查看: 2988|回复: 0
[LabWindows] LabWindows/CVI 9.0.1 Runtime Win32Eng LabWindows/CVI9.0.1运行版下载
  • 签到天数: 3629 天
    连续签到: 3 天
    发表于 2020-12-8 23:30:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    9.0.1RT
    文件大小: 59845737 字节 (57.07 MB)
    修改日期: 2019-06-25 03:00
    MD5: 24f9721f4118503f3cfa841557a7de32(官方正确)
    SHA1: 3dba0ba13218b791a31520bfa6b393cd4e6dd363
    SHA256: c8c37d537e41f2b55329144d9a0891400e582c09e17cc2f86708713f02f41198
    CRC32: 40ff0696
    百度和NI官方下载地址:
    CVI9.0.1RT.txt (615 Bytes, 下载次数: 1, 售价: 5 圆)
    LabWindows/CVI for Windows Vista/XP/2000, Version 9.0.1Readme File
    This file contains installation information, programming considerations, and changes that are too recent to be included in the LabWindows/CVI Help. Refer to the LabWindows/CVI Release Notes for more information about new features.
    LabWindows/CVI 9.0.1 is an update release of LabWindows/CVI 9.0.
    Contents
    Minimum System Requirements
    Installing LabWindows/CVI
    Activating LabWindows/CVI
    After Installation
    Updating to LabWindows/CVI 9.0.x
    To run LabWindows/CVI 9.0.1, you must have the following items:
    • Personal computer using a Pentium 1GHz or higher microprocessor
    • Windows Vista/XP/2000 Service Pack 3 or later
    • 1024 × 768 resolution (or higher) video adapter
    • Minimum of 128 MB of RAM, 512 MB recommended
    • 200 MB free hard disk space
    • Microsoft-compatible mouse
    National Instruments recommends that you install the complete LabWindows/CVI program to take full advantage of all LabWindows/CVI 9.0.1 functionality. If you choose to install with options, select the options you want and follow the on-screen directions. If necessary, you can run the setup program again to install or remove additional files.
    Before Installation
    • If you install the LabWindows/CVI Real-Time Module and device drivers with LabWindows/CVI 9.0.1, you must install these products in the following order:
      • LabWindows/CVI 9.0.1
      • LabWindows/CVI 9.0 Real-Time Module
      • Device driver software using NI Device Drivers media
        The LabWindows/CVI package includes the device driver software on a DVD. If you require device driver software on CDs, refer to the National Instruments Web site at ni.com/info and enter the info code drivercd.
      If you are installing the LabWindows/CVI Real-Time Module, do not install the device driver software when you are prompted to do so during the LabWindows/CVI 9.0.1 installation. Instead, install the device driver software when you are prompted during the LabWindows/CVI Real-Time Module installation.
    • When you install LabWindows/CVI, your user account must have administrator privileges.
    • You must explicitly select the Interface to Win32 API feature of the LabWindows/CVI installer to install the complete Interface to Win32 API from the LabWindows/CVI Full Development System (FDS). Some Win32 API header and import library files are included when you install the LabWindows/CVI Base package.
      The Interface to Win32 API is based on the Windows Server 2003 R2 Platform SDK. The Windows Server 2003 R2 Platform SDK was released in March 2006 and does not include tools or functionality added in later versions of the SDK, such as support for functionality specific to Windows Vista.
    • The LabWindows/CVI installation includes the LabWindows/CVI 9.0.1 Run-Time Engine. This version overwrites previous versions of the run-time engine. After you install LabWindows/CVI 9.0.1, executables and DLLs created with previous versions of LabWindows/CVI automatically use the new LabWindows/CVI 9.0.1 Run-Time Engine.
    • If you install LabWindows/CVI onto a network drive, you might encounter an error during installation that prevents files that the IVI Instrument Driver Wizard requires from being installed. This issue does not affect other functionality in LabWindows/CVI.
    • If you have installed Microsoft Security Update 896358, you might not be able to view topics within the LabWindows/CVI Help if the file is on a network drive. To solve this issue, copy the .chm files that LabWindows/CVI installs to your local hard drive and launch them as normal.
