 2009 in LabWindows/CVI 8.1.1 or earlier.
You can save .uir files you create or load in LabWindows/CVI 2009 in the following formats:
- LabWindows/CVI 7.1
- LabWindows/CVI 8.0-8.1
- LabWindows/CVI 8.5-9.0
Select File»Save .uir As and specify the format in the Save as type option. If you save a user interface with features that were added in later versions of LabWindows/CVI, those features are removed when you save the file in 7.1 or 8.0-8.1 format. - Using Microsoft Excel as an ActiveX Control—If you develop an application that uses Excel as an ActiveX control on a LabWindows/CVI user interface panel, make sure that a separate instance of Excel is not running simultaneously. Otherwise, programmatic calls to the Excel control might not work as expected after the separate Excel application terminates.
- Navigating the Tools Library and Toolkit Topics in the LabWindows/CVI Help—If you click a link from a topic in the Tools Library or a toolkit section of the LabWindows/CVI Help or from the toolslib function panel help, you cannot use the Back button in the help viewer toolbar to return to the original topic.
- Using the Advanced Analysis Library—Upgrading to LabWindows/CVI 8.5 and later may cause the Advanced Analysis or Analysis Library to produce numerical differences in floating point results and different results for exceptional inputs, such as positive or negative infinity and NaN. These differences may occur because the underlying C Analysis library has been recompiled in LabWindows/CVI 8.5 to take advantage of new processors and operating systems.
- Analysis Function Behavior Changes—The following function behavior has changed from LabWindows/CVI 7.1 to LabWindows/CVI 8.x:
- SVD and CxSVD—The following formula defines the SVD factorization of an n-by-m matrix A: A = USVT.
In LabWindows/CVI 7.1 and earlier, CxSVD has the following requirement: If numberOfRows (n) < numberOfColumns (m), you must allocate m*m*sizeof(ComplexNum) bytes of memory to the input matrix and the U orthogonal matrix. LabWindows/CVI 8.x and later no longer has this requirement. - Lu and CxLU—In LabWindows/CVI 7.1 and earlier, if the input matrix is singular, the functions stop the decomposition and return SingularMatrixErr. In LabWindows/CVI 8.x and later, if the input matrix is singular, the functions complete the decomposition and return SingularMatrixWarn. In this case, there are one or more zero elements along the diagonal of U.
- CxTrace—CxTrace accepts only a square matrix. In LabWindows/CVI 7.1 and earlier, the function requires both the number of rows and the number of columns as input parameters. In LabWindows/CVI 8.x and later, matrixSize specifies both the number of rows and the number of columns. The numberOfColumns parameter in LabWindows/CVI 7.1 and earlier is a reserved parameter in LabWindows/CVI 8.x and later. This parameter is not referenced in the function.
- ConditionNumber and CxConditionNumber—In LabWindows/CVI 7.1 and earlier, these functions return NaN for singular input matrices. In LabWindows/CVI 8.x and later, these functions return Inf for singular input matrices.
- GenLSFit—In LabWindows/CVI 8.x and later, GenLSFit calculates the mean squared error as the weighted mean square error, which differs from the prior implementation of the function.
- Help File Font Size—Starting with LabWindows/CVI 2009, the LabWindows/CVI Help includes a Font button that you can use to increase or decrease the font size in the help file. The Font button might not update the font size in help files that merge into the LabWindows/CVI Help.
In addition, the smallest font size setting of the Font button is the standard font size for National Instruments help files. The text size settings in Internet Explorer might cause the font to appear larger than typical National Instruments help files. If you resize the font, the help file retains the font size the next time you open the product help.