    • The IVI Installer Creator and IVI Specific Driver Test Suite items are selected by default in the installer feature tree only if the IVI Compliance Package is installed. You can select these items if the IVI Compliance Package is not installed, but you must then install the IVI Compliance Package, which you can download from ni.com.
    • You can install the Visual Studio 2005 Wizards and Visual Studio 2008 Wizards features only if you have installed Visual Studio 2005 and Visual Studio 2008, respectively.
    Running the Installation
    Complete the following steps to install LabWindows/CVI 9.0.1:
    Note  If you already have LabWindows/CVI 8.x.x or earlier installed on your computer, be sure to install version 9.0.1 in a different directory. If you have LabWindows/CVI 9.0 installed on your computer, the LabWindows/CVI installer replaces LabWindows/CVI 9.0 with version 9.0.1.
    • Insert the LabWindows/CVI CD into the CD drive. If the CD does not run automatically, open Windows Explorer, right-click the CD drive icon, and select AutoPlay.
    • On installation startup, the National Instruments LabWindows/CVI 9.0.1 screen appears. Click Install LabWindows/CVI.
    • In the User Information panel, enter your name and organization. Select one of the following options:
      • Install this product using the following serial number
      • Install this product for evaluation
      If you choose to enter a serial number, enter the serial number found on your Certificate of Ownership card. LabWindows/CVI uses this serial number when you run the NI Activation Wizard.
    • Continue to follow the instructions on the screen.
    Complete the following steps to activate LabWindows/CVI.
    • Select the Automatically activate through a secure Internet connection option and click Next. Your computer must be connected to the Internet for this option to work. If you do not have Internet access on your computer, refer to the LabWindows/CVI Release Notes.
    • The serial number is populated with the number you entered during installation. Click Next.
    • Fill in the necessary information and click Next.
    • Check the option if you would like to receive a confirmation email of your activation and click Next.
    • After a brief moment, you should receive a message indicating whether LabWindows/CVI has been activated or not. Enter or verify your serial number. Click Next.
    • When you successfully activate LabWindows/CVI, click Finish. LabWindows/CVI will then display a window indicating when this license will expire.
    For more information about activation, refer to the LabWindows/CVI Release Notes.
    After Installation
    • Installing LabWindows/CVI in a New Directory—If you installed driver or toolkit software for LabWindows/CVI 8.1.1 or earlier and you install LabWindows/CVI 9.0.1 in a new directory, you must uninstall and reinstall the LabWindows/CVI portion of the driver or toolkit software.
    • Using Example Programs—You can find example programs in the following location on Windows Vista: \Users\Public\Documents\National Instruments\CVI90\samples. On Windows 2000/XP, example programs are located in the following location: \Documents and Settings\All Users\Documents\National Instruments\CVI90\samples.
    • Working with Project and File Templates—Save user-defined project and file templates in the LabWindows/CVI public documents directory (\Documents and Settings\All Users\Documents\National Instruments\CVI on Windows XP/2000 and \Users\Public\Documents\National Instruments\CVI on Windows Vista). LabWindows/CVI 8.5 and later does not search previous locations, \Documents and Settings\All Users\Application Data\CVI and \Documents and Settings\\Application Data\CVI, for project and file templates.
    • toolbox.h now includes some LabWindows/CVI headers that must be included after including windows.h. Therefore, if your code includes toolbox.h before including windows.h, reverse the order of these includes.
    • Network variable processes that begin with NI_ are disallowed. The CNVNewProcess function returns an error if the process name you specify begins with NI_.
    • The following macros have been renamed:
      LibraryPrevious Macro NameNew Macro Name
      WordReport.fp Instrument DriverNONEWR_NONE
      Analysis LibrarySORT_ASCENDINGANALYSIS_SORT_ASCENDING
      Analysis LibrarySORT_DESCENDINGANALYSIS_SORT_DESCENDING
    • The enum value CVIConst_CVI_FPVERSION_90 has been changed to CVIConst_CVI_FPVERSION_85 for the fpVersion parameter of the FPGenCreateFunctionTree function of the LabWindows/CVI ActiveX Server Interface Library.
    • The modini utility and related source code as well as the modreg source code are deprecated and no longer installed with LabWindows/CVI.
    • The LabWindows/CVI Quick Reference card is no longer published and is not installed with LabWindows/CVI.
    • The option to create Microsoft Windows WinHelp files (.hlp) from LabWindows/CVI, Generate»Documentation»Windows Help, is no longer available.
    • The Auto Size and Scroll (when loaded) option of table controls and tree controls is also enforced when printing the control, and when the control resizes as a result of the Scale Contents On Resize option of panels.
    • Flushing Internal Buffers in a Network Variable Write Operation—Starting with LabWindows/CVI 8.5.1, the Network Variable Library flushes all internal buffers in a write operation, which improves network variable performance.
      Flushing on write may cause lower throughput in some high bandwidth conditions, in which case you can set CNVFlushOnWriteAttribute to 0 (FALSE). In high bandwidth conditions, National Instruments recommends using the CNVBufferedWriter connection.
    • Flushing Internal Buffers in a Network Variable Read Operation—During a read operation, the Network Variable Library flushes all network variable connections in your program, including data in writer connections, for better performance.
    • Debugging Executables on Windows Vista—On Windows Vista, executables that contain setup, install, or update as part of their name automatically require administrator privileges. If you run these executables as stand-alone from a user-level account, Windows will prompt you for an administrator password. However, LabWindows/CVI cannot debug these applications from a user-level account. When you try to run them, LabWindows/CVI displays a Could not run executable notification. NI recommends that you rename your executable so that it does not contain those words in its name, or that you embed a manifest into the application that marks the application as being Vista-aware. You can embed a manifest using the Target Settings dialog box.
    • Performing DAQmx USB Buffered Operations on Windows Vista—On Windows Vista x64 Edition, running a program that uses NI-DAQmx 8.5 and terminating the program while it is performing DAQmx USB buffered operations can cause the machine to reboot or to display a Windows kernel bugcheck.
      The following may cause a process to terminate unexpectedly:
      • Selecting the End Process option in the Task Manager to kill the process.
      • Using a utility such as pskill to request process termination.
      • Shutting down the computer from the command line using shutdown -r -t 0 while the task is still running.
      • The process encountering an access violation, breakpoint, or other unhandled exception.
      • Attempting to log off, restart, or shutdown and clicking Cancel when the process prompts you to quit or cancel.
      • Choosing to stop the process from the LabWindows/CVI debugger while it is running or suspended.
    • Using Functions Requiring the Low-Level Driver—The LabWindows/CVI low-level driver is not supported on Windows Vista x64 Edition. The following functions are affected: inp, inpd, inpw, MapPhysicalMemory, outp, outpd, outpw, ReadFromPhysicalMemory, ReadFromPhysicalMemoryEx, StartPCSound, StopPCSound, UnMapPhysicalMemory, WriteToPhysicalMemory, WriteToPhysicalMemoryEx.
    • Registering ActiveX Servers—When you build ActiveX servers in LabWindows/CVI 8.1.1 and later on Windows Vista and XP, the ActiveX servers are registered in your user profile. This registration is not visible to other users on your system. On previous versions of Windows, ActiveX servers are registered for all users. When you register these servers outside the LabWindows/CVI environment, they are always registered for all users; this option requires administrator privileges on Windows Vista.
    • Registering LabWindows/CVI as an ActiveX Server—Installing LabWindows/CVI registers it for all users. Launching LabWindows/CVI registers LabWindows/CVI as an ActiveX server. LabWindows/CVI is registered in your user profile on all versions of Windows.
    • Viewing Help—If you open the LabWindows/CVI Help outside of LabWindows/CVI, such as launching it through the Start menu, you might not see all driver or toolkit content. Select Help»Contents to open the LabWindows/CVI Help from within LabWindows/CVI to ensure that all driver and toolkit content is available.
    • Creating and Deleting Network Variables and Processes—You may notice that about 50 bytes of memory are lost when you create and delete a network variable or process.
    • Setting the Compatibility Mode for Real-Time DLLs—When you create a DLL to run on a real-time target, you must use the Visual C/C++ compatibility mode. The Borland C/C++ compatibility mode is not supported for real-time DLLs.