Bug FixesThe following items are the IDs and titles of the bugs fixed between LabWindows/CVI 9.0.1 and LabWindows/CVI 2009. For a list of bug fixes in previous releases, refer to ni.com. User InterfaceID | Fixed Issue | Has Run-Time Impact? | 190831 | ATTR_NO_EDIT_TEXT does not prevent tab spaces from being entered into a text box control | Yes | 189400 | Loading a very wide .bmp or .pcx file can fail with an Out of Memory error | Yes | 189247 | Drag and drop operation on the title bar or window frame does not work | Yes | 184792 | String control sends EVENT_VAL_CHANGED with | No | 183301 | Splitter controls with no range limit do not draw shadow when operated | Yes | 182743 | Editing a panel that has a control with a label of exactly 50 characters can cause a crash | No | 177284 | Table and tree scroll bars are not always clipped to a child panel's bounds | Yes | 101593 | Strip chart scroll bar overlaps the plot area | Yes | 101591 | Phantom arrow buttons can appear when a strip chart is scrolled | Yes | 173952 | Truncating tree item strings can cause user applications to crash under some circumstances | Yes | 175118 | Minor gridlines of graphs and minor ticks of numeric slides can disappear | Yes | 139151 | Debugger does not always catch incorrect use of ATTR_COPY_ORIGINAL_DATA | Yes | 134165 | Menu bar does not resize when using Scale Contents On Resize or Resolution Adjustment | Yes | 134049 | User Interface Editor does not retain the awareness that it should save the .uir in an older format | No | 133845 | Table row labels cannot be sized when the column labels are not visible, and vice-versa | Yes | 139269 | Hidden tab panels of a nested tab control can be made active | Yes | 60017 | LabWindows/CVI loses some color customizations when color depth changes | No | 147609 | Setting ATTR_COLOR_RAMP_WIDTH can leave the control apparently unchanged | Yes | 149350 | The cursor position of a text box can be incorrect when typing Thai characters | Yes | 177493 | Plotting to a hidden strip chart can cause the application to hang | Yes | 152088 | ATTR_XMARK_ORIGIN and ATTR_YMARK_ORIGIN can change the wrong axis | Yes | 191757 | ActiveX controls might not appear if a panel is displayed in a thread other than the thread that created the panel | Yes | Development EnvironmentID | Fixed Issue | Has Run-Time Impact? | 194053 | There can be multiple prompts to check out a project file from source code control | No | 185942 | Cannot add empty function panel file to a project | No | 156166 | Cut Line does not work correctly with a collapsed block of code | No | 127036 | Repeated save prompts can be shown if a project file path is made invalid | No | 167925 | LabWindows/CVI can crash when browsing the set of values for an attribute | No | 172750 | UI Localizer preview does not work correctly with non-native character sets | No | 136293 | LabWindows/CVI can crash after removing from the workspace a project that uses an external release compiler | No | 136341 | LabWindows/CVI Welcome Page cannot be minimized | No | 130204 | Multi-file search does not ignore invalid paths, even when searching only a specific set of files | No | 126050 | tmpdir registry value is not used when backing up files | No | 154794 | Web links in Help menu do not work when .html files are not associated with a Web browser | No | 135900 | LabWindows/CVI Workspace window title bar does not show Aero transparency | No | 166027 | Cannot launch Icon Editor from Tools menu | No | 137735 | Browse window does not retain all its settings when a file is recompiled | No | 157568 | Go to Next Reference does not cycle through all references of a variable or a function in other files | No | 156975 | User Interface Editor asks to assign constant names when backing up files | No | 162197 | Help tooltip for the Run button in the toolbar is incorrect after running the Interactive Execution window | No | CompilerID | Fixed Issue | Has Run-Time Impact? | 179613 | _declspec in function pointer typedef causes compile error. | No | 160327 | LabWindows/CVI can crash when compiling designated initializers for array of structs/unions | No | 132689 | LabWindows/CVI Show Completions does not work for nested struct array fields | No | 145895 | struct auto completion does not handle arrays of structs inside other structs correctly | No | 129546 | Cannot use the Utility or Formatting and I/O Libraries and some Interface to Win32 API functions at the same time | No | 131351 | Some Interface to Win32 API header files that use EXTERN_C can cause compile errors | No | 157216 | Batch building with auto-increment leaves version numbers for debug and release builds offset by one | No | 168621 | Using an object file built with precompiled headers can lead to link errors | No | 177794 | LabWindows/CVI can crash when compiling a complex mathematical computation that is not assigned to a variable | No | 130056 | Compiler does not define NDEBUG in release configuration | No | 127909 | Instrument drivers are marked for compilation with each configuration switch | No | 158055 | Cannot include windows.h in the Interactive Execution window | No | 186965 | Command line compiler crashes when building project with Add type library