    • Using the LabWindows/CVI Conversion Wizard in Microsoft Visual Studio 2005 or Microsoft Visual Studio 2008—Microsoft Visual Studio 2005 and later do not support the single-threaded version of the Visual Studio C library. Therefore, you must configure your project's linker settings to ignore directives to use the single-threaded C library. In Visual Studio, select Project» Properties and expand the properties tree to the Configuration Properties»Linker»Input item. Add libc to the Ignore Specific Library option. Refer to the I Receive Linker Errors When Using LabWindows/CVI-Generated Static Libraries and Object Files in Microsoft Visual Studio 2005 KnowlegeBase article for more information.
    • Updating an Existing Distribution—The LabWindows/CVI distribution creation feature does not provide the option to include .obj files for both compatible compilers. If you convert an existing distribution that has this option enabled, LabWindows/CVI includes the .obj files only for the current compatible compiler in the updated distribution.
    • Using the NI Instrument I/O Assistant—The Instrument I/O Assistant 2.0 generates LabWindows/CVI code that is not backward compatible with code that previous versions of the Instrument I/O Assistant generated. If you run code generated with the Instrument I/O Assistant 2.0 with an existing application, the code in that application might not compile.
    • Uninstalling LabWindows/CVI—If you have multiple versions of LabWindows/CVI installed and you uninstall one of the versions, the remaining installation will be missing its file associations, and its automation capabilities will not function properly. To fix this problem, perform a repair installation of the remaining LabWindows/CVI version.
    • Making Backup .uir Files—Make backup copies of your .uir files if you have been using previous versions of LabWindows/CVI. Once you save .uir files in LabWindows/CVI 9.0.1, the .uir files are no longer compatible with versions 8.1.1 or earlier. You cannot load .uir files that you have saved in LabWindows/CVI 9.0.1 in LabWindows/CVI 8.1.1 or earlier.
      You can save .uir files you create or load in LabWindows/CVI 9.0.1 in the following formats:
      • LabWindows/CVI 7.1
      • LabWindows/CVI 8.0-8.1
      • LabWindows/CVI 8.5-9.0
      Select File»Save .uir As and specify the format in the Save as type option. If you save a user interface with features that were added in later versions of LabWindows/CVI, those features are removed when you save the file in 7.1 or 8.0-8.1 format.
    • Using Microsoft Excel as an ActiveX Control—If you develop an application that uses Excel as an ActiveX control on a LabWindows/CVI user interface panel, make sure that a separate instance of Excel is not running simultaneously. Otherwise, programmatic calls to the Excel control might not work as expected after the separate Excel application terminates.
    • Navigating the Tools Library and Toolkit Topics in the LabWindows/CVI Help—If you click a link from a topic in the Tools Library or a toolkit section of the LabWindows/CVI Help or from the toolslib function panel help, you cannot use the Back button in the help viewer toolbar to return to the original topic.
    • Using the Advanced Analysis Library—Upgrading to LabWindows/CVI 8.5 and later may cause the Advanced Analysis or Analysis Library to produce numerical differences in floating point results and different results for exceptional inputs, such as positive or negative infinity and NaN. These differences may occur because the underlying C Analysis library has been recompiled in LabWindows/CVI 8.5 to take advantage of new processors and operating systems.
    • Analysis Function Behavior Changes—The following function behavior has changed from LabWindows/CVI 7.1 to LabWindows/CVI 8.x:
      • SVD and CxSVD—The following formula defines the SVD factorization of an n-by-m matrix A: A = USVT.
        In LabWindows/CVI 7.1 and earlier, CxSVD has the following requirement: If numberOfRows (n) < numberOfColumns (m), you must allocate m*m*sizeof(ComplexNum) bytes of memory to the input matrix and the U orthogonal matrix. LabWindows/CVI 8.x and later no longer has this requirement.
      • Lu and CxLU—In LabWindows/CVI 7.1 and earlier, if the input matrix is singular, the functions stop the decomposition and return SingularMatrixErr. In LabWindows/CVI 8.x and later, if the input matrix is singular, the functions complete the decomposition and return SingularMatrixWarn. In this case, there are one or more zero elements along the diagonal of U.
      • CxTrace—CxTrace accepts only a square matrix. In LabWindows/CVI 7.1 and earlier, the function requires both the number of rows and the number of columns as input parameters. In LabWindows/CVI 8.x and later, matrixSize specifies both the number of rows and the number of columns. The numberOfColumns parameter in LabWindows/CVI 7.1 and earlier is a reserved parameter in LabWindows/CVI 8.x and later. This parameter is not referenced in the function.
      • ConditionNumber and CxConditionNumber—In LabWindows/CVI 7.1 and earlier, these functions return NaN for singular input matrices. In LabWindows/CVI 8.x and later, these functions return Inf for singular input matrices.
      • GenLSFit—In LabWindows/CVI 8.x and later, GenLSFit calculates the mean squared error as the weighted mean square error, which differs from the prior implementation of the function.
    The following items are the IDs and titles of the bugs fixed between LabWindows/CVI 9.0 and LabWindows/CVI 9.0.1. For a list of bug fixes in previous releases, refer to ni.com.
    User Interface
    IDFixed IssueHas Run-Time Impact?
    143075Tables and tree controls do not scale proportionally to other controlsYes
    135032Checkerboard dimming of controls is leaving label text etchedYes
    145322Graph y-axis name not drawn correctly after graph changes position before being displayedYes
    140209Cannot change coordinates of control label in editor if control is in a tab panelNo
    138050Remove All button in multi-file select dialog box is missing a cornerYes
    135264Done button can disappear when you resize a file selection dialog boxYes
    131413After widening the inc/dec arrows, the entire area of the arrows is not clickableYes
    129832Editing multiple controls changes tab order and z-plane orderNo
    131102On Windows Vista, file selection dialog boxes add an extra backslash (\) character when selecting a file at the root of a volumeYes
    131218Edit Item dialog box of a tree control shows an incorrect description of the image nameNo
    136678Menu events cause a crash if there is no menu callback specified and the application has a main callbackYes
    149012Cannot list ViInt64 attributes in function panelNo
    136241Released interactive execution window runs project instead, when started from toolbarNo
    129695LabWindows/CVI can crash on exit after TestStand executes code modules in an external instance of LabWindows/CVINo
    Compiler
    120676Even with C99 enabled, some variables cannot be declared immediately following a switch statementNo
    152423Arrays initialized with string literals are not completely filled with zero bytesNo
    152421The compiler can crash when very large arrays are initialized with small string literalsNo
    152425No error reported when arrays are initialized with string literals that are too largeNo
    138186Function pointers for functions without parameters require void keyword in parameter listNo
    135927ActiveX wrappers fail to compile when LabWindows/CVI uses the Borland compatibility modeNo
    134406The Win32 API fails to compile with third-party compilers if C99 is enabledNo
    134407Build warnings are reported when compiling the Win32 API with third-party compilersNo
    134066Linking a project can fail with Out of Memory error, in very rare circumstancesNo
    139419Win32 API compile errors when WSPiApi.h and WS2tcpip.h are includedNo
    131800Too many initializers error when initializing incomplete array typedefsNo
    128921Incorrect compilation of code containing multiple, anonymous inner struct membersNo
    136156When passing 64-bit integers to a 32-bit integer parameter in a function call, other parameters can end up with incorrect valuesNo
    Debugging
    134586Erroneous user protection error when accessing member of a multidimensional array of struct/pointerNo
    Performance
    144806CmtWaitForThreadPoolFunctionCompletion can hang in some rare circumstancesYes
    144368strtod and scanf can crash in multithreaded applicationsYes
    Installation
    149929If the full Win32 API is installed, the system is left in a bad state after LabWindows/CVI is uninstalledNo
    Stand-Alone Applications and Distributions
    141434LabWindows/CVI crashes when unloading a workspace with an ActiveX server project after building a distributionNo
    131196Import Measurement & Automation Explorer (MAX) Configuration File checkbox always checked on Edit Installer Advanced tabNo
    137318Adding dependencies of an executable to Installation Files & Directories section in Edit Installer dialog box displays two copies of the DLLNo
    154605Projects with a relative path for the application file can crash when configuring a distributionNo
    © 1993–2009 National Instruments Corporation. All rights reserved.
    CVI, National Instruments, NI, ni.com, and NI TestStand are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2025-8-20 20:34