resource to DLL option | No | DebuggingID | Fixed Issue | Has Run-Time Impact? | 193526 | Adding a watch expression that already exists fails silently | No | 184979 | Breakpoint pass counts are off by one | No | 127318 | Calling some inifile.fp functions while the Programmer's Toolbox is compiled from source code can result in a false report of leaked resources | No | 179034 | Obtaining a non-existant attribute with CVIXMLGetAttributeByName results in a false report of leaked resources | No | 162554 | Some source code constructs can cause incorrect Local was referenced before being initialized runtime errors | Yes | 155604 | Adding a watch expression that references a variable declared in block scope can hang the program when it is debugged | No | 139139 | Viewing memory as HEX longs (64 bit) in the Memory Display causes all values to turn red | No | 177188 | LabWindows/CVI debugger can crash when using memcpy to copy data from a const struct array | No | 189661 | Variables window does not always show variable declared in for-loop scope | No | PerformanceID | Fixed Issue | Has Run-Time Impact? | 184428 | LabWindows/CVI can crash when calling the Delay function from multiple threads | Yes | 175150 | LabWindows/CVI can crash when opening a .c file containing lines with approximately 1020 characters | No | 167239 | LabWindows/CVI can hang while editing a large non-source-code data file | No | 157141 | Memory leak in the thread-safe queue | Yes | Stand-Alone Applications and DistributionsID | Fixed Issue | Has Run-Time Impact? | 192040 | LabWindows/CVI can crash after changing a registry key name in the Edit Distribution dialog box | No | 179863 | Error dialog boxes can appear when editing a distribution before and after discarding a User Interface Editor window | No | 177971 | Creating an installer spec file fails if a Visual Studio 2008 wizard is explicitly included | No | 148892 | The Files tab of the Edit Distribution dialog box is too small | No | 141648 | Auto-incrementing the distribution is marking the project for recompilation | No | 182036 | CreateUDPChannelConfig fails if ws2_32.dll is installed to the application directory | Yes | 165495 | Installing an application that uses ActiveX controls to a clean machine might result in a runtime error | Yes | 165285 | Subdirectories of application directory are all lowercase in an installed distribution | No | 141444 | Creating a distribution for a DLL that installs the support files to the application directory might fail if the DLL is loaded from a different folder | No | 130286 | Cannot install TDMS support or RT Utility support to application directory | No | 130423 | .NET library cannot be included in a distribution without also including the full run-time engine | Yes | .NET and ActiveXID | Fixed Issue | Has Run-Time Impact? | 174102 | Hidden LabWindows/CVI ActiveX Automation interface is visible in function panel tree | No | 168302 | Cannot create a numeric floating-point function panel control via ActiveX Automation | No | 39122 | Intrusive registration message when building ActiveX server project | No | AnalysisID | Fixed Issue | Has Run-Time Impact? | 183434 | NonLinearFitWithMaxIters function does not return best fit array when max interations is exceeded | Yes | 156791 | Several Analysis Library function panels incorrectly relying on AnalysisLibPowerOfTwo enum | No | 140249 | NonLinearFitWithMaxIters does not return an error when maximum iterations is 1 | Yes | 140913 | ThresholdPeakDetector has unexpected results when width > 1 | Yes | MiscellaneousID | Fixed Issue | Has Run-Time Impact? | 191778 | The application crashes when passing NULL data length to RegEnumerateValue | Yes | 178655 | GetDrive returns an incorrect total number of drives if there are non-contiguous drives present | Yes | 173689 | LoadLocalizedPanel fails for trees with more than 7 column translations | Yes | 162814 | Cannot embed type library in DLL when function panel has a custom type based on a character array | No | 162398 | Toolbox lists can grow by amounts greater than the allocation policy specifies | Yes | 142035 | LabWindows/CVI ibdev function returns positive value if GPIB driver is not installed | Yes | 139658 | GetFileSize can crash if you pass in a path that is too long | Yes | 129812 | Calling a LabVIEW-built DLL causes printf to format a double to a string incorrectly | Yes | 129094 | Asynchronous timer limited to intervals no greater than approximately 429 seconds | Yes | 128060 | Visual Studio cannot find Interface to Win32 API libraries in LabWindows/CVI projects converted to Visual Studio using the project wizard | No | 60948 | A file path sometimes appears in printed Microsoft Word reports | Yes |
Copyright © 1993–2009 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. Trademarks CVI, National Instruments, NI, ni.com, LabVIEW, and NI TestStand are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. The mark LabWindows is used under a license from Microsoft Corporation. Windows is a registered trademark of Microsoft Corporation in the United States and other countries. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents
For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents. |
